I am trying to use DVR RDK v4.1 for evaluating B frame usage.
But when I turn on interFrameInterval=2(intraFrameInterval=30), it shows the following error log.
Could you help to point out what the problem is? Thanks.
[M3 ][Debug] [m3video] 43337: IPC_BITS_IN : Create in progress !!!
[M3 ][Debug] [m3vpss ] WARNING!!.Tiler Memory cannot be accessed by M3 in 2G build.Will not disable
[M3 ][Debug] [m3video] 43337: SYSTEM: Opening ListMP [HOST_IPC_OUT_25] ...
[M3 ][Debug] [m3video] 43338: SYSTEM: Opening ListMP [HOST_IPC_IN_25] ...
[M3 ][Debug] [m3video] 43338: SYSTEM: Opening MsgQ [HOST_MSGQ] ...
[M3 ][Debug] [m3video] 43340: IPC_BITS_IN : Create Done !!!
[M3 ][Debug] [m3video] 43340: DECODE: Create in progress ... !!!
[M3 ][Debug] [m3video] DECLINK_H264:HEAPID:0 USED:4264
[M3 ][Debug] [m3video] DECLINK_H264:HEAPID:3 USED:8937472
[M3 ][Debug] [m3video] 43466: DECODE: Creating CH0 of 1920 x 1080 [PROGRESSIVE] [NON-TILED ],target bitrate = 2000 Kbps ...
[M3 ][Debug] [m3video] 43468: DECODE: All CH Create ... DONE !!!
[M3 ][Debug] [m3vpss ] 43473: IPC_IN_M3 : Create in progress !!!
[M3 ][Debug] [m3video] DECLINK:HEAPID:0 USED:4384
[M3 ][Debug] [m3vpss ] 43473: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_0] ...
[M3 ][Debug] [m3video] DECLINK:HEAPID:3 USED:27000832
[M3 ][Debug] [m3vpss ] 43474: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_0] ...
[M3 ][Debug] [m3video] 43472: DECODE: Create ... DONE !!!
[M3 ][Debug] [m3vpss ] 43474: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
[M3 ][Debug] [m3video] 43472: IPC_OUT_M3 : Create in progress !!!
[M3 ][Debug] [m3vpss ] 43476: IPC_IN_M3 : Create Done !!!
[M3 ][Debug] [m3video] 43473: IPC_OUT_M3 : Create Done !!!
[M3 ][Debug] [m3vpss ] 43476: CAPTURE: Create in progress !!!
[M3 ][Debug] [m3vpss ] 43506: CAPTURE: VIP0 PortA capture mode is [16-bit, Non-mux Embedded Sync] !!!
[M3 ][Debug] [m3vpss ] 43719: CAPTURE: VIP1 PortA capture mode is [16-bit, Non-mux Embedded Sync] !!!
[M3 ][Debug] [m3vpss ] UTILS: DMA: Allocated CH (TCC) = 58 (58)
[M3 ][Debug] [m3vpss ] UTILS: DMA: 0 of 4: Allocated PaRAM = 58 (0x49004740)
[M3 ][Debug] [m3vpss ] UTILS: DMA: 1 of 4: Allocated PaRAM = 64 (0x49004800)
[M3 ][Debug] [m3vpss ] UTILS: DMA: 2 of 4: Allocated PaRAM = 65 (0x49004820)
[M3 ][Debug] [m3vpss ] UTILS: DMA: 3 of 4: Allocated PaRAM = 66 (0x49004840)
[M3 ][Debug] [m3vpss ] CAPTURE::HEAPID:0 USED:520
[M3 ][Debug] [m3vpss ] CAPTURE::HEAPID:4 USED:95385600
[M3 ][Debug] [m3vpss ] 43934: CAPTURE: Create Done !!!
[M3 ][Debug] [m3vpss ] 43937: DUP: 0: Format: PROGRESSIVE, 1920 x 1080
[M3 ][Debug] [m3vpss ] 43938: DUP: 1: Format: PROGRESSIVE, 1920 x 1080
[M3 ][Debug] [m3vpss ] 43939: DUP : Create Done !!!
[M3 ][Debug] [m3vpss ] 43939: NULL_SRC: Create in progress !!!
[M3 ][Debug] [m3vpss ] NULLSRC: channel: 0 , extendParam=0
[M3 ][Debug] [m3vpss ] NULLSRC: channel: 1 , extendParam=0
[M3 ][Debug] [m3vpss ] NULLSRC: channel: 2 , extendParam=0
[M3 ][Debug] [m3vpss ] NULLSRC: channel: 3 , extendParam=0
[M3 ][Debug] [m3vpss ] NULLSRC: channel: 4 , extendParam=1
[M3 ][Debug] [m3vpss ] NullSrc: Paint black !!
[M3 ][Debug] [m3vpss ] NullSrc: Paint pause !!
[M3 ][Debug] [m3vpss ] 43964: NULL_SRC: Create Done !!!
