DM36XCODECS: Alignment trap after serval hours
Part Number: DM36XCODECS
Hi Experts
My device happens alognment trap, and av_server.out crashs after several hours.
I need your suggestion to help me find the root cause.
I used "printf()" to find the cause, and found that the issue may be in the VIDENC1_process().
My device uses appro ipnc rdk 3.0, and codec version is H264ENC.version.02.30.00.03.
My application is "Corridor". So i use EDMA to corridor 1080x720 frame to 720x1080, and that means the input frame size of encode is 720x1080.
My simple image flow is below.
My log is also below.
Log 1
Alignment trap: av_server.out (780) PC=0x000ee790 Instr=0xe5832000 Address=0xa898aa65 FSR 0x801
Unable to handle kernel paging request at virtual address 327b3381
pgd = c689c000
[327b3381] *pgd=00000000
Internal error: Oops: 1 [#1]
Modules linked in: puller davinci_mmc mmc_block mmc_core davinci_emac slhc tun loop nls_utf8 nls_ascii sha1 md5 des deflate crc32c i2c_emac cfq_iosched deadline_iosched libcrc32c crc_ccitt dm365mmap irqk edmak cmemk drv csl
CPU: 0
PC is at HeapMem_free+0x40/0xb4 [cmemk]
LR is at 0x1000
pc : [<bf022184>]    lr : [<00001000>]    Not tainted
sp : c0c67d64  ip : 327b3381  fp : c0c67d74
r10: 00000000  r9 : 00000001  r8 : c09c2a28
r7 : bf026da0  r6 : 00000000  r5 : c09c2a28  r4 : bf026d80
r3 : 00000001  r2 : 00000724  r1 : c9748000  r0 : 327b3381
Flags: nzcv  IRQs on  FIQs on  Mode SVC_32  Segment user
Control: 5317F
Table: 8689C000  DAC: 00000015
Process av_server.out (pid: 770, stack limit = 0xc0c66258)
Stack: (0xc0c67d64 to 0xc0c68000)
7d60:          c09c2a20 c0c67dc4 c0c67d78 bf022ca4 bf022154 00000000 00000000
7d80: bf026d98 c725b760 bf026da0 c09c2a60 00000000 00000005 c00b67a8 c725b760
7da0: c725b760 c73f26c8 c0506e20 c7436098 00000000 00000000 c0c67dec c0c67dc8
7dc0: c0097988 bf022b28 c00306f4 c725b760 00000000 c0514500 c0514508 00000000
7de0: c0c67dfc c0c67df0 c0097c4c c0097938 c0c67e1c c0c67e00 c0094444 c0097c28
7e00: c0c66000 00007ff7 c0514500 00000030 c0c67e4c c0c67e20 c004cf10 c00943e8
7e20: c0c67e4c c0514500 c71d89a0 c7203a90 00000000 00000007 00000000 c0c67f50
7e40: c0c67e6c c0c67e50 c004e518 c004ce8c 00002731 02a2740c c0c67ea0 c0c66000
7e60: c0c67e84 c0c67e70 c004eda8 c004e2d8 00000000 00000009 c0c67ebc c0c67e88
7e80: c0059d54 c004ecfc c0c67fb0 c71d8b80 c00561c4 c0c66000 c0034f88 c0c67fb0
7ea0: 00000000 c0034f88 c0c66000 00000000 c0c67f9c c0c67ec0 c0037ba4 c0059984
7ec0: c0c66000 00000001 c71d8b80 c0c67ed8 00000009 00000000 00000000 00000000
7ee0: 00000000 00000001 c0c67f14 c0c67ef8 c0065478 c0c67f88 00000000 00000001
7f00: befaab88 befaab88 00000008 00000000 c0c67f20 c0064f14 08b43ac2 00002c9c
7f20: c6385f21 00000000 00000000 00000000 1c3a999a 00002c9c c0065024 c0349110
7f40: 00000000 00000002 c0c67f48 c0c67f48 c71d89a0 000000a2 00000000 13865ed8
7f60: c0c67f88 befaab88 00000080 000000a2 c0034f88 00000000 0000004d 00000080
7f80: 000000a2 c0034f88 c0c66000 00000000 c0c67fac c0c67fa0 c0038058 c0037b5c
7fa0: 00000000 c0c67fb0 c0034e2c c003803c fffffdfc befaab88 4001f3e4 00000002
7fc0: 00000000 0000004d 00000080 000000a2 00000021 00000021 0000065c 0013e03c
7fe0: 00000000 befaab80 400344f4 40035634 80000010 befaab90 00000000 00000000
Backtrace:
[<bf022144>] (HeapMem_free+0x0/0xb4 [cmemk]) from [<bf022ca4>] (release+0x18c/0x270 [cmemk])
r4 = C09C2A20
