I'm about to look at developing an application which will use 1 DM388 to process 2 x dash camera CMOS at the same time.
I see there is a series and parallel port for camera in the datasheet. can they be both used at the same time. If not is it possible to multiplex the input of the 2 camera even if it reduce the FPS.
As well those 2 Camera will be encode into video and stored on SD card and / or send for streaming via Wi-FI SDIO module.
