• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Digital Signal Processors (DSP) » DaVinci™ Video Processors » DM816x, C6A816x and AM389x Processors Forum » saLoopBack not displaying
Share
  • Forums
  • Announcements
Options
  • Subscribe via RSS
This question is not answered
John Stuart
Posted by John Stuart
on May 11 2012 13:04 PM
Prodigy140 points
I've finally got the saLoopBack function executing without errors. The issue is that the screen flashes blue and goes blank for a few seconds and then flashes blue again and saLoopBack exits. The saLoopBackFbdev performs almost the same (no second flash).
I'm using ezsdk v.5-04-00-11 on the 816x EVM with I/O card with updated uboot. The DVD player HDMI is plugged into the I/O card connector labeled HDMI input (P3 on the schematics). Everything else is per the quick start guide. I verified output of the DVD by plugging in directly to the monitor.
The output from saLoopBack is below. I enabled the debug output in the code and corrected the display driver output to display the actually driver information in initDisplay. Notice that the display driver is "ti81xx_vidout" while the driver is loaded as "ti81xxvo". I doubt it's significant as the string is only displayed. All of the other data seems reasonable.
root@dm816x-evm:~# ./saLoopBack
Driver Name: ti81xxvin
Driver bus info: TI81xx Platform
Driver is capable of doing capture
saLoopBack:
Mode set is 1080P60
Driver Name: t81xx_vidout
Driver bus info:
Driver is capable of doing display
Capture Format:
fmt.type = 1
fmt.width = 1920
fmt.height = 1080
fmt.pixelformat = 1448695129
fmt.bytesperline = 3840
fmt.sizeimage = 4147200
Display Format:
fmt.type = 2
fmt.width = 1920
fmt.height = 1080
Fix Screen Info:
Line Length - 3840
Physical Address = 93a00000
Buffer Length = 41943040
Var Screen Info:
Xres - 1920
Yres - 1080
Xres Virtual - 1920
Yres Virtual - 8640
nonstd - 0
Bits Per Pixel - 16
blue lenth 5 msb 0 offset 0
red lenth 5 msb 0 offset 11
green lenth 6 msb 0 offset 5
trans lenth 0 msb 0 offset 0
Var Screen Info:
Xres - 1920
Yres - 1080
Xres Virtual - 1920
Yres Virtual - 8640
nonstd - 0
Bits Per Pixel - 16
Fix Screen Info:
Line Length - 3840
Count=0
Frame rate = 62
8168 capture example saloopback
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • HardikShah
    Posted by HardikShah
    on May 13 2012 22:44 PM
    Mastermind20155 points
    Was it working in earlier release. Can you please get us the detailed steps you are executing for this to work. Like what firmware you are loading etc.
    Hardik Shah
    Hardik Shah
    Please mark this post as answered via the Verify Answer button below if you think it answers your question.  Thanks!
    Report Abuse
    • Reply
  • John Stuart
    on May 14 2012 09:58 AM
    Prodigy140 points
    I only spent two days with the EZSDK v5.03 release prior to the v5.04 becoming available, and decided to move to v5.04 because I'm running Ubuntu 11.10 native and little with v.503 was working. saLoopBack was attempted once or twice with v5.03 but it was not working.
    The initial setup consisted of running set-up.sh and updating Uboot on the 8168EVM when I started using v5.04. I built the sa* examples from ${EZSDK}/example-applications/linux-driver-examples-psp04.04.00.01/video. They built without error.
    The step used are only those defined in the documentation for running from an SD card. On the SD, I copied /usr/share/ti/ti-media-controller-utils/load-hd-v4l2-firmware.sh to /etc/init.d/load-hd-firmware.sh. There was an issues with control of the I2C and I had to augment the "firmware_loader" lines to include "-i2c 0", see below. Other than that, the file is as supplied. The versions of firmware that it loads are the ones supplied with the v5.04.00.11 release.
    Except from load-hd-v4l2-firmware.sh:
    start)
    echo "Loading HDVICP2 Firmware"
    prcm_config_app s
    modprobe syslink
    until [[ -e /dev/syslinkipc_ProcMgr && -e /dev/syslinkipc_ClientNotifyMgr ]]
    do
    sleep 0.5
    done
    firmware_loader $HDVICP2_ID /usr/share/ti/ti-media-controller-utils/dm816x_hdvicp.xem3 start -i2c 0
    echo "Loading HDVPSS (V4L2) Firmware "
    firmware_loader $HDVPSS_ID /usr/share/ti/ti-media-controller-utils/dm816x_hdvpss_v4l2.xem3 start -i2c 0
    modprobe vpss sbufaddr=0xBFB00000 mode=hdmi:1080p-60,dvo2:1080p-60,hdcomp:1080p-60 i2c_mode=0
    modprobe ti81xxfb vram=0:40M,1:1M,2:1M
    modprobe ti81xxvo
    modprobe tvp7002
    modprobeset -depth 32 -rgba 8/16,8/8,8/0,0/0
    modprobe ti81xxhdmi
    To run, I execute "/etc/init.d/matrix-gui-e stop" and "/etc/init.d/pvr-init stop". Followed by "./saLoopBack". Stopping the PVR disables the VPSS graphics0 buffer.