[<bf022b18>] (release+0x0/0x270 [cmemk]) from [<c0097988>] (__fput+0x60/0x1bc)
[<c0097928>] (__fput+0x0/0x1bc) from [<c0097c4c>] (fput+0x34/0x38)
r8 = 00000000  r7 = C0514508  r6 = C0514500  r5 = 00000000
r4 = C725B760
[<c0097c18>] (fput+0x0/0x38) from [<c0094444>] (filp_close+0x6c/0x78)
[<c00943d8>] (filp_close+0x0/0x78) from [<c004cf10>] (put_files_struct+0x94/0xe8)
r6 = 00000030  r5 = C0514500  r4 = 00007FF7
[<c004ce7c>] (put_files_struct+0x0/0xe8) from [<c004e518>] (do_exit+0x250/0xa24)
[<c004e2c8>] (do_exit+0x0/0xa24) from [<c004eda8>] (sys_exit_group+0x0/0x1c)
[<c004ecec>] (do_group_exit+0x0/0xbc) from [<c0059d54>] (get_signal_to_deliver+0x3e0/0x42c)
r4 = 00000009
[<c0059974>] (get_signal_to_deliver+0x0/0x42c) from [<c0037ba4>] (do_signal+0x58/0x4e0)
[<c0037b4c>] (do_signal+0x0/0x4e0) from [<c0038058>] (do_notify_resume+0x2c/0x30)
[<c003802c>] (do_notify_resume+0x0/0x30) from [<c0034e2c>] (work_pending+0x1c/0x20)
Code: 1062e003 e1a0c004 ea000001 e1a0c000 (e5900000)
 <1>Fixing recursive fault but reboot is needed!
Log 2
Alignment trap: av_server.out (774) PC=0x000e1178 Instr=0xe5823000 Address=0x3c843d7a FSR 0x801
Unable to handle kernel paging request at virtual address 29822a7c
pgd = c0004000
[29822a7c] *pgd=00000000
Internal error: Oops: 5 [#1]
CPU: 0
LR is at 0x1000
sp : c78abd64  ip : 29822a7c  fp : c78abd74
r10: 00000000  r9 : 00000001  r8 : c76083a8
r7 : bf026da0  r6 : 00000000  r5 : c76083a8  r4 : bf026d80
r3 : 00000001  r2 : 00000724  r1 : c9748000  r0 : 29822a7c
Control: 5317F
Table: 877C8000  DAC: 00000015
Process av_server.out (pid: 766, stack limit = 0xc78aa258)
Stack: (0xc78abd64 to 0xc78ac000)
bd60:          c76083a0 c78abdc4 c78abd78 bf022ca4 bf022154 00000000 00000000
bd80: bf026d98 c8076080 bf026da0 c76083e0 00000000 00000005 c00b67a8 c8076080
bda0: c8076080 c0fe46c8 c800ce20 c707b098 00000000 00000000 c78abdec c78abdc8
bdc0: c0097988 bf022b28 c0e203d4 c8076080 00000000 c801c800 c801c808 00000000
bde0: c78abdfc c78abdf0 c0097c4c c0097938 c78abe1c c78abe00 c0094444 c0097c28
be00: c78aa000 00007ff7 c801c800 00000030 c78abe4c c78abe20 c004cf10 c00943e8
be20: c78abe4c c801c800 c0e1e3e0 c0f2b070 00000000 00000007 00000000 c78abf50
be40: c78abe6c c78abe50 c004e518 c004ce8c c0035ba4 c0051434 c78abea0 c78aa000
be60: c78abe84 c78abe70 c004eda8 c004e2d8 00000000 00000009 c78abebc c78abe88
be80: c0059d54 c004ecfc c78abfb0 c0e1e5c0 c00561c4 c78aa000 c0034f88 c78abfb0
bea0: 00000000 c0034f88 c78aa000 00000000 c78abf9c c78abec0 c0037ba4 c0059984
bec0: c78aa000 00000001 c0e1e5c0 c78abed8 00000009 00000000 00000000 00000000
bee0: 00000000 00000001 c78abf14 c78abef8 c0065478 c78abf88 00000000 00000001
bf00: bec53b88 bec53b88 00000008 00000000 c78abf20 c0064f14 00d962b7 00001e61
bf20: c7841f20 00000000 00000000 00000000 39ca321f 00001e61 c0065024 c0349110
bf40: 00000000 00000002 c78abf48 c78abf48 c0e1e3e0 c78abf60 00000000 38f0cf68
bf60: c78abf88 bec53b88 00000080 000000a2 c0034f88 00000000 0000004d 00000080
bf80: 000000a2 c0034f88 c78aa000 00000000 c78abfac c78abfa0 c0038058 c0037b5c
bfa0: 00000000 c78abfb0 c0034e2c c003803c fffffdfc bec53b88 4001f3e4 00000002
bfc0: 00000000 0000004d 00000080 000000a2 00000021 00000021 0000065c 0013db44
bfe0: 00000000 bec53b80 400344f4 40035634 80000010 bec53b90 37243027 8cdc6353
Backtrace:
r4 = C76083A0
r8 = 00000000  r7 = C801C808  r6 = C801C800  r5 = 00000000
r4 = C8076080
