• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Digital Signal Processors (DSP) » DaVinci™ Video Processors » DM814x and AM387x Processors Forum » Posix Message Queue Not Implemented Problem
Share
  • Forums
  • Announcements
Options
  • Subscribe via RSS
This question is answered
SID814
Posted by SID814
on Apr 02 2012 08:21 AM
Prodigy250 points
Having problems building in the posix message queue support into the kernel. (5.03.01.15)
We used the menuconfig option to reconfigure the kernel build options.
We did a complete recompile using "make clean" , "make all" , make "install"  and reloaded on SD card.
We verified in .config and ti8148_evm_defconfig files that it is turned on but its either not building it into
the kernel or its not really using our new kernel image....
When application runs:
mq_open encounters a failure with errno 38 (function not implemented)
posix message queue
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • AmirthaRaj
    Posted by AmirthaRaj
    on Sep 04 2012 23:45 PM
    Expert1030 points
    Hi all,
       Any one please help us with this problem?
    Thanks & Regards,
    K.AmirthaRaj
    Report Abuse
    • Reply
  • Vlаdimir_KаfаliеvXID
    Posted by Vlаdimir_KаfаliеvXID
    on Sep 17 2012 08:37 AM
    Verified Answer
    Verified by Vlаdimir_KаfаliеvXID
    Genius9990 points
    Please, try:
    cd <EZSDK_HOME>/board-support/linux-<XX>/
    cp arch/arm/configs/ti8148_evm_defconfig .config
    make ARCH=arm xconfig
    <<Reconfig the kernel and save>>
    cp .config arch/arm/configs/ti8148_evm_defconfig
    cd ../..
    make linux_clean
    make linux
    make linux_install
    cp ~/install/dm816x-evm/boot/uImage /media/boot/
    sync
    BR
    Vladimir
    P.S. If this response helps answering your question please mark this post as verified - Thanks!
    Report Abuse
    • Reply
    on Sep 17 2012 09:15 AM
    Genius9990 points
    PS: I updated my post, so please, read it from the forum, not from your e-mail.
    Report Abuse
    • Reply
  • AmirthaRaj
    on Sep 18 2012 03:53 AM
    Expert1030 points
    Hi Vladimir,
     we tried as you recommended above steps, the following error appears  after " make arch= ARM xconfig" execution.
    Kindly suggest the solution asap.
    Thanks in Advance,
    Amirtharaj.k
    Report Abuse
    • Reply
    on Sep 18 2012 07:09 AM
    Genius9990 points
    xconfig is just the tool which provides you with easy-to-use interface to configure the kernel. You can use anything else: menuconfig (you can just continue with this), gconfig.
    Your xconfig is not working because you need to install some QT4 packages. Perhaps if just install this it will start to work on your host as well:
    # apt-get install qt4-dev-tools
    BR
    Vladimir
    Report Abuse
    • Reply
    on Sep 18 2012 07:17 AM
    Verified Answer
    Genius9990 points
    The main idea of my first post was to copy back the configuration to default configuration file, so to be sure that the Makefile-s, as they are, will apply the right configuration changes. This is not the only way to do it.
    If you don't have one, it is a good idea to have a local version control (i.e. initialize a local git) so you can track your source and bring back the previous configuration.
    BR
    Vladimir
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
