• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Digital Signal Processors (DSP) » OMAP™ Processors » OMAP-L13x, AM1x and C674x Processors Forum » AM1705_Custom Board - CRC error during UART Boot
Share
OMAP™ Processors
  • Forums
  • Announcements
Options
  • Subscribe via RSS
Resources
  • OMAP-L1x DSP+ARM9™-based Processors Product Folder
  • OMAP3525/30 DSP+ARM Cortex™-A8-based SOCs Product Folder
  • Top OMAPL Wiki Links
  • OMAPL3x Schematic Review Checklist
  • OMAPL13x Boot resources
  • OMAPL Document Resources
  • OMAPL137 Technical reference manual
  • OMAPL138 Technical reference manual
  • OMAPL Boot loader App Notes
  • AM1705_Custom Board - CRC error during UART Boot
    This question is answered
    Loic Cheminade
    Posted by Loic Cheminade
    on May 17 2011 22:55 PM
    Prodigy30 points
    Hi
    I am trying to get u-boot on a custom board based on an AM1705. I am using the AIS UART tool to boot from UART and everything goes fine (BOOTME, synchro, send file, jump, close port) except that I don't get the u-boot prompt when using a COM terminal. In order to find where's the issue I tried to enable the CRC checking in AIS and I got the following error:
    (AIS Parse): CRC enabled.
    (AIS Parse): Processing command 58: 0x58535901.
    (AIS Parse): Performing Opcode Sync...
    (AIS Parse): Loading section...
    (AIS Parse): Loaded 152752-Byte section to address 0xC1080000.
    (AIS Parse): Processing command 59: 0x58535902.
    (AIS Parse): Requesting CRC...
    (AIS Parse): CRC failed!  Sending STARTOVER...
    (AIS Parse): 4294814520-Byte seek applied.
    (AIS Parse): Processing command 60: 0x58535901.
    Which I believe means nothing got written properly into RAM (which is 16*16M=256MB). Does this mean it is a RAM issue (is CRC trying to read from RAM?) or can this be coming from somewhere else? As synchro is fine I don't really expect things to go wrong during the transfer (especially as the seek applied is always the same).
    RAM registers are configured and the CLOCK signal going into RAM is 133MHZ as expected.
    Thank you for your help!
    Loic
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • Joe Coombs
      Posted by Joe Coombs
      on May 18 2011 10:22 AM
      Expert8845 points
      Loic,
      When you say that you don't get a U-boot prompt, what do you mean?  It is probably not possible to have a COM terminal open while the UART boot host utility runs.  (If they are both open, then they are probably using different serial ports.)  The EVM approach is to place the AIS boot image in a slave memory (like SPI flash) so that the PC serial port is available for U-boot.  If you want to use UART for both AIS boot and U-boot, then you may have to follow a procedure like this:
      1. Run UART host utility
      2. Power on device
      3. Wait for UART host utility to report completion
      4. Close UART host utility
      5. Open COM terminal
      6. Assume you have missed the first U-boot prompt
      Regarding the AIS parsing error, does that error repeat itself, or does it only happen once?  If possible, please post the entire log from the UART boot host utility and your AIS file.  This could help me to diagnose what is going wrong.
      Hope this helps.
      Please click the  Verify Answer  button on this post if it answers your question.
      Report Abuse
      • Reply
    • Loic Cheminade
      on May 18 2011 19:05 PM
      Prodigy30 points
      Thank you for your answer! I indeed followed your 6 steps, assumed that I missed the u-boot prompt but thought that when opening a COM terminal and pressing enter I would get some reply from u-boot. Is that wrong?
      Yes the parsing error is repeating itself many times:
      (File IO): Read 196396 bytes from file C:\Users\Yop\Desktop\test_crc.bin.
      (Serial Port): Opening COM18 at 115200 baud...
      (AIS Parse): Read magic word 0x41504954.
      (AIS Parse): Waiting for BOOTME... (power on or reset target now)
      (AIS Parse): BOOTME received!
      (AIS Parse): Performing Start-Word Sync...
      (AIS Parse): Performing Ping Opcode Sync...
