Linux/TMDSCSK388: image display issue
Part Number: TMDSCSK388
Tool/software: Linux
The customer has bought  a new board csk388. He boot up by sd card. But he cann't see any image after he logged  in the web ui. This is the log file.
U-Boot SPL 2016.05-00004-g63acf8c-dirty (Feb 13 2017 - 17:24:46)
Trying to boot from MMC2
reading u-boot.img
reading u-boot.img
U-Boot 2016.05-00004-g63acf8c-dirty (Feb 13 2017 - 17:24:46 -0500)
I2C: ready
DRAM: 1 GiB
MMC: OMAP SD/MMC: 0
*** Warning - bad CRC, using default environment
Net: <ethaddr> not set. Reading from E-fuse
cpsw
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
Booting from mmc ...
reading uImage
2662320 bytes read in 307 ms (8.3 MiB/s)
reading dm38x-csk.dtb
58698 bytes read in 14 ms (4 MiB/s)
## Booting kernel from Legacy Image at 82000000 ...
Image Name: Linux-4.4.12-00004-g82adbbf-dirt
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 2662256 Bytes = 2.5 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
## Flattened Device Tree blob at 84000000
Booting using the fdt blob at 0x84000000
Loading Kernel Image ... OK
Loading Device Tree to 844ee000, end 844ff549 ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.12-00004-g82adbbf-dirty (gtbldadm@ubuntu-16) (gcc version 5.3.1 20160113 (Linaro GCC 5.3-2016.02) ) #1 Mon Feb 13 17:38:26 EST 2017
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine model: DM38X CSK
[ 0.000000] bootconsole [earlycon0] enabled
[ 0.000000] omap_barrier_reserve_memblock():Reserving DRAM area @ addr = 0x84e00000 size = 1048576 Bytes
[ 0.000000] cma: Reserved 24 MiB at 0x82c00000
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] TI81XX: Map 0x84e00000 to 0xfe500000 for dram barrier
[ 0.000000] TI81XX: Map 0x40300000 to 0xfe600000 for sram barrier
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] TI814X ES1.0 (iva neon )
[ 0.000000] powerdomain: gem_pwrdm: voltagedomain dsp does not exist
[ 0.000000] powerdomain: ivahd_pwrdm: voltagedomain iva does not exist
[ 0.000000] powerdomain: hdvpss_pwrdm: voltagedomain dsp does not exist
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 19788
[ 0.000000] Kernel command line: console=ttyS0,115200n8 root=/dev/mmcblk0p2 rootwait rw mem=80M vram=4M cmemk.phys_start=0x85000000 cmemk.phys_end=0x89000000 cmemk.allowOverlap=1 notifyk.vpssm3_sva=0xBFD00000 earlyprintk
[ 0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
[ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Memory: 46648K/79872K available (4911K kernel code, 260K rwdata, 1708K rodata, 276K init, 241K bss, 8648K reserved, 24576K cma-reserved, 0K highmem)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xc5800000 - 0xff800000 ( 928 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xc5000000 ( 80 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc067efa4 (6620 kB)
[ 0.000000] .init : 0xc067f000 - 0xc06c4000 ( 276 kB)
[ 0.000000] .data : 0xc06c4000 - 0xc0705308 ( 261 kB)
[ 0.000000] .bss : 0xc0705308 - 0xc0741718 ( 242 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
[ 0.000000] OMAP clockevent source: timer2 at 20000000 Hz
[ 0.000016] sched_clock: 32 bits at 20MHz, resolution 50ns, wraps every 107374182375ns
[ 0.008264] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 95563022313 ns
[ 0.017840] OMAP clocksource: timer1 at 20000000 Hz
[ 0.023134] Console: colour dummy device 80x30
[ 0.027834] Calibrating delay loop... 597.60 BogoMIPS (lpj=2988032)
[ 0.086911] pid_max: default: 32768 minimum: 301
[ 0.091860] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.098774] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.106821] Initializing cgroup subsys io
[ 0.111052] Initializing cgroup subsys memory
[ 0.115673] Initializing cgroup subsys devices
[ 0.120346] Initializing cgroup subsys freezer
[ 0.125027] Initializing cgroup subsys pids
[ 0.129439] CPU: Testing write buffer coherency: ok
[ 0.134892] Setting up static identity map for 0x800082c0 - 0x80008318
[ 0.142711] devtmpfs: initialized
[ 0.168784] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 0.217165] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.229300] pinctrl core: initialized pinctrl subsystem
[ 0.236089] NET: Registered protocol family 16
[ 0.242329] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.255287] OMAP GPIO hardware version 0.1
[ 0.267870] omap-gpmc 50000000.gpmc: could not find pctldev for node /ocp/l4ls@48000000/control@140000/pinmux@800/nandflash_pins_s0, deferring probe
[ 0.301557] edma 49000000.edma: TI EDMA DMA engine driver
[ 0.309808] omap_i2c 48028000.i2c: could not find pctldev for node /ocp/l4ls@48000000/control@140000/pinmux@800/pinmux_i2c0_pins, deferring probe
[ 0.323412] omap_i2c 4802a000.i2c: could not find pctldev for node /ocp/l4ls@48000000/control@140000/pinmux@800/pinmux_i2c1_pins, deferring probe
[ 0.337083] media: Linux media interface: v0.10
[ 0.341896] Linux video capture interface: v2.00
[ 0.346806] pps_core: LinuxPPS API ver. 1 registered
[ 0.352000] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.361530] PTP clock support registered
[ 0.365672] EDAC MC: Ver: 3.0.0
[ 0.369725] Advanced Linux Sound Architecture Driver Initialized.
[ 0.377127] clocksource: Switched to clocksource timer1
[ 0.394564] NET: Registered protocol family 2
[ 0.399934] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.407246] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.413884] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.420607] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.426710] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.433430] NET: Registered protocol family 1
[ 0.438380] RPC: Registered named UNIX socket transport module.
[ 0.444562] RPC: Registered udp transport module.
[ 0.449519] RPC: Registered tcp transport module.
[ 0.454445] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.462498] omap-iommu 55082000.mmu: 55082000.mmu registered
[ 0.469605] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.486570] NFS: Registering the id_resolver key type
[ 0.491966] Key type id_resolver registered
[ 0.496358] Key type id_legacy registered
[ 0.502258] io scheduler noop registered
[ 0.506395] io scheduler deadline registered
[ 0.511150] io scheduler cfq registered (default)
[ 0.517476] pinctrl-single 48140800.pinmux: 270 pins at pa fa140800 size 1080
[ 0.598620] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[ 0.609637] console [ttyS0] disabled
[ 0.613450] 48020000.uart: ttyS0 at MMIO 0x48020000 (irq = 21, base_baud = 3000000) is a 8250
[ 0.622407] console [ttyS0] enabled
[ 0.629599] bootconsole [earlycon0] disabled
[ 0.639391] Reference Linux version 4.4.12
[ 0.643687] File /home/gtbldadm/nightlybuilds/ipnc_rdk/utils/package-script/TI_GIT/NEWDIR/Source/ti_tools/linuxutils_3_23_00_01/packages/ti/sdo/linuxutils/cmem/src/module/cmemk.c
[ 0.662232] allocated heap buffer 0xc8000000 of size 0x4000000
[ 0.668133] cmemk initialized
[ 0.678484] loop: module loaded
[ 0.747190] davinci_mdio 4a100800.mdio: davinci mdio revision 1.6
[ 0.753327] libphy: 4a100800.mdio: probed
[ 0.758205] davinci_mdio 4a100800.mdio: phy[25]: device 4a100800.mdio:19, driver TI DP83867
[ 0.767195] cpsw 4a100000.ethernet: Detected MACID = 7c:66:9d:f8:ee:c8
[ 0.777276] 47401300.usb-phy supply vcc not found, using dummy regulator
[ 0.807348] mousedev: PS/2 mouse device common for all mice
[ 0.813862] omap_rtc 480c0000.rtc: rtc core: registered 480c0000.rtc as rtc0
[ 0.821338] i2c /dev entries driver
[ 0.825801] omap_wdt: OMAP Watchdog Timer Rev 0x00: initial timeout 60 sec
[ 0.832934] sdhci: Secure Digital Host Controller Interface driver
[ 0.839168] sdhci: Copyright(c) Pierre Ossman
[ 0.962633] omap_hsmmc 48060000.mmc: card claims to support voltages below defined range
[ 0.981659] mmc0: queuing unknown CIS tuple 0x91 (3 bytes)
[ 0.988026] mmc0: new high speed SDIO card at address 0001
[ 0.997397] Synopsys Designware Multimedia Card Interface Driver
[ 1.003895] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.010882] notify_shm_drv: no DSP present (MULTIPROC_INVALIDID)
[ 1.017039] notify_init : notify drivercreated for remote proc id 1 at physical Address 0xbfd00000
[ 1.028799] davinci_evm sound: ASoC: CODEC DAI tlv320aic3x-hifi not registered
[ 1.036076] davinci_evm sound: snd_soc_register_card failed (-517)
[ 1.043549] NET: Registered protocol family 10
[ 1.050419] sit: IPv6 over IPv4 tunneling driver
[ 1.055905] NET: Registered protocol family 17
[ 1.060556] Key type dns_resolver registered
[ 1.065091] omap_voltage_late_init: Could not get sys clk.
[ 1.071001] Power Management for TI81XX.
