Tool/software: Starterware
The Make system for ipnc_rdk-3.9.1 does not properly support debugging. The Rules.make configuration file gives the impression that if you set APP_BUILD_CFG to debug that the build will support debugging, but this is never exported, so is not visible to the compilation units. In particular, system_server will never be build with -g enabled. Likewise, while the makerules files for the McFW subsystem imply that it will build with -g set, if CONFIG=debug, the CONFIG variable is never set. In general, I have a very poor impression of this make system.
