Hi Ti:
We are integrating AR0521 sensor to Dm388 now.
The i2c communication is ready.
MIPI clock and data line has signal too.
But we can't find video image still.
We use AR0330 as template to modify it.
The MIPI config has be turned on too. (CAPTURE_MODE:= MIPI_CSI2)
But the video can't show still.
The error is below.
Error Log: (AR0521.log)
VPSS_FVID2: contrl event 0x1004001a timeout
VPSS_DCTRL: failed to get venc info.
Do you have any suggestion for it?
Thanks~
Remounting root file system... Caching udev devnodes root: mount: mounting /dev/root on / failed: No such file or directory Configuring network interfaces... done. Setting up IP spoofing protection: rp_filter. rm: cannot remove '/tmp': Read-only file system hwclock: can't open '/dev/misc/rtc': No such file or directory Thu Jan 1 00:00:00 UTC 2015 hwclock: can't open '/dev/misc/rtc': No such file or directory inside finish.sh numid=1,iface=MIXER,name='PCM Playback Volume' ; type=INTEGER,access=rw---R--,values=2,min=0,max=127,step=0 : values=127,127 | dBscale-min=-63.50dB,step=0.50dB,mute=0 [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000 [m3video] Remote Debug Shared Memory @ 0xbff05020 [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040 SysLink version : 2.21.02.10 SysLink module created on Date:Jun 4 2017 Time:23:19:24 Trace enabled Trace SetFailureReason enabled /dev/mem opened. Phy Addr : 0x48181560 Data : 0x00Unhandled fault: external abort on non-linefetch (0x1018) at 0x2ad480e4 000102 Phy Addr : 0x48180f10 Data : 0x00000000 Phy Addr : 0x48180508 Data : 0x00000302 Phy Addr : 0x48180520 Data : 0x00000002 Phy Addr : 0x48180524 Data : 0x00000002 Phy Addr : 0x48180528 Data : 0x00000002 Phy Addr : 0x4c0000e4 Data : 0x00170209 Bus error [host] Setting L3 bandwidth regulator for [HDVICP0 ] to [press=[0,0] BW=900, WM Cycles=2500] [host] Setting L3 bandwidth regulator for [ISS ] to [press=[3,3] BW=400, WM Cycles=2500] [host] Setting DMM priority for [ISS ] to [0] ( 0x4e000634 = 0x00080000 ) [host] Setting DMM priority for [HDVICP0 ] to [1] ( 0x4e000634 = 0x00000009 ) zero gadget: Gadget Zero, version: Cinco de Mayo 2008 zero gadget: zero ready musb-hdrc musb-hdrc.0: MUSB HDRC host driver musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 1 usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 usb usb1: Product: MUSB HDRC host driver usb usb1: Manufacturer: Linux 2.6.37_DM388_IPNC_3.80.00 musb-hcd usb usb1: SerialNumber: musb-hdrc.0 hub 1-0:1.0: USB hub found hub 1-0:1.0: 1 port detected udevd-work[67]: kernel-provided name 'usbdev1.1' and NAME= 'bus/usb/001/001' disagree, please use SYMLINK+= or change the kernel to provide the proper name [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000 [m3video] Remote Debug Shared Memory @ 0xbff05020 [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040 [host] Attached to slave procId 1. RTL871X: module init start RTL871X: rtl8188eu v4.3.0.4_11485.20140519 RTL871X: build time: Jun 4 2017 23:55:22 usbcore: registered new interface driver rtl8188eu RTL871X: module init ret=0 usb 1-1: new high speed USB device using musb-hdrc and address 2 [host] Loaded file ./firmware/ipnc_rdk_fw_m3vpss.xem3 on slave procId 1. [host] Started slave procId 1. [host] After Ipc_loadcallback status [0x00000000] usb 1-1: device v0bda p0179 is not supported usb 1-1: New USB device found, idVendor=0bda, idProduct=0179 usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3 usb 1-1: Product: 802.11n NIC usb 1-1: Manufacturer: Realtek usb 1-1: SerialNumber: 00E04C0001 [host] Attached to slave procId 0. [m3vpss ] ***** SYSTEM : Frequency <ORG> - 200000000, <NEW> - 200000000 [m3vpss ] notify_attach rtnVal 0 bFWReady == _FALSE call reset 8051... [m3vpss ] initProxyServer rtnVal 0 [m3vpss ] [m3vpss ] *** UTILS: CPU KHz = 400000 Khz *** [m3vpss ] [m3vpss ] 67: SYSTEM : System Common Init in progress !!! [m3vpss ] 68: SYSTEM: IPC init in progress !!! [m3vpss ] 68: SYSTEM: Attaching to [HOST] ... [m3vpss ] 117: SYSTEM: Attaching to [HOST] ... [m3vpss ] 119: SYSTEM: Attaching to [HOST] ... SUCCESS !!! [m3vpss ] 120: SYSTEM: Attaching to [VIDEO-M3] ... [host] After Ipc_startcallback status [0x00000000] [m3vpss ] 169: SYSTEM: Attaching to [VIDEO-M3] ... RTL871X: rtw_ndev_init(wlan0) [m3vpss ] 219: SYSTEM: