hi all ,when i enable the OPENGL in the 8168 dvr_rdk's Graphics_SDK ,then i run my app it will create the display link failed ,the log is following:
[m3vpss ] 372747: CAPTURE: Create in progress !!!
[m3vpss ] 372777: CAPTURE: VIP0 PortA capture mode is [16-bit, Non-mux Discrete Sync - ACTVID_VSYNC] !!!
[m3vpss ] 373010: CAPTURE: VIP1 PortA capture mode is [16-bit, Non-mux Discrete Sync - ACTVID_VSYNC] !!!
[m3vpss ] UTILS: DMA: Allocated CH (TCC) = 58 (58)
[m3vpss ] UTILS: DMA: 0 of 4: Allocated PaRAM = 58 (0x49004740)
[m3vpss ] UTILS: DMA: 1 of 4: Allocated PaRAM = 64 (0x49004800)
[m3vpss ] UTILS: DMA: 2 of 4: Allocated PaRAM = 65 (0x49004820)
[m3vpss ] UTILS: DMA: 3 of 4: Allocated PaRAM = 66 (0x49004840)
[m3vpss ] CAPTURE::HEAPID:0 USED:520
[m3vpss ] CAPTURE::HEAPID:4 USED:103680000
[m3vpss ] 373243: CAPTURE: Create Done !!!
[m3vpss ] 373249: DUP : Create Done !!!
[m3vpss ] 373249: DEI : Create in progress !!!
[m3vpss ] 373454: DEI : Loading Down-scaling Co-effs
[m3vpss ] 373454: DEI : Co-effs Loading ... DONE !!!
[m3vpss ] 373455:DEI:Resolution LinkId[0x20000026],ChId[0],inW[1920],inH[1080],outW[1920],outH[1080]
[m3vpss ] 373455:DEI:Resolution LinkId[0x20000026],ChId[1],inW[1920],inH[1080],outW[1920],outH[1080]
[m3vpss ] 373455:DEI:ScalerCoeff LinkId[0x20000026],VIP_SC :HorzCoeff:VPS_SC_SET_1_1,VertCoeff:VPS_SC_SET_1_1
[m3vpss ] DEI:HEAPID:0 USED:64
[m3vpss ] DEI:HEAPID:1 USED:6144
[m3vpss ] DEI:HEAPID:4 USED:43545600
[m3vpss ] 373455: DEI : Create Done !!!
[m3vpss ] 373456: IPC_OUT_M3 : Create in progress !!!
[m3vpss ] 373457: IPC_OUT_M3 : Create Done !!!
[m3vpss ] 373458: CAPTURE: Start in progress !!!
[m3vpss ] 373557: CAPTURE: Enabled Time Stamping !!!
[m3vpss ] 373565: CAPTURE: Enabled Time Stamping !!!
[m3video] 373574: IPC_IN_M3 : Create in progress !!!
[m3vpss ] 373573: CAPTURE: Start Done !!!
[m3video] 373574: SYSTEM: Opening ListMP [VPSS-M3_IPC_OUT_0] ...
[m3video] 373574: SYSTEM: Opening ListMP [VPSS-M3_IPC_IN_0] ...
[m3video] 373576: IPC_IN_M3 : Create Done !!!
[m3video] 373577: ENCODE: Create in progress ... !!!
[m3video] 373637: ENCODE: Creating CH0 of 1920 x 1080, pitch = (1920, 1920) [PROGRESSIVE] [NON-TILED ], bitrate =
[m3video] ENCLINK_H264:HEAPID:0 USED:13808
[m3video] ENCLINK_H264:HEAPID:3 USED:7176192
[m3video] 373672: ENCODE: Creating CH1 of 1920 x 1080, pitch = (1920, 1920) [PROGRESSIVE] [NON-TILED ], bitrate =
[m3video] ENCLINK_H264:HEAPID:0 USED:11912
[m3video] 373706: ENCODE: All CH Create ... DONE !!!
[m3vpss ] 373738: IPC_IN_M3 : Create in progress !!!
[m3video] ENCLINK:HEAPID:0 USED:25840
[m3vpss ] 373738: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_0] ...
