• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Digital Signal Processors (DSP) » DaVinci™ Video Processors » DM64x DaVinci Video Processor Forum » Loading U-Boot
Share
  • Forums
  • Announcements
Options
  • Subscribe via RSS
Loading U-Boot
Loading U-Boot
This question is not answered
SJackson
Posted by SJackson
on Jul 08 2008 09:42 AM
Intellectual350 points
I am using Code Composer Studio and a Blackhawk JTAG pod to burn U-Boot to Flash memory on my DaVinci-based board.  I'm using the flash writer CCS application supplied by TI for programming the EVM, modified to recognize the Flash chip/manufacturer that I'm using.  Furthermore, I have modified U-Boot to make use of the correct DDR memory timings for my board.  After burning U-Boot in flash, I can use Code Composer and my JTAG pod to set the DaVinci's program counter to 0x02000000 (the beginning of Flash memory), begin execution, and watch U-Boot messages come out of the UART.  If I turn off the power, disconnect my JTAG pod and power on the board (with BTSEL pins configured to boot from NOR flash: BTSEL1=0, BTSEL0=1) nothing happens.
I have previously tried to use TI's DVFlasher utility although I had to modify it to recognize my flash chip and deal with a bottom-boot flash device.  However the programming sequence either experiences a write timeout or gets stuck in an infinite loop. It seems to happen around the same address every time.
If U-Boot runs when I tell the chip to start execution at 0x02000000 in CCS, shouldn't it also run when I power on the board without JTAG?
Thanks.
flash u-boot
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Juan Gonzales
    Posted by Juan Gonzales
    on Jul 08 2008 10:21 AM
    Mastermind33875 points
    I assume by DaVinci EVM, you mean DM644X EVM (DaVinci represents family of processors: DM355, DM644X, DM6467, DM643X...).
    If so, can you confirm the CS2 jumper is set to FLASH and S3 settings are 1011111110 (1=ON, 0=OFF).  If the switch settings are correct, as soon as you power on the board (with, or without JTAG), you should see u-boot messages.
    DM6446
    Report Abuse
    • Reply
  • SJackson
    Posted by SJackson
    on Jul 08 2008 10:34 AM
    Yes, I meant the DM644X EVM, but I don't think I was clear enough in my explaination.
    I'm trying to do this on my own custom board, NOT the EVM.  I meant that I'm using the tools supplied to program U-Boot onto the EVM to program U-Boot onto my custom hardware.
    Report Abuse
    • Reply
  • Juan Gonzales
    on Jul 08 2008 11:09 AM
    2 things to consider.
    1) Read BOOTCFG register to determine BTSEL settings at reset, just to make sure you are really in NOR boot mode.
    2) When you are connecting with CCS, are you using a GEL file (often changes hardware state)?  If so, try running without the GEL file and see if you can still get CCS to work.
    DM6446 u-boot
    Report Abuse
    • Reply
  • SJackson
    Posted by SJackson
    on Jul 08 2008 16:15 PM
    What address is the BOOTCFG register at?
    The datasheet for TMS320DM6446 states that it is at 0x01C4 000A (section 3.3.1.1) while the "TMS320DM644x DMSoC ARM Subsystem Reference Guide" (SPRUE14A) indicates that BOOTCFG should be at 0x01C40014 (section 10.9).  If the datasheet is right, then my BOOTCFG values are incorrect.  If the ARM Subsystem Reference Guide is right, then my values are OK.
    DM6446 BOOTCFG Register
    Report Abuse
    • Reply
  • Juan Gonzales
    on Jul 08 2008 16:41 PM
    0x01C40014 is correct.  Actually, this value is also found in table 3-1 on the data-sheet; you seemed to have found a typo in section 3.3.1.1 of the data-sheet.  I will make sure this gets corrected.
     Did you check the GEL file?
    DM6446
    Report Abuse
    • Reply
  • Bernie Thompson TI
    Posted by Bernie Thompson TI
    on Jul 08 2008 17:01 PM
    Mastermind41680 points
    Since your BOOTCFG register is correct, that indicates that your boot mode is being latched in properly, so the only obvious point that could be causing this is the GEL file, as the only difference between running the code out of flash directly with this boot mode and setting the PC to the beginning of the flash with CCS is the GEL file. I would guess that if you have a GEL file it is doing some configuration that is allowing the binary to run properly (power up, clocks, DDR, EMIF, etc). If you are already running without a GEL file than I am not sure what the problem could be, it may be worth checking your new schematic against the EVM to make sure no reserved pins or boot pins are being treated incorrectly.
    Report Abuse
    • Reply
  • SJackson
    Posted by SJackson
    on Jul 09 2008 11:37 AM
    When using CCS, I cannot get U-Boot to run without a GEL file so it seems that there's some configuration going on in the GEL file that isn't happening on the board.  Its interesting that U-Boot would run fine on the EVM but not on my custom board when, as far as low level init goes, I'm only using different flash and different DDR.  In any case, I am exploring modifying U-Boot to use the same procedures as the GEL file in hopes that it will alleviate the problem.
    Nice icon by the way.
    Report Abuse
    • Reply
    on Jul 09 2008 11:50 AM
     It sounds like you are on the right track, I imagine there is some DDR initialization the GEL file is doing that U-Boot is not handling properly for your particular DDR device, the rest of the init sequence should be the same as you mention the only difference with your board vs the EVM is the flash and DDR, assuming your flash can handle the default EMIF timings used by this boot mode (which I believe are the slowest possible so it should).
    Report Abuse
    • Reply
  • SJackson
    Posted by SJackson
    on Jul 10 2008 14:00 PM
    Turns out that somehow the symbol CONFIG_SKIP_LOWLEVEL_INIT got defined and completely bypassed all the DDR2 initialization that should have been taking place.  Things seem to work now.
    Thanks for all the help!
    Report Abuse
    • Reply
TI E2E™ Community
  • Support Forums
  • Blogs
  • Videos
  • Groups
  • Site Support & Feedback
  • Settings
TI E2E™ Community Groups
  • TI University Program
  • Make the Switch
  • Microcontroller Projects
  • Motor Drive & Control
Other Communities
  • Deyisupport
  • Designsomething.org
  • beagleboard.org
  • TI on Element 14
  • TI on TechXchangeSM
Other Technical & Support Resources
  • WEBENCH® Design Center
  • Product Information Centers
  • Technical Documents
  • TI Design Network
  • TI Technical Articles
  • TI Training
All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
embedded processors, along with software, tools and the industry’s largest sales/support staff.
© Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
Trademarks | Privacy Policy | Terms of Use