Attaching to [VIDEO-M3] ... udevd-work[67]: kernel-provided name 'usbdev1.2' and NAME= 'bus/usb/001/002' disagree, please use SYMLINK+= or change the kernel to provide the proper name [m3vpss ] 269: SYSTEM: Attaching to [VIDEO-M3] ... [m3vpss ] 319: SYSTEM: Attaching to [VIDEO-M3] ... [m3vpss ] 369: SYSTEM: Attaching to [VIDEO-M3] ... [m3vpss ] 419: SYSTEM: Attaching to [VIDEO-M3] ... [m3vpss ] 469: SYSTEM: Attaching to [VIDEO-M3] ... [host] Loaded file ./firmware/ipnc_rdk_fw_m3video.xem3 on slave procId 0. [host] Started slave procId 0. [host] After Ipc_loadcallback status [0x00000000] [m3video] ***** SYSTEM : Frequency <ORG> - 200000000, <NEW> - 200000000 [m3vpss ] 569: SYSTEM: Attaching to [VIDEO-M3] ... [m3video] [m3video] *** UTILS: CPU KHz = 400000 Khz *** [m3video] [m3video] 554: SYSTEM : System Common Init in progress !!! [m3video] 555: SYSTEM: IPC init in progress !!! [m3video] 555: SYSTEM: Attaching to [HOST] ... [m3video] 604: SYSTEM: Attaching to [HOST] ... [m3video] 607: SYSTEM: Attaching to [HOST] ... SUCCESS !!! [host] After Ipc_startcallback status [0x00000000] [m3video] 607: SYSTEM: Attaching to [VPSS-M3] ... [m3vpss ] 619: SYSTEM: Attaching to [VIDEO-M3] ... [m3video] 656: SYSTEM: Attaching to [VPSS-M3] ... Is TI ready? [m3video] 670: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!! [m3vpss ] 669: SYSTEM: Attaching to [VIDEO-M3] ... [m3viusb 1-1: USB disconnect, address 2 deo] 670: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ... [m3vpss ] 670: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!! [m3vpss ] 670: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP] ... [m3vpss ] 671: SYSTEM: Creating MsgQ [VPSS-M3_MSGQ] ... [m3vpss ] 671: SYSTEM: Creating MsgQ [VPSS-M3_ACK_MSGQ] ... [m3vpss ] 673: SYSTEM: Notify register to [HOST] line 0, event 12 ... [m3vpss ] 673: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ... [m3vpss ] 673: SYSTEM: IPC init DONE !!! [m3vpss ] 684: MEM: Shared Region 2: Base = 0xb4500000, Length = 0x06900000 (105 MB) [m3vpss ] 685: MEM: Shared Region 1: Base = 0xbbe00000, Length = 0x03b00000 (59 MB) [m3vpss ] 687: SYSTEM : System Common Init Done !!! [m3vpss ] 687: SYSTEM : System VPSS Init in progress !!! [m3vpss ] 687: SYSTEM: All VPDMA Free !!! [m3vpss ] === I2C0/2 Clk is active === [m3vpss ] PLATFORM: UNKNOWN CPU detected, defaulting to VPS_PLATFORM_CPU_REV_1_0 [m3vpss ] PLATFORM: UNKNOWN CPU detected, defaulting to ISS_PLATFORM_CPU_REV_2_1 [m3vpss ] 705: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_0] in region 0 ... [m3vpss ] 706: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_0] in region 0 ... [m3vpss ] 706: SYSTEM: ListElem Shared Addr = 0xbae84180 [m3vpss ] 708: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_1] in region 0 ... [m3vpss ] 709: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_1] in region 0 ... [m3vpss ] 709: SYSTEM: ListElem Shared Addr = 0xbae87680 [m3vpss ] 722: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_24] in region 0 ... [m3vpss ] 723: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_24] in region 0 ... [m3vpss ] 723: SYSTEM: ListElem Shared Addr = 0xbae8ab80 [m3vpss ] 725: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_25] in region 0 ... [m3vpss ] 726: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_25] in region 0 ... [m3vpss ] 726: SYSTEM: ListElem Shared Addr = 0xbaeaa580 [m3vpss ] 729: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_26] in region 0 ... [m3vpss ] 729: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_26] in region 0 ... [m3vpss ] 729: SYSTEM: ListElem Shared Addr = 0xbaec9f80 [m3vpss ] 735: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_29] in region 0 ... [m3vpss ] 736: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_29] in region 0 ... [m3vpss ] 736: SYSTEM: ListElem Shared Addr = 0xbaee9980 [m3vpss ] 739: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_30] in region 0 ... [m3vpss ] 739: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_30] in region 0 ... [m3vpss ] 739: SYSTEM: ListElem Shared Addr = 0xbaf03600 [m3vpss ] 741: SYSTEM : HDVPSS Drivers Version: HDVPSS_01_00_01_37 [m3vpss ] 742: SYSTEM : FVID2 Init in progress !!! [m3video] 770: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ... [m3video] 771: