Hi all
Create error:
8: SYSTEM: System Common Init Done !!!
72: MCFW : CPU Revision [ES2.0] !!!
[m3vpss ] 114259: CAPTURE: Create in progress !!!
[m3vpss ] 114289: CAPTURE: VIP0 PortA capture mode is [16-bit, Non-mux Embedded Sync] !!!
[m3vpss ] Vps_captAllocPath passed
[m3vpss ] Vps_captCreateChObj passed
[m3vpss ] Vps_captCreateVip passed
[m3vpss ] Vps_captCreateQueues passed
[m3vpss ] Vps_captSubFrameInitArgs passed
[m3vpss ] Vps_captInitTimeStamp passed
[m3vpss ] 114605: CAPTURE: VIP1 PortA capture mode is [16-bit, Non-mux Embedded Sync] !!!
[m3vpss ] Vps_tvp7002Lock
[m3vpss ] Vps_tvp7002Unlock
[m3vpss ] Vps_tvp7002AllocObj
[m3vpss ] Vps_tvp7002LockObj
[m3vpss ] Vps_tvp7002Control,cmd = IOCTL_VPS_VIDEO_DECODER_GET_CHIP_ID
[m3vpss ] Vps_tvp7002UnlockObj
[m3vpss ] Vps_tvp7002Control,cmd = IOCTL_VPS_VIDEO_DECODER_GET_VIDEO_STATUS
[m3vpss ] 114812: CAPTURE: VIP 2: VID DEC 1025 (0x5c): 7002:0002:0000
[m3vpss ] 114812:CAPTURE: VIP-2:VID DEC 1025 (0x5c): Detected video (192x1125@125Hz, 1) !!!
[m3vpss ] UTILS: DMA: Allocated CH (TCC) = 58 (58)
[m3vpss ] UTILS: DMA: 0 of 4: Allocated PaRAM = 58 (0x49004740)
[m3vpss ] UTILS: DMA: 1 of 4: Allocated PaRAM = 64 (0x49004800)
[m3vpss ] UTILS: DMA: 2 of 4: Allocated PaRAM = 65 (0x49004820)
[m3vpss ] UTILS: DMA: 3 of 4: Allocated PaRAM = 66 (0x49004840)
[m3vpss ] CAPTURE::HEAPID:0 USED:680
[m3vpss ] CAPTURE::HEAPID:4 USED:95385600
[m3vpss ] 114813: CAPTURE: Create Done !!!
[m3vpss ] Vps_tvp7002Control,cmd = IOCTL_VPS_VIDEO_DECODER_SET_VIDEO_MODE
[m3vpss ] 114817: DEI : Create in progress !!!
[m3vpss ] DeiLink_drvCreateOutObj,pObj->inQueInfo.numCh = 1
[m3vpss ] DEI: Ch 0, Outformat is PROGRESSIVE
[m3vpss ] 114837: DEI: OUT1: 0: Format: PROGRESSIVE, 0xb3f13c80, 704 x 576, 7 frames
[m3vpss ] 114838: DEI : Loading Down-scaling Co-effs
[m3vpss ] 114838: DEI : Co-effs Loading ... DONE !!!
[m3vpss ] DEI:HEAPID:0 USED:64
[m3vpss ] DEI:HEAPID:1 USED:4704
[m3vpss ] DEI:HEAPID:4 USED:4257792
[m3vpss ] 114839: DEI : Create Done !!!
[m3vpss ] 114839: IPC_FRAMES_OUT : Create in progress !!!
[m3vpss ] ---EricDebug:memleak-----IpcFramesOutLink_create---------------
[m3vpss ] 114841: IPC_FRAMES_OUT : Create Done !!!
[m3vpss ] 114918: DEI : Create in progress !!!
837:!!!SLAVE CORE [VPSS-M3] DOWN!!!
SystemLink_copySlaveCoreExceptionContext:120
SystemLink_copySlaveCoreExceptionContext:127
SystemLink_handleSlaveCoreException:149
DEMO: VSYS_EVENT_SLAVE_CORE_EXCEPTION !!!
843:!!!SLAVE CORE DOWN!!!.EXCEPTION INFO DUMP
!!HW EXCEPTION ACTIVE (0/1): [0]
!!EXCEPTION CORE NAME : [VPSS-M3]
!!EXCEPTION TASK NAME : [DEI1 ]
!!EXCEPTION LOCATION : [links_m3vpss/dei/deiLink_drv.c:943]
!!EXCEPTION INFO : [pObj->fvidHandle != NULL]
[m3vpss ] 115019: DEI: OUT2: 0: Format: PROGRESSIVE, 0xb4323480, 1920 x 1080, 7 frames
[m3vpss ] 115020: Assertion @ Line: 943 in links_m3vpss/dei/deiLink_drv.c: pObj->fvidHandle != NULL : failed !!!
