Tool/software: TI-RTOS
hi,
we use REL.500.V.H264AVC.E.IVAHD.02.00.08.00 to test h264,
the default in/out fps for codec is 30/30 and we set the bit rate 4Mbps. the output is around 4Mbps
As we set in/out fps is 60/30, and the actual in fps is 60 to codec(we still set the bit rate 4Mbps), but we get 8Mbps.
why ???
Bit rate should be independent of frame rate. right ??
Is there something wrong I miss ??
