Hello!
I want to stream mpegts over the ethernet. I use a gstreamer-pipeline from a Ubuntu PC on the streaming end (actually I want to use vlc later), and on the client, DM368, I perform the following pipeline:
gst-launch udpsrc uri="udp://192.168.1.255:5005/255" caps="application/x-rtp, media=(string)video, clock-rate=(int)90000, encoding-name=(string)MP2T-ES, payload=(int)33" ! rtpmp2tdepay ! queue ! mpegtsparse ! queue ! mpegtsdemux ! queue ! mpeg4videoparse ! queue ! TIViddec2 displayBuffer=true engineName=codecServer codecName=mpeg4dec framerate=24000/1001 ! queue ! tidisplaysink2 video-standard=auto display-output=component sync=false -vvv --gst-debug=2
I get the following behavior:
After some seconds, when the buffer is filled, I get the 1st image of my video (with false colors), and after this, I get some blocks in the picture and the video becomes unreadable and stops.
Thanks for any help in advance!
Gustav
PS:Maybe the following part of the log might be helpful:
/GstPipeline:pipeline0/GstTIViddec2:tividdec20.GstPad:src: caps = video/x-raw-yu
v, format=(fourcc)NV12, framerate=(fraction)24000/1001, width=(int)1280, height=
(int)720
[B | ]
[RW | ]
[R-W | ]
[R--W | ]
[R---W | ]
[R----W | ]
[R-----W | ]
[R------W | ]
[R-------W | ]
[R--------W | ]
[R---------W | ]
[R----------W | ]
[R-----------W | ]
[R------------W | ]
[R-------------W | ]
[R--------------W | ]
[R---------------W | ]
[R----------------W | ]
[R-----------------W | ]
[R------------------W | ]
[R-------------------W | ]
[R--------------------W| ]
[R=====================W ]
[R=====================|W ]
[R=====================|=W ]
[R=====================|==W ]
[R=====================|===W ]
[R=====================|====W ]
/GstPipeline:pipeline0/GstQueue:queue4.GstPad:sink: caps = video/x-raw-yuv, form
at=(fourcc)NV12, framerate=(fraction)24000/1001, width=(int)1280, height=(int)72
0
/GstPipeline:pipeline0/GstQueue:queue4.GstPad:src: caps = video/x-raw-yuv, forma
t=(fourcc)NV12, framerate=(fraction)24000/1001, width=(int)1280, height=(int)720
/GstPipeline:pipeline0/GstTIDisplaySink2:tidisplaysink20.GstPad:sink: caps = vid
eo/x-raw-yuv, format=(fourcc)NV12, framerate=(fraction)24000/1001, width=(int)12
80, height=(int)720
[ R=====================|====W ]
[ R=====================|===W ]
[ R=====================|==W ]
davinci_v4l2 davinci_v4l2.1: Before finishing with S_FMT:
layer.pix_fmt.bytesperline = 1280,
layer.pix_fmt.width = 720,
layer.pix_fmt.height = 480,
layer.pix_fmt.sizeimage =1382400
davinci_v4l2 davinci_v4l2.1: pixfmt->width = 720,
layer->layer_info.config.line_length= 1280
[ R=====================|=W ]
/GstPipeline:pipeline0/GstTIDisplaySink2:tidisplaysink20: device = "/dev/video2"
/GstPipeline:pipeline0/GstTIDisplaySink2:tidisplaysink20: video-standard = "480p
/GstPipeline:pipeline0/GstTIDisplaySink2:tidisplaysink20: display-output = "comp
onent"
/GstPipeline:pipeline0/GstTIDisplaySink2:tidisplaysink20: queue-size = 3
/GstPipeline:pipeline0/GstTIDisplaySink2:tidisplaysink20: mmap-buffer = FALSE
/GstPipeline:pipeline0/GstTIDisplaySink2:tidisplaysink20: dma-copy = TRUE
[ R=====================|W ]
[ R=====================W ]
[ R--------------------W| ]
[ R---------------------W ]
[ R=====================|=====W ]
0:00:12.007229848 2271 0x140f00 ERROR GstTIDmaiBufTab gsttidmaibuftab.
c:163:gst_tidmaibuftab_get_buf: Failed to get a buffer from the GstTIDmaiBufTab
object
0:00:12.008165640 2271 0x140f00 WARN TIViddec2 gsttividdec2.c:1
622:gst_tividdec2_decode_thread:<tividdec20> error: failed to get a free contigu
ous buffer from BufTab
ERROR: from element /GstPipeline:pipeline0/GstTIViddec2:tividdec20: failed to ge
t a free contiguous buffer from BufTab
Additional debug info:
gsttividdec2.c(1622): gst_tividdec2_decode_thread (): /GstPipeline:pipeline0/Gst
Execution ended after 11301481385 ns.
