Tool/software: Linux
but when i use standard math lib and make omx, it has error "undefined references cos",and other math functions like sin, sqrt,also have the same error. i want to konw
whether need to revise the makefile under the folder ti-ezsdk_dm816x-evm_5_03_01_15.
here is the two makefile :
# OMX
ifeq ($(ROOTDIR),)
$(error Error: Environment variable ROOTDIR not set)
endif
ifeq ($(PLATFORM),)
$(error Error: Environment variable PLATFORM not set)
endif
# Begin block - Build options
# By the end of this block, we'd have either xdc or make or both in BUILD_OPTIONS
# using which, we'd build either XDC packages (+run configuro)
# or make based components (+link) or both.
BUILD_OPTIONS = xdc make
VALID_BUILD_OPTIONS = full $(BUILD_OPTIONS)
ifeq ($(filter $(BUILD),$(VALID_BUILD_OPTIONS)),)
ifeq ($(BUILD),)
BUILD = full
else
$(error Error: Invalid value specified for BUILD. Valid values are - $(VALID_BUILD_OPTIONS))
endif
endif
ifneq ($(BUILD),full)
BUILD_OPTIONS = $(BUILD)
endif
# End block - Build options
include $(ROOTDIR)/makerules/build_config.mk
include $(ROOTDIR)/makerules/env.mk
include $(INTERNAL_SW_ROOT)/component.mk
omx_COMP_LIST_ALL = $(omx_COMP_LIST_c6xdsp) $(omx_COMP_LIST_m3video) $(omx_COMP_LIST_m3vpss) $(omx_COMP_LIST_a8host) $(omx_COMP_LIST_common) $(EXT_COMP_LIST_c6xdsp) $(EXT_COMP_LIST_common) $(EXT_COMP_LIST_m3video) $(EXT_COMP_LIST_m3vpss) $(EXT_COMP_LIST_a8host)
omx_PKG_LIST_ALL = $(foreach PKG,$(omx_COMP_LIST_ALL),$($(PKG)_PKG_LIST))
omx_PKG_LIST_common = $(foreach PKG,$(omx_COMP_LIST_common),$($(PKG)_PKG_LIST))
omx_PKG_LIST_c6xdsp = $(foreach PKG,$(omx_COMP_LIST_c6xdsp),$($(PKG)_PKG_LIST))
omx_PKG_LIST_m3video = $(foreach PKG,$(omx_COMP_LIST_m3video),$($(PKG)_PKG_LIST))
ALL_COMP_LIST_m3vpss = $(omx_COMP_LIST_m3vpss) $(EXT_COMP_LIST_m3vpss)
omx_PKG_LIST_m3vpss = $(foreach PKG,$(ALL_COMP_LIST_m3vpss),$($(PKG)_PKG_LIST))
omx_PKG_LIST_a8host = $(foreach PKG,$(omx_COMP_LIST_a8host),$($(PKG)_PKG_LIST))
CLEANALL_TARGETS = $(addsuffix _clean, $(omx_PKG_LIST_ALL))
CLEANALL_c6xdsp = $(addsuffix _clean, $(omx_PKG_LIST_c6xdsp))
CLEANALL_m3video = $(addsuffix _clean, $(omx_PKG_LIST_m3video))
CLEANALL_m3vpss = $(addsuffix _clean, $(omx_PKG_LIST_m3vpss))
CLEANALL_a8host = $(addsuffix _clean, $(omx_PKG_LIST_a8host))
CLEANALL_common = $(addsuffix _clean, $(omx_PKG_LIST_common))
CLEANALL_EXAMPLES = $(addsuffix _clean, $(omx_EXAMPLES_LIST))
CLEANALL_EXAMPLES_NONXDC = $(addsuffix _clean, $(omx_EXAMPLES_LIST_NONXDC))
.PHONY : $(omx_PKG_LIST_ALL) $(omx_EXAMPLES_LIST) $(omx_EXAMPLES_LIST_NONXDC)
libs: libs_host libs_dsp
libs_host: omxobjs
libs_dsp:
all: libs examples
examples: $(omx_EXAMPLES_LIST) $(omx_EXAMPLES_LIST_NONXDC)
examples_dsp: $(omx_EXAMPLES_DSP)
examples_host: $(omx_EXAMPLES_HOST)
clean: $(CLEANALL_TARGETS)
cleanall: $(CLEANALL_TARGETS) $(CLEANALL_EXAMPLES) $(CLEANALL_EXAMPLES_NONXDC)
# Rule to build all modules and examples
$(omx_PKG_LIST_common) :
$(ECHO) \# Making $(PLATFORM):a8host:$(PROFILE_a8host):$@...
