Hi, Sir
I'm using DM8168 with RDK3.0.
And I want to encode 3-path video to H.264 streams,
the resolution are 1080P30, 1080P30, 1080P30 and 720P30
or 1080P30, 1080P30, 1080P30 and 720X576@30;
Encountered one problem:
TILER AllocFailed:CntMode:0,Width=1920,Height=1088
Assertion @ Line: 159 in utils/src/utils_tiler.c: (UInt32)(pFrame->addr[0][0]) != SYSTEM_TILER_INVALID_ADDR : failed !!!
detailed in the attachment...
Script started on Wed Aug 20 11:59:28 2014 root@dm816x:~# ./de root@dm816x:~# ./demo.[Jn[8D root@dm816x:~# ./demo.nfs.yrp.sh [J *** Bootargs Validated for mem param *** *** Bootargs Validated for notifyk.vpssm3 params *** Kernel bootargs validated numid=1,iface=MIXER,name='PCM Playback Volume' ; type=INTEGER,access=rw---R--,values=2,min=0,max=48,step=0 : values=0,0 | dBscale-min=0.00dB,step=0.50dB,mute=0 numid=9,iface=MIXER,name='ADC Level Volume' ; type=INTEGER,access=rw---R--,values=2,min=0,max=40,step=0 : values=0,0 | dBscale-min=0.00dB,step=0.50dB,mute=0 [c6xdsp ] Remote Debug Shared Memory @ 0xbf000000 [m3video] Remote Debug Shared Memory @ 0xbf005020 [m3vpss ] Remote Debug Shared Memory @ 0xbf00a040 Setting DMM priority for [DUCATI ] to [0] ( 0x4e000624 = 0x08000000 ) Setting DMM priority for [HDVICP0 ] to [2] ( 0x4e000634 = 0x0000000a ) Setting DMM priority for [HDVICP1 ] to [2] ( 0x4e000634 = 0x000a0000 ) Setting DMM priority for [HDVICP2 ] to [2] ( 0x4e000634 = 0x00a00000 ) Attached to slave procId 2. Loaded file ../firmware/dvr_rdk_fw_m3vpss.xem3 on slave procId 2. Started slave procId 2. After Ipc_loadcallback status [0x00000000] [m3vpss ] ***** SYSTEM : Frequency <ORG> - 250000000, <NEW> - 280000000 [m3vpss ] notify_attach rtnVal 0 [m3vpss ] initProxyServer rtnVal 0 [m3vpss ] [m3vpss ] *** UTILS: CPU KHz = 560000 Khz *** [m3vpss ] [m3vpss ] 43: SYSTEM : System Common Init in progress !!! [m3vpss ] 43: SYSTEM: IPC init in progress !!! [m3vpss ] 44: SYSTEM: Attaching to [HOST] ... [m3vpss ] 1043: SYSTEM: Attaching to [HOST] ... [m3vpss ] 1045: SYSTEM: Attaching to [HOST] ... SUCCESS !!! [m3vpss ] 1045: SYSTEM: Attaching to [DSP] ... After Ipc_startcallback status [0x097d2000] Attached to slave procId 1. Loaded file ../firmware/dvr_rdk_fw_m3video.xem3 on slave procId 1. Started slave procId 1. After Ipc_loadcallback status [0x00000000] [m3video] ***** SYSTEM : Frequency <ORG> - 250000000, <NEW> - 280000000 [m3vpss ] 2044: SYSTEM: Attaching to [DSP] ... [m3video] [m3video] *** UTILS: CPU KHz = 560000 Khz *** [m3video] [m3video] 1458: SYSTEM : System Common Init in progress !!! [m3video] 1458: SYSTEM: IPC init in progress !!! [m3video] 1458: SYSTEM: Attaching to [HOST] ... [m3video] 2457: SYSTEM: Attaching to [HOST] ... [m3video] 2459: SYSTEM: Attaching to [HOST] ... SUCCESS !!! [m3video] 2460: SYSTEM: Attaching to [DSP] ... After Ipc_startcallback status [0x00000000] Attached to slave procId 0. Loaded file ../firmware/dvr_rdk_fw_c6xdsp.xe674 on slave procId 0. Started slave procId 0. After Ipc_loadcallback status [0x00000000] [c6xdsp ] ***** SYSTEM : Frequency <ORG> - 800000000, <NEW> - 800000000 [m3video] 3459: SYSTEM: Attaching to [DSP] ... [m3vpss ] 3044: SYSTEM: Attaching to [DSP] ... [c6xdsp ] [m3vpss ] 4044: SYSTEM: Attaching to [DSP] ... [c6xdsp ] *** UTILS: CPU KHz = 800000 Khz *** [c6xdsp ] [c6xdsp ] 7: SYSTEM : System Common Init in progress !!! [c6xdsp ] 7: SYSTEM: IPC init in progress !!! [c6xdsp ] 7: SYSTEM: Attaching to [HOST] ... [c6xdsp ] 1423: SYSTEM: Attaching to [HOST] ... [c6xdsp ] 1426: SYSTEM: Attaching to [HOST] ... SUCCESS !!! [c6xdsp ] 1426: SYSTEM: Attaching to [VIDEO-M3] ... After Ipc_startcallback status [0x00000000] [c6xdsp ] Remote Debug Shared Memory @ 0xbf000000 [m3video] Remote Debug Shared Memory @ 0xbf005020 [m3vpss ] Remote Debug Shared Memory @ 0xbf00a040 [m3video] 4459: SYSTEM: Attaching to [DSP] ... [m3vpss ] 5044: SYSTEM: Attaching to [DSP] ... [c6xdsp ] 2841: SYSTEM: Attaching to [VIDEO-M3] ... [c6xdsp ] 3224: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!! [m3video] 5459: SYSTEM: Attaching to [DSP] ... [c6xdsp ] 3224: SYSTEM: Attaching to [VPSS-M3] ... [m3video] 5460: SYSTEM: Attaching to [DSP] ... SUCCESS !!! [m3video] 5460: SYSTEM: Attaching to [VPSS-M3] ... [m3vpss ] 6044: SYSTEM: Attaching to [DSP] ... [m3video] 6459: SYSTEM: Attaching to [VPSS-M3] ... [c6xdsp ] 4640: SYSTEM: Attaching to [VPSS-M3] ... [c6xdsp ] 5321: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!! [m3vpss ] 7044: SYSTEM: Attaching to [DSP] ... [c6xdsp ] 5321: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ... [m3vpss ] 7045: SYSTEM: Attaching to [DSP] ... SUCCESS !!! [m3vpss ] 7045: SYSTEM: Attaching to [VIDEO-M3] ... [m3video] 7459: SYSTEM: Attaching to [VPSS-M3] ... [m3video] 8045: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!! [m3vpss ] 8044: SYSTEM: Attaching to [VIDEO-M3] ... [m3video] 8045: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ... [m3vpss ] 8045: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!! [m3video] 8045: SYSTEM: Creating MsgQ [VIDEO-M3_MSGQ] ... [m3vpss ] 8045: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP] ... [m3video] 8045: SYSTEM: Creating MsgQ [VIDEO-M3_ACK_MSGQ] ... [m3vpss ] 8045: SYSTEM: Creating MsgQ [VPSS-M3_MSGQ] ... [m3video] 8047: SYSTEM: Notify register to [HOST] line 0, event 15 ... [m3vpss ] 8045: SYSTEM: Creating MsgQ [VPSS-M3_ACK_MSGQ] ... [m3video] 8047: SYSTEM: Notify register to [DSP] line 0, event 15 ... [m3vpss ] 8047: SYSTEM: Notify register to [HOST] line 0, event 15 ... [m3video] 8047: SYSTEM: Notify register to [VPSS-M3] line 0, event 15 ... [m3vpss ] 8047: SYSTEM: Notify register to [DSP] line 0, event 15 ... [m3video] 8047: SYSTEM: IPC init DONE !!! [m3vpss ] 8047: SYSTEM: Notify register to [VIDEO-M3] line 0, event 15 ... [m3video] 8054: MEM: Shared Region 2: Base = 0xb0000000, Length = 0x0e9c0000 (233 MB) [m3vpss ] 8047: SYSTEM: IPC init DONE !!! [m3video] 8054: MEM: Shared Region 1: Base = 0x88000000, Length = 0x14a80000 (330 MB) [m3vpss ] 8054: MEM: Shared Region 2: Base = 0xb0000000, Length = 0x0e9c0000 (233 MB) [m3vpss ] 8054: MEM: Shared Region 1: Base = 0x88000000, Length = 0x14a80000 (330 MB) [m3video] 8056: SYSTEM : System Common Init Done !!! [m3vpss ] 8056: SYSTEM : System Common Init Done !!! [m3video] 8056: SYSTEM : System Video Init in progress !!! [m3vpss ] 8056: SYSTEM : System VPSS Init in progress !!! [m3video] 8056: SYSTEM : System Video Init Done !!! [m3vpss ] === HDVPSS Clocks are enabled === [m3video] 8056: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_0] in region 0 ... [m3vpss ] === HDVPSS is fully functional === [m3video] 8057: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_0] in region 0 ... [m3vpss ] === HDVPSS module is not in standby === [m3video] 8057: SYSTEM: ListElem Shared Addr = 0xbf18b680 [m3vpss ] === I2C1 Clk is active === [m3video] 8059: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_1] in region 0 ... [m3vpss ] PLATFORM: UNKNOWN CPU detected, defaulting to VPS_PLATFORM_CPU_REV_2_0 [m3video] 8059: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_1] in region 0 ... [m3vpss ] 8062: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_0] in region 0 ... [m3video] 8059: SYSTEM: ListElem Shared Addr = 0xbf18eb80 [m3vpss ] 8062: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_0] in region 0 ... [m3video] 8064: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_19] in region 0 ... [m3vpss ] 8062: SYSTEM: ListElem Shared Addr = 0xbf192080 [m3video] 8065: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_19] in region 0 ... [m3vpss ] 8064: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_1] in region 0 ... [m3video] 8065: SYSTEM: ListElem Shared Addr = 0xbf198a80 [m3vpss ] 8064: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_1] in region 0 ... [m3vpss ] 8065: SYSTEM: ListElem Shared Addr = 0xbf195b00 [m3video] 8067: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_20] in region 0 ... [m3vpss ] 8075: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_19] in region 0 ... [m3video] 8067: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_20] in region 0 ... [m3vpss ] 8076: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_19] in region 0 ... [m3video] 8067: SYSTEM: ListElem Shared Addr = 0xbf1b8480 [m3vpss ] 8076: SYSTEM: ListElem Shared Addr = 0xbf1f7880 [m3video] 8069: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_21] in region 0 ... [m3video] 8069: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_21] in region 0 ... [m3video] 8070: SYSTEM: ListElem Shared Addr = 0xbf1d7e80 [m3video] 