SYSTEM: Creating MsgQ [VIDEO-M3_MSGQ] ... [m3video] 771: SYSTEM: Creating MsgQ [VIDEO-M3_ACK_MSGQ] ... [m3video] 773: SYSTEM: Notify register to [HOST] line 0, event 12 ... [m3video] 773: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ... [m3video] 774: SYSTEM: IPC init DONE !!! [m3video] 784: MEM: Shared Region 2: Base = 0xb4500000, Length = 0x06900000 (105 MB) [m3video] 785: MEM: Shared Region 1: Base = 0xbbe00000, Length = 0x03b00000 (59 MB) [m3video] 787: SYSTEM : System Common Init Done !!! [m3video] 787: SYSTEM : System Video Init in progress !!! [m3video] 788: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_0] in region 0 ... [m3video] 788: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_0] in region 0 ... [m3video] 788: SYSTEM: ListElem Shared Addr = 0xbaf1d280 [m3video] 791: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_1] in region 0 ... [m3video] 791: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_1] in region 0 ... [m3video] 791: SYSTEM: ListElem Shared Addr = 0xbaf20780 [m3video] 801: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_29] in region 0 ... [m3vRTL871X: indicate disassoc ideo] 801: SYSTEM: Creating LisRTL871X: rtw_ndev_uninit(wlan0) tMP [VIDEO-M3_IPC_IN_29] in region 0 ... [m3video] 802: SYSTEM: ListElem Shared Addr = 0xbaf23c80 [m3video]RTL871X: rtw_cmd_thread: DriverStopped(0) SurpriseRemoved(1) break at line 478 804: SYSTEM: CRTL871X: rtw_dev_unload: driver not in IPS reating ListMP [VIDEO-M3_IPC_OUT_30] in region 0 ... [m3video] 804: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_30] in region 0 ... [m3video] 805: SYSTEM: ListElem Shared Addr = 0xbaf3d900 [m3video] 807: HDVICP: Doing PRCM for IVAHD[0] ... [m3video] 807: HDVICP: PRCM for IVAHD[0] ... DONE. [m3video] 808: SYSTEM : Initializing Links !!! [m3video] 808: SYSTEM : FREE SPACE : System Heap = 2088976 B, Mbx = 10240 msgs) [m3vpss ] 812: SYSTEM : FVID2 Init in progress DONE !!! [m3vpss ] 813: SYSTEM : Device Init in progress !!! [m3video] 808: SYSTEM : FREE SPACE : SR0 Heap = 15372416 B (14 MB) [m3vpss ] Iss_init called !!!!!! [m3vpss ] CPIS_init DONE !!!!!! [m3video] 808: SYSTEM : FREE SPACE : Frame Buffer = 110100352 B (104 MB) [m3vpss ] initPrms.isI2cInitReq = 1 [m3video] 809: SYSTEM : FREE SPACE : Bitstream Buffer = 61865856 B (58 MB) [m3vpss ] initPrms.isI2cInitReq = 0 [m3video] 809: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ... [m3video] 810: SYSTEM : FREE SPACE : Tiler Buffer = 69 B (0 MB) - TILER OFF [m3video] Entered the MctnfLink_init() [m3video] 869: SYSTEM : Initializing Links ... DONE !!! [m3video] 869: SYSTEM : System Video Init Done !!! [m3vpss ] 936: SYSTEM : Device Init in progress DONE !!! [m3vpss ] *1* devAddr:0x36 CMOS Sensor ID (457/0)!!! [m3vpss ] I2C regAddr:0x3042, value:0x4 status:0x0 [m3vpss ] I2C regAddr:0x3044, value:0x4580 status:0x0 [m3vpss ] I2C regAddr:0x30ee, value:0x1136 status:0x0 [m3vpss ] I2C regAddr:0x3120, value:0x1 status:0x0 [m3vpss ] I2C regAddr:0x3f2c, value:0x442e status:0x0 [m3vpss ] I2C regAddr:0x30d2, value:0x0 status:0x0 [m3vpss ] I2C regAddr:0x30d4, value:0x0 status:0x0 [m3vpss ] I2C regAddr:0x30d6, value:0x2fff status:0x0 [m3vpss ] I2C regAddr:0x30da, value:0xfff status:0x0 [m3vpss ] I2C regAddr:0x30dc, value:0xfff status:0x0 usb 1-1: new high speed USB device using musb-hdrc and address 3 [m3vpss ] I2C regAddr:0x30de, value:0x0 status:0x0 [m3vpss ] I2C regAddr:0x31e0, value:0x781 status:0x0 [m3vpss ] I2C regAddr:0x3180, value:0x9434 status:0x0 [m3vpss ] I2C regAddr:0x3172, value:0x206 status:0x0 [m3vpss ] I2C regAddr:0x3f00, value:0x17 status:0x0 [m3vpss ] I2C regAddr:0x3f02, value:0x2dd status:0x0 [m3vpss ] I2C regAddr:0x3f04, value:0x20 status:0x0 [m3vpss ] I2C regAddr:0x3f08, value:0x70 status:0x0 [m3vpss ] I2C regAddr:0x3f0a, value:0x101 status:0x0 [m3vpss ] I2C regAddr:0x3f0c, value:0x302 status:0x0 [m3vpss ] I2C regAddr:0x3f1e, vusb 1-1: device v0bda p0179 is not supported alue:0x22 statususb 1-1: New USB device found, idVendor=0bda, idProduct=0179 :0x0 usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3 usb 1-1: Product: 802.11n NIC usb 1-1: Manufacturer: Realtek usb 1-1: SerialNumber: 00E04C0001 [m3vpss ] I2C regAddr:0x3f1a, value:0x1ff status:0x0 [m3vpss ] I2C regAddr:0x3f14, value:0x505 status:0x0 