[ 1.080234] omap-gpmc 50000000.gpmc: GPMC revision 6.0
[ 1.085419] gpmc_mem_init: disabling cs 0 mapped at 0x0-0x1000000
[ 1.093035] nand: device found, Manufacturer ID: 0x2c, Chip ID: 0xca
[ 1.099493] nand: Micron MT29F2G16ABAEAWP
[ 1.103526] nand: 256 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 64
[ 1.111162] nand: using OMAP_ECC_BCH8_CODE_HW ECC scheme
[ 1.116581] 8 ofpart partitions found on MTD device 8000000.nand
[ 1.122636] Creating 8 MTD partitions on "8000000.nand":
[ 1.127997] 0x000000000000-0x000000020000 : "NAND.SPL"
[ 1.137764] 0x000000020000-0x000000420000 : "NAND.u-boot"
[ 1.145897] 0x000000420000-0x000000440000 : "NAND.u-boot-env"
[ 1.153006] 0x000000440000-0x000000a40000 : "NAND.kernel"
[ 1.162031] 0x000000a40000-0x00000ca40000 : "NAND.file-system"
[ 1.171811] mmc1: host does not support reading read-only switch, assuming write-enable
[ 1.187212] mmc1: new high speed SDHC card at address 0007
[ 1.207180] mmcblk0: mmc1:0007 SD16G 14.5 GiB
[ 1.213146] mmcblk0: p1 p2
[ 1.259997] 0x00000ca40000-0x00000ca80000 : "NAND.u-boot-spl-os"
[ 1.267370] 0x00000ca80000-0x00000d680000 : "NAND.data"
[ 1.278072] 0x00000d680000-0x000010000000 : "NAND.reserved"
[ 1.344036] tps65910-rtc tps65910-rtc: rtc core: registered tps65910-rtc as rtc1
[ 1.351739] omap_i2c 48028000.i2c: bus 0 rev0.11 at 400 kHz
[ 1.359238] omap_i2c 4802a000.i2c: bus 1 rev0.11 at 100 kHz
[ 1.366038] davinci_evm sound: ASoC: DAPM unknown pin MONO_LOUT
[ 1.373110] davinci_evm sound: tlv320aic3x-hifi <-> 4803c000.mcasp mapping ok
[ 1.382534] omap_rtc 480c0000.rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800)
[ 1.404370] wlan-en-regulator: disabling
[ 1.408734] ALSA device list:
[ 1.411723] #0: TI81XX-CSK
[ 1.416693] EXT4-fs (mmcblk0p2): mounting ext3 file system using the ext4 subsystem
[ 10.741403] EXT4-fs (mmcblk0p2): recovery complete
[ 10.753791] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 10.762029] VFS: Mounted root (ext3 filesystem) on device 179:2.
[ 10.777572] devtmpfs: mounted
[ 10.781156] Freeing unused kernel memory: 276K (c067f000 - c06c4000)
[ 10.787570] This architecture does not have kernel memory protection.
[ 11.037607] systemd[1]: System time before build time, advancing clock.
[ 11.059991] random: systemd urandom read with 31 bits of entropy available
[ 11.080563] systemd[1]: systemd 229 running in system mode. (-PAM -AUDIT -SELINUX -IMA -APPARMOR -SMACK +SYSVINIT -UTMP -LIBCRYPTSETUP -GCRYPT +GNUTLS +ACL -XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN)
[ 11.099362] systemd[1]: Detected architecture arm.
Welcome to Arago 2016.05!
[ 11.129166] systemd[1]: Set hostname to <ti81xx>.
[ 11.419675] systemd[1]: Configuration file /etc/systemd/system/ipnc-rdk-usecase.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 11.567904] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ OK ] Listening on /dev/initctl Compatibility Named Pipe.
[ 11.597996] systemd[1]: Listening on Network Service Netlink Socket.
[ OK ] Listening on Network Service Netlink Socket.
[ 11.627684] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ OK ] Started Forward Password Requests to Wall Directory Watch.
[ 11.657541] systemd[1]: Listening on udev Kernel Socket.
[ OK ] Listening on udev Kernel Socket.
[ 11.677607] systemd[1]: Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket (/dev/log).
[ 11.697619] systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Journal Socket.
[ 11.717714] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Started Dispatch Password Requests to Console Directory Watch.
[ 11.747551] systemd[1]: Listening on Syslog Socket.
[ OK ] Listening on Syslog Socket.
[ 11.785817] systemd[1]: Reached target Swap.
[ OK ] Reached target Swap.
[ 11.811342] systemd[1]: Created slice System Slice.
[ OK ] Created slice System Slice.
[ 11.841333] systemd[1]: Mounting /media/ram...
[ 11.883967] systemd[1]: Starting Journal Service...
[ 11.938760] systemd[1]: Mounting /var/volatile...
[ 11.993373] systemd[1]: Mounting POSIX Message Queue File System...
[ 12.051449] systemd[1]: Starting Synchronize System and HW clocks...
[ 12.089112] systemd[1]: Created slice system-getty.slice.
[ OK ] Created slice system-getty.slice.
[ 12.140888] systemd[1]: Mounting Temporary Directory...
[ 12.181609] systemd[1]: Reached target Slices.
[ OK ] Reached target Slices.
[ 12.198798] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ OK ] Created slice system-serial\x2dgetty.slice.
[ 12.217481] systemd[1]: Reached target Timers.
[ OK ] Reached target Timers.
[ 12.237483] systemd[1]: Reached target Paths.
[ OK ] Reached target Paths.
[ 12.257735] systemd[1]: Listening on udev Control Socket.
OK ] Listening on udev Control Socket.
y[ 12.281385] systemd[1]: Starting udev Coldplug all Devices...
[ 12.311766] systemd[1]: Starting udev Kernel Device Manager...
[ 12.353404] systemd[1]: Reached target Remote File Systems.
[ OK ] Reached target Remote File Systems.
[ 12.412643] systemd[1]: Mounted POSIX Message Queue File System.
[ OK ] Mounted POSIX Message Queue File System.
[ 12.438847] systemd[1]: Mounted Temporary Directory.
[ OK ] Mounted Temporary Directory.
[ 12.457627] systemd[1]: Mounted /var/volatile.
[ OK ] Mounted /var/volatile.
[ 12.477623] systemd[1]: Mounted /media/ram.
OK ] Mounted /media/ram.
.[ 12.498345] systemd[1]: Started Journal Service.
[ OK ] Started Journal Service.
[ OK ] Started Synchronize System and HW clocks.
[ OK ] Started udev Kernel Device Manager.
[ OK ] Started udev Coldplug all Devices.
[ OK ] Found device /dev/ttyS0.
[ OK ] Started IPNC RDK use case service.
[ OK ] Reached target Local File Systems.
[ OK ] Reached target System Initialization.
[ OK ] Listening on D-Bus System Message Bus Socket.
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
[ OK ] Started Serial Getty on ttyS0.
[ 13.569673] autorun-usecase.sh[111]: numid=1,iface=MIXER,name='PCM Playback Volume'
[ 13.592027] autorun-usecase.sh[111]: ; type=INTEGER,access=rw---R--,values=2,min=0,max=127,step=0
[ OK ] Started D-Bus System Message Bus.
[ 13.611794] autorun-usecase.sh[111]: : values=115,115
[ 13.641857] autorun-usecase.sh[111]: | dBscale-min=-63.50dB,step=0.50dB,mute=0
[ 13.662125] autorun-usecase.sh[111]: numid=31,iface=MIXER,name='PGA Capture Volume'
[ 13.681821] autorun-usecase.sh[111]: ; type=INTEGER,access=rw---R--,values=2,min=0,max=119,step=0
[ 13.701868] autorun-usecase.sh[111]: : values=72,72
[ 13.721817] autorun-usecase.sh[111]: | dBscale-min=0.00dB,step=0.50dB,mute=0
[ 13.743534] autorun-usecase.sh[111]: numid=51,iface=MIXER,name='Right PGA Mixer Mic2R Switch'
[ 13.772042] autorun-usecase.sh[111]: ; type=BOOLEAN,access=rw------,values=1
[ 13.791830] autorun-usecase.sh[111]: : values=on
[ 13.813903] autorun-usecase.sh[111]: numid=46,iface=MIXER,name='Left PGA Mixer Mic2L Switch'
Starting Network Service...
[ 13.841760] autorun-usecase.sh[111]: ; type=BOOLEAN,access=rw------,values=1
[ OK ] Started System Logging Service.
[ OK ] Started Kernel Logging Service.
[ 13.871732] autorun-usecase.sh[111]: : values=on
[ 13.901727] ubi0: attaching mtd6
[ 13.903887] autorun-usecase.sh[111]: Mount mtd6 and mtd7 partitions
[ OK ] Started Getty on tty1.
[ OK ] Reached target Login Prompts.
Starting uim-sysfs.service...
[ 14.104982] net eth0: initializing cpsw version 1.10 (0)
[ 14.110415] net eth0: initialized cpsw ale version 1.3
[ 14.118864] net eth0: phy found : id is : 0x2000a231
[ 14.123906] libphy: PHY not found
[ 14.127357] net eth0: phy "" not found on slave 1, err -19
[ 14.173643] ubi0: scanning is finished
[ OK ] Started Network Service.
