• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Digital Signal Processors (DSP) » DaVinci™ Video Processors » DM64x DaVinci Video Processor Forum » Switch #10 of S3 doesn't work
Share
  • Forums
  • Announcements
Options
  • Subscribe via RSS
  • LorryAstra
    Posted by LorryAstra
    on Jul 22 2008 22:23 PM
    Expert1300 points
       My camera is PAL, so I put on switch #10 of S3 in EVM board (for PAL region), and then I debug "encodedecode" demo in dvevm_1_20 folder.
      In function detectVideoStandard(void), when I run to
         if (ioctl(fd, FBIO_GETSTD, &std) == -1) {
            ERR("Failed to get video standard from display device driver\n");
            return FAILURE;
        if ((std >> 16) == 0x1) {
            DBG("NTSC selected\n");
            gblSetYFactor(NTSCSTD);
        else {
            DBG("PAL selected\n");
            gblSetYFactor(PALSTD);
      I find that (std >> 16) is always 0x1, no matter switch #10 is on or off, I don't know whether there is something wrong with my board. (I've tried to reboot my linux and montavista linux.)
    Thanks.
    PAL S3
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
  • Bernie Thompson TI
    Posted by Bernie Thompson TI
    on Jul 22 2008 23:13 PM
    Mastermind41680 points
    I am assuming you are working with a DM6446. There is a bit more to setting the board up for PAL than the S3 #10 dip switch, although it may seem that way from glancing over the documentation. This switch actually is just a pin that is checked by U-Boot, and causes U-Boot to set the environment variable 'videostd' to be 'pal' or 'ntsc', which unfortunately is not quite enough to change your standard to PAL on its own, however it does allow you to setup U-Boot options so that the switch does change between PAL and NTSC. Essentially you need to change your 'bootcmd' U-Boot environment variable to contain a reference to 'videostd' so it passes it on to the kernel such that the kernel can recognize if it should be working with NTSC or PAL. Your 'bootcmd' variable should look something like below.
    bootcmd="setenv setboot setenv bootargs \$(bootargs) video=dm64xxfb:output=\$(videostd);run setboot;bootm 0x2050000"
    With 'bootargs' set as something like:
    bootargs="mem=120M console=ttyS0,115200n8 root=/dev/hda1 rw noinitrd ip=dhcp"
    This is actually discussed in section 4.3.6 of the getting started guide which can be found below.
    http://focus.ti.com/lit/ug/sprue66c/sprue66c.pdf
    DaVinci DVEVM PAL
    Report Abuse
    • Reply
  • LorryAstra
    on Jul 23 2008 01:48 AM
    Expert1300 points
    Thanks Bernie.
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