[M3 ][Debug] [m3vpss ] 43965: MERGE: 0: Format: PROGRESSIVE, 1920 x 1080
[M3 ][Debug] [m3vpss ] 43965: MERGE: 1: Format: PROGRESSIVE, 1920 x 1080
[M3 ][Debug] [m3vpss ] 43966: MERGE: 2: Format: PROGRESSIVE, 1920 x 1080
[M3 ][Debug] [m3vpss ] 43966: MERGE: 3: Format: PROGRESSIVE, 360 x 240
[M3 ][Debug] [m3vpss ] 43966: MERGE: 4: Format: PROGRESSIVE, 360 x 240
[M3 ][Debug] [m3vpss ] 43966: MERGE: 5: Format: PROGRESSIVE, 360 x 240
[M3 ][Debug] [m3vpss ] 43966: MERGE: 6: Format: PROGRESSIVE, 360 x 240
[M3 ][Debug] [m3vpss ] 43967: MERGE: 7: Format: PROGRESSIVE, 360 x 240
[M3 ][Debug] [m3vpss ] 43967: MERGE : Create Done !!!
[M3 ][Debug] [m3vpss ] 43970: DUP: 0: Format: PROGRESSIVE, 1920 x 1080
[M3 ][Debug] [m3vpss ] 43970: DUP: 1: Format: PROGRESSIVE, 1920 x 1080
[M3 ][Debug] [m3vpss ] 43971: DUP: 2: Format: PROGRESSIVE, 1920 x 1080
[M3 ][Debug] [m3vpss ] 43971: DUP: 3: Format: PROGRESSIVE, 360 x 240
[M3 ][Debug] [m3vpss ] 43971: DUP: 4: Format: PROGRESSIVE, 360 x 240
[M3 ][Debug] [m3vpss ] 43971: DUP: 5: Format: PROGRESSIVE, 360 x 240
[M3 ][Debug] [m3vpss ] 43971: DUP: 6: Format: PROGRESSIVE, 360 x 240
[M3 ][Debug] [m3vpss ] 43971: DUP: 7: Format: PROGRESSIVE, 360 x 240
[M3 ][Debug] [m3vpss ] 43972: DUP : Create Done !!!
[M3 ][Debug] [m3vpss ] 43973: SWMS: Create in progress !!!
[M3 ][Debug] [m3vpss ] SwMsLink_drvCreateOutInfo[link: 536870961] outFrameFormat width 1920 height 1080 pitch[3840 0 0]
[M3 ][Debug] [m3vpss ] UTILS: DMA: Allocated CH (TCC) = 59 (59)
[M3 ][Debug] [m3vpss ] UTILS: DMA: 0 of 1: Allocated PaRAM = 59 (0x49004760)
[M3 ][Debug] [m3vpss ] SWMS: instance 0, sc id 7, start win 0 end win 17
[M3 ][Debug] [m3vpss ] 44074: SWMS : VipScReq is FALSE!!!
[M3 ][Debug] [m3vpss ] 44077: SWMS0 : Loading Vertical Co-effs (UPSCALE)x ...
[M3 ][Debug] [m3vpss ] 44077: SWMS0 : Loading Horizontal Co-effs (UPSCALE)x ...
[M3 ][Debug] [m3vpss ] 44077: SWMS : Co-effs Loading ... DONE !!!
[M3 ][Debug] [m3vpss ] 44078: SWMS: 0: Format: PROGRESSIVE, 1920 x 1080
[M3 ][Debug] [m3vpss ] 44078: SWMS: 1: Format: PROGRESSIVE, 1920 x 1080
[M3 ][Debug] [m3vpss ] 44078: SWMS: 2: Format: PROGRESSIVE, 1920 x 1080
[M3 ][Debug] [m3vpss ] 44078: SWMS: 3: Format: PROGRESSIVE, 360 x 240
[M3 ][Debug] [m3vpss ] 44078: SWMS: 4: Format: PROGRESSIVE, 360 x 240
[M3 ][Debug] [m3vpss ] 44078: SWMS: 5: Format: PROGRESSIVE, 360 x 240
[M3 ][Debug] [m3vpss ] 44078: SWMS: 6: Format: PROGRESSIVE, 360 x 240
[M3 ][Debug] [m3vpss ] 44078: SWMS: 7: Format: PROGRESSIVE, 360 x 240
[M3 ][Debug] [m3vpss ] SwMsLink_drvSwitchLayout layoutParams outputWidth 0 outputHeight 0
[M3 ][Debug] [m3vpss ] SwMsLink_drvSwitchLayout(linkId: 536870961): outFrameFormat width 1920 height 1080 pitch [3840 0 0]
[M3 ][Debug] [m3vpss ] 44079: SWMS : ******* Configuring clock 33 secs...
[M3 ][Debug] [m3vpss ] SwMsLink_drvSelectScCoeffs(): out=[1920 1080] in=[360 240]
[M3 ][Debug] [m3vpss ] 44079: SWMS0 : Loading Vertical Co-effs (UPSCALE)x ...
[M3 ][Debug] [m3vpss ] 44079: SWMS0 : Loading Horizontal Co-effs (UPSCALE)x ...
