• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Digital Signal Processors (DSP) » DaVinci™ Video Processors » DM816x, C6A816x and AM389x Processors Forum » Multi-chan HD video Capture using Dm8168
Share
  • Forums
  • Announcements
Options
  • Subscribe via RSS
  • Xavier15128
    Posted by Xavier15128
    on May 02 2012 22:37 PM
    Expert1690 points
    I do developpment on the DM8168 EVM board+Vs child Board, and DVRRDK_02.00.00.23 is used to do software developmment.
    As DM8168 can encode 3 channels of  1080p /60fps video image, i want to use it to encode 5 channels of xga video image.
    And i find only three vports tow for capturing and one for display, then how can capture the video images more than tow channels?
    I think two meothds to solve this problem.
    1. Using PCIe + video capture board
    2.Using FPGA capture and sharing mem with Dm8168
    All this two shemes are not so easily to completed.
    Is there other sheme? Link for TVP5185 capture 4 D1 video image at the same time?
    xavier
    thank you
    8168 DVR_RDK demo 8168EVM RDK 816x
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
  • Brett Kuehner
    Posted by Brett Kuehner
    on May 11 2012 15:40 PM
    Intellectual510 points
    Each 5158 can pull in up to 4 channels of video, which get multiplexed into a stream going to the 8168. The EVM I have has a daughterboard with four 5158s, allowing 16 channels of simultaneous input.
    Report Abuse
    • Reply
  • Xavier15128
    on May 12 2012 09:21 AM
    Expert1690 points
    TVP5158 not support HD
    Report Abuse
    • Reply
  • HardikShah
    Posted by HardikShah
    on May 13 2012 22:48 PM
    Mastermind20155 points
    Video capture H/W supports upto 4 8-bit ports. So for XGA you can use BT656 kind of input which is 8-bit. With this you will be able to capture 4-XGA streams. You may have to use FPGA to convert XGA BT1120 to XGA BT656 format.
    Hardik Shah
    Hardik Shah
    Please mark this post as answered via the Verify Answer button below if you think it answers your question.  Thanks!
    Report Abuse
    • Reply
  • Xavier15128
    on Jun 07 2012 22:14 PM
    Expert1690 points
    Hi, Hardik Shah
    Thank you for your replay! Is there any chip can completed convert XGA BT1120 then ?
    Report Abuse
    • Reply
  • HardikShah
    on Jun 07 2012 22:47 PM
    I am not aware of any such chip. I think you may have to use FPGA.
    Hardik Shah
    Hardik Shah
    Report Abuse
    • Reply
  • Xavier15128
    on Jun 07 2012 22:52 PM
    Expert1690 points
    Ok! If bt656 xga is used ,the image quality will loss then ?
    Report Abuse
    • Reply
  • Steve Clynes
    Posted by Steve Clynes
    on Jun 08 2012 09:22 AM
    Mastermind22750 points
    Both 656 and 1120 will suffer a color fidelity loss, yes, since you will be both converting to YUV and decimating the chroma channel.
    BR,
    Steve
    Report Abuse
    • Reply
  • Xavier15128
    on Jun 08 2012 10:11 AM
    Expert1690 points
    If bt656, the image will be down sample to 720?
    Report Abuse
    • Reply
  • Steve Clynes
    on Jun 08 2012 10:45 AM
    There will not be any resolution down sampling, no.
    656 is simply a data transfer protocol. There is no inherent change in the data.
    What is really happening is that the 656 protocol is being 'modified' in order to transfer an image of different size/frame rate etc...
    All we are really using from the 656 protocol is the concept of SAV and EAV coding to encapsulate a video image frame.
    BR,
    Steve
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
