• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Digital Signal Processors (DSP) » DaVinci™ Video Processors » DM816x, C6A816x and AM389x Processors Forum » Redirecting output to HDMI/DVI display
Share
  • Forums
  • Announcements
Options
  • Subscribe via RSS
This question is not answered
Alla
Posted by Alla
on Apr 25 2012 02:48 AM
Expert1100 points
I use DM816xEVM with EZSDK 5.03 and I want to redirect an output to HDMI/DVI display.
I saw that sometimes the omapfb.vram=0:12M,1:12M,2:12M omapfb.mode=dvi:1280x1024MR-32@60 omapdss.def_disp=dvi parameters
are sent as bootargs, but it didn't help me.
What should I do?
Thanks.
display HDMI DVI
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Prathap Srinivas
    Posted by Prathap Srinivas
    on Apr 25 2012 04:53 AM
    Expert3980 points
    Have you checked the VPSS , HDMI user guides .  The below link gives the default setup/configuration for graphics & video pipelines & also the steps/instructions on how you can switch/change them.
    http://processors.wiki.ti.com/index.php/DM81XX_AM38XX_VPSS_Video_Driver_User_Guide#Miscellaneous_Configurations
    http://processors.wiki.ti.com/index.php/DM81xx_AM38xx_HDMI_User_Guide
    Prathap.
    If my reply answers your question then please click on the "Verify Answer" button.
    Report Abuse
    • Reply
  • Alla
    Posted by Alla
    on Apr 29 2012 01:53 AM
    Expert1100 points
    Hi Prathap,
    Thank you for your quick answer.
    I didn't explain myself properly. I want to be able to use input that comes from the keyboard added to my board,
    instead right now I can only use the keyboard added to the host.
    Report Abuse
    • Reply
  • Prathap Srinivas
    on Apr 30 2012 01:58 AM
    Expert3980 points
    Hi Alla,
    The understanding from your initial post was that you are facing problem with the display & switching the display to HDMI as you had mentioned about HDMI.
    Now it looks like an USB keyboard issue.  I do not work on USB but i see that users have got this working as per some thread below.
    Have you checked the other threads. I see that users have got this working & provided some suggestions-
    http://e2e.ti.com/support/dsp/davinci_digital_media_processors/f/717/t/134042.aspx
    http://e2e.ti.com/support/dsp/davinci_digital_media_processors/f/717/p/139520/513252.aspx#513252
    Prathap.
    Report Abuse
    • Reply
  • Alla
    Posted by Alla
    on May 01 2012 07:39 AM
    Expert1100 points
    The reason for my initial post is that I want the display which is connected to my EVM will be defined as the default display (instead of display of the host) and than maybe
    I would see the input of the keyboard attached to the EVM.
    Report Abuse
    • Reply
  • Prathap Srinivas
    on May 03 2012 13:19 PM
    Expert3980 points
    Did you try the suggestions in other threads where some users have got the USB keyboard connected to EVM working.
    Also did you try with another USB keyboard? Do you see the keyboard device getting enumerated?
    Attach the dmesg logs & also provide the PSP(kernel) version used so that users working on USB can take a look & respond to the issue.
    Prathap.
    Report Abuse
    • Reply
  • Steve Clynes
    Posted by Steve Clynes
    on May 03 2012 14:26 PM
    Mastermind22750 points
    I think what you are really needing to do is enable the frame buffer console.
    This requires compiling the Kernel with this configuration option enabled.
    The second part of the issue is then getting the keyboard working.
    BR,
    Steve
    Please mark this post as answered via the Verify Answer button below if you think it answers your question.  Thanks!
    Report Abuse
    • Reply
  • HardikShah
    Posted by HardikShah
    on May 08 2012 01:43 AM
    Mastermind20155 points
    Framebuffer console need be enabled from the menu configure, you can choose either static or dynamic build for framebuffer console. CONFIG_FRAMEBUFFER_CONSOLE is the entry for framebuffer console in .config file.
     If it is static build, once fb.ko is loaded, console output will be on the HDMI(/dev/fb0)
    If it is dynamic build, load the fbconsole module after fb.ko.
    Hardik Shah
    Hardik Shah
    Report Abuse
    • Reply
  • Gabi Gvili
    Posted by Gabi Gvili
    on May 08 2012 03:54 AM
    Genius3785 points
    take a look at this.
    http://e2e.ti.com/support/dsp/davinci_digital_media_processors/f/100/p/8332/33732.aspx#33732
    Report Abuse
    • Reply
  • Alla
    Posted by Alla
    on May 20 2012 03:45 AM
    Expert1100 points
    I enabled Device Drivers -> Graphics support -> Console display driver support -> Framebuffer Console support (static build). When I recompiled the image and modules and loaded the ti81xxfb.ko, but nothing has changed. Any suggestions?
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