[M3 ][Debug] [m3vpss ] 44079: SWMS : Co-effs Loading ... DONE !!!
[M3 ][Debug] [m3vpss ] *** [SWMS0] Mosaic Parameters ***
[M3 ][Debug] [m3vpss ] Output FPS: 30
[M3 ][Debug] [m3vpss ] Win | Ch | Input | Input | Input | Input | Output | Output | Output | Output | Scan | Low Cost | SWMS | Data | Bl|
[M3 ][Debug] [m3vpss ] Num | Num | Start X, Y | Width x Height | Pitch Y / C | Memory Type | Start X, Y | Width x Height | Pitch Y / C | Memory Type | Fmt | ON / OFF | Inst | Format| Fr|
[M3 ][Debug] [m3vpss ] --------------------------------------------------------------------------------------------------------------------------------------------------------------------------------
[M3 ][Debug] [m3vpss ] 0 | 3 | 0, 0 | 360 x 240 | 736 / 736 | NON-TILED | 0, 0 | 1920 x 1080 | 3840 / 0 | NON-TILED | PROGRESSIVE | OFF | 0 | 422I | |
[M3 ][Debug] [c6xdsp ] 43747: IPC_FRAMES_IN : Create in progress !!!
[M3 ][Debug] [c6xdsp ] 43747: SYSTEM: Opening ListMP [VPSS-M3_IPC_OUT_20] ...
[M3 ][Debug] [c6xdsp ] 43747: SYSTEM: Opening ListMP [VPSS-M3_IPC_IN_20] ...
[M3 ][Debug] [c6xdsp ] 43747: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
[M3 ][Debug] [m3vpss ] SWMS:HEAPID:0 USED:224
[M3 ][Debug] [m3vpss ] SWMS:HEAPID:1 USED:17056
[M3 ][Debug] [m3vpss ] SWMS:HEAPID:4 USED:20736000
[M3 ][Debug] [c6xdsp ] IPC_FRAMES_IN:HEAPID:0 USED:304
[M3 ][Debug] [m3vpss ] 44080: SWMS: Create Done !!!
[M3 ][Debug] [c6xdsp ] 43748: IPC_FRAMES_IN : Create Done !!!
[M3 ][Debug] [m3vpss ] 44081: SWMS: Create in progress !!!
[M3 ][Debug] [c6xdsp ] 43749: ALG : Create in progress !!!
[M3 ][Debug] [m3vpss ] SwMsLink_drvCreateOutInfo[link: 536870962] outFrameFormat width 1920 height 1080 pitch[3840 0 0]
[M3 ][Debug] [m3vpss ] UTILS: DMA: Allocated CH (TCC) = 60 (60)
[M3 ][Debug] [m3vpss ] UTILS: DMA: 0 of 1: Allocated PaRAM = 60 (0x49004780)
[M3 ][Debug] [c6xdsp ] ALGLINK:HEAPID:0 USED:2616
[M3 ][Debug] [m3vpss ] SWMS: instance 0, sc id 5, start win 0 end win 17
[M3 ][Debug] [c6xdsp ] ALGLINK:HEAPID:1 USED:12312
[M3 ][Debug] [m3vpss ] 44185: SWMS1 : Loading Vertical Co-effs (UPSCALE)x ...
[M3 ][Debug] [c6xdsp ] 43757: ALG : Create Done !!!
[M3 ][Debug] [m3vpss ] 44185: SWMS1 : Loading Horizontal Co-effs (UPSCALE)x ...
[M3 ][Debug] [m3vpss ] 44185: SWMS : Co-effs Loading ... DONE !!!
[M3 ][Debug] [m3vpss ] 44185: SWMS: 0: Format: PROGRESSIVE, 1920 x 1080
[M3 ][Debug] [m3vpss ] 44186: SWMS: 1: Format: PROGRESSIVE, 1920 x 1080
[M3 ][Debug] [m3vpss ] 44186: SWMS: 2: Format: PROGRESSIVE, 1920 x 1080
[M3 ][Debug] [m3vpss ] 44186: SWMS: 3: Format: PROGRESSIVE, 360 x 240
[M3 ][Debug] [m3vpss ] 44186: SWMS: 4: Format: PROGRESSIVE, 360 x 240
[M3 ][Debug] [m3vpss ] 44186: SWMS: 5: Format: PROGRESSIVE, 360 x 240
[M3 ][Debug] [m3vpss ] 44186: SWMS: 6: Format: PROGRESSIVE, 360 x 240
[M3 ][Debug] [m3vpss ] 44186: SWMS: 7: Format: PROGRESSIVE, 360 x 240
[M3 ][Debug] [m3vpss ] SwMsLink_drvSwitchLayout(linkId: 536870962): outFrameFormat width 1920 height 1080 pitch [3840 0 0]
[M3 ][Debug] [m3vpss ] 44187: SWMS : ******* Configuring clock 33 secs...
[M3 ][Debug] [m3vpss ] 44187: SWMS1 : Loading Vertical Co-effs (UPSCALE)x ...