r6 = 00000030  r5 = C801C800  r4 = 00007FF7
r4 = 00000009
Log 3
Alignment trap: av_server.out (778) PC=0x000e11c8 Instr=0xe5823000 Address=0x0280017e FSR 0x801
Unable to handle kernel paging request at virtual address 01800180
pgd = c0004000
[01800180] *pgd=00000000
CPU: 0
LR is at 0x1000
sp : c78afd64  ip : 01800180  fp : c78afd74
r10: 00000000  r9 : 00000001  r8 : c760e9a8
r7 : bf026da0  r6 : 00000000  r5 : c760e9a8  r4 : bf026d80
r3 : 00000001  r2 : 00000724  r1 : c9748000  r0 : 01800180
Control: 5317F
Table: 86BD0000  DAC: 00000015
Process av_server.out (pid: 770, stack limit = 0xc78ae258)
Stack: (0xc78afd64 to 0xc78b0000)
fd60:          c760e9a0 c78afdc4 c78afd78 bf022ca4 bf022154 00000000 00000000
fd80: bf026d98 c0e04e60 bf026da0 c760e9e0 00000000 00000005 c00b67a8 c0e04e60
fda0: c0e04e60 c0fe16c8 c800ce20 c7080098 00000000 00000000 c78afdec c78afdc8
fdc0: c0097988 bf022b28 c81b5894 c0e04e60 00000000 c801c800 c801c808 00000000
fde0: c78afdfc c78afdf0 c0097c4c c0097938 c78afe1c c78afe00 c0094444 c0097c28
fe00: c78ae000 00007ff7 c801c800 00000030 c78afe4c c78afe20 c004cf10 c00943e8
fe20: c78afe4c c801c800 c0e22100 c0d3eab0 00000000 00000007 00000000 c78aff50
fe40: c78afe6c c78afe50 c004e518 c004ce8c 00000000 000f4fb0 c78afea0 c78ae000
fe60: c78afe84 c78afe70 c004eda8 c004e2d8 00000000 00000009 c78afebc c78afe88
fe80: c0059d54 c004ecfc c78affb0 c0e222e0 c00561c4 c78ae000 c0034f88 c78affb0
fea0: 00000000 c0034f88 c78ae000 00000000 c78aff9c c78afec0 c0037ba4 c0059984
fec0: c78ae000 00000001 c0e222e0 c78afed8 00000009 00000000 00000000 00000000
fee0: 00000000 00000001 c78aff14 c78afef8 c0065478 c78aff88 00000000 00000001
ff00: bed42b88 bed42b88 00000008 00000000 c78aff20 c0064f14 35c2839c 00000102
ff20: c780bf20 00000000 00000000 00000000 2e774b4f 00000103 c0065024 c0349110
ff40: 00000000 00000002 c78aff48 c78aff48 c0e22100 c01cddf8 00000000 344f91b3
ff60: c78aff88 bed42b88 00000080 000000a2 c0034f88 00000000 0000004d 00000080
ff80: 000000a2 c0034f88 c78ae000 00000000 c78affac c78affa0 c0038058 c0037b5c
ffa0: 00000000 c78affb0 c0034e2c c003803c fffffdfc bed42b88 4001f3e4 00000002
ffc0: 00000000 0000004d 00000080 000000a2 00000021 00000021 0000065c 0013e084
ffe0: 00000000 bed42b80 400344f4 40035634 80000010 bed42b90 79cdbff5 7a8fa6b9
Backtrace:
r4 = C760E9A0
r4 = C0E04E60
r4 = 00000009
    Can you please upgrade your codec version and check.
    Anuj
    Pathpartner Technology Pvt Ltd
    Anuj
  • In reply to Anuj Kumar Gupta:
    Hi Anuj
    Thank your reply.
    I had tested the codec H264ENC.version.02.30.00.06.
    It also crashes after serval hours.
    What could i do to check furtherly ?
  • In reply to kuo wenliang:
    Hi ,
    I am not sure of rdk 3.0 , for DM36x latest is 5.1 and 5.0 version , please confirm the version so that others can help.
    Since it is long run issue , codec as been ran for few days in our earlier project there was no crash . I suggest few things since you have few customization,
    Please check Memory leak if any , check available memory at fixed interval after 2, 4, 6 hrs until crash . If there is any constant memory leak that is first place to fix.
    If your running av_server alone , try it under GDB . So that you can get backtrace of all the threads on crash.
    Thanks & Regards,
    Vishwanath Patil
    Thanks & Regards,
    Vishwanath Patil
