Dear Group Members ,
Our requirement is to create an 5min file for 8hours continuously.
So currently we are doing an pipeline start & stop after every 5min. Below is the details
A) We have build an Gst application for :-
Processor ( TI Netra DM8168)
Audio ( Stereo 16bit 44.1KHZ)
Video ( DVI 1080p @ 60hz using TFP401A-EP DVI receiver)
MUX (MATROSKA)
Overlay ( Time )
Filesink as ".avi"
B) We are loosing around 1.7sec at the start of every capture. Let me explain
If we put the pipeline in PLAYING mode at t=0 for total duration of 100 sec , the recordded file has below mentioned status :-
a) Video from t=0 to t=3 sec is not captured in the recorded file .
b) The recorded file has first frame of video from t=3 sec to t=103 sec
C) This data loss of initial 3sec is observed every time i start & stop the engine.
D) The basic flow is :-
a) Creating the pipeline with the elements and linking them in main thread .
gst_bin_add_many(GST_BIN(pipeline), AVIMux, FileSink,NULL);
gst_bin_add_many(GST_BIN(pipeline), omx_videosrc, clockoverlay, omx_videoEnc,NULL);
gst_element_link_many(omx_videosrc, clockoverlay,omx_videoEnc, AVIMux, NULL);
gst_bin_add(GST_BIN(pipeline), alsaAudSrc);
gst_element_link(alsaAudSrc, AVIMux);
gst_element_link(AVIMux, FileSink);
if (TRUE != gst_pipeline_set_clock(pipeline, gst_system_clock_obtain())) {
printf("gst_pipeline_set_clock(GstSystemClock) did not work\n");
nRetVal = FAILURE;
goto labelExit;
b) Create an child thread and do the below mentioned activities ( rough flow ):-
GSource *bus_source;
GstBus *bus;
main_loop_cntxt = g_main_context_new();
g_main_context_push_thread_default(main_loop_cntxt);
bus = gst_element_get_bus (pipeline); // Pipeline is created in parent thread
bus_source = gst_bus_create_watch (bus);
g_source_set_callback (bus_source, (GSourceFunc) gst_bus_async_signal_func, NULL, NULL);
g_source_attach (bus_source, main_loop_cntxt);
g_source_unref (bus_source);
g_signal_connect (G_OBJECT (bus), "message::eos", (GCallback)eos_cb, NULL);
main_loop = g_main_loop_new(main_loop_cntxt, FALSE);
gst_element_set_state (pipeline, GST_STATE_PLAYING);
if (gst_element_get_state (pipeline, NULL, NULL, (GST_SECOND * 15)) == GST_STATE_CHANGE_FAILURE){
goto exit_label;
g_main_loop_run (main_loop);
So could team members please let me know where should we debug and probable point of problem.
Thanks ,
Ashish Kumar Mishra.