[M3 ][Debug] [m3vpss ] 44187: SWMS1 : Loading Horizontal Co-effs (UPSCALE)x ...
[M3 ][Debug] [m3vpss ] 44187: SWMS : Co-effs Loading ... DONE !!!
[M3 ][Debug] [m3vpss ] *** [SWMS1] Mosaic Parameters ***
[M3 ][Debug] [m3video] 44646: IPC_IN_M3 : Create in progress !!!
[M3 ][Debug] [m3video] 44646: SYSTEM: Opening ListMP [VPSS-M3_IPC_OUT_0] ...
[M3 ][Debug] [m3video] 44646: SYSTEM: Opening ListMP [VPSS-M3_IPC_IN_0] ...
[M3 ][Debug] [m3video] 44648: IPC_IN_M3 : Create Done !!!
[M3 ][Debug] [m3video] 44649: ENCODE: Create in progress ... !!!
[M3 ][Debug] [m3vpss ] SWMS:HEAPID:1 USED:47296
[M3 ][Debug] [m3video] ENCLINK:INFO: !!!Number of output buffers for ch[3] set to [1]
[M3 ][Debug] [m3video] ENCLINK: B Frame is enabled for a channel 2
[M3 ][Debug] [m3vpss ] 44188: SWMS: Create Done !!!
[M3 ][Debug] [m3vpss ] 44189: IPC_FRAMES_OUT : Create in progress !!!
[M3 ][Debug] [m3video] ENCLINK: WARNING: B Frame is enabled for a channel, cannot do batch processing (processMulti) for H.264 channels
[M3 ][Debug] [m3vpss ] 44190: IPC_FRAMES_OUT : Create Done !!!
[M3 ][Debug] [m3vpss ] 44202: NSF: Create in progress !!!
[M3 ][Debug] [m3video] 44692: ENCODE: Creating CH0 of 720 x 480, pitch = (1920, 1920) [PROGRESSIVE] [NON-TILED ], bitrate = 1600 Kbps, I-P Interval 1...
[M3 ][Debug] [m3vpss ] NSF::HEAPID:0 USED:128
[M3 ][Debug] [m3vpss ] NSF::HEAPID:1 USED:4928
[M3 ][Debug] [m3video] ENCLINK_H264:HEAPID:0 USED:11912
[M3 ][Debug] [m3vpss ] NSF::HEAPID:4 USED:21934080
[M3 ][Debug] [m3video] ENCLINK_H264:HEAPID:3 USED:1511424
[M3 ][Debug] [m3vpss ] 44306: NSF: Create Done !!!
[M3 ][Debug] [m3video] 44701: ENCODE: Creating CH1 of 720 x 480, pitch = (1920, 1920) [PROGRESSIVE] [NON-TILED ], bitrate = 1600 Kbps, I-P Interval 1...
[M3 ][Debug] [m3vpss ] 44310: DUP: 0: Format: PROGRESSIVE, 1920 x 1080
[M3 ][Debug] [m3vpss ] 44311: DUP : Create Done !!!
[M3 ][Debug] [m3vpss ] 44311: NSF: Create in progress !!!
[M3 ][Debug] [m3video] 44709: ENCODE: Creating CH2 of 1920 x 1080, pitch = (1920, 1920) [PROGRESSIVE] [NON-TILED ], bitrate = 6400 Kbps, I-P Interval 2...
[M3 ][Debug] [m3vpss ] NSF::HEAPID:1 USED:1408
[M3 ][Debug] [m3video] 44743:!ERROR!:ENCLINK::links_m3video/iva_enc/encLink_h264.c:[577]::INTERNAL ERROR:-1
[M3 ][Debug] [m3video] ALGCONTROL FAILED:CMD:1
[M3 ][Debug] [m3video] ERROR: XDM_UNSUPPORTEDPARAM = 14,
[M3 ][Debug] [m3vpss ] 44415: NSF: Create Done !!!
[M3 ][Debug] [m3video] ERROR: XDM_FATALERROR = 15
[M3 ][Debug] [m3vpss ] 44415: NULL_SRC: Create in progress !!!
[M3 ][Debug] [m3video] ERROR: IH264ENC_UNSUPPORTED_RATECONTROLPARAMS = 21,
[M3 ][Debug] [m3video] 44744:!ERROR!:ENCLINK::links_m3video/iva_enc/encLink_h264.c:[588]::INTERNAL ERROR:-1
[M3 ][Debug] [m3video] Ext Error :0
[M3 ][Debug] [m3video] EXT_ERROR: IH264ENC_EXTERROR_RATECTRL_RCALGO = 110
[M3 ][Debug] [m3vpss ] 44440: NULL_SRC: Create Done !!!
[M3 ][Debug] [m3video] EXT_ERROR: IH264ENC_EXTERROR_RATECTRL_RCALGO_INTERLACE_OR_BFRAME = 111
[M3 ][Debug] [m3vpss ] 44440: NULL_SRC: Create in progress !!!
