now i do 2 ch loopback enc and dec test.but i found that if i set ch 0 1080P60 and ch 1 1080P30 then the app run for some time and the channel 0 will can decode to be 60fps ,sometimes the image will be fuzzy .so i do some other test to check the performance,i found that i can set the ch 1 to be 23fps ,the ch 0 will not be fuzzy.so i can not confirm that is my program's problem or my own board performance limit.
the following is my three times print log:
tks