bFWReady == _FALSE call reset 8051... [m3vpss ] I2C regAddr:0x3f44, value:0x707 status:0x0 [m3vpss ] I2C regAddr:0x3f18, value:0x1ff status:0x0 RTL871X: rtw_ndev_init(wlan0) [m3vpss ] I2C regAddr:0x3f12, value:0x505 status:0x0 [m3vpss ] I2C regAddr:0x3f42, value:0x1511 status:0x0 [m3vpss ] I2C regAddr:0x3f16, value:0x1ff status:0x0 udevd-work[67]: kernel-provided name 'usbdev1.3' and NAME= 'bus/usb/001/003' disagree, please use SYMLINK+= or change the kernel to provide the proper name [m3vpss ] I2C regAddr:0x3f10, value:0x505 status:0x0 [m3vpss ] I2C regAddr:0x3f40, value:0x1511 status:0x0 [m3vpss ] I2C regAddr:0x3d00, vudev[66]: renamed network interface wlan0 to wlan1 alue:0x43e status:0x0 [m3vpss ] I2C regAddr:0x3d02, value:0x4760 status:0x0 [m3vpss ] I2C regAddr:0x3d04, value:0xffff status:0x0 [m3vpss ] I2C regAddr:0x3d06, value:0xffff status:0x0 [m3vpss ] I2C regAddr:0x3d08, value:0x8000 status:0x0 Is TI ready? [m3vpss ] I2C regAddr:0x3d0a, value:0x510 status:0x0 [m3vpss ] I2C regAddr:0x3d0c, value:0xaf08 status:0x0 [m3vpss ] I2C regAddr:0x3d0e, value:0x252 status:0x0 [m3vpss ] I2C regAddr:0x3d10, value:0x486f status:0x0 [m3vpss ] I2C regAddr:0x3d12, value:0x5d5d status:0x0 [m3vpss ] I2C regAddr:0x3d14, value:0x8056 status:0x0 [m3vpss ] I2C regAddr:0x3d16, value:0x8313 status:0x0 [m3vpss ] I2C regAddr:0x3d18, value:0x87 status:0x0 [m3vpss ] I2C regAddr:0x3d1a, value:0x6a48 status:0x0 [m3vpss ] I2C regAddr:0x3d1c, value:0x6982 status:0x0 [m3vpss ] I2C regAddr:0x3d1e, value:0x280 status:0x0 [m3vpss ] I2C regAddr:0x3d20, value:0x8359 status:0x0 [m3vpss ] I2C regAddr:0x3d22, value:0x8d02 status:0x0 [m3vpss ] I2C regAddr:0x3d24, value:0x8020 status:0x0 [m3vpss ] I2C regAddr:0x3d26, value:0x4882 status:0x0 [m3vpss ] I2C regAddr:0x3d28, value:0x4269 status:0x0 [m3vpss ] I2C regAddr:0x3d2a, value:0x6a95 status:0x0 [m3vpss ] I2C regAddr:0x3d2c, value:0x5988 status:0x0 [m3vpss ] I2C regAddr:0x3d2e, value:0x5a83 status:0x0 [m3vpss ] I2C regAddr:0x3d30, value:0x5885 status:0x0 [m3vpss ] I2C regAddr:0x3d32, value:0x6280 status:0x0 [m3vpss ] I2C regAddr:0x3d34, value:0x6289 status:0x0 [m3vpss ] I2C regAddr:0x3d36, value:0x6097 status:0x0 [m3vpss ] I2C regAddr:0x3d38, value:0x5782 status:0x0 [m3vpss ] I2C regAddr:0x3d3a, value:0x605c status:0x0 [m3vpss ] I2C regAddr:0x3d3c, value:0xbf18 status:0x0 [m3vpss ] I2C regAddr:0x3d3e, value:0x961 status:0x0 [m3vpss ] I2C regAddr:0x3d40, value:0x5080 status:0x0 [m3vpss ] I2C regAddr:0x3d42, value:0x2090 status:0x0 [m3vpss ] I2C regAddr:0x3d44, value:0x4394 status:0x0 [m3vpss ] I2C regAddr:0x3d46, value:0x5f8a status:0x0 [m3vpss ] I2C regAddr:0x3d48, value:0x5d5d status:0x0 [m3vpss ] I2C regAddr:0x3d4a, value:0x8d43 status:0x0 [m3vpss ] I2C regAddr:0x3d4c, value:0x8d63 status:0x0 [m3vpss ] I2C regAddr:0x3d4e, value:0x8063 status:0x0 [m3vpss ] I2C regAddr:0x3d50, value:0xa960 status:0x0 [m3vpss ] I2C regAddr:0x3d52, value:0x9757 status:0x0 [m3vpss ] I2C regAddr:0x3d54, value:0x8260 status:0x0 [m3vpss ] I2C regAddr:0x3d56, value:0x5cff status:0x0 [m3vpss ] I2C regAddr:0x3d58, value:0xbf10 status:0x0 [m3vpss ] I2C regAddr:0x3d5a, value:0x1681 status:0x0 [m3vpss ] I2C regAddr:0x3d5c, value:0x802 status:0x0 [m3vpss ] I2C regAddr:0x3d5e, value:0x8000 status:0x0 [m3vpss ] I2C regAddr:0x3d60, value:0x141c status:0x0 [m3vpss ] I2C regAddr:0x3d62, value:0x6000 status:0x0 [m3vpss ] I2C regAddr:0x3d64, value:0x6022 status:0x0 [m3vpss ] I2C regAddr:0x3d66, value:0x4d80 status:0x0 [m3vpss ] I2C regAddr:0x3d68, value:0x5c97 status:0x0 [m3vpss ] I2C regAddr:0x3d6a, value:0x6a69 status:0x0 [m3vpss ] I2C regAddr:0x3d6c, value:0xac6f status:0x0 [m3vpss ] I2C regAddr:0x3d6e, value:0x4645 status:0x0 [m3vpss ] I2C regAddr:0x3d70, value:0x4400 status:0x0 [m3vpss ] I2C regAddr:0x3d72, value:0x513 status:0x0 [m3vpss ] I2C regAddr:0x3d74, value:0x8069 status:0x0 [m3vpss ] I2C regAddr:0x3d76, value:0x6ac6 status:0x0 [m3vpss ] I2C regAddr:0x3d78, value:0x5f95 status:0x0 [m3vpss ] I2C regAddr:0x3d7a, value:0x5f70 status:0x0 [m3vpss ] I2C regAddr:0x3d7c, value:0x8040 status:0x0 [m3vpss ] I2C regAddr:0x3d7e, value:0x4a81 status:0x0 [m3vpss ] I2C regAddr:0x3d80, value:0x300 status:0x0 [m3vpss ] I2C regAddr:0x3d82, value:0xe703 status:0x0 [m3vpss ] I2C regAddr:0x3d84, value:0x88 status:0x0 [m3vpss ] I2C