I want to up-sampling video from 720*480 format to 1024*768 format by using THS8200 daughter card and DM6446 EVM board
any Suggestions ...............
Thanks for your post.
Unfortunately, the THS8200 does not have a scaler. But if you still need to resize your image, you can check the image resizing method within a VB.NET image process project below:
http://www.rasteredge.com/how-to/vb-net-imaging/resize-image/
In general we never use such THS8200 to process image, there are many free trial image resizing and other image editing tools which you could try as below:
http://www.rasteredge.com/how-to/vb-net-imaging/imaging-processing/
Also, there is a "calccoef" utility associated with the "Understanding the Davinci Resizer" app note (SPRAAI7B) to generate coefficients and other resizer parameter structure values as below:
http://www.ti.com/lit/an/spraai7b/spraai7b.pdf
Alternativey, you could also try to walkthrough the below E2E thread to interface a DaVinci SoC DM6446 to a THS8200:
http://e2e.ti.com/support/dsp/davinci_digital_media_processors/f/99/t/5909
To use resizer on DM6446, please refer the below E2E thread and hope it helps:
http://e2e.ti.com/support/dsp/davinci_digital_media_processors/f/99/t/6166
Thanks & regards,
Sivaraj K
Please click the Verify Answer button on this post if it answers your question.