[ 14.235463] ubi0: attached mtd6 (name "NAND.data", size 12 MiB)
[ 14.241505] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 14.248441] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 512
[ 14.255173] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 14.262181] ubi0: good PEBs: 96, bad PEBs: 0, corrupted PEBs: 0
[ 14.268144] ubi0: user volume: 1, internal volumes: 1, max. volumes count: 128
[ 14.275400] ubi0: max/mean erase counter: 4/2, WL threshold: 4096, image sequence number: 3570551878
[ 14.284590] ubi0: available PEBs: 0, total reserved PEBs: 96, PEBs reserved for bad PEB handling: 40
[ 14.294242] ubi0: background thread "ubi_bgt0d" started, PID 144
[ 14.335429] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 14.515617] autorun-usecase.sh[111]: UBI device number 0, total 96 LEBs (12189696 bytes, 11.6 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
[ 15.147229] UBIFS (ubi0:0): background thread "ubifs_bgt0_0" started, PID 149
[ 15.205988] UBIFS (ubi0:0): recovery needed
[ 15.485710] UBIFS (ubi0:0): recovery completed
[ 15.490351] UBIFS (ubi0:0): UBIFS: mounted UBI device 0, volume 0, name "ubifs_volume"
[ 15.498343] UBIFS (ubi0:0): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 15.508323] UBIFS (ubi0:0): FS size: 5332992 bytes (5 MiB, 42 LEBs), journal size 1015809 bytes (0 MiB, 6 LEBs)
[ 15.518474] UBIFS (ubi0:0): reserved for root: 251889 bytes (245 KiB)
[ 15.524950] UBIFS (ubi0:0): media format: w4/r0 (latest is w4/r0), UUID 0BE9751A-1974-49C3-AB08-367788CE1177, small LPT model
,[0;32m OK ] Reached target Network.
b Starting Network Name Resolution...
[ OK ] Started Network Name Resolution.
[ 16.361002] ubi1: attaching mtd7
[ OK ] Started uim-sysfs.service.
[ 16.628447] ubi1: scanning is finished
Starting telnetd.service...
[ 16.655675] ubi1: attached mtd7 (name "NAND.reserved", size 41 MiB)
[ 16.662065] ubi1: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 16.669007] ubi1: min./max. I/O unit sizes: 2048/2048, sub-page size 512
[ 16.675740] ubi1: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 16.682749] ubi1: good PEBs: 332, bad PEBs: 0, corrupted PEBs: 0
[ 16.688799] ubi1: user volume: 1, internal volumes: 1, max. volumes count: 128
[ 16.696055] ubi1: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 3239883363
[ 16.705246] ubi1: available PEBs: 0, total reserved PEBs: 332, PEBs reserved for bad PEB handling: 40
[ 16.722202] ubi1: background thread "ubi_bgt1d" started, PID 162
[ OK ] Started telnetd.service.
[ 16.822154] autorun-usecase.sh[111]: UBI device number 1, total 332 LEBs (42156032 bytes, 40.2 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
Starting thermal-zone-init.service...
[ OK ] Started thermal-zone-init.service.
[ OK ] Reached target Multi-User System.
[ 17.118134] cpsw 4a100000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[ 17.140156] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 17.377246] UBIFS (ubi1:0): background thread "ubifs_bgt1_0" started, PID 179
[ 17.402353] UBIFS (ubi1:0): recovery needed
[ 17.422291] UBIFS (ubi1:0): recovery completed
[ 17.426856] UBIFS (ubi1:0): UBIFS: mounted UBI device 1, volume 0, name "ubifs_volume"
[ 17.434880] UBIFS (ubi1:0): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 17.444864] UBIFS (ubi1:0): FS size: 35299328 bytes (33 MiB, 278 LEBs), journal size 1777664 bytes (1 MiB, 14 LEBs)
[ 17.455365] UBIFS (ubi1:0): reserved for root: 1667274 bytes (1628 KiB)
[ 17.462035] UBIFS (ubi1:0): media format: w4/r0 (latest is w4/r0), UUID C9C72D67-21F2-41B3-A70D-289C8E21DC6A, small LPT model
[ 17.977854] autorun-usecase.sh[111]: wifi: in STA mode
_____ _____ _ _
| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
| | _| .'| . | . | | __| _| . | | | -_| _| _|
|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
|___| |___|
Arago Project http://arago-project.org ti81xx ttyS0
Arago 2016.05 ti81xx ttyS0
ti81xx login: [ 18.844958] cfg80211: World regulatory domain updated:
[ 18.850249] cfg80211: DFS Master region: unset
[ 18.854630] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 18.864465] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 18.872527] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 18.880586] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 18.888805] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 18.898545] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 18.908114] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 18.916244] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 18.924303] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 19.678609] wl18xx_driver wl18xx.1.auto: Direct firmware load for ti-connectivity/wl1271-nvs.bin failed with error -2
[ 20.077803] wlcore: wl18xx HW: 183x or 180x, PG 2.2 (ROM 0x11)
[ 20.104822] wlcore: loaded
[ 20.715747] wlcore: PHY firmware version: Rev 8.2.0.0.232
[ 20.792976] random: nonblocking pool is initialized
[ 20.840356] wlcore: firmware booted (Rev 8.9.0.0.48)
[ 20.856824] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 25.121562] autorun-usecase.sh[111]: SSID: Test
[ 25.123394] autorun-usecase.sh[111]: SSID: 35-LAB
[ 25.124827] autorun-usecase.sh[111]: SSID: CTI_test
[ 25.126167] autorun-usecase.sh[111]: SSID: Test
[ 25.127504] autorun-usecase.sh[111]: SSID: Candela
[ 25.128804] autorun-usecase.sh[111]: SSID: HUAWEI-1
[ 25.140409] autorun-usecase.sh[111]: SSID: Test
[ 25.142264] autorun-usecase.sh[111]: SSID: HoneybotTestVIP
[ 25.143904] autorun-usecase.sh[111]: SSID: Candela
[ 25.147994] autorun-usecase.sh[111]: SSID: HP-Print-8D-LaserJet Pro MFP
[ 25.149815] autorun-usecase.sh[111]: SSID: Test
[ 25.151601] autorun-usecase.sh[111]: SSID: Candela
[ 25.158107] autorun-usecase.sh[111]: SSID: Candela
[ 25.167978] autorun-usecase.sh[111]: SSID: SZHUIYU_5G
[ 25.170496] autorun-usecase.sh[111]: SSID: 35-LAB-5G
[ 25.188659] autorun-usecase.sh[111]: SSID: CTI_Test_5G
[ 25.192006] autorun-usecase.sh[111]: SSID:
[ 25.194847] autorun-usecase.sh[111]: SSID: HoneybotTestVIP_5G
[ 25.197217] autorun-usecase.sh[111]: SSID: Candela-5G
[ 25.198923] autorun-usecase.sh[111]: SSID: Test5G
[ 25.200706] autorun-usecase.sh[111]: SSID: Candela-5G
[ 25.202185] autorun-usecase.sh[111]: SSID: Test5G
[ 25.212456] autorun-usecase.sh[111]: SSID: Candela-5G
[ 25.214095] autorun-usecase.sh[111]: SSID: HUAWEI-1_5G
[ 25.216088] autorun-usecase.sh[111]: SSID: CaiWuShi_5G
[ 25.543943] <1>SysLink version : 2.21.02.10
[ 25.543943] SysLink module created on Date:Feb 13 2017 Time:19:16:30
[ 25.554612] <1>Trace enabled
[ 25.557538] <1>Trace SetFailureReason enabled
[ 25.618341] autorun-usecase.sh[111]: /dev/mem opened.
[ 25.620383] autorun-usecase.sh[111]: Phy Addr : 0x48181560 Data : 0x00000002
[ 25.626633] autorun-usecase.sh[111]: Phy Addr : 0x48180f10 Data : 0x00000000
[ 25.635975] autorun-usecase.sh[111]: Phy Addr : 0x48180508 Data : 0x00000302
[ 25.643827] autorun-usecase.sh[111]: Phy Addr : 0x48180520 Data : 0x00000002
[ 25.651663] autorun-usecase.sh[111]: Phy Addr : 0x48180524 Data : 0x00000002
[ 25.656805] autorun-usecase.sh[111]: Phy Addr : 0x48180528 Data : 0x00000002
[ 25.664490] autorun-usecase.sh[111]: Phy Addr : 0x4c0000e4 Data : 0x00170209
[ 25.666295] autorun-usecase.sh[111]: Phy Addr : 0x4c0000e4 Data : 0x00170209
[ 25.667898] autorun-usecase.sh[111]: DDR IOs RX is shutdown
[ 25.669365] autorun-usecase.sh[111]: Phy Addr : 0x48180a04 Data : 0x00000000
[ 26.612838] autorun-usecase.sh[111]: /opt/ipnc/autorun-usecase.sh: line 52: kill: (226) - No such process
[host] Setting DMM priority for [HDVICP0 ] to [1] ( 0x4e000634 = 0x00000009 )
[host] Setting L3 bandwidth regulator for [ISS ] to [press=[3,3] BW=400, WM Cycles=2500]
[host] Setting DMM priority for [ISS ] to [0] ( 0x4e000634 = 0x00080000 )
[host] Setting L3 bandwidth regulator for [HDVICP0 ] to [press=[0,0] BW=900, WM Cycles=2500]
[ 26.717381] autorun-usecase.sh[111]: insmod: ERROR: could not insert module sbull.ko: File exists
[ 27.741827] autorun-usecase.sh[111]: mkfs.fat 3.0.28 (2015-05-16)
[ 27.743576] autorun-usecase.sh[111]: unable to get drive geometry, using default 255/63
[ 27.744923] autorun-usecase.sh[111]: /dev/sbulla has 255 heads and 63 sectors per track,
[ 27.746193] autorun-usecase.sh[111]: hidden sectors 0x0000;
[ 27.747426] autorun-usecase.sh[111]: logical sector size is 512,
[ 27.748751] autorun-usecase.sh[111]: using 0xf8 media descriptor, with 1024 sectors;
[ 27.749997] autorun-usecase.sh[111]: drive number 0x80;
[ 27.764348] autorun-usecase.sh[111]: filesystem has 2 16-bit FATs and 4 sectors per cluster.