[m3video] ENCLINK:HEAPID:2 USED:12441600
[m3vpss ] 373738: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_0] ...
[m3video] ENCLINK:HEAPID:3 USED:14352384
[m3vpss ] 373739: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
[m3video] 373708: ENCODE: Create ... DONE !!!
[m3vpss ] 373741: IPC_IN_M3 : Create Done !!!
[m3video] 373708: IPC_BITS_OUT : Create in progress !!!
[m3vpss ] 373742: MERGE : Create Done !!!
[m3video] 373710: IPC_BITS_OUT : Create Done !!!
[m3vpss ] 373747: DUP : Create Done !!!
[m3video] 373721: IPC_BITS_IN : Create in progress !!!
[m3vpss ] 373748: SWMS: Create in progress !!!
[m3video] 373721: SYSTEM: Opening ListMP [HOST_IPC_OUT_24] ...
[m3video] 373721: SYSTEM: Opening ListMP [HOST_IPC_IN_24] ...
[m3video] 373722: SYSTEM: Opening MsgQ [HOST_MSGQ] ...
[m3video] 373724: IPC_BITS_IN : Create Done !!!
[m3video] 373724: DECODE: Create in progress ... !!!
[m3video] 373725: DECODE: CodecInst and OutFrm bufs are NOT created for CH0
[m3video] 373725: DECODE: Creating CH0 of 352 x 288 [PROGRESSIVE] [NON-TILED ],target bitrate = 2000 Kbps ...
[m3video] 373726: DECODE: CodecInst and OutFrm bufs are NOT created for CH1
[m3video] 373726: DECODE: Creating CH1 of 352 x 288 [PROGRESSIVE] [NON-TILED ],target bitrate = 2000 Kbps ...
[m3video] 373726: DECODE: CodecInst and OutFrm bufs are NOT created for CH2
[m3video] 373726: DECODE: Creating CH2 of 352 x 288 [PROGRESSIVE] [NON-TILED ],target bitrate = 2000 Kbps ...
[m3video] 373726: DECODE: CodecInst and OutFrm bufs are NOT created for CH3
[m3video] 373726: DECODE: Creating CH3 of 352 x 288 [PROGRESSIVE] [NON-TILED ],target bitrate = 2000 Kbps ...
[m3video] 373727: DECODE: CodecInst and OutFrm bufs are NOT created for CH4
[m3video] 373727: DECODE: Creating CH4 of 352 x 288 [PROGRESSIVE] [NON-TILED ],target bitrate = 2000 Kbps ...
[m3video] 373727: DECODE: CodecInst and OutFrm bufs are NOT created for CH5
[m3video] 373727: DECODE: Creating CH5 of 352 x 288 [PROGRESSIVE] [NON-TILED ],target bitrate = 2000 Kbps ...
[m3video] 373727: DECODE: CodecInst and OutFrm bufs are NOT created for CH6
[m3video] 373727: DECODE: Creating CH6 of 352 x 288 [PROGRESSIVE] [NON-TILED ],target bitrate = 2000 Kbps ...
[m3video] 373727: DECODE: CodecInst and OutFrm bufs are NOT created for CH7
[m3video] 373728: DECODE: Creating CH7 of 352 x 288 [PROGRESSIVE] [NON-TILED ],target bitrate = 2000 Kbps ...
[m3video] 373728: DECODE: CodecInst and OutFrm bufs are NOT created for CH8
[m3video] 373728: DECODE: Creating CH8 of 352 x 288 [PROGRESSIVE] [NON-TILED ],target bitrate = 2000 Kbps ...
[m3video] 373728: DECODE: CodecInst and OutFrm bufs are NOT created for CH9
[m3video] 373728: DECODE: Creating CH9 of 352 x 288 [PROGRESSIVE] [NON-TILED ],target bitrate = 2000 Kbps ...
[m3video] 373728: DECODE: CodecInst and OutFrm bufs are NOT created for CH10
[m3video] 373728: DECODE: Creating CH10 of 352 x 288 [PROGRESSIVE] [NON-TILED ],target bitrate = 2000 Kbps ...
