• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Digital Signal Processors (DSP) » DaVinci™ Video Processors » DM816x, C6A816x and AM389x Processors Forum » DM8168 power-up instability
Share
  • Forums
  • Announcements
Options
  • Subscribe via RSS
This question is not answered
Xiaohui Lin
Posted by Xiaohui Lin
on Dec 24 2011 20:54 PM
Prodigy100 points
Hello, I did 5 model board with the DM8168,The 1V_AVS power using TPS40400 chip, output 0.99V.Currently both the power supply board or the power requirements of the order are in line DM8168, but when power up the board, my SD card on the board sometimes start, sometimes it will not start, USART port does not print any information, and when it is seted to NandFlash start up first, is the samesituation! I have the power to fly to the EVM board of Ti, EVM board each time you open all the normal, very stable! Power problems should be excluded. I Would like to ask, if there are any factors affecting the chip enable those which that i need to pay attention? Which aspects of this large number? Thanks
DM8168 DaVinci DSP power rails DM816x/C6A816x/AM389x Evaluation Module CCSV5 DAVİNCİ 8168 DM8168 Reset
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • MarcPyne
    Posted by MarcPyne
    on Jan 06 2012 14:57 PM
    Mastermind23505 points
    So do you mean that you confirmed that it is following the correct power up sequence?
    Can you please provide any output logs you see on the UART output?
    Marc
    Please mark this Forum post as answered via the Verify Answer button below if it helps answer your question.  Thanks!
    Report Abuse
    • Reply
  • Xiaohui Lin
    on Jan 07 2012 08:15 AM
    Prodigy100 points
    Thanks for your reply!  I have checked the power up sequence !And it does meet the requirement! But there is not any message output on the UART when turn on the switch of power for DM8168 !and then i checked the DDR3 clock,it is also not output,I checked the Pin of SD card power enable(U4)at the same time,this pin is also keep in low level  !  But sometimes the chip could boot up correctly,the DDR3 clock and the Pin of U4 are all right!and the message is printed on the UART just like the EVM board!  So i am confused with this condition!
    The follow is power sequence in time and the PowerOn reset
    3.3V 0ms (beginning)
    1.0V_AVS 4ms
    1.0V_CON    6ms
    1.8V 26ms
    1.5V 34ms
    0.9V 48ms
    PowerOnReset 400ms (end)
    Report Abuse
    • Reply
  • Xiaohui Lin
    on Jan 09 2012 07:20 AM
    Prodigy100 points
    and another question is :If the power does not meet the sequence requirements,DM8168 chip's internal logic would be damaged?
    Report Abuse
    • Reply
  • MarcPyne
    Posted by MarcPyne
    on Jan 09 2012 17:10 PM
    Yes.
    Report Abuse
    • Reply
  • Xiaohui Lin
    on Jan 31 2012 02:44 AM
    Prodigy100 points
    Hi ,there is another question:the implementation of SmartReflex AVS is necessary or just recommended? does it can affect the chip boot up? Thanks!
    Report Abuse
    • Reply
  • MarcPyne
    Posted by MarcPyne
    on Jan 31 2012 17:17 PM
    It will not affect chip bootup, but AVS is required for correct chip operation.
    Marc
    Report Abuse
    • Reply
  • yuqing cai
    Posted by yuqing cai
    on May 04 2012 21:33 PM
    Intellectual600 points
    HI~~~Lin, have you solved the problem?I made a board as the TI DM8168 EVM sch(version G). I meet the same situation as you, the power sequence goes fine, but there is no output when power up. Do you have some suggestion? Does anybody have some idea?
    Report Abuse
    • Reply
  • Li Michelle
    Posted by Li Michelle
    on May 21 2013 03:03 AM
    Intellectual475 points
    We meet the similar problem here. There are some boards can't finish the boot process. The power sequence is in line with the datasheet. The tracing register 0x4031D040h shows a value of 0x6. It means the ROM boot code can't reach the 2nd stage boot process. And if we connect to the A8 core using CCS and use assembly step to debug, it would loop in below 3 instructions:
    00021abe:   1570F8D0 LDRNEB          PC, [R0, #--2256]!
    00021ac2:   3F40F411 SWICC           #4256785
    00021ac6:   4809D1FA STMMIED         R9, {R1, R3, R4, R5, R6, R7, R8, R12, R14, PC}
     Anyone can shed some light here? We are stuck in for a long time.
    Report Abuse
    • Reply
  • Phil Yi
    Posted by Phil Yi
    on May 23 2013 09:31 AM
    Intellectual780 points
       Please check the AVS output from very beginning of power up, it shall be set higher (about 1.2V) instead of 0.9V for normal boo-up and then can be lowered down later according to application needs by using the PMBus commands through registers of VOUT_TRIM, VOUT_MARGIN_HIGH and VOUT_MARGIN_LOW.
      Thanks!
      Phil
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
