• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Digital Signal Processors (DSP) » DaVinci™ Video Processors » DM816x, C6A816x and AM389x Processors Forum » DM816x DDR3 Software Levelling
Share
  • Forums
  • Announcements
Options
  • Subscribe via RSS
This question is not answered
James Long
Posted by James Long
on May 01 2012 10:21 AM
Prodigy130 points
We're using the DM8168 in a new design and want to make use of the ability to swap DQ data bits within a byte lane to make the PCB routing easier.
The flight time levelling aspect of DDR3 means that one bit in each byte (the prime) bit carries info during the levelling process, but the DDR3 spec does not specify which bit this will be. This implies that a DDR3 memory controller which aims to work with DDR3 components from all vendors will have to discover which bit which is prime on each board.
I understand that the DM816x doesn't fully support the hardware levelling algorithm in the Rev 1.1 and Rev 2.0 silicon versions, but does the replacement software levelling algorithm have any sensetivity to which bit is the prime bit?
There is a discussion of this issue for the DM814x on this thread, but my question is specific to the software levelling:
http://e2e.ti.com/support/dsp/davinci_digital_media_processors/f/716/p/160641/660439.aspx
James
dm8168 ddr3 levelling
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Anil
    Posted by Anil
    on May 03 2012 02:11 AM
    Expert6655 points
    Hi James,
    You can find the DDR3 initialization details with SW leveling at
    http://processors.wiki.ti.com/index.php/DM816x_C6A816x_AM389x_DDR3_Init
    AnilKumar
    Please mark this Forum post as answered via the Verify Answer button below if it helps answer your question.  Thanks!
    PSP dm8168 ddr3
    Report Abuse
    • Reply
  • James Long
    on May 16 2012 03:41 AM
    Prodigy130 points
    The page you referred to looks like it describes what we need to do to run the levelling algorithm, but it doesn't describe much about the algorithm itself.
    I'm concerned that since the DM8168 eval board uses micron memory and doesn't swap any pins that the algorithm might be specific to that setup. The micron memory parts output their levelling info (prime DQ) on DQ0 and so if the algorithm was expecting the information to be on DQ0, then our design might not work since we haven't mapped DQ0 on the memory to DQ0 on the DM8168.
    Can you confirm whether the SW levelling searches all DQs for the prime DQ or not?
    Is this likely to change in a future revision of the device if hardware levelling is implemented?
    James.
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