[m3video] 373729: DECODE: CodecInst and OutFrm bufs are NOT created for CH11
[m3video] 373729: DECODE: Creating CH11 of 352 x 288 [PROGRESSIVE] [NON-TILED ],target bitrate = 2000 Kbps ...
[m3video] 373729: DECODE: CodecInst and OutFrm bufs are NOT created for CH12
[m3video] 373729: DECODE: Creating CH12 of 352 x 288 [PROGRESSIVE] [NON-TILED ],target bitrate = 2000 Kbps ...
[m3video] 373729: DECODE: CodecInst and OutFrm bufs are NOT created for CH13
[m3video] 373729: DECODE: Creating CH13 of 352 x 288 [PROGRESSIVE] [NON-TILED ],target bitrate = 2000 Kbps ...
[m3video] 373729: DECODE: CodecInst and OutFrm bufs are NOT created for CH14
[m3video] 373730: DECODE: Creating CH14 of 352 x 288 [PROGRESSIVE] [NON-TILED ],target bitrate = 2000 Kbps ...
[m3video] 373730: DECODE: CodecInst and OutFrm bufs are NOT created for CH15
[m3video] 373730: DECODE: Creating CH15 of 352 x 288 [PROGRESSIVE] [NON-TILED ],target bitrate = 2000 Kbps ...
[m3video] 373731: DECODE: All CH Create ... DONE !!!
[m3vpss ] UTILS: DMA: Allocated CH (TCC) = 59 (59)
[c6xdsp ] 372314: IPC_FRAMES_IN : Create in progress !!!
[m3vpss ] UTILS: DMA: 0 of 1: Allocated PaRAM = 59 (0x49004760)
[c6xdsp ] 372314: SYSTEM: Opening ListMP [VPSS-M3_IPC_OUT_19] ...
[m3vpss ] UTILS: DMA: Allocated CH (TCC) = 60 (60)
[c6xdsp ] 372315: SYSTEM: Opening ListMP [VPSS-M3_IPC_IN_19] ...
[m3video] DECLINK:HEAPID:0 USED:120
[m3vpss ] UTILS: DMA: 0 of 4: Allocated PaRAM = 60 (0x49004780)
[c6xdsp ] 372315: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
[m3video] 373734: DECODE: Create ... DONE !!!
[m3vpss ] UTILS: DMA: 1 of 4: Allocated PaRAM = 67 (0x49004860)
[m3video] 373735: IPC_OUT_M3 : Create in progress !!!
[m3vpss ] UTILS: DMA: 2 of 4: Allocated PaRAM = 160 (0x49005400)
[m3video] 373735: IPC_OUT_M3 : Create Done !!!
[m3vpss ] UTILS: DMA: 3 of 4: Allocated PaRAM = 161 (0x49005420)
[c6xdsp ] IPC_FRAMES_IN:HEAPID:0 USED:304
[m3vpss ] SWMS: instance 0, sc id 7, start win 0 end win 15
[c6xdsp ] 372316: IPC_FRAMES_IN : Create Done !!!
[m3vpss ] SWMS: instance 1, sc id 5, start win 16 end win 33
[c6xdsp ] 372316: ALG : Create in progress !!!
[m3vpss ] 373892: SWMS : VipScReq is FALSE!!!
[m3vpss ] 373896: SWMS0 : Loading Vertical Co-effs (UPSCALE)x ...
[m3vpss ] 373896: SWMS0 : Loading Horizontal Co-effs (UPSCALE)x ...
[c6xdsp ] ALGLINK:HEAPID:0 USED:2616
[m3vpss ] 373896: SWMS : Co-effs Loading ... DONE !!!
[c6xdsp ] ALGLINK:HEAPID:1 USED:31512
[m3vpss ] 373899: SWMS0 : Loading Vertical Co-effs (UPSCALE)x ...
[c6xdsp ] 372330: ALG : Create Done !!!
[m3vpss ] 373899: SWMS0 : Loading Horizontal Co-effs (UPSCALE)x ...
[m3vpss ] 373899: SWMS : Co-effs Loading ... DONE !!!