      (AIS Parse): Processing command 0: 0x5853590D.
      (AIS Parse): Executing function...
      (AIS Parse): Processing command 1: 0x58535907.
      (AIS Parse): Loading boot table...
      (AIS Parse): Processing command 2: 0x5853590D.
      ... more commands
      (AIS Parse): Processing command 56: 0x5853590D.
      (AIS Parse): Processing command 57: 0x58535903.
      (AIS Parse): Loaded 152908-Byte section to address 0xC1080000.
      (AIS Parse): 4294814364-Byte seek applied.
      (AIS Parse): Processing command 61: 0x58535902.
      (AIS Parse): Processing command 62: 0x58535901.
      (AIS Parse): Processing command 63: 0x58535902.
      (AIS Parse): Processing command 70: 0x58535901.
      (System): Boot aborted by user.
      (Serial Port): Closing COM18.
      And here is what happens with the same config but without CRC:
      (File IO): Read 196344 bytes from file C:\Users\Yop\Desktop\test.bin.
      ... more commands
      (AIS Parse): Processing command 57: 0x58535901.
      (AIS Parse): Loaded 33044-Byte section to address 0xC10A5550.
      (AIS Parse): Processing command 59: 0x58535901.
      (AIS Parse): Loaded 7864-Byte section to address 0xC10AD664.
      (AIS Parse): Loaded 1596-Byte section to address 0xC10AF51C.
      (AIS Parse): Processing command 61: 0x58535906.
      (AIS Parse): Performing jump and close...
      (AIS Parse): AIS complete. Jump to address 0xC1080000.
      (AIS Parse): Waiting for DONE...
      (AIS Parse): Boot completed successfully.
      The thing is I had to modify and recompile u-boot to get the prompt on UART1 (instead of UART2 on da830). I also changed a couple of other things to adapt it to my board. I might have done something wrong there but as the CRC is not fine i'm not sure wether it is an hardware or a software issue.
      By the way and still concerning u-boot, I was wondering if all the multiplexing and power-on configuration made in board/davinci/daxxevm/da830evm.c were required seeing that AISGen is also doing it? I'm also pretty sure modules are being powered-on seeing that the current consumption increases of something like 80mA just after the AIS commands have been applied.
      Any suggestions?
      Thank you!
      Loic
      Report Abuse
      • Reply
    • Joe Coombs
      on May 19 2011 10:46 AM
      Verified Answer
      Verified by Loic Cheminade
      Expert8845 points
      Loic,
      Thanks for providing more details.  It looks like there may be something wrong with the EMIF configuration that's being applied during boot.  As an experiment, try the following procedure:
      1. Attempt to boot the device using either AIS image (with or without CRC)
      2. Connect to the device using an emulator (important: don't use any GEL file)
      3. Try to read and write directly to external memory using a CCS memory window or similar
      If external memory access is not functioning correctly, that would explain the problems that you're seeing.  Note that it's very important to disable the GEL file for this test.  If the GEL file applies its own EMIF configuration, the test won't tell us anything useful.
      The following information could help us diagnose the problem further:
      • Information about your custom board (including input clock and EMIF connections)
      • The settings you're applying in the AISgen tool (use File->Save Configuration To... and attach that file)
      Report Abuse
      • Reply
    • Loic Cheminade
      on May 24 2011 01:25 AM
      Prodigy30 points
      JTAG showed that one data pin was not properly soldered... Did check it a couple of time but slightly touching the pin was enough to allow contact. Works great now, thanks for your help and sorry for wasting your time on such a stupid mistake.
      For information I then had the baudrate issue described in other posts and cleraing the MDR register  worked. Moreover I didn't get any prompt from u-boot until the nand flash was properly configured (NANDFCR, AWCCR, CE2CFG).
      Loic
      Report Abuse
      • Reply
    • Mahesh Mokal
      Posted by Mahesh Mokal
      on Apr 27 2012 08:26 AM
      Prodigy20 points
      Hi Loic,
      i am designing board based on AM1705 can you share schematic and design notes i don't have any with me. please share experience what to do what to not do.
      Report Abuse
      • Reply
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