[ 27.766436] autorun-usecase.sh[111]: FAT size is 1 sector, and provides 247 clusters.
[ 27.768646] autorun-usecase.sh[111]: There is 1 reserved sector.
[ 27.771583] autorun-usecase.sh[111]: Root directory contains 512 slots and uses 32 sectors.
[ 27.786976] autorun-usecase.sh[111]: Volume ID is 9c0af770, no volume label.
[ 28.006547] Mass Storage Function, version: 2009/09/11
[ 28.011804] LUN: removable file: (no medium)
[ 28.016483] LUN: removable file: /dev/sbulla
[ 28.020855] Number of LUNs=1
[ 28.055791] g_mass_storage gadget: Mass Storage Gadget, version: 2009/09/11
[ 28.062850] g_mass_storage gadget: userspace failed to provide iSerialNumber
[ 28.069972] g_mass_storage gadget: g_mass_storage ready
[ 28.123778] autorun-usecase.sh[111]: Creat queue id:0
[ 28.126153] autorun-usecase.sh[111]: queue id:0
[ 28.129657] autorun-usecase.sh[111]: Creat queue id:32769
[ 28.135790] autorun-usecase.sh[111]: queue id:32769
[ 28.140147] autorun-usecase.sh[111]: Creat queue id:65538
[ 28.146379] autorun-usecase.sh[111]: queue id:65538
[ 28.150667] autorun-usecase.sh[111]: Creat queue id:98307
[ 28.160198] autorun-usecase.sh[111]: queue id:98307
[ 28.165720] autorun-usecase.sh[111]: queue id:32769
[host] Attached to slave procId 1.11]:
[host] Attached to slave procId 0.11]:
[host] Loaded file ./firmware/ipnc_rdk_fw_m3vpss.xem3 on slave procId 1.
[host] Started slave procId 1.sh[111]:
[host] Loaded file ./firmware/ipnc_rdk_fw_m3video.xem3 on slave procId 0.
[host] Started slave procId 0.sh[111]:
[host] After Ipc_loadcallback status [0x00000000]
[host] After Ipc_startcallback status [0x00000000]
[ 30.274557] autorun-usecase.sh[111]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 30.276333] autorun-usecase.sh[111]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 30.277724] autorun-usecase.sh[111]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 30.279036] autorun-usecase.sh[111]: [m3vpss ] Received character 's'
[ 30.372827] autorun-usecase.sh[111]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 30.374711] autorun-usecase.sh[111]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 30.376135] autorun-usecase.sh[111]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 30.377455] autorun-usecase.sh[111]: [m3video] Received character 's'
[ 30.400292] autorun-usecase.sh[111]: queue id:65538
[ 30.402178] autorun-usecase.sh[111]: Creat queue id:131076
[ 30.409559] autorun-usecase.sh[111]: queue id:131076
[ 30.411584] autorun-usecase.sh[111]: CPU is TI812x
[ 30.413213] autorun-usecase.sh[111]: vsenable : 0
[ 30.574265] autorun-usecase.sh[111]: Creat queue id:163845
[ 30.576096] autorun-usecase.sh[111]: queue id:163845
[ 30.577534] autorun-usecase.sh[111]: queue id:65538
[ 30.641866] autorun-usecase.sh[111]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 30.648244] autorun-usecase.sh[111]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 30.653252] autorun-usecase.sh[111]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 30.701081] autorun-usecase.sh[111]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 30.702877] autorun-usecase.sh[111]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 30.714630] autorun-usecase.sh[111]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 30.725473] autorun-usecase.sh[111]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 30.730142] autorun-usecase.sh[111]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 30.740317] autorun-usecase.sh[111]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 30.750138] autorun-usecase.sh[111]: [m3video] ***** SYSTEM : Frequency <ORG> - 200000000, <NEW> - 200000000
[ 30.755477] autorun-usecase.sh[111]: [m3vpss ] ***** SYSTEM : Frequency <ORG> - 200000000, <NEW> - 200000000
[ 30.760164] autorun-usecase.sh[111]: [m3video]
[ 30.766035] autorun-usecase.sh[111]: [m3vpss ] notify_attach rtnVal 0
[ 30.769287] autorun-usecase.sh[111]: [m3video] *** UTILS: CPU KHz = 400000 Khz ***
[ 30.772757] autorun-usecase.sh[111]: [m3video]
[ 30.774653] autorun-usecase.sh[111]: [m3video] 36: SYSTEM : System Common Init in progress !!!
[ 30.776542] autorun-usecase.sh[111]: [m3video] 37: SYSTEM: IPC init in progress !!!
[ 30.778111] autorun-usecase.sh[111]: [m3video] 37: SYSTEM: Attaching to [HOST] ...
[ 30.779791] autorun-usecase.sh[111]: [m3video] 86: SYSTEM: Attaching to [HOST] ...
[ 30.781478] autorun-usecase.sh[111]: [m3vpss ] initProxyServer rtnVal 0
[ 30.783032] autorun-usecase.sh[111]: [m3vpss ]
[ 30.789929] autorun-usecase.sh[111]: [m3vpss ] *** UTILS: CPU KHz = 400000 Khz ***
[ 30.791922] autorun-usecase.sh[111]: [m3vpss ]
[ 30.794411] autorun-usecase.sh[111]: [m3vpss ] 67: SYSTEM : System Common Init in progress !!!
[ 30.796208] autorun-usecase.sh[111]: [m3vpss ] 68: SYSTEM: IPC init in progress !!!
[ 30.798254] autorun-usecase.sh[111]: [m3vpss ] 68: SYSTEM: Attaching to [HOST] ...
[ 30.799975] autorun-usecase.sh[111]: [m3video] 98: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[ 30.801927] autorun-usecase.sh[111]: [m3video] 98: SYSTEM: Attaching to [VPSS-M3] ...
[ 30.803722] autorun-usecase.sh[111]: [m3vpss ] 118: SYSTEM: Attaching to [HOST] ...
[ 30.805275] autorun-usecase.sh[111]: [m3vpss ] 128: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[ 30.806933] autorun-usecase.sh[111]: [m3vpss ] 128: SYSTEM: Attaching to [VIDEO-M3] ...
[ 30.808596] autorun-usecase.sh[111]: [m3video] 147: SYSTEM: Attaching to [VPSS-M3] ...
[ 30.810177] autorun-usecase.sh[111]: [m3video] 178: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
[ 30.811713] autorun-usecase.sh[111]: [m3vpss ] 178: SYSTEM: Attaching to [VIDEO-M3] ...
[ 30.813188] autorun-usecase.sh[111]: [m3video] 179: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[ 30.814706] autorun-usecase.sh[111]: [m3vpss ] 178: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
[ 30.816180] autorun-usecase.sh[111]: [m3vpss ] 179: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[ 30.817805] autorun-usecase.sh[111]: [m3vpss ] 179: SYSTEM: Creating MsgQ [VPSS-M3_MSGQ] ...
[ 30.819410] autorun-usecase.sh[111]: [m3vpss ] 179: SYSTEM: Creating MsgQ [VPSS-M3_ACK_MSGQ] ...
[ 30.820977] autorun-usecase.sh[111]: [m3vpss ] 181: SYSTEM: Notify register to [HOST] line 0, event 12 ...
[ 30.822502] autorun-usecase.sh[111]: [m3vpss ] 181: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ...
[ 30.823979] autorun-usecase.sh[111]: [m3vpss ] 182: SYSTEM: IPC init DONE !!!
[ 30.825488] autorun-usecase.sh[111]: [m3vpss ] 193: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x06900000 (105 MB)
[ 30.827362] autorun-usecase.sh[111]: [m3vpss ] 193: MEM: Shared Region 1: Base = 0x89000000, Length = 0x03b00000 (59 MB)
[ 30.829135] autorun-usecase.sh[111]: [m3vpss ] 195: SYSTEM : System Common Init Done !!!
[ 30.830840] autorun-usecase.sh[111]: [m3video] 278: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[ 30.832369] autorun-usecase.sh[111]: [m3video] 279: SYSTEM: Creating MsgQ [VIDEO-M3_MSGQ] ...
[ 30.833892] autorun-usecase.sh[111]: [m3video] 279: SYSTEM: Creating MsgQ [VIDEO-M3_ACK_MSGQ] ...
[ 30.835381] autorun-usecase.sh[111]: [m3video] 281: SYSTEM: Notify register to [HOST] line 0, event 12 ...
[ 30.836900] autorun-usecase.sh[111]: [m3video] 281: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ...
[ 30.838545] autorun-usecase.sh[111]: [m3video] 282: SYSTEM: IPC init DONE !!!
[ 30.840184] autorun-usecase.sh[111]: [m3video] 292: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x06900000 (105 MB)
[ 30.841734] autorun-usecase.sh[111]: [m3video] 292: MEM: Shared Region 1: Base = 0x89000000, Length = 0x03b00000 (59 MB)
[ 30.843216] autorun-usecase.sh[111]: [m3video] 295: SYSTEM : System Common Init Done !!!
[ 30.844684] autorun-usecase.sh[111]: [m3vpss ] 595: SYSTEM : System VPSS Init in progress !!!
