Tool/software: Linux的
when running Qt5 Example "qt5-cinematic-experience" , an error occurs :
QIconvCodec::convertToUnicode: using Latin-1 for conversion, iconv_open failed QIconvCodec::convertFromUnicode: using Latin-1 for conversion, iconv_open failed This application failed to start because it could not find or load the Qt platform plugin "eglfs" in "/usr/local/qt5/plugins". Available platform plugins are: eglfs, linuxfb, minimal, minimalegl, offscreen, vnc, xcb. Reinstalling the application may fix this problem. Aborted
env :
#export QTDIR=/usr/local/qt5
# export QT_QPA_FONTDIR=$QTDIR/lib/fonts
# export QT_QPA_PLATFORM_PLUGIN_PATH=$QTDIR/plugins
# export LD_LIBRARY_PATH=$QTDIR/lib:$LD_LIBRARY_PATH
# export PATH=$QTDIR/bin:$PATH
# export PKG_CONFIG_PATH=$QTDIR/lib/pkgconfig/$PKG_CONFIG_PATH