8080: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_24] in region 0 ... [m3vpss ] 8078: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_20] in region 0 ... [m3video] 8080: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_24] in region 0 ... [m3vpss ] 8078: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_20] in region 0 ... [m3video] 8081: SYSTEM: ListElem Shared Addr = 0xbf236f00 [m3vpss ] 8078: SYSTEM: ListElem Shared Addr = 0xbf217280 [m3video] 8082: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_25] in region 0 ... [m3vpss ] 8080: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_21] in region 0 ... [m3video] 8083: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_25] in region 0 ... [m3vpss ] 8081: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_21] in region 0 ... [m3video] 8083: SYSTEM: ListElem Shared Addr = 0xbf274180 [m3vpss ] 8081: SYSTEM: ListElem Shared Addr = 0xbf254780 [m3video] 8084: HDVICP: Doing PRCM for IVAHD[0] ... [m3vpss ] 8082: SYSTEM : HDVPSS Drivers Version: HDVPSS_01_00_01_37 [m3video] 8085: HDVICP: PRCM for IVAHD[0] ... DONE. [m3vpss ] 8083: SYSTEM : FVID2 Init in progress !!! [m3video] 8085: HDVICP: Doing PRCM for IVAHD[1] ... [m3video] 8085: HDVICP: PRCM for IVAHD[1] ... DONE. [m3video] 8085: HDVICP: Doing PRCM for IVAHD[2] ... [m3video] 8085: HDVICP: PRCM for IVAHD[2] ... DONE. [m3video] 8085: SYSTEM : Initializing Links !!! [m3video] 8086: SYSTEM : FREE SPACE : System Heap = 6280232 B, Mbx = 10240 msgs) [m3video] 8086: SYSTEM : FREE SPACE : SR0 Heap = 14084480 B (13 MB) [c6xdsp ] 6737: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ... [m3video] 8086: SYSTEM : FREE SPACE : Frame Buffer = 245104512 B (233 MB) [c6xdsp ] 6737: SYSTEM: Creating MsgQ [DSP_MSGQ] ... [c6xdsp ] 6737: SYSTEM: Creating MsgQ [DSP_ACK_MSGQ] ... [m3video] 8086: SYSTEM : FREE SPACE : Bitstream Buffer = 346554240 B (330 MB) [c6xdsp ] 6738: SYSTEM: Notify register to [HOST] line 0, event 15 ... [c6xdsp ] 6738: SYSTEM: Notify register to [VIDEO-M3] line 0, event 15 ... [m3video] 8086: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ... [c6xdsp ] 6738: SYSTEM: Notify register to [VPSS-M3] line 0, event 15 ... [m3video] 8087: SYSTEM : FREE SPACE : Tiler 8-bit = 134217728 B (128 MB) - TILER ON [c6xdsp ] 6738: SYSTEM: IPC init DONE !!! [c6xdsp ] 6740: MEM: Shared Region 2: Base = 0xb0000000, Length = 0x0e9c0000 (233 MB) [m3video] 8087: SYSTEM : FREE SPACE : Tiler 16-bit = 134217728 B (128 MB) - TILER ON [c6xdsp ] 6740: MEM: Shared Region 1: Base = 0x88000000, Length = 0x14a80000 (330 MB) [c6xdsp ] 6741: SYSTEM : System Common Init Done !!! [m3video] 8108: SYSTEM : Initializing Links ... DONE !!! [c6xdsp ] 4754: SYSTEM : System DSP Init in progress !!! [c6xdsp ] 4754: SYSTEM : RpeServer_init() done... Ret Val 0!!! [c6xdsp ] 6744: SYSTEM: Creating ListMP [DSP_IPC_OUT_19] in region 0 ... [c6xdsp ] 6744: SYSTEM: Creating ListMP [DSP_IPC_IN_19] in region 0 ... [c6xdsp ] 6744: SYSTEM: ListElem Shared Addr = 0xbf291c80 [c6xdsp ] 6745: SYSTEM: Creating ListMP [DSP_IPC_OUT_20] in region 0 ... [c6xdsp ] 6745: SYSTEM: Creating ListMP [DSP_IPC_IN_20] in region 0 ... [c6xdsp ] 6745: SYSTEM: ListElem Shared Addr = 0xbf2b1680 [c6xdsp ] 6746: SYSTEM: Creating ListMP [DSP_IPC_OUT_21] in region 0 ... [c6xdsp ] 6747: SYSTEM: Creating ListMP [DSP_IPC_IN_21] in region 0 ... [c6xdsp ] 6747: SYSTEM: ListElem Shared Addr = 0xbf2d1080 [c6xdsp ] 6748: SYSTEM: Creating ListMP [DSP_IPC_OUT_24] in region 0 ... [c6xdsp ] 6748: SYSTEM: Creating ListMP [DSP_IPC_IN_24] in region 0 ... [c6xdsp ] 6748: SYSTEM: ListElem Shared Addr = 0xbf2f0a80 [c6xdsp ] 6749: SYSTEM: Creating ListMP [DSP_IPC_OUT_25] in region 0 ... [c6xdsp ] 6749: SYSTEM: Creating ListMP [DSP_IPC_IN_25] in region 0 ... [c6xdsp ] 6749: SYSTEM: ListElem Shared Addr = 0xbf30e580 [c6xdsp ] !!WARNING.Resource already registered:2 [c6xdsp ] 4761: SYSTEM : Initializing Links !!! [c6xdsp ] 6750: SYSTEM : FREE SPACE : System Heap = 10268208 B, Mbx = 10240 msgs) [m3vpss ] 8139: SYSTEM : FVID2 Init in progress DONE !!! [m3vpss ] 8139: SYSTEM : Device Init in progress !!! [c6xdsp ] 4769: SYSTEM : Initializing Links ... DONE !!! [m3vpss ] initPrms.isI2cInitReq = 0 [c6xdsp ] 4770: SYSTEM : System DSP Init Done !!! [m3vpss ] initPrms.isI2cInitReq = 0 [m3vpss ] 8142: SYSTEM : Device Init in progress DONE !!! [m3vpss ] 8263: SYSTEM : System VPSS Init Done !!! [m3vpss ] 8264: UTILS: DMA: HWI Create for INT63 !!! [m3vpss ] 8264: SYSTEM : Initializing Links !!! [m3vpss ] 8264: SYSTEM : FREE SPACE : System Heap = 13112 B, Mbx = 10240 msgs) [m3vpss ] 8264: SYSTEM : FREE SPACE : SR0 Heap = 13452672 B (12 MB) [m3vpss ] 8264: SYSTEM : FREE SPACE : Frame Buffer = 240794496 B (229 MB) [m3vpss ] 8264: SYSTEM : FREE SPACE : Bitstream Buffer = 346554240 B (330 MB) [m3vpss ] 8265: SYSTEM : FREE SPACE : Tiler 8-bit = 134217728 B (128 MB) - TILER ON [m3vpss ] 8265: SYSTEM : FREE SPACE : Tiler 16-bit = 134217728 B (128 MB) - TILER ON [m3vpss ] Received character 's' [m3vpss ] 8348: SYSTEM : Initializing Links ... DONE !!! [c6xdsp ] Remote Debug Shared Memory @ 0xbf000000 [m3video] Remote Debug Shared Memory @ 0xbf005020 [m3vpss ] Remote Debug Shared Memory @ 0xbf00a040 [m3video] Received character 's' [m3vpss ] 8348: SYSTEM : Set Static L3 pressure for HDVPSS as High [c6xdsp ] Remote Debug Shared Memory @ 0xbf000000 [m3video] Remote Debug Shared Memory @ 0xbf005020 [m3vpss ] Remote Debug Shared Memory @ 0xbf00a040 [c6xdsp ] Received character 's' /mnt/opt/dvr_rdk/ti816x ORG 0x46c00524: 0 NEW 0x46c00524: 2 Document parsed successfully. ATsha204 -1.0 check success 0: SYSTEM: System Common Init in progress !!! 0: SYSTEM: IPC init in progress !!! 14: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ... 16: SYSTEM: Creating MsgQ [HOST_MSGQ] ... 17: SYSTEM: Creating MsgQ [HOST_ACK_MSGQ] ... 17: SYSTEM: Opening MsgQ [DSP_MSGQ] ... 18: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ... 18: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ... 19: SYSTEM: Notify register to [DSP] line 0, event 15 ... 19: SYSTEM: Notify register to [VIDEO-M3] line 0, event 15 ... 20: SYSTEM: Notify register to [VPSS-M3] line 0, event 15 ... 20: SYSTEM: IPC init DONE !!! 21: SYSTEM: Creating ListMP [HOST_IPC_OUT_24] in region 0 ... 23: SYSTEM: Creating ListMP [HOST_IPC_IN_24] in region 0 ... 24: SYSTEM: ListElem Shared Addr = 0x4085f080 25: SYSTEM: Creating ListMP [HOST_IPC_OUT_25] in region 0 ... 26: SYSTEM: Creating ListMP [HOST_IPC_IN_25] in region 0 ... 28: SYSTEM: ListElem Shared Addr = 0x4087cb80 29: SYSTEM: Creating ListMP [HOST_IPC_OUT_19] in region 0 ... 31: SYSTEM: Creating ListMP [HOST_IPC_IN_19] in region 0 ... 32: SYSTEM: ListElem Shared Addr = 0x4089a680 33: SYSTEM: Creating ListMP [HOST_IPC_OUT_20] in region 0 ... 35: SYSTEM: Creating ListMP [HOST_IPC_IN_20] in region 0 ... 36: SYSTEM: ListElem Shared Addr = 0x408ba080 37: SYSTEM: Creating ListMP [HOST_IPC_OUT_21] in region 0 ... 39: SYSTEM: Creating ListMP [HOST_IPC_IN_21] in region 0 ... 40: SYSTEM: ListElem Shared Addr = 0x408d9a80 56: SYSTEM: System Common Init Done !!! sii9233 init start sii9233 init done MDIN325 Init Done! pcie video channel Init Done! 1576: CHAINS : CPU Revision [ES2.0] !!! 1576: CHAINS : Detected [UNKNOWN] Board !!! 1576: CHAINS : Base Board Revision [REV A] !!! [host] Entered:audioEnvironmentInit... [host] complete:audioEnvironmentInit...***************period size:[1024] AUDIO: ENC Handle A82C28, Int Handle A82C34 AUDIO: ENC -> bitrate 30000 inputBitsPerSample 16, sampleRate - 22050, numberOfChannels - 1... AUDIO: ENC -> Rpe_create(AAC_ENC) done.... AUDIO: ENC Handle A82DF8, Int Handle A82E04 AUDIO: ENC -> bitrate 30000 inputBitsPerSample 16, sampleRate - 22050, numberOfChannels - 1... AUDIO: ENC -> Rpe_create(AAC_ENC) done.... AUDIO: ENC Handle A831F0, Int Handle A831FC AUDIO: ENC -> bitrate 30000 inputBitsPerSample 16, sampleRate - 22050, numberOfChannels - 1... AUDIO: ENC -> Rpe_create(AAC_ENC) done.... AUDIO: DEC -> Handle A83318, Int Handle A83320 AUDIO: DEC -> Rpe_create(AAC_DEC) done.... AUDIO: DEC -> Handle A83418, Int Handle A83420 AUDIO: DEC -> Rpe_create(AAC_DEC) done.... 2.078666 [ IPCBitsOutDataStructInit] DataStruct(EmptyQueueOut-FullQueueOut) Created 2.084122 [ GetEmptyBuffersfromIPCBitsOutHLOSLINK] PID = 1519, Thread ID = 1533, Run 2.084219 [ IPCBitsOutCoreThreadsStart] GetEmptyBuffersfromIPCBitsOutHLOSLINK Created 2.084327 [ PutFullBufferstoIPCBitsOutHLOSLINK] PID = 1519, Thread ID = 1534, Run 2.084365 [ IPCBitsOutCoreThreadsStart] PutFullBufferstoIPCBitsOutHLOSLINK Created 2.084389 [ IPCBitsInDataStructInit] DataStruct(FullSemaphoreIn, BDTaskQueue) Created 2.084406 [ IPCBitsEnvironmentInit]Created 2.131097 [ ProcessEncodedData- 0] PID = 1519, Thread ID = 1535, Run 2.131319 [ ProcessEncodedData- 0] StreamServerURLPort = 8560 2.131743 [ ProcessEncodedData- 0] rtsp object created successfully 2.131787 [ ProcessEncodedData- 0] StreamServerURLName = Cam3 2.131807 [ ProcessEncodedData- 0] StreamServerURLName = Stream_A_Cam3 2.131824 [ ProcessEncodedData- 0] StreamServerURLName = Stream_B_Cam3 Play this stream using the URL "rtsp://192.168.129.8:8560/Cam3" Play this stream using the URL "rtsp://192.168.129.8:9560/Stream_A_Cam3" Play this stream using the URL "rtsp://192.168.129.8:9561/Stream_B_Cam3" 2.133003 [ PeripheralProcessEncodedDataStart] ProcessEncodedData- 0 Created 2.133164 [ ProcessEncodedData- 1] PID = 1519, Thread ID = 1539, Run 2.133309 [ ProcessEncodedData- 1] StreamServerURLPort = 8556 2.133591 [ ProcessEncodedData- 1] rtsp object created successfully 2.133626 [ ProcessEncodedData- 1] StreamServerURLName = Cam1 2.133644 [ ProcessEncodedData- 1] StreamServerURLName = Stream_A_Cam1 2.133662 [ ProcessEncodedData- 1] StreamServerURLName = Stream_B_Cam1 Play this stream using the URL "rtsp://192.168.129.8:8556/Cam1" Play this stream using the URL "rtsp://192.168.129.8:9556/Stream_A_Cam1" Play this stream using the URL "rtsp://192.168.129.8:9557/Stream_B_Cam1" 2.134114 [ PeripheralProcessEncodedDataStart] ProcessEncodedData- 1 Created 2.134245 [ ProcessEncodedData- 2] PID = 1519, Thread ID = 1543, Run 2.134328 [ ProcessEncodedData- 2] StreamServerURLPort = 8562 2.134425 [ ProcessEncodedData- 2] rtsp object created successfully 2.134453 [ ProcessEncodedData- 2] StreamServerURLName = PCIe Play this stream using the URL "rtsp://192.168.129.8:8562/PCIe" 2.134619 [ PeripheralProcessEncodedDataStart] ProcessEncodedData- 2 Created 2.134728 [ ProcessEncodedData- 3] PID = 1519, Thread ID = 1545, Run 2.134802 [ ProcessEncodedData- 3] StreamServerURLPort = 8564 2.134904 [ ProcessEncodedData- 3] rtsp object created successfully 2.134945 [ ProcessEncodedData- 3] StreamServerURLName = Swms0 Play this stream using the URL "rtsp://192.168.129.8:8564/Swms0" 2.135128 [ PeripheralProcessEncodedDataStart] ProcessEncodedData- 3 Created 2.135241 [ BDTask] PID = 1519, Thread ID = 1547, Run 2.135269 [ BDTask] wait for get Cell from Queue...... 2.135292 [ PeripheralProcessEncodedDataStart] BDTask Created 2.135394 [ CopyDatafromIPCBitsInHLOSLINK] PID = 1519, Thread ID = 1548, Run 2.135427 [ TestCopyThreadsStart] CopyDatafromIPCBitsInHLOSLINK Created set_uart_parame[39] configure complete 2.141751 [ PeripheralGetStreamsStart] GetStream- 0 Created 2.142168 [ PeripheralGetStreamsStart] GetStream- 1 Created [host] Entered:audio_createDecode... [host] Entered:audioDecProcessFxn... [host] Entered:audioDecProcessFxn... [host] 1829: IPC_FRAMES_OUT : Create in progress !!! [host] 1830: IPC_FRAMES_OUT : Create Done !!! [m3vpss ] 13212: CAPTURE: Create in progress !!! [m3vpss ] 13244: CAPTURE: VIP0 PortA capture mode is [ 8-bit, Non-mux Discrete Sync - ACTVID_VSYNC] !!! [m3vpss ] CAPTURE:Create args numBufsPerCh[4] < min[6]Overriding create args [m3vpss ] 13362: CAPTURE: VIP0 PortB capture mode is [ 8-bit, Non-mux Discrete Sync - ACTVID_VSYNC] !!! [m3vpss ] 13481: CAPTURE: VIP1 PortA capture mode is [ 8-bit, Non-mux Discrete Sync - ACTVID_VSYNC] !!! [m3vpss ] 13599: CAPTURE: VIP1 PortB capture mode is [ 8-bit, Non-mux Discrete Sync - ACTVID_VSYNC] !!! [host] CHAINS_IPCALLOCBUF:Translated Addr Virt:0x40ab4900 To Phy:0xbf581900 Shared:0x481900 [host] CHAINS_IPCALLOCBUF:Translated Addr Virt:0x40ae1900 To Phy:0xbf5ae900 Shared:0x4ae900 [host] CHAINS_IPCALLOCBUF:Translated Addr Virt:0x40b0e900 To Phy:0xbf5db900 Shared:0x4db900 [host] CHAINS_IPCALLOCBUF:Translated Addr Virt:0x40b3b900 To Phy:0xbf608900 Shared:0x508900 [m3vpss ] 14031: CAPTURE: 0: 0xb676d480, 1920 x 1080, 003f4800 B --> Extra Frames [m3vpss ] 14031: CAPTURE: 1: 0xb6b61c80, 1920 x 1080, 003f4800 B --> Extra Frames [m3vpss ] 14031: CAPTURE: 2: 0xb6f56480, 1920 x 1080, 003f4800 B --> Extra Frames [m3vpss ] 14032: CAPTURE: 3: 0xb734ac80, 1920 x 1080, 003f4800 B --> Extra Frames [m3vpss ] 14032: CAPTURE: 4: 0xb773f480, 1920 x 1080, 003f4800 B --> Extra Frames [m3vpss ] 14032: CAPTURE: 5: 