[ 30.846158] autorun-usecase.sh[111]: [m3vpss ] === I2C0/2 Clk is active ===
[ 30.847759] autorun-usecase.sh[111]: [m3vpss ] PLATFORM: UNKNOWN CPU detected, defaulting to VPS_PLATFORM_CPU_REV_1_0
[ 30.849335] autorun-usecase.sh[111]: [m3vpss ] PLATFORM: UNKNOWN CPU detected, defaulting to ISS_PLATFORM_CPU_REV_2_1
[ 30.850924] autorun-usecase.sh[111]: [m3vpss ] 614: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_0] in region 0 ...
[ 30.852435] autorun-usecase.sh[111]: [m3vpss ] 614: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_0] in region 0 ...
[ 30.853958] autorun-usecase.sh[111]: [m3vpss ] 614: SYSTEM: ListElem Shared Addr = 0xbe984180
[ 30.855434] autorun-usecase.sh[111]: [m3vpss ] 617: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_1] in region 0 ...
[ 30.856898] autorun-usecase.sh[111]: [m3vpss ] 617: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_1] in region 0 ...
[ 31.189899] autorun-usecase.sh[111]: [m3vpss ] 617: SYSTEM: ListElem Shared Addr = 0xbe987680
[ 31.191780] autorun-usecase.sh[111]: [m3vpss ] 631: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_24] in region 0 ...
[ 31.193467] autorun-usecase.sh[111]: [m3vpss ] 631: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_24] in region 0 ...
[ 31.195061] autorun-usecase.sh[111]: [m3vpss ] 631: SYSTEM: ListElem Shared Addr = 0xbe98ab80
[ 31.196559] autorun-usecase.sh[111]: [m3vpss ] 634: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_25] in region 0 ...
[ 31.198049] autorun-usecase.sh[111]: [m3vpss ] 634: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_25] in region 0 ...
[ 31.199558] autorun-usecase.sh[111]: [m3vpss ] 634: SYSTEM: ListElem Shared Addr = 0xbe9aa580
[ 31.201163] autorun-usecase.sh[111]: [m3vpss ] 637: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_26] in region 0 ...
[ 31.202665] autorun-usecase.sh[111]: [m3vpss ] 637: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_26] in region 0 ...
[ 31.204318] autorun-usecase.sh[111]: [m3vpss ] 638: SYSTEM: ListElem Shared Addr = 0xbe9c9f80
[ 31.207911] autorun-usecase.sh[111]: [m3vpss ] 644: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_29] in region 0ApproDrvInit: 7
[ 31.209514] autorun-usecase.sh[111]: queue id:163845
[ 34.095237] autorun-usecase.sh[111]: ...
[ 34.097116] autorun-usecase.sh[111]: [m3vpss ] 644: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_29] in region 0 ...
[ 34.098546] autorun-usecase.sh[111]: [m3vpss ] 644: SYSTEM: ListElem Shared Addr = 0xbe9e9980
[ 34.099909] autorun-usecase.sh[111]: [m3vpss ] 647: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_30] in region 0 ...
[ 34.101898] autorun-usecase.sh[111]: [m3vpss ] 647: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_30] in region 0 ...
[ 34.103551] autorun-usecase.sh[111]: [m3vpss ] 647: SYSTEM: ListElem Shared Addr = 0xbea03600
[ 34.105336] autorun-usecase.sh[111]: [m3vpss ] 649: SYSTEM : HDVPSS Drivers Version: HDVPSS_01_00_01_37
[ 34.106986] autorun-usecase.sh[111]: [m3vpss ] 650: SYSTEM : FVID2 Init in progress !!!
[ 34.108541] autorun-usecase.sh[111]: [m3video] 694: SYSTEM : System Video Init in progress !!!
[ 34.110190] autorun-usecase.sh[111]: [m3video] 695: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_0] in region 0 ...
[ 34.111897] autorun-usecase.sh[111]: [m3video] 695: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_0] in region 0 ...
[ 34.113501] autorun-usecase.sh[111]: [m3video] 696: SYSTEM: ListElem Shared Addr = 0xbea1d280
[ 34.115212] autorun-usecase.sh[111]: [m3video] 698: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_1] in region 0 ...
[ 34.116904] autorun-usecase.sh[111]: [m3video] 698: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_1] in region 0 ...
[ 34.118457] autorun-usecase.sh[111]: [m3video] 699: SYSTEM: ListElem Shared Addr = 0xbea20780
[ 34.120084] autorun-usecase.sh[111]: [m3video] 708: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_29] in region 0 ...
[ 34.121712] autorun-usecase.sh[111]: [m3video] 709: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_29] in region 0 ...
[ 34.123349] autorun-usecase.sh[111]: [m3video] 709: SYSTEM: ListElem Shared Addr = 0xbea23c80
[ 34.125047] autorun-usecase.sh[111]: [m3video] 711: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_30] in region 0 ...
[ 34.126728] autorun-usecase.sh[111]: [m3video] 712: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_30] in region 0 ...
[ 34.128391] autorun-usecase.sh[111]: [m3video] 712: SYSTEM: ListElem Shared Addr = 0xbea3d900
[ 34.129991] autorun-usecase.sh[111]: [m3video] 714: HDVICP: Doing PRCM for IVAHD[0] ...
[ 34.132510] autorun-usecase.sh[111]: [m3video] 714: HDVICP: PRCM for IVAHD[0] ... DONE.
[ 34.134158] autorun-usecase.sh[111]: [m3video] 715: SYSTEM : Initializing Links !!!
[ 34.135937] autorun-usecase.sh[111]: [m3vpss ] 721: SYSTEM : FVID2 Init in progress DONE !!!
[ 34.137535] autorun-usecase.sh[111]: [m3vpss ] 721: SYSTEM : Device Init in progress !!!
[ 34.139225] autorun-usecase.sh[111]: [m3video] 715: SYSTEM : FREE SPACE : System Heap = 2088976 B, Mbx = 10240 msgs)
[ 34.140891] autorun-usecase.sh[111]: [m3vpss ] Iss_init called !!!!!!
[ 34.142553] autorun-usecase.sh[111]: [m3video] 716: SYSTEM : FREE SPACE : SR0 Heap = 15372416 B (14 MB)
[ 34.144126] autorun-usecase.sh[111]: [m3vpss ] CPIS_init DONE !!!!!!
[ 34.145868] autorun-usecase.sh[111]: [m3video] 716: SYSTEM : FREE SPACE : Frame Buffer = 110100352 B (104 MB)
[ 34.147461] autorun-usecase.sh[111]: [m3vpss ] initPrms.isI2cInitReq = 1
[ 34.149195] autorun-usecase.sh[111]: [m3video] 716: SYSTEM : FREE SPACE : Bitstream Buffer = 61865856 B (58 MB)
[ 34.150930] autorun-usecase.sh[111]: [m3vpss ] initPrms.isI2cInitReq = 0
[ 34.152602] autorun-usecase.sh[111]: [m3video] 717: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
[ 34.154227] autorun-usecase.sh[111]: [m3video] 718: SYSTEM : FREE SPACE : Tiler Buffer = 128 B (0 MB) - TILER OFF
[ 34.156036] autorun-usecase.sh[111]: [m3video] Entered the MctnfLink_init()
[ 34.157635] autorun-usecase.sh[111]: [m3video] 776: SYSTEM : Initializing Links ... DONE !!!
[ 34.159269] autorun-usecase.sh[111]: [m3video] 777: SYSTEM : System Video Init Done !!!
[ 34.160949] autorun-usecase.sh[111]: [m3vpss ] Vps_deviceInit Daughter card not detected/connected!
[ 34.162659] autorun-usecase.sh[111]: [m3vpss ] 915: SYSTEM : Device Init in progress DONE !!!
[ 34.164253] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:0
[ 34.166025] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:2
[ 34.167658] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:3
[ 34.169283] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:4
[ 34.170909] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:6
[ 34.172563] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:8
[ 34.174127] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:10
[ 34.175840] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:12
[ 34.177475] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:14
[ 34.179151] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:16
[ 34.180779] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:18
[ 34.182416] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:20
[ 34.514914] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:22
[ 34.516526] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:24
[ 34.518139] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:26
[ 34.519859] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:28
[ 34.521535] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:30
[ 34.523190] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:32
[ 34.524768] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:34
[ 34.526359] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:36
[ 34.527994] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:38
[ 34.529665] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:40
[ 34.531376] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:42
[ 34.532986] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:44
[ 34.534586] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:46
[ 34.536221] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:48
[ 34.537902] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:50
[ 34.539546] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:52
[ 34.541270] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:54
[ 34.541814] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:56
[ 34.542383] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:58
[ 34.542858] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:60
[ 34.543364] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:62
[ 34.543818] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:64
[ 34.544298] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:66
[ 34.544752] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:68
[ 34.545187] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:70
[ 34.545693] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:72
[ 34.546134] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:74
[ 34.546627] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:76
[ 34.547101] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:78
[ 34.547533] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:80
[ 36.116121] autorun-usecase.sh[111]: [m3vpss ] I2C write Equeue id:0
[ 36.232165] autorun-usecase.sh[111]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 36.232829] autorun-usecase.sh[111]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 36.233236] autorun-usecase.sh[111]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 36.234052] autorun-usecase.sh[111]: [m3vpss ] Received character 't'
[ 36.253657] autorun-usecase.sh[111]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 36.254334] autorun-usecase.sh[111]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 36.254752] autorun-usecase.sh[111]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 36.255113] autorun-usecase.sh[111]: [m3video] Received character 't'
[ 36.282252] autorun-usecase.sh[111]: rmmod: ERROR: Module osa_kermod is not currently loaded
[ 36.346668] DMA: Module install successful, device major num = 244
[ 36.353062] DRV: Module install successful
[ 36.357209] DRV: Module built on Feb 13 2017 19:26:20
[ 36.426721]
[ 36.426721] soc_is_dm38x
[ 36.494557] HDMI W1 rev 4.0
[ 36.497452] HDMI CEC Spec version 1.2
[ 36.877142] I2C No Ack
[ 36.879642] HDMI failed to read E-EDID
[host]368392] autorun-usecase.sh[111]:
[host] ORG 0x46c00524: 0case.sh[111]:
[host] NEW 0x46c00524: 2case.sh[111]:
[host]370379] autorun-usecase.sh[111]:
[host] Application Start Completed11]:
[host] 0: SYSTEM: System Common Init in progress !!!
