Hi all,
I am working with a DM368 IPNC camera with using K9F1G08U0B PCB0 SamSung Flash memory.
I am using Nandwriter ultility of Appro to flash UBL-UBOOT and diagnostic but after burn successfully our camera cannot start (I could not see any message in terminal).
I guess we did something wrong with nand partitions and entryPoint + ldAddress setting.
I attached nandwriter.c, device_nand.h and 2 flashing logs as below.
6518.nand368writerAppro.txt
8883.device_nand.txt
1856.nandwriter.txt
please give me a hand to figure out the issue.
Thank you very much!
I came across the same problem.
Any one give some suggestions.
Hi, DM368 support 2 uart port, 1 and 0. You should choose 1 port to use for debug and In kernel or UBL you also need to set correct one.