regAddr:0x3d86, value:0x4a83 status:0x0 [m3vpss ] I2C regAddr:0x3d88, value:0x40ff status:0x0 [m3vpss ] I2C regAddr:0x3d8a, value:0xffff status:0x0 [m3vpss ] I2C regAddr:0x3d8c, value:0xfd70 status:0x0 [m3vpss ] I2C regAddr:0x3d8e, value:0x8040 status:0x0 [m3vpss ] I2C regAddr:0x3d90, value:0x4a85 status:0x0 [m3vpss ] I2C regAddr:0x3d92, value:0x4fa8 status:0x0 [m3vpss ] I2C regAddr:0x3d94, value:0x4f8c status:0x0 [m3vpss ] I2C regAddr:0x3d96, value:0x70 status:0x0 Is TI ready? [m3vpss ] I2C regAddr:0x3d98, value:0xbe47 status:0x0 [m3vpss ] I2C regAddr:0x3d9a, value:0x8847 status:0x0 [m3vpss ] I2C regAddr:0x3d9c, value:0xbc78 status:0x0 [m3vpss ] I2C regAddr:0x3d9e, value:0x6b89 status:0x0 [m3vpss ] I2C regAddr:0x3da0, value:0x6a80 status:0x0 [m3vpss ] I2C regAddr:0x3da2, value:0x6986 status:0x0 [m3vpss ] I2C regAddr:0x3da4, value:0x6b8e status:0x0 [m3vpss ] I2C regAddr:0x3da6, value:0x6b80 status:0x0 [m3vpss ] I2C regAddr:0x3da8, value:0x6980 status:0x0 [m3vpss ] I2C regAddr:0x3daa, value:0x6a88 status:0x0 [m3vpss ] I2C regAddr:0x3dac, value:0x7c9f status:0x0 [m3vpss ] I2C regAddr:0x3dae, value:0x866b status:0x0 [m3vpss ] I2C regAddr:0x3db0, value:0x8765 status:0x0 [m3vpss ] I2C regAddr:0x3db2, value:0x46ff status:0x0 [m3vpss ] I2C regAddr:0x3db4, value:0xe365 status:0x0 [m3vpss ] I2C regAddr:0x3db6, value:0xa679 status:0x0 [m3vpss ] I2C regAddr:0x3db8, value:0x4a40 status:0x0 [m3vpss ] I2C regAddr:0x3dba, value:0x4580 status:0x0 [m3vpss ] I2C regAddr:0x3dbc, value:0x44bc status:0x0 [m3vpss ] I2C regAddr:0x3dbe, value:0x7000 status:0x0 [m3vpss ] I2C regAddr:0x3dc0, value:0x8040 status:0x0 [m3vpss ] I2C regAddr:0x3dc2, value:0x802 status:0x0 [m3vpss ] I2C regAddr:0x3dc4, value:0x10ef status:0x0 [m3vpss ] I2C regAddr:0x3dc6, value:0x104 status:0x0 [m3vpss ] I2C regAddr:0x3dc8, value:0x3860 status:0x0 [m3vpss ] I2C regAddr:0x3dca, value:0x5d5d status:0x0 [m3vpss ] I2C regAddr:0x3dcc, value:0x5682 status:0x0 [m3vpss ] I2C regAddr:0x3dce, value:0x1300 status:0x0 [m3vpss ] I2C regAddr:0x3dd0, value:0x8648 status:0x0 [m3vpss ] I2C regAddr:0x3dd2, value:0x8202 status:0x0 [m3vpss ] I2C regAddr:0x3dd4, value:0x8082 status:0x0 [m3vpss ] I2C regAddr:0x3dd6, value:0x598a status:0x0 [m3vpss ] I2C regAddr:0x3dd8, value:0x280 status:0x0 [m3vpss ] I2C regAddr:0x3dda, value:0x2048 status:0x0 [m3vpss ] I2C regAddr:0x3ddc, value:0x3060 status:0x0 [m3vpss ] I2C regAddr:0x3dde, value:0x8042 status:0x0 [m3vpss ] I2C regAddr:0x3de0, value:0x9259 status:0x0 [m3vpss ] I2C regAddr:0x3de2, value:0x865a status:0x0 [m3vpss ] I2C regAddr:0x3de4, value:0x8258 status:0x0 [m3vpss ] I2C regAddr:0x3de6, value:0x8562 status:0x0 [m3vpss ] I2C regAddr:0x3de8, value:0x8062 status:0x0 [m3vpss ] I2C regAddr:0x3dea, value:0x8560 status:0x0 [m3vpss ] I2C regAddr:0x3dec, value:0x9257 status:0x0 [m3vpss ] I2C regAddr:0x3dee, value:0x8221 status:0x0 [m3vpss ] I2C regAddr:0x3df0, value:0x10ff status:0x0 [m3vpss ] I2C regAddr:0x3df2, value:0xb757 status:0x0 [m3vpss ] I2C regAddr:0x3df4, value:0x9361 status:0x0 [m3vpss ] I2C regAddr:0x3df6, value:0x1019 status:0x0 [m3vpss ] I2C regAddr:0x3df8, value:0x8020 status:0x0 [m3vpss ] I2C regAddr:0x3dfa, value:0x9043 status:0x0 [m3vpss ] I2C regAddr:0x3dfc, value:0x945f status:0x0 [m3vpss ] I2C regAddr:0x3dfe, value:0x835d status:0x0 [m3vpss ] I2C regAddr:0x3e00, value:0x805d status:0x0 [m3vpss ] I2C regAddr:0x3e02, value:0x8163 status:0x0 [m3vpss ] I2C regAddr:0x3e04, value:0x8063 status:0x0 [m3vpss ] I2C regAddr:0x3e06, value:0x8443 status:0x0 [m3vpss ] I2C regAddr:0x3e08, value:0x9a60 status:0x0 [m3vpss ] I2C regAddr:0x3e0a, value:0x9157 status:0x0 [m3vpss ] I2C regAddr:0x3e0c, value:0x8260 status:0x0 [m3vpss ] I2C regAddr:0x3e0e, value:0x5cff status:0x0 [m3vpss ] I2C regAddr:0x3e10, value:0xffff status:0x0 [m3vpss ] I2C regAddr:0x3e12, value:0xffe5 status:0x0 [m3vpss ] I2C regAddr:0x3e14, value:0x1016 status:0x0 [m3vpss ] I2C regAddr:0x3e16, value:0x2048 status:0x0 [m3vpss ] I2C regAddr:0x3e18, value:0x802 status:0x0 [m3vpss ] I2C regAddr:0x3e1a, value:0x1c60 status:0x0 [m3vpss ] I2C regAddr:0x3e1c, value:0x14 status:0x0 [m3vpss ] I2C regAddr:0x3e1e, value:0x60 status:0x0 [m3vpss ] I2C regAddr:0x3e20, value:0x2205 status:0x0 [m3vpss ] I2C regAddr:0x3e22, value:0x8120 status:0x0 [m3vpss ] I2C