Hello everyone:
I use ezsdk_5_03_01_15_dm814x,and update the syslink ,IPC and XDC.
Now I want to update omx_05_02_00_30 with the newwer syslink and HDVPSS, I use syslink_2_10_03_20,xdctools_3_23_01_43,bios_6_33_02_31,ipc_1_24_02_27,TI81xx-HDVPSS-01.00.01.37,but when compile omx_05_02_00_30 turn out the followings errors,It looks like the omx verision is not match the new syslink and xdc version,How can I fix this?thanks very much.
make[2]: Leaving directory `/home/anuo/Sdb1/Dm81xx/ezsdk5_0301_15/component-sources/omx_05_02_00_30/examples/ti/omx/demos/omxobjs'cp /home/anuo/Sdb1/Dm81xx/ezsdk5_0301_15/component-sources/omx_05_02_00_30/src/../lib/omxobjs/obj/ti814x-evm/a8host/debug/*.ov5T /home/anuo/Sdb1/Dm81xx/ezsdk5_0301_15/component-sources/omx_05_02_00_30/src/../librm /home/anuo/Sdb1/Dm81xx/ezsdk5_0301_15/component-sources/omx_05_02_00_30/src/../lib/main.ov5Tmake -C /home/anuo/Sdb1/Dm81xx/ezsdk5_0301_15/component-sources/omx_05_02_00_30/examples/ti/omx/demos/omxobjs archive_spl CORE=a8host AR_SPL_PATH=/home/anuo/Sdb1/Dm81xx/ezsdk5_0301_15/component-sources/omx_05_02_00_30/src/../lib AR_SPL_NAME=omxcfg.av5Tmake[2]: Entering directory `/home/anuo/Sdb1/Dm81xx/ezsdk5_0301_15/component-sources/omx_05_02_00_30/examples/ti/omx/demos/omxobjs'## [SPL] Archiving /home/anuo/Sdb1/Dm81xx/ezsdk5_0301_15/component-sources/omx_05_02_00_30/src/../lib/domx_cfg.ov5T /home/anuo/Sdb1/Dm81xx/ezsdk5_0301_15/component-sources/omx_05_02_00_30/src/../lib/domx_delegates_shmem_cfg.ov5T /home/anuo/Sdb1/Dm81xx/ezsdk5_0301_15/component-sources/omx_05_02_00_30/src/../lib/domxProxyWrappers.ov5T /home/anuo/Sdb1/Dm81xx/ezsdk5_0301_15/component-sources/omx_05_02_00_30/src/../lib/memtbl_cfg.ov5T /home/anuo/Sdb1/Dm81xx/ezsdk5_0301_15/component-sources/omx_05_02_00_30/src/../lib/omxcore_cfg.ov5T into /home/anuo/Sdb1/Dm81xx/ezsdk5_0301_15/component-sources/omx_05_02_00_30/src/../lib/omxcfg.av5T...#/home/anuo/CodeSourcery/Sourcery_G++_Lite//bin/arm-none-linux-gnueabi-ar cr /home/anuo/Sdb1/Dm81xx/ezsdk5_0301_15/component-sources/omx_05_02_00_30/src/../lib/omxcfg.av5T /home/anuo/Sdb1/Dm81xx/ezsdk5_0301_15/component-sources/omx_05_02_00_30/src/../lib/*.ov5Tmake[2]: Leaving directory `/home/anuo/Sdb1/Dm81xx/ezsdk5_0301_15/component-sources/omx_05_02_00_30/examples/ti/omx/demos/omxobjs'rm /home/anuo/Sdb1/Dm81xx/ezsdk5_0301_15/component-sources/omx_05_02_00_30/src/../lib/*.ov5Tmake[1]: Leaving directory `/home/anuo/Sdb1/Dm81xx/ezsdk5_0301_15/component-sources/omx_05_02_00_30/src'make -C /home/anuo/Sdb1/Dm81xx/ezsdk5_0301_15/component-sources/omx_05_02_00_30/src ROOTDIR=/home/anuo/Sdb1/Dm81xx/ezsdk5_0301_15/component-sources/omx_05_02_00_30 EXTERNAL_SW_ROOT=/home/anuo/Sdb1/Dm81xx/ezsdk5_0301_15/component-sources INTERNAL_SW_ROOT=/home/anuo/Sdb1/Dm81xx/ezsdk5_0301_15/component-sources/omx_05_02_00_30/src