[M3 ][Debug] [m3video] EXT_ERROR: IH264ENC_EXTERROR_METADATATYPES = 78
[M3 ][Debug] [m3video] EXT_ERROR: IH264ENC_EXTERROR_MULITCHNL_BFRAME_NOTSUPPORTED = 79
[M3 ][Debug] [m3vpss ] 44465: NULL_SRC: Create Done !!!
[M3 ][Debug] [m3video] EXT_ERROR: IH264ENC_EXTERROR_STEREO_PRESET = 130
[M3 ][Debug] [m3vpss ] 44466: MERGE: 0: Format: PROGRESSIVE, 1920 x 1080
[M3 ][Debug] [m3video] EXT_ERROR: IH264ENC_EXTERROR_VERSION_BUFFER_NULL_OR_SIZE = 131
[M3 ][Debug] [m3vpss ] 44466: MERGE: 1: Format: PROGRESSIVE, 1920 x 1080
[M3 ][Debug] [m3video] EXT_ERROR: IH264ENC_EXTERROR_VUI_NUMUNITSINTICKS = 132
[M3 ][Debug] [m3vpss ] 44466: MERGE: 2: Format: PROGRESSIVE, 360 x 240
[M3 ][Debug] [m3video] EXT_ERROR: IH264ENC_EXTERROR_VUI_PRESET = 133
[M3 ][Debug] [m3vpss ] 44467: MERGE : Create Done !!!
[M3 ][Debug] [m3video] EXT_ERROR: ���
[M3 ][Debug] [m3vpss ] 44467: MERGE: 0: Format: PROGRESSIVE, 1920 x 1080
[M3 ][Debug] [m3vpss ] 44467: MERGE: 1: Format: PROGRESSIVE, 1920 x 1080
[M3 ][Debug] [m3video] 44745:!ERROR!:ENCLINK::links_m3video/iva_enc/encLink_h264.c:[588]::INTERNAL ERROR:-1
[M3 ][Debug] [m3vpss ] 44468: MERGE: 2: Format: PROGRESSIVE, 360 x 240
[M3 ][Debug] [m3video] EXT_ERROR: IH264ENC_EXTERROR_INARGS_OUTARGS_SIZE = 46
[M3 ][Debug] [m3vpss ] 44468: MERGE : Create Done !!!
[M3 ][Debug] [m3video] EXT_ERROR: IH264ENC_EXTERROR_INARGS_PTRNULL = 47
[M3 ][Debug] [m3vpss ] 44468: SWMS: Create in progress !!!
[M3 ][Debug] [m3video] EXT_ERROR: IH264ENC_EXTERROR_RATECTRL_BFRAMEPICSIZE = 98
[M3 ][Debug] [m3vpss ] SwMsLink_drvCreateOutInfo[link: 536870963] outFrameFormat width 720 height 480 pitch[1920 1920 1920]
[M3 ][Debug] [m3video] EXT_ERROR: IH264ENC_EXTERROR_RATECTRL_CBCRQPINDEX_INITBUFLVL = 99
[M3 ][Debug] [m3vpss ] UTILS: DMA: Allocated CH (TCC) = 61 (61)
[M3 ][Debug] [m3video] EXT_ERROR: IH264ENC_EXTERROR_RATECTRL_HRDBUFFER_LVLEXCEED = 100
[M3 ][Debug] [m3vpss ] UTILS: DMA: 0 of 1: Allocated PaRAM = 61 (0x490047A0)
[M3 ][Debug] [m3video] EXT_ERROR: IH264ENC_EXTERROR_RATECTRL_IFRAME_QP = 101
[M3 ][Debug] [m3vpss ] SWMS: instance 0, sc id 4, start win 0 end win 17
[M3 ][Debug] [m3video] EXT_ERROR: IH264ENC_EXTERROR_SCLMATRIX_METADATA = 104
[M3 ][Debug] [m3vpss ] 44550: SWMS2 : Loading Vertical Co-effs (UPSCALE)x ...
[M3 ][Debug] [m3video] EXT_ERROR: IH264ENC_EXTERROR_STATUS_SIZE = 128
[M3 ][Debug] [m3vpss ] 44550: SWMS2 : Loading Horizontal Co-effs (UPSCALE)x ...
[M3 ][Debug] [m3video] EXT_ERROR: IH264ENC_EXTERROR_STEREO_INPCONTENT = 129
[M3 ][Debug] [m3vpss ] 44550: SWMS : Co-effs Loading ... DONE !!!
[M3 ][Debug] [m3vpss ] 44550: SWMS: 0: Format: PROGRESSIVE, 1920 x 1080
[M3 ][Debug] [m3video] 44747:!ERROR!:ENCLINK::links_m3video/iva_enc/encLink_h264.c:[588]::INTERNAL ERROR:-1
[M3 ][Debug] [m3video] Ext Error :C000
[M3 ][Debug] [m3vpss ] 44550: SWMS: 1: Format: PROGRESSIVE, 1920 x 1080
[M3 ][Debug] [m3video] EXT_ERROR: IH264ENC_EXTERROR_CREATE_LTRP_HP = 14
[M3 ][Debug] [m3vpss ] 44550: SWMS: 2: Format: PROGRESSIVE, 360 x 240
[M3 ][Debug] [m3video] EXT_ERROR: IH264ENC_EXTERROR_CREATE_LTRP_PERIOD = 15
[M3 ][Debug] [m3video] EXT_ERROR: IH264ENC_EXTERROR_INTRA_REFRESHRATE = 66
[M3 ][Debug] [m3vpss ] SwMsLink_drvSwitchLayout(linkId: 536870963): outFrameFormat width 720 height 480 pitch [1920 1920 1920]
[M3 ][Debug] [m3video] EXT_ERROR: IH264ENC_EXTERROR_IVAHD_BADRESET = 67
[M3 ][Debug] [m3vpss ] 44551: SWMS : ******* Configuring clock 40 secs...