0xb7b33c80, 1920 x 1080, 003f4800 B --> Extra Frames [m3vpss ] 14032: CAPTURE: 6: 0xb7f28480, 1920 x 1080, 003f4800 B --> Extra Frames [m3vpss ] 14032: CAPTURE: 7: 0xb831cc80, 1920 x 1080, 003f4800 B --> Extra Frames [m3vpss ] 14032: CAPTURE: 8: 0xb8711480, 1920 x 1080, 003f4800 B --> Extra Frames [m3vpss ] 14032: CAPTURE: 9: 0xb8b05c80, 1920 x 1080, 003f4800 B --> Extra Frames [m3vpss ] 14032: CAPTURE: 10: 0xb8efa480, 1920 x 1080, 003f4800 B --> Extra Frames [m3vpss ] 14032: CAPTURE: 11: 0xb92eec80, 1920 x 1080, 003f4800 B --> Extra Frames [m3vpss ] 14032: CAPTURE: 12: 0xb96e3480, 1920 x 1080, 003f4800 B --> Extra Frames [m3vpss ] 14032: CAPTURE: 13: 0xb9ad7c80, 1920 x 1080, 003f4800 B --> Extra Frames [m3vpss ] 14032: CAPTURE: 14: 0xb9ecc480, 1920 x 1080, 003f4800 B --> Extra Frames [m3vpss ] 14032: CAPTURE: 15: 0xba2c0c80, 1920 x 1080, 003f4800 B --> Extra Frames [m3vpss ] UTILS: DMA: Allocated CH (TCC) = 58 (58) [host] CHAINS_IPCALLOCBUF:Translated Addr Virt:0x40b68900 To Phy:0xbf635900 Shared:0x535900 [host] 2632: IPC_BITS_OUT : Create in progress !!! ###Bit buff of size from the SR # 1 : 66355200 [host] IPC_BITSOUT:BitBuffer Alloc.PoolID:0,Size:0x3F48000 [host] IPCBITSOUTLINK:Translated Addr Virt:0x41722c80 To Phy:0x881b2c80 [host] 2633: IPC_BITS_OUT : Create Done !!! [m3vpss ] CAPTURE::HEAPID:0 USED:992 [m3vpss ] CAPTURE::HEAPID:4 USED:170496000 [m3vpss ] 14033: CAPTURE: Create Done !!! [m3video] 14065: IPC_BITS_IN : Create in progress !!! [m3video] 14065: SYSTEM: Opening ListMP [HOST_IPC_OUT_24] ... [m3video] 14066: SYSTEM: Opening ListMP [HOST_IPC_IN_24] ... [m3video] 14067: SYSTEM: Opening MsgQ [HOST_MSGQ] ... [m3video] 14069: IPC_BITS_IN : Create Done !!! [m3video] 14070: DECODE: Create in progress ... !!! [m3video] DECLINK_H264:HEAPID:0 USED:4264 [m3video] DECLINK_H264:HEAPID:3 USED:29274112 [m3video] 14211: DECODE: Creating CH0 of 1920 x 1080 [PROGRESSIVE] [TILED ],target bitrate = 0 Kbps ... [m3vpss ] 14357: IPC_IN_M3 : Create in progress !!! [m3video] DECLINK_H264:HEAPID:0 USED:2368 [m3vpss ] 14358: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_0] ... [m3video] DECLINK_H264:HEAPID:3 USED:29274112 [m3vpss ] 14358: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_0] ... [m3video] 14352: DECODE: Creating CH1 of 1920 x 1080 [PROGRESSIVE] [TILED ],target bitrate = 0 Kbps ... [m3vpss ] 14359: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ... [m3video] 14353: DECODE: All CH Create ... DONE !!! [m3vpss ] 14360: IPC_IN_M3 : Create Done !!! [m3vpss ] 14361: IPC_FRAMES_IN : Create in progress !!! [m3vpss ] 14361: SYSTEM: Opening ListMP [HOST_IPC_OUT_19] ... [m3video] DECLINK:HEAPID:0 USED:6752 [m3vpss ] 14361: SYSTEM: Opening ListMP [HOST_IPC_IN_19] ... [m3video] DECLINK:HEAPID:3 USED:58548224 [m3vpss ] 14362: SYSTEM: Opening MsgQ [HOST_MSGQ] ... [m3video] 14356: DECODE: Create ... DONE !!! [m3video] 14356: IPC_OUT_M3 : Create in progress !!! [m3video] 14357: IPC_OUT_M3 : Create Done !!! [m3vpss ] IPC_FRAMES_IN:HEAPID:0 USED:304 [c6xdsp ] 15015: IPC_FRAMES_IN : Create in progress !!! [m3vpss ] 14365: IPC_FRAMES_IN : Create Done !!! [c6xdsp ] 15015: SYSTEM: Opening ListMP [VPSS-M3_IPC_OUT_19] ... [m3vpss ] 14366: MERGE : Create Done !!! [c6xdsp ] 15015: SYSTEM: Opening ListMP [VPSS-M3_IPC_IN_19] ... [m3vpss ] 14366: IPC_FRAMES_OUT : Create in progress !!! [c6xdsp ] 15016: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ... [m3vpss ] 14368: IPC_FRAMES_OUT : Create Done !!! [c6xdsp ] IPC_FRAMES_IN:HEAPID:0 USED:304 [m3vpss ] 14385: DUP : Create Done !!! [c6xdsp ] 15017: IPC_FRAMES_IN : Create Done !!! [m3vpss ] 14385: SWMS: Create in progress !!! [c6xdsp ] 15020: ALG : Create in progress !!! [c6xdsp ] 15028: ALG : Create Done !!! [m3vpss ] UTILS: DMA: Allocated CH (TCC) = 59 (59) [m3vpss ] UTILS: DMA: Allocated CH (TCC) = 60 (60) [m3vpss ] SWMS: instance 0, sc id 6, start win 0 end win 1 [m3vpss ] 14563: SWMS : VipScReq is FALSE!!! [m3vpss ] 14564: SWMS0 : Loading Vertical Co-effs (UPSCALE)x ... [m3vpss ] 14564: SWMS0 : Loading Horizontal Co-effs (UPSCALE)x ... [m3vpss ] 14564: SWMS : Co-effs Loading ... DONE !!! [m3vpss ] SWMS: instance 1, sc id 7, start win 2 end win 19 [m3vpss ] 14564: SWMS : VipScReq is FALSE!!! [m3vpss ] 14567: SWMS0 : Loading Vertical Co-effs (UPSCALE)x ... [m3vpss ] 14567: SWMS0 : Loading Horizontal Co-effs (UPSCALE)x ... [m3vpss ] 14567: SWMS : Co-effs Loading ... DONE !!! [m3vpss ] [m3vpss ] 14586: SWMS : ******* Configuring clock 33 secs... [m3vpss ] 14586: SWMS0 : Loading Vertical Co-effs (UPSCALE)x ... [m3vpss ] 14586: SWMS0 : Loading Horizontal Co-effs (UPSCALE)x ... [m3vpss ] 14586: SWMS : Co-effs Loading ... DONE !!! [m3vpss ] [m3vpss ] *** [SWMS0] Mosaic Parameters *** [m3vpss ] [m3vpss ] Output FPS: 30 [m3vpss ] [m3vpss ] Win | Ch | Input | Input | Input | Input | Output | Output | Output | Output | Low Cost | SWMS | Data | Blank | [m3vpss ] Num | Num | Start X, Y | Width x Height | Pitch Y / C | Memory Type | Start X, Y | Width x Height | Pitch Y / C | Memory Type | ON / OFF | Inst | Format| Frame | [m3vpss ] ---------------------------------------------------------------------------------------------------------------------------------------------------------------------- [m3vpss ] 0 | 3 | 0, 0 | 1920 x 540 | 7680 / 7680 | NON-TILED | 240, 0 | 1440 x 810 | 3840 / 0 | NON-TILED | ON | 0 | 422I | OFF | [m3vpss ] 1 | 1 | 0, 0 | 1920 x 540 | 7680 / 7680 | NON-TILED | 0, 810 | 480 x 270 | 3840 / 0 | NON-TILED | ON | 0 | 422I | OFF | [m3vpss ] 2 | 2 | 0, 0 | 1920 x 540 | 7680 / 7680 | NON-TILED | 480, 810 | 480 x 270 | 3840 / 0 | NON-TILED | ON | 1 | 422I | OFF | [m3vpss ] 3 | 0 | 0, 0 | 1920 x 540 | 7680 / 7680 | NON-TILED | 960, 810 | 480 x 270 | 3840 / 0 | NON-TILED | ON | 1 | 422I | OFF | [m3vpss ] 4 | 4 | 0, 0 | 1280 x 720 | 2560 / 0 | NON-TILED | 1440, 810 | 480 x 270 | 3840 / 0 | NON-TILED | OFF | 1 | 422I | OFF | [m3vpss ] 5 | 255 | 0, 0 | 352 x 264 | 704 / 704 | NON-TILED | 0, 0 | 240 x 810 | 3840 / 0 | NON-TILED | ON | 1 | 422I | OFF | [m3vpss ] 6 | 255 | 0, 0 | 352 x 264 | 704 / 704 | NON-TILED | 1680, 0 | 240 x 810 | 3840 / 0 | NON-TILED | ON | 1 | 422I | OFF | [m3vpss ] [c6xdsp ] 15315: IPC_FRAMES_IN : Create in progress !!! [c6xdsp ] 15315: SYSTEM: Opening ListMP [VPSS-M3_IPC_OUT_20] ... [m3vpss ] SWMS:HEAPID:0 USED:792 [c6xdsp ] 15315: SYSTEM: Opening ListMP [VPSS-M3_IPC_IN_20] ... [m3vpss ] SWMS:HEAPID:1 USED:22336 [m3vpss ] SWMS:HEAPID:3 USED:29030400 [m3vpss ] SWMS:HEAPID:4 USED:8294400 [c6xdsp ] IPC_FRAMES_IN:HEAPID:0 USED:304 [m3vpss ] 14590: SWMS: Create Done !!! [c6xdsp ] 15317: IPC_FRAMES_IN : Create Done !!! [m3vpss ] 14593: IPC_FRAMES_OUT : Create in progress !!! [c6xdsp ] 15321: ALG : Create in progress !!! [m3vpss ] 14595: IPC_FRAMES_OUT : Create Done !!! [m3vpss ] 14613: DUP : Create Done !!! [c6xdsp ] ALGLINK:HEAPID:0 USED:2616 [m3vpss ] 14613: DISPLAY: Create in progress !!! [c6xdsp ] ALGLINK:HEAPID:1 USED:12304 [m3vpss ] 14614: DISPLAY: Create Done !!! [c6xdsp ] 15330: ALG : Create Done !!! [m3vpss ] 14615: SWMS: Create in progress !!! [m3vpss ] UTILS: DMA: Allocated CH (TCC) = 61 (61) [m3vpss ] UTILS: DMA: Allocated CH (TCC) = 62 (62) [m3vpss ] SWMS: instance 0, sc id 6, start win 0 end win 1 [m3vpss ] 14696: SWMS : VipScReq is FALSE!!! [m3vpss ] 14697: SWMS1 : Loading Vertical Co-effs (UPSCALE)x ... [m3vpss ] 14697: SWMS1 : Loading Horizontal Co-effs (UPSCALE)x ... [m3vpss ] 14697: SWMS : Co-effs Loading ... DONE !!! [m3vpss ] SWMS: instance 1, sc id 7, start win 2 end win 19 [m3vpss ] 14697: SWMS : VipScReq is FALSE!!! [m3vpss ] 14701: SWMS1 : Loading Vertical Co-effs (UPSCALE)x ... [m3vpss ] 14701: SWMS1 : Loading Horizontal Co-effs (UPSCALE)x ... [m3vpss ] 14701: SWMS : Co-effs Loading ... DONE !!! [m3vpss ] [m3vpss ] 14720: SWMS : ******* Configuring clock 16 secs... [m3vpss ] 14720: SWMS1 : Loading Vertical Co-effs (UPSCALE)x ... [m3vpss ] 14720: SWMS1 : Loading Horizontal Co-effs (UPSCALE)x ... [m3vpss ] 14720: SWMS : Co-effs Loading ... DONE !!! [m3vpss ] [m3vpss ] *** [SWMS1] Mosaic Parameters *** [m3vpss ] [m3vpss ] Output FPS: 60 [m3vpss ] [m3vpss ] Win | Ch | Input | Input | Input | Input | Output | Output | Output | Output | Low Cost | SWMS | Data | Blank | [m3vpss ] Num | Num | Start X, Y | Width x Height | Pitch Y / C | Memory Type | Start X, Y | Width x Height | Pitch Y / C | Memory Type | ON / OFF | Inst | Format| Frame | [m3vpss ] ---------------------------------------------------------------------------------------------------------------------------------------------------------------------- [m3vpss ] 0 | 4 | 0, 