$(MAKE) -C $($@_PATH) CORE=a8host
$(omx_PKG_LIST_a8host) :
# DECODER NT demo/app
decode: decodehost
decodehost:
ifeq ($(findstring make,$(BUILD_OPTIONS)),make)
$(ECHO) \# Building $(subst host,,$@) executable for core: a8host
$(MAKE) -C $($(subst host,,$@)_EXAMPLES_PATH) CORE=a8host
endif
# DECODE DISPLAY NT demo/app
decode_display: decode_displayhost
decode_displayhost:
endif
encode: encodehost
encodehost:
endif
# CAPTURE->ENCODE NT demo/app
capture_encode: capture_encodehost
capture_encodehost:
endif
# C6XTEST DSP NT demo/app
c6xtest: c6xtesthost
c6xtesthost:
endif
# ADEC_SNT DSP NT demo/app
adec_snt: adec_snthost
adec_snthost:
endif
# audio_encode demo/app
audio_encode: audio_encode
audio_encode:
endif
# VSWMOSAIC demo/app
decode_mosaicdisplay: decode_mosaicdisplayhost
decode_mosaicdisplayhost:
endif
# dm81xx dsp source build
dm81xxdspXdc:
ifeq ($(findstring xdc,$(BUILD_OPTIONS)),xdc)
$(ECHO) \# Making XDC dependent packages for $(subst dspXdc,,$@):c6x
$(MAKE) -f xdcdepmakefile _APP=$(subst dspXdc,,$@) CORE=c6xdsp
$(ECHO) \# Configuring XDC packages for $(subst dspXdc,,$@):c6x
$(MAKE) -C $($(subst dspXdc,,$@)_EXAMPLES_PATH) xdc_configuro CORE=c6xdsp
endif
dm81xx: dm81xxdspXdc
$(ECHO) \# Building $(subst dsp,,$@) executable for core: c6xdsp
$(MAKE) -C $($(subst dsp,,$@)_EXAMPLES_PATH) CORE=c6xdsp
endif
omxobjs:
$(CP) $(DEST_ROOT)/omxobjs/obj/$(PLATFORM)/a8host/$(PROFILE_a8host)/*.ov5T $(DEST_ROOT)
$(RM) $(DEST_ROOT)/main.ov5T
$(MAKE) -C $($(subst host,,$@)_EXAMPLES_PATH) archive_spl CORE=a8host AR_SPL_PATH=$(DEST_ROOT) AR_SPL_NAME=omxcfg.av5T
$(RM) $(DEST_ROOT)/*.ov5T
endif
# Clean targets
$(CLEANALL_common) :
$(ECHO) \# Cleaning $(subst _clean,,$@)...
$(MAKE) -C $($(subst _clean,,$@)_PATH) clean CORE=c6xdsp
$(MAKE) -C $($(subst _clean,,$@)_PATH) clean CORE=m3video
$(MAKE) -C $($(subst _clean,,$@)_PATH) clean CORE=m3vpss
$(MAKE) -C $($(subst _clean,,$@)_PATH) clean CORE=a8host
$(CLEANALL_c6xdsp) :
$(CLEANALL_a8host) :
$(CLEANALL_EXAMPLES):
$(MAKE) -f xdcdepmakefile xdcdepclean _APP=$(subst _clean,,$@) CORE=c6xdsp
endif
$(MAKE) -C $($(subst _clean,,$@)_EXAMPLES_PATH) clean CORE=c6xdsp
$(MAKE) -C $($(subst _clean,,$@)_EXAMPLES_PATH) clean CORE=a8host
$(CLEANALL_EXAMPLES_NONXDC):
# SDK Related targets
# ==== Standard Variables ====
# Where to install/stage the packages
# Typically this would point to the devkit location
DESTDIR ?= $(HOME)/target-root
libdir ?= /lib
includedir ?= /include
ifeq ($(docdir),)
docdir := /share/ti/omx/doc
endif
ifeq ($(prefix),)
prefix := /usr
xdcprefix := /
endif
# == Helper variables ==
LIBSINPACKAGES = $(shell cd src && find . -name '*.ae674' -or -name '*.av5T' -type f)
LIBSINBIN = $(shell cd bin && find . -name '*.ae674' -or -name '*.av5T' -type f)
LIBSINLIB = $(shell cd lib && find ti -name '*.ae674' -or -name '*.av5T' -type f)
HEADERS = $(shell cd src && find . -name '*.h' -type f -not \( -name "package.defs.h" -o -name "_*.h" \))
DOCS = $(wildcard *ReleaseNotes.PDF) $(wildcard *UserGuide.pdf)
LIBDIRSDK = $(DESTDIR)/$(prefix)/$(libdir)
INCDIRSDK = $(DESTDIR)/$(prefix)/$(includedir)
DOCDIR = $(DESTDIR)/$(prefix)/$(docdir)
PACKAGEDIR = $(DESTDIR)/$(xdcprefix)/$(packagedir)
# ==== Helper functions ====
purge = @find $(1) -name $(2) -exec rm -rf {} \;
all_packages = $(XDCPKG) packages | sed -e 's:packages/::' -e 's:/:.:g'
# ==== Targets ====
install:
@echo "Installing libraries.."