regAddr:0x3e24, value:0x908f status:0x0 [m3vpss ] I2C regAddr:0x3e26, value:0x6a80 status:0x0 Is TI ready? [m3vpss ] I2C regAddr:0x3e28, value:0x6982 status:0x0 [m3vpss ] I2C regAddr:0x3e2a, value:0x5f9f status:0x0 [m3vpss ] I2C regAddr:0x3e2c, value:0x6f46 status:0x0 [m3vpss ] I2C regAddr:0x3e2e, value:0x4544 status:0x0 [m3vpss ] I2C regAddr:0x3e30, value:0x5 status:0x0 [m3vpss ] I2C regAddr:0x3e32, value:0x8013 status:0x0 [m3vpss ] I2C regAddr:0x3e34, value:0x8069 status:0x0 [m3vpss ] I2C regAddr:0x3e36, value:0x6a80 status:0x0 [m3vpss ] I2C regAddr:0x3e38, value:0x7000 status:0x0 [m3vpss ] I2C regAddr:0x3e3a, value:0x0 status:0x0 [m3vpss ] I2C regAddr:0x3e3c, value:0x0 status:0x0 [m3vpss ] I2C regAddr:0x3e3e, value:0x0 status:0x0 [m3vpss ] I2C regAddr:0x3e40, value:0x0 status:0x0 [m3vpss ] I2C regAddr:0x3e42, value:0x0 status:0x0 [m3vpss ] I2C regAddr:0x3e44, value:0x0 status:0x0 [m3vpss ] I2C regAddr:0x3e46, value:0x0 status:0x0 [m3vpss ] I2C regAddr:0x3e48, value:0x0 status:0x0 [m3vpss ] I2C regAddr:0x3e4a, value:0x0 status:0x0 [m3vpss ] I2C regAddr:0x3e4c, value:0x0 status:0x0 [m3vpss ] I2C regAddr:0x3e4e, value:0x0 status:0x0 [m3vpss ] I2C regAddr:0x3e50, value:0x0 status:0x0 [m3vpss ] I2C regAddr:0x3e52, value:0x0 status:0x0 [m3vpss ] I2C regAddr:0x3e54, value:0x0 status:0x0 [m3vpss ] I2C regAddr:0x3e56, value:0x0 status:0x0 [m3vpss ] I2C regAddr:0x3e58, value:0x0 status:0x0 [m3vpss ] I2C regAddr:0x3e5a, value:0x0 status:0x0 [m3vpss ] I2C regAddr:0x3e5c, value:0x0 status:0x0 [m3vpss ] I2C regAddr:0x3e5e, value:0x0 status:0x0 [m3vpss ] I2C regAddr:0x3e60, value:0x0 status:0x0 [m3vpss ] I2C regAddr:0x3e62, value:0x0 status:0x0 [m3vpss ] I2C regAddr:0x3e64, value:0x0 status:0x0 [m3vpss ] I2C regAddr:0x3e66, value:0x0 status:0x0 [m3vpss ] I2C regAddr:0x3e68, value:0x0 status:0x0 [m3vpss ] I2C regAddr:0x3e6a, value:0x0 status:0x0 [m3vpss ] I2C regAddr:0x3e6c, value:0x0 status:0x0 [m3vpss ] I2C regAddr:0x3e6e, value:0x0 status:0x0 [m3vpss ] I2C regAddr:0x3e70, value:0x0 status:0x0 [m3vpss ] I2C regAddr:0x3e72, value:0x0 status:0x0 [m3vpss ] I2C regAddr:0x3e74, value:0x0 status:0x0 [m3vpss ] I2C regAddr:0x3e76, value:0x0 status:0x0 [m3vpss ] I2C regAddr:0x3e78, value:0x0 status:0x0 [m3vpss ] I2C regAddr:0x3e7a, value:0x0 status:0x0 [m3vpss ] I2C regAddr:0x3e7c, value:0x0 status:0x0 [m3vpss ] I2C regAddr:0x3e7e, value:0x0 status:0x0 [m3vpss ] I2C regAddr:0x3e80, value:0x0 status:0x0 [m3vpss ] I2C regAddr:0x3e82, value:0x0 status:0x0 [m3vpss ] I2C regAddr:0x3e84, value:0x0 status:0x0 [m3vpss ] I2C regAddr:0x3e86, value:0x0 status:0x0 [m3vpss ] I2C regAddr:0x3e88, value:0x0 status:0x0 [m3vpss ] I2C regAddr:0x3e8a, value:0x0 status:0x0 [m3vpss ] I2C regAddr:0x3e8c, value:0x0 status:0x0 [m3vpss ] I2C regAddr:0x3e8e, value:0x0 status:0x0 [m3vpss ] I2C regAddr:0x3e90, value:0x0 status:0x0 [m3vpss ] I2C regAddr:0x3e92, value:0x0 status:0x0 [m3vpss ] I2C regAddr:0x3e94, value:0x0 status:0x0 [m3vpss ] I2C regAddr:0x3e96, value:0x0 status:0x0 [m3vpss ] I2C regAddr:0x3e98, value:0x0 status:0x0 [m3vpss ] I2C regAddr:0x3e9a, value:0x0 status:0x0 [m3vpss ] I2C regAddr:0x3e9c, value:0x0 status:0x0 [m3vpss ] I2C regAddr:0x3e9e, value:0x0 status:0x0 [m3vpss ] I2C regAddr:0x3ea0, value:0x0 status:0x0 [m3vpss ] I2C regAddr:0x3ea2, value:0x0 status:0x0 [m3vpss ] I2C regAddr:0x3ea4, value:0x0 status:0x0 [m3vpss ] I2C regAddr:0x3ea6, value:0x0 status:0x0 [m3vpss ] I2C regAddr:0x3ea8, value:0x0 status:0x0 [m3vpss ] I2C regAddr:0x3eaa, value:0x0 status:0x0 [m3vpss ] I2C regAddr:0x3eac, value:0x0 status:0x0 [m3vpss ] I2C regAddr:0x3eae, value:0x0 status:0x0 [m3vpss ] I2C regAddr:0x3eb0, value:0x0 status:0x0 [m3vpss ] I2C regAddr:0x3eb2, value:0x0 status:0x0 [m3vpss ] I2C regAddr:0x3eb4, value:0x0 status:0x0 Is TI ready? [m3vpss ] I2C regAddr:0x3eb6, value:0x4c status:0x0 [m3vpss ] I2C regAddr:0x3eba, value:0xaaaa status:0x0 [m3vpss ] I2C regAddr:0x3ebc, value:0x86 status:0x0 [m3vpss ] I2C regAddr:0x3ec0, value:0x1e00 status:0x0 [m3vpss ] I2C regAddr:0x3ec2, value:0xb status:0x0 [m3vpss ] I2C regAddr:0x3ec4, value:0x3300 status:0x0 [m3vpss ] I2C regAddr:0x3ec6, value:0xea44 status:0x0 [m3vpss ] I2C regAddr:0x3ec8, value:0x6f6f status:0x0 [m3vpss ] I2C regAddr:0x3eca, value:0x2f4a status:0x0 [m3vpss ] I2C regAddr:0x3ecc, value:0x506 