    The hardware configuration has the serial port connected to my laptop (working), Ethernet network connected (working), monitor connected to EVM P6 (working), RGB connected to EVM J5-J7 and Daughter I/O J5-J7 (working for gstreamer demo), and DVD source connected to Daughter I/O P3 HDMI input. The DVD has been confirmed for output by connecting directly to the monitor. The EVM is rev G and the Daughter I/O is rev C.
    Other than the small mod to load-hd-v4l2-firmware.sh, I enable the additional debug messages in the code and the system conforms to the directions. I have tried some of the suggestions in the forums regarding mods to the saLoopBack and saLoopBackFbdev code but those appear to be negated by the v5.04 release.
    I've been unable to find any document for the Daughter I/O that is equivalent to the 'evm816x_TechRef_RevG.pdf'. And I'm uncertain how the Daughter I/O interfaces can be utilized to try alternative tests.
    Report Abuse
    • Reply
  • A Marchini
    Posted by A Marchini
    on May 15 2012 09:19 AM
    Intellectual590 points
    Wait, I thought the HDMI input connector couldn't be used with an HDMI source because the decoder was only for DVI?
    Tony
    Report Abuse
    • Reply
  • John Stuart
    on May 15 2012 11:32 AM
    Prodigy140 points
    HDMI is DVI + PCM (uncompressed) or IEC61937-compliant (compressed) digital audio. And HDMI support of audio is optional.
    IOW, it should work either way.
    Report Abuse
    • Reply
  • A Marchini
    on May 15 2012 12:07 PM
    I thought the limiting issue was the SiI1161 , I didn't think it could figure out the inband audio component to the degree that it could ignore it. I am aware of the electrical compliance.
    You already made the modification to the driver to switch the multiplexer to the SiI1161 chip? It isn't on by default , at least it wasn't prior to the 5.04 version of EZSDK.
    Tony M.
    Report Abuse
    • Reply
  • John Stuart
    on May 15 2012 12:16 PM
    Prodigy140 points
    A Marchini
    Tony M.
    All modifications have already been explained in my previous posts. The instructions don't identify anything regarding changing the driver. Which driver needs to change and what needs to change?
    I've seen posts stating that the saLoopBack example is working so I don't think there is a limitation in the SiI1161.
    Report Abuse
    • Reply
  • A Marchini
    on May 15 2012 12:30 PM
    Here is a note I received in another thread. Anyone I have seen using this program, including myself, was using the component video. You may have issues with HDCP I imagine from your player.
    I am not sure what are you trying to do here. But if you are trying to setup PCF8575 for reception of input from DVI decoder instead of TVP7002 then you need to do following changes. You need to modify following function under arch/arm/mach-omap2/board-ti8168evm.c. Currently we are setting it for TVP7002 decoder. You just need to set it for DVI decoder. You need to set 1 on that VPS_VC_IO_EXP_SEL_VIN0_S1_MASK bits to select DVI instead of TVP7002.
    "int vps_ti816x_select_video_decoder(int vid_decoder_id)"
    Hardik Shah
    Report Abuse
    • Reply
  • HardikShah
    on May 16 2012 23:03 PM
    I am not able to follow thread fully, But  what i got is that you want to capture through Sii1161. Is this correct. If this case,  than sii1161 driver is not supported and you need to refer to http://processors.wiki.ti.com/index.php/DM81xx_AM38xx_Adding_External_Decoders_to_V4L2_Capture_Driver on how to add new decoders support to V4L2 capture driver.
    Hardik Shah
    Hardik Shah
    Report Abuse
    • Reply
  • John Stuart
    on May 17 2012 11:56 AM
    Prodigy140 points
    OK, it's now capturing and displaying, but it's only in one-eighth of the screen. Shouldn't the playback be full screen?
    For the record, the solution was that the saLoopBack application, as provided, captures from the component inputs of the 8168 EVM expansion I/O board (these are the RCA RGB connectors between the HDMI connectors.) In the Capture Driver User Guide, the "Read This First" with the sample programs said "Capture source must be connected to the component input..." and I interpreted that as the device doing the capturing, the 8168, as interpreted in "capture driver". It actually means "source to be captured". And since the quick start default configuration has the capture device and the expansion I/O connected via RGB, I assumed no change was needed.
    HardikShah
    Regards, Hardik Shah
    Now that the capture is somewhat working, I will want to capture from the HDMI input as that is part of my evaluation of the 8168 chip. Although, I'm beginning to think that it  doesn't matter to the 8168 since there are interface chips performing a conversion of the input. It's disappointing that the EZSDK doesn't support all of the components of the evaluation platform (unless, of course, that you didn't mean "not supported" but meant "needs to be modified to include support", as inferred by Tony.)
    If there is an answer as to why the captured video is so small on the display, I'd like to hear it, otherwise I'm satisfied with information as supplied by Tony and I'm done with this thread.
    Report Abuse
    • Reply
  • A Marchini
    on Jun 19 2012 11:04 AM
    John,
    Did you ever get the DVI input working with standard HDMI input? I was curious if the input chip was capable of ignoring the embedded audio in a standard HDMI signal.
    Tony
    Report Abuse
    • Reply
  • John Stuart
    on Jun 21 2012 09:13 AM
    Prodigy140 points
    Tony,
    Sorry, I can't answer your question. I didn't try very hard to get that working. I switched to the RGB inputs to satisfy a couple of points of interest and then moved on. And I'm now on a different (paying) project.
    John
    Report Abuse
    • Reply
  • A Marchini
    on Jun 21 2012 11:05 AM
    Ok, thanks for the reply at least.
    Tony
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