0 | 1280 x 720 | 2560 / 0 | NON-TILED | 0, 0 | 1280 x 720 | 2560 / 0 | NON-TILED | OFF | 0 | 422I | OFF | [m3vpss ] [m3vpss ] SWMS:HEAPID:0 USED:792 [m3vpss ] SWMS:HEAPID:1 USED:15296 [m3vpss ] SWMS:HEAPID:3 USED:14745600 [m3vpss ] SWMS:HEAPID:4 USED:1843200 [m3vpss ] 14721: SWMS: Create Done !!! [m3vpss ] 14725: DUP : Create Done !!! [m3vpss ] 14725: DISPLAY: Create in progress !!! [m3vpss ] 14726: DISPLAY: Create Done !!! [m3vpss ] 14727: MERGE : Create Done !!! [m3vpss ] 14731: DUP : Create Done !!! [m3vpss ] 14732: SELECT: OUT QUE0: OUT CH0: IN CH0: 1920 x 1080, pitch = (3840, 3840) [PROGRESSIVE] [NON-TILED ] [m3vpss ] 14732: SELECT: OUT QUE0: OUT CH1: IN CH1: 1920 x 1080, pitch = (3840, 3840) [PROGRESSIVE] [NON-TILED ] [m3vpss ] 14732: SELECT: OUT QUE0: OUT CH2: IN CH4: 1280 x 720, pitch = (2560, 0) [PROGRESSIVE] [NON-TILED ] [m3vpss ] 14733: SELECT: OUT QUE0: OUT CH3: IN CH7: 1920 x 1080, pitch = (3840, 0) [PROGRESSIVE] [NON-TILED ] [m3vpss ] 14733: SELECT : Create Done !!! [m3vpss ] 14734: SELECT: OUT QUE0: OUT CH0: IN CH7: 1920 x 1080, pitch = (3840, 0) [PROGRESSIVE] [NON-TILED ] [m3vpss ] 14734: SELECT : Create Done !!! [m3vpss ] 14735: MERGE : Create Done !!! [m3vpss ] 14735: SWMS: Create in progress !!! [m3vpss ] UTILS: DMA: Allocated CH (TCC) = 63 (63) [m3vpss ] SWMS: instance 0, sc id 6, start win 0 end win 17 [m3vpss ] 14759: SWMS : VipScReq is FALSE!!! [m3vpss ] 14762: SWMS2 : Loading Vertical Co-effs (UPSCALE)x ... [m3vpss ] 14762: SWMS2 : Loading Horizontal Co-effs (UPSCALE)x ... [m3vpss ] 14762: SWMS : Co-effs Loading ... DONE !!! 3297:!!!SLAVE CORE [VPSS-M3] DOWN!!! SystemLink_copySlaveCoreExceptionContext:146 mmap of [0xbe9e0000:36864] mmap virt addresss:0x4005d000 munmap of [0x4005d000:36864] SystemLink_copySlaveCoreExceptionContext:153 [m3vpss ] AVSYNC:WARNING!! Application wrongly configureddisplayID[-1]. Reseting to correct displayID[2] [m3vpss ] 14763: SWMS : ******* Configuring clock 40 secs... [m3vpss ] 14763: SWMS2 : Loading Vertical Co-effs (UPSCALE)x ... [m3vpss ] 14763: SWMS2 : Loading Horizontal Co-effs (UPSCALE)x ... [m3vpss ] 14763: SWMS : Co-effs Loading ... DONE !!! [m3vpss ] [m3vpss ] *** [SWMS2] Mosaic Parameters *** [m3vpss ] [m3vpss ] Output FPS: 25 [m3vpss ] [m3vpss ] Win | Ch | Input | Input | Input | Input | Output | Output | Output | Output | Low Cost | SWMS | Data | Blank | [m3vpss ] Num | Num | Start X, Y | Width x Height | Pitch Y / C | Memory Type | Start X, Y | Width x Height | Pitch Y / C | Memory Type | ON / OFF | Inst | Format| Frame | [m3vpss ] ---------------------------------------------------------------------------------------------------------------------------------------------------------------------- [m3vpss ] 0 | 0 | 0, 0 | 1920 x 540 | 7680 / 0 | NON-TILED | 0, 0 | 720 x 576 | 1472 / 0 | NON-TILED | ON | 0 | 422I | OFF | [m3vpss ] [m3vpss ] SWMS:HEAPID:0 USED:360 [m3vpss ] SWMS:HEAPID:1 USED:15840 [m3vpss ] SWMS:HEAPID:3 USED:3391488 [m3vpss ] SWMS:HEAPID:4 USED:847872 [m3vpss ] 14765: SWMS: Create Done !!! [m3vpss ] 14765: DISPLAY: Create in progress !!! [m3vpss ] 14766: DISPLAY: Create Done !!! [m3vpss ] 14766: NSF: Create in progress !!! [m3vpss ] 14768:WARN [m3vpss ] 14768:TILER AllocFailed:CntMode:0,Width=1920,Height=1088 [m3vpss ] 14768: SYSTEM : FREE SPACE : System Heap = 3504 B, Mbx = 10239 msgs) [m3vpss ] 14768: SYSTEM : FREE SPACE : SR0 Heap = 10082048 B (9 MB) [m3vpss ] 14768: SYSTEM : FREE SPACE : Frame Buffer = 764800 B (0 MB) [m3vpss ] 14768: SYSTEM : FREE SPACE : Bitstream Buffer = 231250816 B (220 MB) [m3vpss ] 14769: SYSTEM : FREE SPACE : Tiler 8-bit = 2646016 B (2 MB) - TILER ON [m3vpss ] 14769: SYSTEM : FREE SPACE : Tiler 16-bit = 68407296 B (65 MB) - TILER ON [m3vpss ] 14769: Assertion @ Line: 159 in utils/src/utils_tiler.c: (UInt32)(pFrame->addr[0][0]) != SYSTEM_TILER_INVALID_ADDR : failed !!! 16.514001 [ GetEmptyBuffersfromIPCBitsOutHLOSLINK] execute 1800, Get 0 Empty Frames(current 0) 16.514086 [ PutFullBufferstoIPCBitsOutHLOSLINK] execute 1800, Put 0 Full Frames(current 0) ^Z[1] + Stopped ./demo.nfs.yrp.sh root@dm816x:~# exit You have stopped jobs. root@dm816x:~# exit Script done on Wed Aug 20 12:00:08 2014
But work properly with the resolution 1080P30, 1080P30, 720P30 and 720X576@30;
How can I fix this issue?
Best Regards!
