Hi
RDK: IPNC RDK3.8, DM388
I have a separate process which uses GetAVData() to get encoded frames from streaming ring buffer. It is consuming lot of CPU power on A8, since I am using while(1) loop. Is there a simple way to avoid using while(1) loop, so that I process the frame only when it is actually available , instead of waiting in a loop. I have already gone thru the RTSP/HTTP streaming code in ipnc_app.(APPROInput.c) It looks very complex. I need a simple mechanism to replace the while(1) loop. Pls help.
Any code examples. hints?
Best Regards
JK
