• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Digital Signal Processors (DSP) » DaVinci™ Video Processors » DM64x DaVinci Video Processor Forum » DM6467T vs DM6467 current usage.
Share
  • Forums
  • Announcements
Options
  • Subscribe via RSS
This question is answered
Helmut Forren
Posted by Helmut Forren
on May 12 2011 16:58 PM
Mastermind6470 points
I'm struggling to get a second batch of my custom boards working.  The first batch of three used TMS320DM6467ZUT1 chips, with appropriate crystal speed (27MHz) and core power supply voltage (1.2V).  When just powered on and not yet programmed, they each drew something like 20mA or less with a 12V supply, including any supply inefficiencies.
Now, on the second batch of two, using the remaining boards from the *only* batch of five boards, I'm using TMS320DM6467TZUTD1 chips.  In the same condition, these immediately consume 24mA to 35mA to 45mA, at various times on various power-on tests.  I've changed power supply programming resistors to produce 1.3V core voltage.  I originally had a 33MHz crystal, but was unsure of oscillation, so I jumpered the circuit to operate off the 27MHz coming from the CDCE949 clock generator.  So while the core voltage is higher, the clock speed is the same.  In this current configuration, one of the boards immediately powers up to 30mA.
Note as well that the DM6467T chips get extremely hot on the surface (150+ degF), while I never noticed this with the DM6467 chips.
The original design was indeed for DM6467T, but the first batch didn't use them due to lack of availability.
QUESTION: Is there any way that the DM6467T is *supposed* to be drawing so much more current and generating so much more heat, or is this *perhaps proof* that there is a BGA assembly problem (another issue I'm considering).
Thanks very much,
helmut
DM6467T DM6467 current heat
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • srirami
    Posted by srirami
    on May 12 2011 17:09 PM
    Expert8260 points
    Helmut,
    Looks like there is a typo in the part number of your statment "....The first batch of three used TMS320DM6467ZUT1 chips....". The part number "TMS320DM6467ZUT1" is not a correct part  number. Are you comparing DM6467ZUT Vs DM6467TZUTD1?
    Regards, Srirami.
    PS: Please mark this post as answered via the Verify Answer button below if you think it answers your question.  Thanks!
    Report Abuse
    • Reply
  • jh y
    Posted by jh y
    on May 29 2012 01:43 AM
    Prodigy10 points
    Helmut Forren,
         I'm using DM6467TZUTD1 too,It is very hot on my board.how can I do to reduce heat of DM6467TZUTD1.Note as well that the DM6467tZUTD1 Maintain the same performance as before. thank you.
    DM6467tZUTD1
    Report Abuse
    • Reply
  • Helmut Forren
    on May 29 2012 11:55 AM
    Srirami,
    Thanks for answering way back when.  The first part was ZUT7 and the second ZUTD1.  A couple months ago I discovered my problem was with having JTAG lines too long.  On a THIRD batch using ZUT7, none worked.  But when I went to serial port programming rather than JTAG, they all worked.  So, presumably, the problem with the ZUTD1 boards was also this JTAG line situation.  I can't confirm, however, because those boards got destructively tested.
    What I've learned, and for others to know, is that those JTAG lines are persnickety.  I was forced to run them off the board through a connector and FFC to another board.  Design forces in the future won't allow that to happen, or else I'll just go straight to serial port programming (sfh_DM646x.exe).
    jy h,
    If your processor is working properly yet running too hot, then add more heat sink (in-board or above) or slow down the clock.
    -Helmut
    Report Abuse
    • Reply
  • srirami
    Posted by srirami
    on May 29 2012 12:26 PM
    Verified Answer
    Verified by Helmut Forren
    Expert8260 points
    Helmut,
    Thanks for the update and comments about JTAG lines. Did you check how these lines are routed on DM6467/DM6467T EVM?
    Regards, Srirami.
    Report Abuse
    • Reply
  • Helmut Forren
    on May 29 2012 12:31 PM
    Yes, mine were nasty compared.
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