[M3 ][Debug] [m3video] EXT_ERROR: IH264ENC_EXTERROR_IVAHD_BADSTATE = 68
[M3 ][Debug] [m3vpss ] SwMsLink_drvSelectScCoeffs(): out=[720 480] in=[1920 1080]
[M3 ][Debug] [m3video] EXT_ERROR: IH264ENC_EXTERROR_IVAHD_RELEASE = 69
[M3 ][Debug] [m3vpss ] 44551: SWMS2 : Loading Vertical Co-effs (7/16)x ...
[M3 ][Debug] [m3video] EXT_ERROR: IH264ENC_EXTERROR_LOOPFILTER_OFFST_LFIDC = 72
[M3 ][Debug] [m3vpss ] 44551: SWMS2 : Loading Horizontal Co-effs (5/16)x ...
[M3 ][Debug] [m3video] EXT_ERROR: IH264ENC_EXTERROR_PROFILE_DATASYNC_INPCONTENT_RES = 96
[M3 ][Debug] [m3vpss ] 44551: SWMS : Co-effs Loading ... DONE !!!
[M3 ][Debug] [m3video] EXT_ERROR: IH264ENC_EXTERROR_PROFILE_INPCONTENT = 97
[M3 ][Debug] [m3vpss ] *** [SWMS2] Mosaic Parameters ***
[M3 ][Debug] [m3vpss ] Output FPS: 25
[M3 ][Debug] [m3vpss ] 0 | 0 | 0, 0 | 1920 x 1080 | 3840 / 3840 | NON-TILED | 0, 0 | 720 x 480 | 1920 / 1920 | NON-TILED | PROGRESSIVE | OFF | 0 | 422I | |
[M3 ][Debug] [m3video] 44749:!ERROR!:ENCLINK::links_m3video/iva_enc/encLink_h264.c:[588]::INTERNAL ERROR:-1
[M3 ][Debug] [m3video] EXT_ERROR: IH264ENC_EXTERROR_FMO_PRESET = 34
[M3 ][Debug] [m3video] EXT_ERROR: IH264ENC_EXTERROR_FRMPACKING_PRESET = 35
[M3 ][Debug] [m3video] EXT_ERROR: IH264ENC_EXTERROR_FRMPACKING_TYPE_INPCONTENT = 36
[M3 ][Debug] [m3vpss ] SWMS:HEAPID:4 USED:15552000
[M3 ][Debug] [m3video] EXT_ERROR: IH264ENC_EXTERROR_FRMRATE_NUMUNITSINTICKS = 37
[M3 ][Debug] [m3vpss ] 44552: SWMS: Create Done !!!
[M3 ][Debug] [m3video] EXT_ERROR: IH264ENC_EXTERROR_HIGHSPEED_BFARME = 40
[M3 ][Debug] [m3vpss ] 44553: SWMS: Create in progress !!!
[M3 ][Debug] [m3video] EXT_ERROR: IH264ENC_EXTERROR_INTRA_REFRESHMETHOD = 64
[M3 ][Debug] [m3vpss ] SwMsLink_drvCreateOutInfo[link: 536870964] outFrameFormat width 720 height 480 pitch[1920 1920 1920]
[M3 ][Debug] [m3video] EXT_ERROR: IH264ENC_EXTERROR_INTRA_REFRESHMETHOD_RATE = 65
[M3 ][Debug] [m3vpss ] UTILS: DMA: Allocated CH (TCC) = 62 (62)
[M3 ][Debug] [m3vpss ] UTILS: DMA: 0 of 1: Allocated PaRAM = 62 (0x490047C0)
[M3 ][Debug] [m3vpss ] 44634: SWMS3 : Loading Vertical Co-effs (UPSCALE)x ...
[M3 ][Debug] [m3vpss ] 44634: SWMS3 : Loading Horizontal Co-effs (UPSCALE)x ...
[M3 ][Debug] [m3vpss ] 44634: SWMS : Co-effs Loading ... DONE !!!