@mkdir -p $(LIBDIRSDK)
ifneq ($(LIBSINPACKAGES),)
@cd packages && cp --parents $(LIBSINPACKAGES) $(LIBDIRSDK)
endif
ifneq ($(LIBSINBIN),)
@cd bin && cp --parents $(LIBSINBIN) $(LIBDIRSDK)
endif
ifneq ($(LIBSINLIB),)
@cd lib && cp --parents $(LIBSINLIB) $(LIBDIRSDK)
endif
@echo "Installing header files.."
@mkdir -p $(INCDIRSDK)
@cd packages && cp --parents $(HEADERS) $(INCDIRSDK)
@echo "Installing documentation.."
@mkdir -p $(DOCDIR)
@cp $(DOCS) $(DOCDIR)
# Nothing beyond this point
the app makefilie:
# Makefile for encode app
APP_NAME = capture_encode
ifeq ($(PLATFORM),ti816x-evm)
PLATDIR = dm816x
else
PLATDIR = dm814x
endif
SRCDIR = src src/$(PLATDIR) ../common
INCDIR = . src src/$(PLATDIR) ../common
# List all the external components/interfaces, whose interface header files
# need to be included for this component
INCLUDE_EXERNAL_INTERFACES = bios xdc omx timmosal ipc fc xdais osal syslink \
ce h264enc uia slog
# List of all external libraries that need to be linked
EXTLIBS_m3video =
EXTLIBS_m3vpss =
EXTLIBS_a8host = $(omx_LIBPATH)/../lib/omxcore.av5T \
$(omx_LIBPATH)/../lib/memcfg.av5T \
$(omx_LIBPATH)/../lib/domx.av5T \
$(omx_LIBPATH)/../lib/domx_delegates_shmem.av5T \
$(omx_LIBPATH)/../lib/timmosal.av5T \
$(omx_LIBPATH)/../lib/omxcfg.av5T \
$(osal_PATH)/packages/linuxdist/build/lib/osal.a \
$(osal_PATH)/packages/linuxdist/cstubs/lib/cstubs.a \
$(fc_PATH)/packages/ti/sdo/rcm/lib/debug/rcm_syslink.av5T \
$(fc_PATH)/packages/ti/sdo/fc/memutils/lib/release/memutils.av5T \
$(osal_PATH)/packages/ti/sdo/xdcruntime/linux/lib/debug/osal_linux_470.av5T \
$(fc_PATH)/packages/ti/sdo/fc/global/lib/debug/fcsettings.av5T \
$(syslink_PATH)/packages/ti/syslink/lib/syslink.a_release \
$(linuxutils_PATH)/packages/ti/sdo/linuxutils/cmem/lib/cmem.a470MV \
$(uia_PATH)/packages/ti/uia/linux/lib/servicemgr.a
# $(omx_LIBPATH)/../lib/ldrmemcfg.av5T
# $(slog_PATH)/lib/slog.a
# List all the components required by the application
COMP_LIST_m3video = omxbase venc server scheduler domx omxcore
COMP_LIST_m3vpss = omxbase vfcc vfpc vfdc ctrl domx omxcore hdvpss
COMP_LIST_a8host =
# Common source files and CFLAGS across all platforms and cores
SRCS_COMMON =
CFLAGS_LOCAL_COMMON = -DGlobal_appTerminate=0
SRCS_a8host = main.c msgq.c platform_utils.c \
ilclient.c ilclient_utils.c semp.c
CFLAGS_LOCAL_a8host = -DGlobal_GrpxDssMsgHeapId=6 -DGlobal_TilerHeapId=7 -D_VIDEO_M3_DYNAMIC_CONFIG
ifeq ($(CORE),a8host)
CFLAGS_LOCAL_a8host += -D_LOCAL_CORE_a8host_
endif
# Include common make files
include $(ROOTDIR)/makerules/common.mk
Thanks for solving sincerely!