status:0x0 [m3vpss ] I2C regAddr:0x3ece, value:0x203b status:0x0 [m3vpss ] I2C regAddr:0x3ed0, value:0x13f0 status:0x0 [m3vpss ] I2C regAddr:0x3ed2, value:0x9a3d status:0x0 [m3vpss ] I2C regAddr:0x3ed4, value:0x862f status:0x0 [m3vpss ] I2C regAddr:0x3ed6, value:0x4081 status:0x0 [m3vpss ] I2C regAddr:0x3ed8, value:0x4003 status:0x0 [m3vpss ] I2C regAddr:0x3eda, value:0x9a80 status:0x0 [m3vpss ] I2C regAddr:0x3edc, value:0xc000 status:0x0 [m3vpss ] I2C regAddr:0x3ede, value:0xc103 status:0x0 [m3vpss ] I2C regAddr:0x3426, value:0x1600 status:0x0 [m3vpss ] I2C regAddr:0x342a, value:0x38 status:0x0 [m3vpss ] I2C regAddr:0x3f3e, value:0x1 status:0x0 [m3vpss ] I2C regAddr:0x341a, value:0x6051 status:0x0 [m3vpss ] I2C regAddr:0x3420, value:0x6051 status:0x0 [m3vpss ] I2C regAddr:0x3ec2, value:0xa status:0x0 [m3vpss ] I2C regAddr:0x3ed8, value:0x8003 status:0x0 [m3vpss ] I2C regAddr:0x341a, value:0x4735 status:0x0 [m3vpss ] I2C regAddr:0x3420, value:0x4735 status:0x0 [m3vpss ] I2C regAddr:0x3426, value:0x8a1a status:0x0 [m3vpss ] I2C regAddr:0x342a, value:0x18 status:0x0 [m3vpss ] I2C regAddr:0x3ed2, value:0xa53d status:0x0 [m3vpss ] I2C regAddr:0x3eda, value:0xa580 status:0x0 [m3vpss ] I2C regAddr:0x3eba, value:0xaaad status:0x0 [m3vpss ] I2C regAddr:0x3eb6, value:0x4c status:0x0 [m3vpss ] I2C regAddr:0x3f3e, value:0x0 status:0x0 [m3vpss ] I2C regAddr:0x31b0, value:0x58 status:0x0 [m3vpss ] I2C regAddr:0x31b2, value:0x2c status:0x0 [m3vpss ] I2C regAddr:0x31b4, value:0x23d2 status:0x0 [m3vpss ] I2C regAddr:0x31b6, value:0x13e9 status:0x0 [m3vpss ] I2C regAddr:0x31b8, value:0x2413 status:0x0 [m3vpss ] I2C regAddr:0x31ba, value:0x1c68 status:0x0 [m3vpss ] I2C regAddr:0x31bc, value:0x860b status:0x0 [m3vpss ] I2C regAddr:0x112, value:0xa0a status:0x0 [m3vpss ] I2C regAddr:0x304, value:0x303 status:0x0 [m3vpss ] I2C regAddr:0x306, value:0x7359 status:0x0 [m3vpss ] I2C regAddr:0x302, value:0x1 status:0x0 [m3vpss ] I2C regAddr:0x30a, value:0x1 status:0x0 [m3vpss ] I2C regAddr:0x300, value:0x5 status:0x0 [m3vpss ] I2C regAddr:0x308, value:0xa status:0x0 [m3vpss ] I2C regAddr:0x3016, value:0x101 status:0x0 [m3vpss ] I2C regAddr:0x3004, value:0x154 status:0x0 [m3vpss ] I2C regAddr:0x3008, value:0x8db status:0x0 [m3vpss ] I2C regAddr:0x3002, value:0x1b4 status:0x0 [m3vpss ] I2C regAddr:0x3006, value:0x5f3 status:0x0 [m3vpss ] I2C regAddr:0x3040, value:0x41 status:0x0 [m3vpss ] I2C regAddr:0x3172, value:0x206 status:0x0 [m3vpss ] I2C regAddr:0x317a, value:0x416e status:0x0 [m3vpss ] I2C regAddr:0x3f3c, value:0x3 status:0x0 [m3vpss ] I2C regAddr:0x34c, value:0x788 status:0x0 [m3vpss ] I2C regAddr:0x34e, value:0x440 status:0x0 [m3vpss ] I2C regAddr:0x300c, value:0x1178 status:0x0 [m3vpss ] I2C regAddr:0x300a, value:0x4e4 status:0x0 [m3vpss ] I2C regAddr:0x301a, value:0x210 status:0x0 [m3vpss ] I2C regAddr:0x301e, value:0xa8 status:0x0 [m3vpss ] I2C regAddr:0x301a, value:0x218 status:0x0 [m3vpss ] I2C regAddr:0x30ee, value:0x1136 status:0x0 [m3vpss ] I2C regAddr:0x3f2c, value:0x442e status:0x0 [m3vpss ] I2C regAddr:0x301a, value:0x210 status:0x0 [m3vpss ] I2C regAddr:0x301e, value:0xaa status:0x0 [m3vpss ] I2C regAddr:0x301a, value:0x218 status:0x0 [m3vpss ] I2C regAddr:0x3120, value:0x5 status:0x0 [m3vpss ] I2C regAddr:0x300c, value:0x5f0 status:0x0 [m3vpss ] I2C regAddr:0x300a, value:0x8dc status:0x0 Is TI ready? [m3vpss ] I2C regAddr:0x301a, value:0x21c status:0x0 [m3vpss ] 5745: SYSTEM : System VPSS Init Done !!! [m3vpss ] 5745: UTILS: DMA: HWI Create for INT62 !!! [m3vpss ] 5745: SYSTEM : Initializing Links !!! [m3vpss ] 5745: SYSTEM : FREE SPACE : System Heap = 1682760 B, Mbx = 10240 msgs) [m3vpss ] 5745: SYSTEM : FREE SPACE : SR0 Heap = 15372416 B (14 MB) [m3vpss ] 5746: SYSTEM : FREE SPACE : Frame Buffer = 105790336 B (100 MB) [m3vpss ] 5746: SYSTEM : FREE SPACE : Bitstream Buffer = 61865856 B (58 MB) [m3vpss ] 5746: SYSTEM : FREE SPACE : Tiler Buffer = 69 B (0 MB) - TILER OFF [m3vpss ] 5878: SYSTEM : Initializing Links ... DONE !!! [m3vpss ] Received character 's' [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000 [m3video] Remote Debug Shared Memory @ 0xbff05020 [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040 [m3video] Received character 's' DMA: Module install successful, device major num = 