[M3 ][Debug] [m3vpss ] 44634: SWMS: 0: Format: PROGRESSIVE, 1920 x 1080
[M3 ][Debug] [m3vpss ] 44634: SWMS: 1: Format: PROGRESSIVE, 1920 x 1080
[M3 ][Debug] [m3video] --------- CH 0 : H264 ENC : Dynamic Params -------
[M3 ][Debug] [m3vpss ] 44634: SWMS: 2: Format: PROGRESSIVE, 360 x 240
[M3 ][Debug] [m3video] videnc2DynamicParams -> inputHeight : 1080
[M3 ][Debug] [m3vpss ] SwMsLink_drvSwitchLayout(linkId: 536870964): outFrameFormat width 720 height 480 pitch [1920 1920 1920]
[M3 ][Debug] [m3video] videnc2DynamicParams -> inputWidth : 1920
[M3 ][Debug] [m3vpss ] 44635: SWMS : ******* Configuring clock 40 secs...
[M3 ][Debug] [m3video] videnc2DynamicParams -> refFrameRate : 30000
[M3 ][Debug] [m3video] videnc2DynamicParams -> targetFrameRate : 30000
[M3 ][Debug] [m3vpss ] 44635: SWMS3 : Loading Vertical Co-effs (7/16)x ...
[M3 ][Debug] [m3video] videnc2DynamicParams -> targetBitRate : 6400000
[M3 ][Debug] [m3vpss ] 44635: SWMS3 : Loading Horizontal Co-effs (5/16)x ...
[M3 ][Debug] [m3video] videnc2DynamicParams -> intraFrameInterval : 30
[M3 ][Debug] [m3vpss ] 44635: SWMS : Co-effs Loading ... DONE !!!
[M3 ][Debug] [m3video] videnc2DynamicParams -> generateHeader : 0
[M3 ][Debug] [m3vpss ] *** [SWMS3] Mosaic Parameters ***
[M3 ][Debug] [m3video] videnc2DynamicParams -> captureWidth : 1920
[M3 ][Debug] [m3vpss ] 0 | 1 | 0, 0 | 1920 x 1080 | 3840 / 3840 | NON-TILED | 0, 0 | 720 x 480 | 1920 / 1920 | NON-TILED | PROGRESSIVE | OFF | 0 | 422I | |
[M3 ][Debug] [m3video] videnc2DynamicParams -> forceFrame : -1
[M3 ][Debug] [m3video] videnc2DynamicParams -> interFrameInterval : 2
[M3 ][Debug] [m3video] videnc2DynamicParams -> mvAccuracy : 2
[M3 ][Debug] [m3video] videnc2DynamicParams -> sampleAspectRatioHeight : 1
[M3 ][Debug] [m3video] videnc2DynamicParams -> sampleAspectRatioWidth : 1
[M3 ][Debug] [m3vpss ] SWMS:HEAPID:1 USED:43776
[M3 ][Debug] [m3video] videnc2DynamicParams -> ignoreOutbufSizeFlag : 1
[M3 ][Debug] [m3video] videnc2DynamicParams -> lateAcquireArg : -1
[M3 ][Debug] [m3vpss ] 44637: SWMS: Create Done !!!
[M3 ][Debug] [m3vpss ] 44640: DUP: 0: Format: PROGRESSIVE, 1920 x 1080
[M3 ][Debug] [m3video] rateControlParams -> rateControlParamsPreset : 1
[M3 ][Debug] [m3vpss ] 44642: DUP : Create Done !!!
[M3 ][Debug] [m3video] rateControlParams -> scalingMatrixPreset : 1
[M3 ][Debug] [m3vpss ] 44642: MERGE: 0: Format: PROGRESSIVE, 720 x 480
[M3 ][Debug] [m3video] rateControlParams -> rcAlgo : 1
[M3 ][Debug] [m3vpss ] 44643: MERGE: 1: Format: PROGRESSIVE, 720 x 480
[M3 ][Debug] [m3video] rateControlParams -> qpI : -1
[M3 ][Debug] [m3vpss ] 44643: MERGE: 2: Format: PROGRESSIVE, 1920 x 1080
[M3 ][Debug] [m3video] rateControlParams -> qpMaxI : 40
[M3 ][Debug] [m3vpss ] 44644: MERGE: 3: Format: PROGRESSIVE, 1920 x 1080
[M3 ][Debug] [m3video] rateControlParams -> qpMinI : 10
[M3 ][Debug] [m3vpss ] 44644: MERGE: 4: Format: PROGRESSIVE, 1920 x 1080
[M3 ][Debug] [m3video] rateControlParams -> qpP : -1
[M3 ][Debug] [m3vpss ] 44644: MERGE : Create Done !!!
[M3 ][Debug] [m3video] rateControlParams -> qpMaxP : 40
[M3 ][Debug] [m3vpss ] 44645: IPC_OUT_M3 : Create in progress !!!
[M3 ][Debug] [m3video] rateControlParams -> qpMinP : 10
[M3 ][Debug] [m3vpss ] 44646: IPC_OUT_M3 : Create Done !!!