[host] 0: SYSTEM: IPC init in progress !!!
[host] 10: SYSTEM: CPU [DSP] is NOT available on this platform !!!
[ 37.523595] DMA: ChannelID allocated:4nk proc ID is [0] !!!
[host] 11: SYSTEM: C[ 37.536322] DMA: ChannelID allocated:5
PU [VPSS-M3] syslink proc ID is [1] !!!
[host] 12: SYSTEM: CPU [HOST] syslink proc ID is [2] !!!
[host] 12: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[host] 14: SYSTEM: Creating MsgQ [HOST_MSGQ] ...
[host] 14: SYSTEM: Creating MsgQ [HOST_ACK_MSGQ] ...
[host] 14: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
[host] 15: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
[host] 16: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ...
[host] 16: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ...
[host] 16: SYSTEM: IPC init DONE !!!:
[host] 19: SYSTEM: Creating ListMP [HOST_IPC_OUT_29] in region 0 ...
[host] 19: SYSTEM: Creating ListMP [HOST_IPC_IN_29] in region 0 ...
[host] 19: SYSTEM: ListElem Shared Addr = 0xb55f8580
[host] 20: SYSTEM: Creating ListMP [HOST_IPC_OUT_30] in region 0 ...
[host] 20: SYSTEM: Creating ListMP [HOST_IPC_IN_30] in region 0 ...
[host] 20: SYSTEM: ListElem Shared Addr = 0xb5612200
[host] 24: SYSTEM: Creating ListMP [HOST_IPC_OUT_24] in region 0 ...
[host] 24: SYSTEM: Creating ListMP [HOST_IPC_IN_24] in region 0 ...
[host] 25: SYSTEM: ListElem Shared Addr = 0xb562be80
[host] 26: SYSTEM: Creating ListMP [HOST_IPC_OUT_25] in region 0 ...
[host] 26: SYSTEM: Creating ListMP [HOST_IPC_IN_25] in region 0 ...
[host] 26: SYSTEM: ListElem Shared Addr = 0xb564b880
[host] 28: SYSTEM: Creating ListMP [HOST_IPC_OUT_26] in region 0 ...
[host] 28: SYSTEM: Creating ListMP [HOST_IPC_IN_26] in region 0 ...
[host] 28: SYSTEM: ListElem Shared Addr = 0xb566b280
[host] 31: SYSTEM: System Common Init Done !!!
[host] Vsys_allocBuf - addr = 0xa73a1000,size = 65011712
[ 37.517956] autorun-usecase.sh[111]: ##########pInfo->totalsize 63897600
[host] MemMng_memcpy_open:OSA_dmaOpen passed with ch id = 4
[host] CacheMng_MemCpy_open:OSA_dmaOpen passed with ch id = 5
[host] MCFW_IPCFRAMES:App_ipcFramesSendRecvFxn:Entered...
[host] Vsys_allocBuf - addr = 0xb6f34000,size = 33603
[host] DCC buffer allocated for size 33603
[host] DCC Default File Intialization Done
[host] Before System_linkControl SYSTEM_M3VPSS_CMD_GET_DISPLAYCTRL_INIT
[host]606683] autorun-usecase.sh[111]:
[ 37.607841] autorun-usecase.sh[111]: ********** FULL FEATURE USECASE ********
[host] ********* Entered Tri Streaming usecase - H264 1080p @60fps + H264 D1 @30fps + MJPEG 1080p @5fps ********
[host] 138: MCFW : CPU Revision [ES1.0] !!!
[host] 138: MCFW : Detected [UNKNOWN] Board !!!
[host] 138: MCFW : Base Board Revision [REV A] !!!
[ 37.920605] autorun-usecase.sh[111]: rror,index:82
[ 37.921312] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:84
[ 37.921866] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:86
[ 37.922400] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:88
[ 37.922876] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:89
[ 37.923405] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:91
[ 37.923855] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:93
[ 37.924369] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:95
[ 37.925078] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:97
[ 37.925631] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:99
[ 37.926089] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:101
[ 37.926617] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:103
[ 37.927079] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:105
[ 37.927581] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:107
[ 37.928070] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:109
[ 37.928563] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:110
[ 37.929019] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:112
[ 37.929460] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:114
[ 37.929970] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:116
[ 37.930683] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:118
[ 37.931212] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:120
[ 37.931661] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:122
[ 37.932184] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:124
[ 37.932632] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:126
[ 37.933135] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:128
[ 37.933616] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:130
[ 37.934104] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:132
[ 37.934560] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:134
[ 37.935010] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:136
[ 37.935526] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:138
[ 37.935979] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:140
[ 37.936479] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:142
[ 37.936929] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:144
[ 37.937410] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:146
[ 37.937861] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:148
[ 37.938308] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:150
[ 37.938847] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:152
[ 37.939300] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:154
[ 37.939803] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:156
[ 37.940305] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:158
[ 37.940940] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:160
[ 37.941409] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:162
[ 37.941919] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:163
[ 37.942373] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:164
[ 37.942820] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:166
[ 37.943329] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:168
[ 37.943772] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:170
[ 37.944282] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:171
[ 37.944759] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:173
[ 37.945260] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:175
[ 37.945702] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:177
[ 37.946183] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:179
[ 37.946633] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:181
[ 37.947077] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:183
[ 37.947593] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:185
[ 37.948041] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:187
[ 37.948613] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:189
[ 37.949094] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:191
[ 38.280690] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:193
[ 38.281180] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:195
[ 38.281562] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:197
[ 38.281917] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:199
[ 38.282248] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:201
[ 38.282569] autorun-usecase.sh[111]: [m3vpss ] I2C write Error,index:203
[ 38.282889] autorun-usecase.sh[111]: [m3vpss ] DONE ar0331_lvds/src/issdrv_ar0331Api.c:AR0331_Transplant_DRV_imgsSetRegs:705 !!!
[ 38.283215] autorun-usecase.sh[111]: [m3vpss ] 6023: SYSTEM : System VPSS Init Done !!!
[ 38.283541] autorun-usecase.sh[111]: [m3vpss ] 6024: UTILS: DMA: HWI Create for INT62 !!!
[ 38.285012] autorun-usecase.sh[111]: [m3vpss ] 6024: SYSTEM : Initializing Links !!!
[ 38.285701] autorun-usecase.sh[111]: [m3vpss ] 6024: SYSTEM : FREE SPACE : System Heap = 1682768 B, Mbx = 10240 msgs)
[ 38.286208] autorun-usecase.sh[111]: [m3vpss ] 6024: SYSTEM : FREE SPACE : SR0 Heap = 15372416 B (14 MB)
[ 38.286767] autorun-usecase.sh[111]: [m3vpss ] 6025: SYSTEM : FREE SPACE : Frame Buffer = 105790336 B (100 MB)
[ 38.287235] autorun-usecase.sh[111]: [m3vpss ] 6025: SYSTEM : FREE SPACE : Bitstream Buffer = 61865856 B (58 MB)
[ 38.287754] autorun-usecase.sh[111]: [m3vpss ] 6025: SYSTEM : FREE SPACE : Tiler Buffer [ 38.456647] DMA: ChannelID allocated:6
[ 38.288210] autorun-usecase.sh[1[ 38.463400] DMA: ChannelID allocated:7
11]: [m3vpss ] 6156: SYSTEM : Initializing Links ... DONE !!!
[ 38.288699] autorun-usecase.sh[111]: [m3vpss ] tiedVencs VPS_DC_VENC_HDMI | VPS_DC_VENC_HDCOMP
[ 38.289160] autorun-usecase.sh[111]: [m3vpss ] VPS_DCTRL_INST_0
[ 38.289607] autorun-usecase.sh[111]: [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_DVO2
[ 38.290168] autorun-usecase.sh[111]: [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_HDMI
[ 38.290636] autorun-usecase.sh[111]: [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_SD
[ 38.291189] autorun-usecase.sh[111]: [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_HDCOMP
[ 38.291658] autorun-usecase.sh[111]: [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_CLK_SRC VPS_DC_VENC_HDMI | VPS_DC_VENC_HDCOMP
[ 38.292170] autorun-usecase.sh[111]: [m3vpss ] HDCOMPC[ 38.541742] DMA: ChannelID allocated:12
LK
[ 38.292623] autorun-usecase.sh[111]: [m3vpss ] 7470: CAMERA: Create in progress !!!
[ 38.293109] autorun-usecase.sh[111]: [m3vpss ] Channel Num Stream 0 Ch 0 ChannelNum 0
[ 38.293566] autorun-usecase.sh[111]: [m3vpss ] Channel Num Stream 1 Ch 0 ChannelNum 1
[ 38.294212] autorun-usecase.sh[111]: [m3vpss ] 7470: CAMERA: VIP0 PortA camera mode is [ 8-bit, Non-mux Embedded Sync] !!!