[m3vpss ] 373900: SWMS : ******* Configuring clock 15 secs...
[m3vpss ] 373900: SWMS0 : Loading Vertical Co-effs (1/1)x ...
[m3vpss ] 373900: SWMS0 : Loading Horizontal Co-effs (1/1)x ...
[m3vpss ] 373900: SWMS : Co-effs Loading ... DONE !!!
[m3vpss ]
[m3vpss ] *** [SWMS0] Mosaic Parameters ***
[m3vpss ]
[m3vpss ] Output FPS: 60
[m3vpss ]
[m3vpss ] Win | Ch | Input | Input | Input | Input | Output | Output | Ou|
[m3vpss ] Num | Num | Start X, Y | Width x Height | Pitch Y / C | Memory Type | Start X, Y | Width x Height | Pi|
[m3vpss ] ----------------------------------------------------------------------------------------------------------
[m3vpss ] 0 | 0 | 0, 0 | 352 x 288 | 512 / 512 | NON-TILED | 0, 0 | 1920 x 1080 | 38|
[m3vpss ]
[m3vpss ] SWMS:HEAPID:0 USED:424
[m3vpss ] SWMS:HEAPID:1 USED:64352
[m3vpss ] SWMS:HEAPID:4 USED:29030400
[m3vpss ] 373902: SWMS: Create Done !!!
[m3vpss ] 373902: SWMS: Create in progress !!!
[m3vpss ] UTILS: DMA: Allocated CH (TCC) = 61 (61)
[m3vpss ] UTILS: DMA: 0 of 1: Allocated PaRAM = 61 (0x490047A0)
[m3vpss ] UTILS: DMA: Allocated CH (TCC) = 62 (62)
[m3vpss ] UTILS: DMA: 0 of 4: Allocated PaRAM = 62 (0x490047C0)
[m3vpss ] UTILS: DMA: 1 of 4: Allocated PaRAM = 162 (0x49005440)
[m3vpss ] UTILS: DMA: 2 of 4: Allocated PaRAM = 163 (0x49005460)
[m3vpss ] UTILS: DMA: 3 of 4: Allocated PaRAM = 164 (0x49005480)
[m3vpss ] SWMS: instance 1, sc id 4, start win 16 end win 33
[m3vpss ] 374046: SWMS : VipScReq is FALSE!!!
[m3vpss ] 374049: SWMS1 : Loading Vertical Co-effs (UPSCALE)x ...
[m3vpss ] 374049: SWMS1 : Loading Horizontal Co-effs (UPSCALE)x ...
[m3vpss ] 374050: SWMS : Co-effs Loading ... DONE !!!
[m3vpss ] 374054: SWMS1 : Loading Vertical Co-effs (UPSCALE)x ...
[m3vpss ] 374054: SWMS1 : Loading Horizontal Co-effs (UPSCALE)x ...
[m3vpss ] 374054: SWMS : Co-effs Loading ... DONE !!!
[m3vpss ] 374054: SWMS : ******* Configuring clock 15 secs...
[m3vpss ] 374055: SWMS1 : Loading Vertical Co-effs (1/1)x ...
[m3vpss ] 374055: SWMS1 : Loading Horizontal Co-effs (1/1)x ...
[m3vpss ] 374055: SWMS : Co-effs Loading ... DONE !!!
[m3vpss ]
[m3vpss ] *** [SWMS1] Mosaic Parameters ***
[m3vpss ]
[m3vpss ]
[m3vpss ]
[m3vpss ] SWMS:HEAPID:1 USED:60832
[m3vpss ] 374056: SWMS: Create Done !!!
[m3vpss ] 374057: MERGE : Create Done !!!
[m3vpss ] 374057: IPC_FRAMES_OUT : Create in progress !!!
[m3vpss ] 374059: IPC_FRAMES_OUT : Create Done !!!
[m3vpss ] 374078: DISPLAY: Create in progress !!!
[m3vpss ] 374079: Assertion @ Line: 1134 in links_m3vpss/display/displayLink_drv.c: pObj->displayHndl != NULL : fai!
but if i do not enable the OPENGL ,it will run normally, so why and how can i fix this problem?
tks