[M3 ][Debug] [m3video] rateControlParams -> qpOffsetB : 4
[M3 ][Debug] [m3video] rateControlParams -> qpMaxB : 44
[M3 ][Debug] [m3video] rateControlParams -> qpMinB : 10
[M3 ][Debug] [m3video] rateControlParams -> allowFrameSkip : 0
[M3 ][Debug] [m3video] rateControlParams -> removeExpensiveCoeff : 0
[M3 ][Debug] [m3video] rateControlParams -> chromaQPIndexOffset : 0
[M3 ][Debug] [m3video] rateControlParams -> IPQualityFactor : 0
[M3 ][Debug] [m3video] rateControlParams -> initialBufferLevel : 6400000
[M3 ][Debug] [m3video] rateControlParams -> HRDBufferSize : 6400000
[M3 ][Debug] [m3video] rateControlParams -> minPicSizeRatioI : 0
[M3 ][Debug] [m3video] rateControlParams -> maxPicSizeRatioI : 640
[M3 ][Debug] [m3video] rateControlParams -> minPicSizeRatioP : 0
[M3 ][Debug] [m3video] rateControlParams -> maxPicSizeRatioP : 0
[M3 ][Debug] [m3video] rateControlParams -> minPicSizeRatioB : 0
[M3 ][Debug] [m3video] rateControlParams -> maxPicSizeRatioB : 0
[M3 ][Debug] [m3video] rateControlParams -> enablePRC : 0
[M3 ][Debug] [m3video] rateControlParams -> enablePartialFrameSkip : 0
[M3 ][Debug] [m3video] rateControlParams -> discardSavedBits : 1
[M3 ][Debug] [m3video] rateControlParams -> VBRDuration : 8
[M3 ][Debug] [m3video] rateControlParams -> VBRsensitivity : 0
[M3 ][Debug] [m3video] rateControlParams -> skipDistributionWindowLength : 5
[M3 ][Debug] [m3video] rateControlParams -> numSkipInDistributionWindow : 2
[M3 ][Debug] [m3video] rateControlParams -> enableHRDComplianceMode : 1
[M3 ][Debug] [m3video] rateControlParams -> frameSkipThMulQ5 : 0
[M3 ][Debug] [m3video] rateControlParams -> vbvUseLevelThQ5 : 0
[M3 ][Debug] [m3video] interCodingParams -> interCodingPreset : 0
[M3 ][Debug] [m3video] interCodingParams -> searchRangeHorP : 144
[M3 ][Debug] [m3video] interCodingParams -> searchRangeVerP : 32
[M3 ][Debug] [m3video] interCodingParams -> searchRangeHorB : 144
[M3 ][Debug] [m3video] interCodingParams -> searchRangeVerB : 16
[M3 ][Debug] [m3video] interCodingParams -> interCodingBias : 1
[M3 ][Debug] [m3video] interCodingParams -> skipMVCodingBias : 1
[M3 ][Debug] [m3video] interCodingParams -> minBlockSizeP : 0
[M3 ][Debug] [m3video] interCodingParams -> minBlockSizeB : 0
[M3 ][Debug] [m3video] interCodingParams -> meAlgoMode : 0
[M3 ][Debug] [m3video] intraCodingParams -> intraCodingPreset : 0
[M3 ][Debug] [m3video] intraCodingParams -> lumaIntra4x4Enable : 0
[M3 ][Debug] [m3video] intraCodingParams -> lumaIntra8x8Enable : 255
[M3 ][Debug] [m3video] intraCodingParams -> lumaIntra16x16Enable : 15
[M3 ][Debug] [m3video] intraCodingParams -> chromaIntra8x8Enable : 15
[M3 ][Debug] [m3video] intraCodingParams -> chromaComponentEnable : 1
[M3 ][Debug] [m3video] intraCodingParams -> intraRefreshMethod : 0
[M3 ][Debug] [m3video] intraCodingParams -> intraRefreshRate : 0
[M3 ][Debug] [m3video] intraCodingParams -> gdrOverlapRowsBtwFrames : 0
[M3 ][Debug] [m3video] intraCodingParams -> constrainedIntraPredEnable : 0
[M3 ][Debug] [m3video] intraCodingParams -> intraCodingBias : 0
[M3 ][Debug] [m3video] sliceCodingParams -> sliceCodingPreset : 0
[M3 ][Debug] [m3video] sliceCodingParams -> sliceMode : 0
[M3 ][Debug] [m3video] sliceCodingParams -> sliceUnitSize : 0
[M3 ][Debug] [m3video] sliceCodingParams -> sliceStartOffset : [0 0 0]
[M3 ][Debug] [m3video] sliceCodingParams -> streamFormat : 0
[M3 ][Debug] [m3video] sliceGroupChangeCycle : 0
[M3 ][Debug] [m3video] searchCenter : 32767
[M3 ][Debug] [m3video] enableStaticMBCount : 0
[M3 ][Debug] [m3video] enableROI : 0
[M3 ][Debug] [m3video] 44757:ERR::linkID:10000022::channelID:2::errorCode:-5::FileName:links_m3video/iva_enc/encLink_h264.c::linuNum:1704::errorCondition:(algStatus == XDM_EOK)
[M3 ][Debug] [m3video] 44758: Assertion @ Line: 1011 in links_m3video/iva_enc/encLink_common.c: retVal == ENC_LINK_S_SUCCESS : failed !!!