[ 38.294689] autorun-usecase.sh[111]: [m3vpss ] 7471: CAMERA: VIP 0: VID DEC 268436737 (0x10): 0002:20202020:20202020, AUD_STATUS 538976288
[ 38.295144] autorun-usecase.sh[111]: [m3vpss ] Iss_captCreate:1661
[ 38.295659] autorun-usecase.sh[111]: [m3vpss ] 7684: CAMERA: Create Done !!!
[ 38.296102] autorun-usecase.sh[111]: [m3vpss ] 7774: CAMERA: Detect video in progress !!!
[ 38.296600] autorun-usecase.sh[111]: [m3vpss ] 7774: CAMERA: Detect video Done !!!
[ 38.297079] autorun-usecase.sh[111]: [m3vpss ] 7847: DUP : Create Done !!!
[ 38.297729] autorun-usecase.sh[111]: [m3vpss ] 7847: IPC_ApproDrvInit: 3
[ 38.298215] autorun-usecase.sh[111]: queue id:163845
[ 38.298731] autorun-usecase.sh[111]: queue id:0
[ 38.299190] autorun-usecase.sh[111]: queue id:32769
[host] Vsys_eventHandler:OSA_dmaOpen passed with ch id = 6
[host] Vsys_eventHandler:OSA_dmaOpen passed with ch id = 7
[host] Vsys_eventHandler:OSA_dmaOpen passed with ch id = 12
[host] IpcBitsInLink_tskMain:Entered]:
[host] 1376: IPC_BITS_IN : Create in progress !!!
[host] 1376: IPC_BITS_IN : ListMPOpen start !!!
[host] 1376: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_29] ...
[host] 1377: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_29] ...
[host] 1377: IPC_BITS_IN : ListMPOpen done !!!
[host] 1378: IPC_BITS_IN : System_linkGetInfo done !!!
[host] 1378: IPC_BITS_IN : Create Done !!!
[host] USECASE SETUP DONEcase.sh[111]:
[ 38.855035] autorun-usecase.sh[111]: OUT_M3 : Create in progress !!!
[ 38.855675] autorun-usecase.sh[111]: [m3vpss ] 7849: IPC_OUT_M3 : Create Done !!!
[ 38.856186] autorun-usecase.sh[111]: [m3video] 7849: IPC_IN_M3 : Create in progress !!!
[ 38.856727] autorun-usecase.sh[111]: [m3vpss ] DCC server task running
[ 38.857193] autorun-usecase.sh[111]: [m3video] 7849: SYSTEM: Opening ListMP [VPSS-M3_IPC_OUT_1] ...
[ 38.857694] autorun-usecase.sh[111]: [m3video] 7850: SYSTEM: Opening ListMP [VPSS-M3_IPC_IN_1] ...
[ 38.858161] autorun-usecase.sh[111]: [m3video] 7853: IPC_IN_M3 : Create Done !!!
[ 38.858610] autorun-usecase.sh[111]: [m3video] Entered the MctnfLink_tskMain()
[ 38.859164] autorun-usecase.sh[111]: [m3video] inChInfo->width = 1920
[ 38.859625] autorun-usecase.sh[111]: [m3video] inChInfo->height = 1080
[ 38.860188] autorun-usecase.sh[111]: [m3video] inChInfo->pitch[0] = 1984
[ 38.860668] autorun-usecase.sh[111]: [m3video] MCTNF Algorithm Instance Creation for the Module MCTNF_TI DEV.500.V.MCTNF.IVAHD.00.13.01.00 Done...
[ 38.861187] autorun-usecase.sh[111]: [m3video] [MCTNF] startX = 0
[ 38.861642] autorun-usecase.sh[111]: [m3vpss ] 8036: IPC_IN_M3 : Create in progress !!!
[ 38.862255] autorun-usecase.sh[111]: [m3video] [MCTNF] startY = 0
[ 38.862770] autorun-usecase.sh[111]: [m3vpss ] 8036: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_0] ...
[ 38.863242] autorun-usecase.sh[111]: [m3video] [MCTNF] outChInfo->width = 1920
[ 38.863773] autorun-usecase.sh[111]: [m3vpss ] 8037: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_0] ...
[ 38.864234] autorun-usecase.sh[111]: [m3video] [MCTNF] outChInfo->height = 1080
[ 38.864771] autorun-usecase.sh[111]: [m3vpss ] 8038: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
[ 38.865650] autorun-usecase.sh[111]: [m3video] [MCTNF] outChInfo->pitch[0] = 1984
[ 38.866176] autorun-usecase.sh[111]: [m3vpss ] 8040: IPC_IN_M3 : Create Done !!!
[ 38.866651] autorun-usecase.sh[111]: [m3video] [MCTNF] outChInfo->pitch[1] = 1984
[ 38.867177] autorun-usecase.sh[111]: [m3video] 8034: IPC_OUT_M3 : Create in progress !!!
[ 38.867637] autorun-usecase.sh[111]: [m3vpss ] 7974: VNF:
[ 38.868155] autorun-usecase.sh[111]: [m3vpss ] Create in progress ... !!!
[ 38.868606] autorun-usecase.sh[111]: [m3video] 8035: IPC_OUT_M3 : Create Done !!!
[ 38.869103] autorun-usecase.sh[111]: [m3vpss ] 7975: VNF:
[ 38.869557] autorun-usecase.sh[111]: [m3vpss ] Input Channel CH0 of 1920 x 1080, pitch = (1984, 1984) [0,0][PROGRESSIVE] [7] ...
[ 38.870110] autorun-usecase.sh[111]: [m3vpss ] 7975: VNF:
[ 38.870777] autorun-usecase.sh[111]: [m3vpss ] [VNF] eOperateMode=7 [6-TNF3,7-NSF2]chVnfCreateParams->ulStartX = -16 chVnfCreateParams->ulStartY = -18 chVnfCreateParams->ulInputStride = 1984 chVnfCreateParams->ulInputWidth=1952,chVnfCreateParams->ulInputHeight=1112
[ 38.871359] autorun-usecase.sh[111]: [m3vpss ] 8145: VNF:
[ 38.871839] autorun-usecase.sh[111]: [m3vpss ] [VNF] outChInfo->StartX = 0 outChInfo->startY = 0 outChInfo->pitch[0] = 1920 outChInfo->width=1920,outChInfo->height=1080
[ 38.872350] autorun-usecase.sh[111]: [m3vpss ] 8147: VNF:
[ 38.872804] autorun-usecase.sh[111]: [m3vpss ] Create ... DONE !!!
[ 38.873470] autorun-usecase.sh[111]: [m3vpss ] 8214: NSF: Create in progress !!!
[ 38.874016] autorun-usecase.sh[111]: [m3vpss ] NSF::HEAPID:0 USED:128
[ 38.874497] autorun-usecase.sh[111]: [m3vpss ] NSF::HEAPID:1 USED:4928
[ 38.875177] autorun-usecase.sh[111]: [m3vpss ] 8339: NSF: Create Done !!!
[ 39.206279] autorun-usecase.sh[111]: [m3vpss ] 8339: Mux : Creating... !!!
[ 39.207093] autorun-usecase.sh[111]: [m3vpss ] 8341: WARNING MUX Link : Ignoring channel no 0 of Input Q ID 0. As this channel was not mapped !!!
[ 39.207807] autorun-usecase.sh[111]: [m3vpss ] 8342: Mux : Create Done !!!
[ 39.208384] autorun-usecase.sh[111]: [m3vpss ] 8348: DUP : Create Done !!!
[ 39.208876] autorun-usecase.sh[111]: [m3vpss ] 8355: DUP : Create Done !!!
[ 39.209609] autorun-usecase.sh[111]: [m3vpss ] 8356: Mux : Creating... !!!
[ 39.210166] autorun-usecase.sh[111]: [m3vpss ] 8358: Mux : Create Done !!!
[ 39.210701] autorun-usecase.sh[111]: [m3vpss ] {SWOSD} edma3Handle->tccVal = 36
[ 39.211206] autorun-usecase.sh[111]: [m3vpss ] {SWOSD} edma3Handle->chId = 36
[ 39.211677] autorun-usecase.sh[111]: [m3vpss ] {SWOSD} edma3Handle->tccVal = 37
[ 39.212200] autorun-usecase.sh[111]: [m3vpss ] {SWOSD} edma3Handle->chId = 37
[ 39.212658] autorun-usecase.sh[111]: [m3vpss ] {SWOSD} edma3Handle->tccVal = 38
[ 39.213171] autorun-usecase.sh[111]: [m3vpss ] {SWOSD} edma3Handle->chId = 38
[ 39.213619] autorun-usecase.sh[111]: [m3vpss ] 8367: SYSTEM: Opening MsgQ [HOST_MSGQ] ...
[ 39.214113] autorun-usecase.sh[111]: [m3vpss ] 8369: SWOSD : Create Done !!!
[ 39.214571] autorun-usecase.sh[111]: [m3vpss ] 8442: DUP : Create Done !!!
[ 39.215020] autorun-usecase.sh[111]: [m3vpss ] 8443: SCLR: Create in progress !!!
[ 39.215531] autorun-usecase.sh[111]: [m3vpss ] 8448: SCLR : Loading Up-scaling Co-effs ...
[ 39.216154] autorun-usecase.sh[111]: [m3vpss ] 8448: SCLR : Co-effs Loading ... DONE !!!
[ 39.216741] autorun-usecase.sh[111]: [m3video] 8465: IPC_IN_M3 : Create in progress !!!
[ 39.217224] autorun-usecase.sh[111]: [m3video] 8465: SYSTEM: Opening ListMP [VPSS-M3_IPC_OUT_0] ...