!!EXCEPTION CCS CRASH DUMP FORMAT FILE STORED @ ./CCS_CRASH_DUMP_VPSS-M3.txt
SystemLink_handleSlaveCoreException:154
Link configure code:
gVcapModuleContext.captureId = SYSTEM_LINK_ID_CAPTURE;
gVcapModuleContext.deiId[1] = SYSTEM_LINK_ID_DEI_HQ_1;
gVcapModuleContext.deiId[0] = SYSTEM_LINK_ID_DEI_0;
capturePrm.numVipInst = 2;
capturePrm.outQueParams[0].nextLink = gVcapModuleContext.deiId[0];
capturePrm.outQueParams[1].nextLink = mergeId0;
capturePrm.outQueParams[2].nextLink = gVcapModuleContext.deiId[1];
capturePrm.tilerEnable = FALSE;
capturePrm.enableSdCrop = FALSE;
pCaptureInstPrm = &capturePrm.vipInst[0];
pCaptureInstPrm->vipInstId = (SYSTEM_CAPTURE_INST_VIP0_PORTA);
pCaptureInstPrm->videoDecoderId = 0;
pCaptureInstPrm->inDataFormat = SYSTEM_DF_YUV422P;
pCaptureInstPrm->standard = SYSTEM_STD_1080P_30;
pCaptureInstPrm->videoIfMode = SYSTEM_CAPT_VIDEO_IF_MODE_16BIT;
pCaptureInstPrm->inScanFormat = SYSTEM_SF_PROGRESSIVE;
pCaptureInstPrm->videoCaptureMode = DEVICE_CAPT_VIDEO_CAPTURE_MODE_SINGLE_CH_NON_MUX_EMBEDDED_SYNC;
pCaptureInstPrm->numOutput = 2;
pCaptureOutPrm = &pCaptureInstPrm->outParams[0];
pCaptureOutPrm->dataFormat =SYSTEM_DF_YUV420SP_UV;//SYSTEM_DF_YUV422I_YUYV;
pCaptureOutPrm->scEnable = FALSE;
pCaptureOutPrm->outQueId = 0;
pCaptureOutPrm = &pCaptureInstPrm->outParams[1];
pCaptureOutPrm->dataFormat = SYSTEM_DF_YUV420SP_UV;//SYSTEM_DF_YUV422I_YUYV;
pCaptureOutPrm->outQueId = 1;
pCaptureInstPrm = &capturePrm.vipInst[1];
pCaptureInstPrm->vipInstId = SYSTEM_CAPTURE_INST_VIP1_PORTA;
pCaptureInstPrm->videoDecoderId = SYSTEM_DEVICE_VID_DEC_TVP7002_DRV;
pCaptureInstPrm->standard = SYSTEM_STD_1080I_60;
pCaptureInstPrm->inScanFormat = SYSTEM_SF_INTERLACED;
pCaptureInstPrm->numOutput = 1;
pCaptureOutPrm->dataFormat = SYSTEM_DF_YUV422I_YUYV;
pCaptureOutPrm->scOutWidth = 1920;
pCaptureOutPrm->scOutHeight = 1080;
pCaptureOutPrm->outQueId = 2;
deiPrm0.inQueParams.prevLinkId = gVcapModuleContext.captureId;
deiPrm0.inQueParams.prevLinkQueId = 0;
deiPrm0.enableDeiForceBypass = TRUE;
deiPrm0.outQueParams[DEI_LINK_OUT_QUE_VIP_SC].nextLink = gVcapModuleContext.ipcFramesOutVpssId[1];//nullId;
deiPrm0.enableOut[DEI_LINK_OUT_QUE_VIP_SC] = TRUE;
deiPrm0.tilerEnable[DEI_LINK_OUT_QUE_VIP_SC] = FALSE;
deiPrm0.inputFrameRate[DEI_LINK_OUT_QUE_VIP_SC] = 30;
deiPrm0.outputFrameRate[DEI_LINK_OUT_QUE_VIP_SC] = 25;
deiPrm0.setVipScYuv422Format = FALSE;
deiPrm0.outScaleFactor[DEI_LINK_OUT_QUE_VIP_SC][0].scaleMode = DEI_SCALE_MODE_ABSOLUTE;
deiPrm0.outScaleFactor[DEI_LINK_OUT_QUE_VIP_SC][0].absoluteResolution.outWidth = 720;
deiPrm0.outScaleFactor[DEI_LINK_OUT_QUE_VIP_SC][0].absoluteResolution.outHeight = 576;
for (chId=1; chId < DEI_LINK_MAX_CH; chId++)
deiPrm0.outScaleFactor[DEI_LINK_OUT_QUE_VIP_SC][chId] = deiPrm0.outScaleFactor[DEI_LINK_OUT_QUE_VIP_SC][0];
deiPrm1.inQueParams.prevLinkId = gVcapModuleContext.captureId;
deiPrm1.inQueParams.prevLinkQueId = 2;
deiPrm1.outQueParams[DEI_LINK_OUT_QUE_VIP_SC].nextLink = mergeId0;
deiPrm1.enableOut[DEI_LINK_OUT_QUE_VIP_SC] = TRUE;
deiPrm1.tilerEnable[DEI_LINK_OUT_QUE_VIP_SC] = FALSE;
deiPrm1.comprEnable = FALSE;
deiPrm1.interlacedBypassMode = FALSE;
deiPrm1.setVipScYuv422Format = FALSE;
deiPrm1.inputDeiFrameRate = 60;
deiPrm1.outputDeiFrameRate = 60;
deiPrm1.inputFrameRate[DEI_LINK_OUT_QUE_VIP_SC] = 60;
deiPrm1.outputFrameRate[DEI_LINK_OUT_QUE_VIP_SC] = 30;
deiPrm1.outScaleFactor[DEI_LINK_OUT_QUE_VIP_SC][0].scaleMode = DEI_SCALE_MODE_RATIO;
deiPrm1.outScaleFactor[DEI_LINK_OUT_QUE_VIP_SC][0].ratio.widthRatio.numerator = 1;
deiPrm1.outScaleFactor[DEI_LINK_OUT_QUE_VIP_SC][0].ratio.widthRatio.denominator = 1;
deiPrm1.outScaleFactor[DEI_LINK_OUT_QUE_VIP_SC][0].ratio.heightRatio.numerator = 1;
deiPrm1.outScaleFactor[DEI_LINK_OUT_QUE_VIP_SC][0].ratio.heightRatio.denominator = 1;
deiPrm1.outScaleFactor[DEI_LINK_OUT_QUE_VIP_SC][chId] = deiPrm1.outScaleFactor[DEI_LINK_OUT_QUE_VIP_SC][0];
