i am facing an issue loading DSP bin file from ARM.The following .cmd DSP file, i am using
-c
-stack 0x100
-heap 0x100
-lrts6400.lib
MEMORY
SDRAM: origin = 0x877034C0, len = 0x15000
L2RAM: origin = 0x118024C0, len = 0x10000
L1DRAM: origin = 0x11F04000, len = 0xc000
SECTIONS
.text > SDRAM
.switch > L2RAM
.cinit > L2RAM
.const > L2RAM
.bss > L2RAM
.data > L2RAM
.stack > L1DRAM
.sysmem > L1DRAM
.far > L2RAM
.pinit > L2RAM
.template > L2RAM
.cio > L2RAM
.csl_vect > L2RAM
RTS_CODE > L2RAM
VpssData > L2RAM
Wen i use the following .cmd dsp file , dsp bin loading and running is successful
-c
-stack 0x100
-heap 0x100
-lrts6400.lib
MEMORY
//L2RAM: origin = 0x118024C0, len = 0x10000
//L1DRAM: origin = 0x11F04000, len = 0xc000
SECTIONS
.text > SDRAM
.switch > SDRAM
.cinit > SDRAM
.const > SDRAM
.bss > SDRAM
.data > SDRAM
.stack > SDRAM
.sysmem > SDRAM
.far > SDRAM
.pinit > SDRAM
.template > SDRAM
.cio > SDRAM
.csl_vect > SDRAM
RTS_CODE > SDRAM
VpssData > SDRAM
So, please help why in first case , the dsp bin loading and running is not successful.
Thanking you,
Pulla Rao Chilakala,
Bharat Electronics Limited ,Central Research Labs,
Bangalore