[ 39.217753] autorun-usecase.sh[111]: [m3vpss ] SCLR:HEAPID:0 USED:64
[ 39.218213] autorun-usecase.sh[111]: [m3video] 8465: SYSTEM: Opening ListMP [VPSS-M3_IPC_IN_0] ...
[ 39.218738] autorun-usecase.sh[111]: [m3vpss ] SCLR:HEAPID:1 USED:5952
[ 39.219244] autorun-usecase.sh[111]: [m3video] 8468: IPC_IN_M3 : Create Done !!!
[ 39.219750] autorun-usecase.sh[111]: [m3vpss ] 8449: SCLR: Create Done !!!
[ 39.220259] autorun-usecase.sh[111]: [m3video] 8468: ENCODE: Create in progress ... !!!
[ 39.220769] autorun-usecase.sh[111]: [m3vpss ] 8396: FD : Alg Create Done !!!
[ 39.221232] autorun-usecase.sh[111]: [m3vpss ] 8396: FD : Create Done !!!
[ 39.221680] autorun-usecase.sh[111]: [m3vpss ] 8463: IPC_OUT_M3 : Create in progress !!!
[ 39.222190] autorun-usecase.sh[111]: [m3vpss ] 8464: IPC_OUT_M3 : Create Done !!!
[ 39.222677] autorun-usecase.sh[111]: [m3video] 8595: ENCODE: Creating CH0 of 1920 x 1080, pitch = (1920, 1920) [PROGRESSIVE] [NON-TILED ], bitrate = 8000 Kbps ...
[ 39.223198] autorun-usecase.sh[111]: [m3video] ENCLINK_H264:HEAPID:0 USED:11720
[ 39.223661] autorun-usecase.sh[111]: [m3video] 8679: ENCODE: Creating CH1 of 720 x 480, pitch = (720, 720) [PROGRESSIVE] [NON-TILED ], bitrate = 8000 Kbps ...
[ 39.224340] autorun-usecase.sh[111]: [m3vpss ] 8775: DISPLAY: Create in progress !!!
[ 39.224830] autorun-usecase.sh[111]: [m3video] ENCLINK_H264:HEAPID:0 USED:11720
[ 39.225351] autorun-usecase.sh[111]: [m3vpss ] DisplayId = 1,DataFormat = 7
[ 39.225979] autorun-usecase.sh[111]: [m3video] 8765: ENCODE: Creating CH2 of 1920 x 1080, pitch
[host]226558] autorun-usecase.sh[111]:
[ 39.227043] autorun-usecase.sh[111]: Application Run Completed
[host] ITT server task running !!!11]:
[host]228060] autorun-usecase.sh[111]:
[ 39.228556] autorun-usecase.sh[111]: ITT ittServer_run
[host] ITT Server Message initialization successful
[host]229586] autorun-usecase.sh[111]:
[ 39.230103] autorun-usecase.sh[111]: ITT capture task created
[host] DCC server Message ques is open succefully
[host] Setting cmd <1> in message <b54a4c00>
[host] Posting message <b54a4c00> in QId <10002>
[host] Response from M3 is : 1sh[111]:
[host] Default parameters were sent sucessfully
[host] Server Socket created with ID <22>
[ 40.138077] autorun-usecase.sh[111]: queue id:0
[ 56.117972] autorun-usecase.sh[111]: TimeOut occure in boot_proc.
[ 56.118766] autorun-usecase.sh[111]: Program exit.
[ 60.140213] autorun-usecase.sh[111]: TimeOut occure in boot_proc.
[ 60.140968] autorun-usecase.sh[111]: Program exit.
[host]252780] autorun-usecase.sh[111]:
[ 69.253589] autorun-usecase.sh[111]: Usecase is Active !!!
[host]254994] autorun-usecase.sh[111]:
[ 100.255781] autorun-usecase.sh[111]: Usecase is Active !!!
[ 105.997341] autorun-usecase.sh[111]: ApproDrvExit: 7
[ 105.998101] autorun-usecase.sh[111]: Error: WaitStreamReady Fail.
[ 106.002297] autorun-usecase.sh[111]: Error: SemWait: Invalid Semaphore handler
[host]006258] autorun-usecase.sh[111]:
[ 106.007177] autorun-usecase.sh[111]: Force IDR on Channel: 0
[host]007886] autorun-usecase.sh[111]:
[ 106.009409] autorun-usecase.sh[111]: Force IDR on Channel: 1Error: SemRelease: Invalid Semaphore handler
[ 106.073302] sh (350): drop_caches: 1
[ 106.171988] autorun-usecase.sh[111]: umount: can't unmount /mnt/mmc: Invalid argument
[ 106.230739] autorun-usecase.sh[111]: mount: /dev/mmcblk0 is already mounted or /mnt/mmc busy
[ 106.282889] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 106.476867] autorun-usecase.sh[111]: killall: dhcpcd: no process killed
[ 107.014624] Mass Storage Function, version: 2009/09/11
[ 107.019899] LUN: removable file: (no medium)
[ 107.024483] LUN: removable file: /dev/sbulla
[ 107.028831] Number of LUNs=1
[ 107.048135] g_mass_storage gadget: Mass Storage Gadget, version: 2009/09/11
[ 107.055186] g_mass_storage gadget: userspace failed to provide iSerialNumber
[ 107.062318] g_mass_storage gadget: g_mass_storage ready
[ 107.078507] autorun-usecase.sh[111]: [05/Dec/2016:07:39:55 +0000] boa: server version Boa/0.94.13
[ 107.079296] autorun-usecase.sh[111]: [05/Dec/2016:07:39:55 +0000] boa: server built Feb 13 2017 at 19:21:10.
[ 107.079818] autorun-usecase.sh[111]: [05/Dec/2016:07:39:55 +0000] boa: starting server pid=344, port 80
[ 107.246528] autorun-usecase.sh[111]: queue id:0
[ 107.530820] autorun-usecase.sh[111]: queue id:131076
[ 107.534165] autorun-usecase.sh[111]: ApproDrvInit: 10
[ 107.535505] autorun-usecase.sh[111]: queue id:163845
[ 107.541510] autorun-usecase.sh[111]: ApproDrvInit: 6
[ 107.543212] autorun-usecase.sh[111]: ApproDrvInit: 2
[ 107.545071] autorun-usecase.sh[111]: ApproDrvInit: 8
[ 107.548072] autorun-usecase.sh[111]: Initializing...
[ 107.571663] autorun-usecase.sh[111]: ApproDrvInit: 9
[ 107.579264] autorun-usecase.sh[111]: queue id:163845
[ 107.581571] autorun-usecase.sh[111]: queue id:163845
[ 107.585653] autorun-usecase.sh[111]: queue id:163845
[ 107.587407] autorun-usecase.sh[111]: ...done initializing
[ 107.588476] autorun-usecase.sh[111]: queue id:163845
[ 107.589462] autorun-usecase.sh[111]: Initializing...
[ 107.590269] autorun-usecase.sh[111]: ...done initializing
[ 107.590922] autorun-usecase.sh[111]: Play this stream using the URL:
[ 107.598837] autorun-usecase.sh[111]: rtsp://192.168.115.204:8556/PSIA/Streaming/channels/2?videoCodecType=H.264
[ 107.599730] autorun-usecase.sh[111]: (We use port 8303 for optional RTSP-over-HTTP tunneling.)
[ 107.600711] autorun-usecase.sh[111]: Initializing...
[ 107.601414] autorun-usecase.sh[111]: ...done initializing
[ 107.602120] autorun-usecase.sh[111]: Initializing...
[ 107.602746] autorun-usecase.sh[111]: Initializing...
[ 107.603399] autorun-usecase.sh[111]: ...done initializing
[ 107.604026] autorun-usecase.sh[111]: Play this stream using the URL:
[ 107.604659] autorun-usecase.sh[111]: rtsp://192.168.115.204:8554/PSIA/Streaming/channels/1?videoCodecType=MPEG4
[ 107.605278] autorun-usecase.sh[111]: (We use port 8301 for optional RTSP-over-HTTP tunneling.)
[ 107.605916] autorun-usecase.sh[111]: ...done initializing
[ 107.606700] autorun-usecase.sh[111]: Play this stream using the URL:
[ 107.607795] autorun-usecase.sh[111]: rtsp://192.168.115.204:8555/PSIA/Streaming/channels/0?videoCodecType=MJPEG
[ 107.608635] autorun-usecase.sh[111]: (We use port 8302 for optional RTSP-over-HTTP tunneling.)
[ 107.609781] autorun-usecase.sh[111]: Play this stream using the URL:
[ 107.610794] autorun-usecase.sh[111]: rtsp://192.168.115.204:8553/PSIA/Streaming/channels/1?videoCodecType=MPEG4
[ 107.611537] autorun-usecase.sh[111]: (We use port 8300 for optional RTSP-over-HTTP tunneling.)
[ 107.612322] autorun-usecase.sh[111]: Play this stream using the URL:
[ 107.612916] autorun-usecase.sh[111]: rtsp://192.168.115.204:8557/PSIA/Streaming/channels/2?videoCodecType=H.264
[ 107.613594] autorun-usecase.sh[111]: (We use port 8304 for optional RTSP-over-HTTP tunneling.)
[ 107.632351] autorun-usecase.sh[111]: ApproDrvExit: 10
[ 107.647493] autorun-usecase.sh[111]: Stream 2 is not avaliable~~~~~~~~
[ 107.648549] autorun-usecase.sh[111]: caught SIGTERM: shutting down
[host]257858] autorun-usecase.sh[111]:
[ 131.258673] autorun-usecase.sh[111]: Usecase is Active !!!
Any other steps or configuration needed to do further?