248 DRV: Module install successful DRV: Module built on Jun 4 2017 23:27:40 [host] [host] ORG 0x46c00524: 0 [host] NEW 0x46c00524: 2 [host] [host] Application Load Completed [host] 0: SYSTEM: System Common Init in progress !!! [host] 1: SYSTEM: IPC init in progress !!! [host] 19: SYSTEM: CPU [DSP] is NOT available on this platform !!! [host] 19: SYSTEM: CPU [VIDEO-M3] syslink proc ID is [0] !!! [host] 20: SYSTEM: CPU [VPSS-M3] syslink proc ID is [1] !!! [host] 20: SYSTEM: CPU [HOST] syslink proc ID is [2] !!! [host] 20: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ... [host] 22: SYSTEM: Creating MsgQ [HOST_MSGQ] ... [host] 23: SYSTEM: Creating MsgQ [HOST_ACK_MSGQ] ... [host] 24: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ... [host] 25: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ... [host] 27: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ... [host] 28: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ... [host] 28: SYSTEM: IPC init DONE !!! [host] 32: SYSTEM: Creating ListMP [HOST_IPC_OUT_29] in region 0 ... [host] 33: SYSTEM: Creating ListMP [HOST_IPC_IN_29] in region 0 ... [host] 34: SYSTEM: ListElem Shared Addr = 0x2b924580 [host] 35: SYSTEM: Creating ListMP [HOST_IPC_OUT_30] in region 0 ... [host] 36: SYSTEM: Creating ListMP [HOST_IPC_IN_30] in region 0 ... [host] 37: SYSTEM: ListElem Shared Addr = 0x2b93e200 [host] 40: SYSTEM: Creating ListMP [HOST_IPC_OUT_24] in region 0 ... [host] 41: SYSTEM: Creating ListMP [HOST_IPC_IN_24] in region 0 ... [host] 42: SYSTEM: ListElem Shared Addr = 0x2b957e80 [host] 43: SYSTEM: Creating ListMP [HOST_IPC_OUT_25] in region 0 ... [host] 45: SYSTEM: Creating ListMP [HOST_IPC_IN_25] in region 0 ... [host] 46: SYSTEM: ListElem Shared Addr = 0x2b977880 [host] 47: SYSTEM: Creating ListMP [HOST_IPC_OUT_26] in region 0 ... [host] 48: SYSTEM: Creating ListMP [HOST_IPC_IN_26] in region 0 ... [host] 49: SYSTEM: ListElem Shared Addr = 0x2b997280 [host] 50: SYSTEM: System Common Init Done !!! [host] Vsys_allocBuf - addr = 0x37d7e000,size = 33603 [host] DCC buffer allocated for size 33603 [host] DCC Default File Intialization Done [host] Before System_linkControl SYSTEM_M3VPSS_CMD_GET_DISPLAYCTRL_INIT [m3vpss ] tiedVencs VPS_DC_VENC_DVO2 | VPS_DC_VENC_HDCOMP=(0x30)(6410) [host] ********* Entered Capture + Display usecase - JPEG 2048x1536 @24 fps, QVGA @24fps ******** [host] ********* DATA:Jun 4 2017 TIME:23:27:55 ******** [host] PET: Python test.py found! [m3vpss ] VPS_DDMA: ChannelID allocated:4 CTRL_INST_0 [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_DVO2 [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_HDMI [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_SD [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_HDCOMP [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_CLK_SRC VPS_DC_VENC_DVO2 | VPS_DC_VENC_HDCOMP [m3vpss ] HDCOMPCLK Is TI ready? [host] MultiCh_createStreamMiiSCaptureDisplay:OSA_dmaOpen passed with ch id = 4 [host] 1540: MCFW : CPU Revision [ES1.0] !!! [host] 1540: MCFW : Detected [4x TVP5158 VS] Board !!! [host] 1540: MCFW : Base Board Revision [REV A] !!! [host] 1540: MCFW : Daughter Card Revision [REV A] !!! [m3vpss ] 7601: CAMERA: Create in progress !!! [m3vpss ] Channel Num Stream 0 Ch 0 ChannelNum 0 [m3vpss ] Channel Num Stream 1 Ch 0 ChannelNum 1 [m3vpss ] 7602: CAMERA: VIP0 PortA camera mode is [ 8-bit, Non-mux Embedded Sync] !!! [m3vpss ] Iss_Ar0330Create entered........ [m3vpss ] 7603: CAMERA: VIP 0: VID DEC 268436751 (0x36): 0002:20202020:20202020, AUD_STATUS 538976288 Is TI ready? Is TI ready? Is TI ready? Is TI ready? [host] PET: Python module imported! [host] PET: yFramebuffer pYFB discovered! [host] PET: framebuffer pFB discovered! [host] Entered IPC Bits Handler function Is TI ready? Is TI ready? Is TI ready? Is TI ready? Is TI ready? Is TI ready? Is TI ready? Is TI ready? Is TI ready? Is TI ready? Is TI ready? Is TI ready? Is TI ready? Is TI ready? Is TI ready? VPSS_FVID2: contrl event 0x1004001a timeout VPSS_DCTRL: failed to get venc info. VPSS_FVID2: contrl event 0x1004001a timeout VPSS_DCTRL: failed to get venc info. VPSS_FVID2: contrl event 0x1004001a timeout VPSS_DCTRL: failed to get venc info. VPSS_FVID2: contrl event 0x1004001a timeout VPSS_DCTRL: failed to get venc info.