kernel_PATH=/home/anuo/Sdb1/Dm81xx/ezsdk5_0301_15/Myfiles/TI81XX-LINUX-PSP-04.04.00.01/src/kernel/linux-04.04.00.01 bios_PATH=/home/anuo/Sdb1/Dm81xx/ezsdk5_0301_15/Myfiles/bios_6_33_02_31 fc_PATH=/home/anuo/Sdb1/Dm81xx/ezsdk5_0301_15/component-sources/framework_components_3_21_03_34 osal_PATH=/home/anuo/Sdb1/Dm81xx/ezsdk5_0301_15/component-sources/osal_1_21_01_08 xdais_PATH=/home/anuo/Sdb1/Dm81xx/ezsdk5_0301_15/component-sources/xdais_7_21_01_07 linuxutils_PATH=/home/anuo/Sdb1/Dm81xx/ezsdk5_0301_15/component-sources/linuxutils_3_21_00_04 ce_PATH=/home/anuo/Sdb1/Dm81xx/ezsdk5_0301_15/component-sources/codec_engine_3_21_02_25 aaclcdec_PATH=/home/anuo/Sdb1/Dm81xx/ezsdk5_0301_15/component-sources/c674x-aaclcdec_01_41_00_00_elf ipc_PATH=/home/anuo/Sdb1/Dm81xx/ezsdk5_0301_15/Myfiles/ipc_1_24_02_27 syslink_PATH=/home/anuo/Sdb1/Dm81xx/ezsdk5_0301_15/Myfiles/syslink_2_10_03_20 xdc_PATH=/home/anuo/Sdb1/Dm81xx/ezsdk5_0301_15/Myfiles/xdctools_3_23_01_43 uia_PATH=/home/anuo/Sdb1/Dm81xx/ezsdk5_0301_15/component-sources/uia_1_00_03_25 slog_PATH=/home/anuo/Sdb1/Dm81xx/ezsdk5_0301_15/component-sources/slog_04_00_00_02 lindevkit_PATH=/home/anuo/Sdb1/Dm81xx/ezsdk5_0301_15/linux-devkit/arm-none-linux-gnueabi/usr PLATFORM=ti814x-evm EXAMPLES_ROOT=/home/anuo/Sdb1/Dm81xx/ezsdk5_0301_15/component-sources/omx_05_02_00_30/examples CODEGEN_PATH_A8=/home/anuo/CodeSourcery/Sourcery_G++_Lite/ CODEGEN_PATH_DSPELF=/home/anuo/Sdb1/Dm81xx/ezsdk5_0301_15/dsp-devkit/cgt6x_7_3_1 DEST_ROOT=/home/anuo/Sdb1/Dm81xx/ezsdk5_0301_15/component-sources/omx_05_02_00_30/bin examples /bin/sh: line 0: cd: src: No such file or directory/bin/sh: line 0: cd: bin: No such file or directory/bin/sh: line 0: cd: lib: No such file or directorymake[1]: Entering directory `/home/anuo/Sdb1/Dm81xx/ezsdk5_0301_15/component-sources/omx_05_02_00_30/src'# Making XDC dependent packages for dm81xx:c6x
js: "./package.bld", line 27: xdc.services.global.XDCException: xdc.PACKAGE_NOT_FOUND: can't locate the package 'ti.syslink.ipc' along the path: '/home/anuo/Sdb1/Dm81xx/ezsdk5_0301_15/Myfiles/bios_6_33_02_31/packages;/home/anuo/Sdb1/Dm81xx/ezsdk5_0301_15/component-sources/framework_components_3_21_03_34/packages;/home/anuo/Sdb1/Dm81xx/ezsdk5_0301_15/Myfiles/ipc_1_24_02_27/packages;/home/anuo/Sdb1/Dm81xx/ezsdk5_0301_15/Myfiles/syslink_2_10_03_20/packages;/home/anuo/Sdb1/Dm81xx/ezsdk5_0301_15/Myfiles/xdctools_3_23_01_43/packages;/home/anuo/Sdb1/Dm81xx/ezsdk5_0301_15/component-sources/codec_engine_3_21_02_25/packages;/home/anuo/Sdb1/Dm81xx/ezsdk5_0301_15/component-sources/omx_05_02_00_30/src;/home/anuo/Sdb1/Dm81xx/ezsdk5_0301_15/component-sources/omx_05_02_00_30/src/ti/omx/interfaces/openMaxv11;/home/anuo/Sdb1/Dm81xx/ezsdk5_0301_15/component-sources/ivahd_h264enc_01_00_04_00_production/packages;/home/anuo/Sdb1/Dm81xx/ezsdk5_0301_15/component-sources/ivahd_h264dec_01_00_00_04_production/packages;/home/anuo/Sdb1/Dm81xx/ezsdk5_0301_15/component-sources/ivahd_mpeg2vdec_01_00_03_00_production/packages;/home/anuo/Sdb1/Dm81xx/ezsdk5_0301_15/component-sources/c674x_mp3dec_01_41_00_00_elf/packages;/home/anuo/Sdb1/Dm81xx/ezsdk5_0301_15/component-sources/c674x-aaclcdec_01_41_00_00_elf/packages;/home/anuo/Sdb1/Dm81xx/ezsdk5_0301_15/component-sources/codecs-dm816x_5_00_00_00/packages;/home/anuo/Sdb1/Dm81xx/ezsdk5_0301_15/component-sources/omx_05_02_00_30/src/ti/omx/comp/omxbase;/home/anuo/Sdb1/Dm81xx/ezsdk5_0301_15/component-sources/omx_05_02_00_30/src/ti/omx/omxcore;/home/anuo/Sdb1/Dm81xx/ezsdk5_0301_15/component-sources/ivahd_hdvicp20api_01_00_00_19_production/packages;/home/anuo/Sdb1/Dm81xx/ezsdk5_0301_15/component-sources/osal_1_21_01_08/packages;/home/anuo/Sdb1/Dm81xx/ezsdk5_0301_15/component-sources/xdais_7_21_01_07/packages;/home/anuo/Sdb1/Dm81xx/ezsdk5_0301_15/component-sources/linuxutils_3_21_00_04/packages;/home/anuo/Sdb1/Dm81xx/ezsdk5_0301_15/component-sources/uia_1_00_03_25/packages;/home/anuo/Sdb1/Dm81xx/ezsdk5_0301_15/component-sources/ivahd_mpeg4enc_01_00_00_03_production/packages;/home/anuo/Sdb1/Dm81xx/ezsdk5_0301_15/component-sources/ivahd_mpeg4vdec_01_00_02_05_production/packages;/home/anuo/Sdb1/Dm81xx/ezsdk5_0301_15/component-sources/ivahd_vc1vdec_01_00_00_03_production/packages;/home/anuo/Sdb1/Dm81xx/ezsdk5_0301_15/component-sources/ivahd_jpegvdec_01_00_01_00_production/packages;/home/anuo/Sdb1/Dm81xx/ezsdk5_0301_15/component-sources/c674x_aaclcenc_01_00_01_00_elf/packages;/home/anuo/Sdb1/Dm81xx/ezsdk5_0301_15/Myfiles/xdctools_3_23_01_43/packages;..;'. Ensure that the package path is set correctly.gmake[1]: *** Deleting file `package.mak'gmake[1]: *** No rule to make target `package.mak', needed by `.interfaces'. Stop.gmake: *** [/home/anuo/Sdb1/Dm81xx/ezsdk5_0301_15/component-sources/omx_05_02_00_30/bin/xdc/dm81xx,.interfaces] Error 2make[2]: *** [xdcdepmake] Error 2make[2]: Leaving directory `/home/anuo/Sdb1/Dm81xx/ezsdk5_0301_15/component-sources/omx_05_02_00_30/src'make[1]: *** [dm81xxdspXdc] Error 2make[1]: Leaving directory `/home/anuo/Sdb1/Dm81xx/ezsdk5_0301_15/component-sources/omx_05_02_00_30/src'make: *** [omx] Error 2
OMX 5.02.00.30 is not compatible with the latest Syslink, IPC, BIOS and XDCTools. We are working on an updated version of OMX that will use these components.
--Sid
Need more information? Some Categories on TI's processors wiki are -
http://processors.wiki.ti.com/index.php/Category:DaVinci
http://processors.wiki.ti.com/index.php/Category:DaVinci_Linux
http://processors.wiki.ti.com/index.php/Category:EZSDK
http://processors.wiki.ti.com/index.php/Category:DVSDK
http://processors.wiki.ti.com/index.php/Category:OMX
