• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Digital Signal Processors (DSP) » OMAP™ Processors » OMAP-L13x, AM1x and C674x Processors Forum » EPWM1 on OMAP-L138
Share
OMAP™ Processors
  • Forums
  • Announcements
Options
  • Subscribe via RSS
Resources
  • OMAP-L1x DSP+ARM9™-based Processors Product Folder
  • OMAP3525/30 DSP+ARM Cortex™-A8-based SOCs Product Folder
  • Top OMAPL Wiki Links
  • OMAPL3x Schematic Review Checklist
  • OMAPL13x Boot resources
  • OMAPL Document Resources
  • OMAPL137 Technical reference manual
  • OMAPL138 Technical reference manual
  • OMAPL Boot loader App Notes
  • EPWM1 on OMAP-L138
    EPWM1 on OMAP-L138
    This question is not answered
    Boris Ruvinsky
    Posted by Boris Ruvinsky
    on Apr 16 2012 13:26 PM
    Expert1260 points
    Thank you for your support and help.
     Right now I am trying to make ePWM1A working.
    Usually – PWM setup is relatively easy but his time – ePWM1A is not working as expected.
    This problem with ePWM1 is getting urgent for us.
    I use the following settings.
    1. TBCL register = 0xC0B8 (Free run, CLKDIV=0, HSPCLKDIV=1 (default),SWFSYNC=0, SYNCOSEL=3(disabled), PRDLD=1,PHSEN=0, CTRMODE=0(counter up)
    2. TPRD register= 0x4E1F= 20,000d –160MHz/2/20000=4KHz. I need 4KHz square wave
    3. CMPB register = 0x2710= 10,000d  for 50% duty cycle
    4. CMPCTL register = 0x0050 – SHDWBMODE=1, SHDWAMODE=1 – immediate mode for both and only CMPB register is used
    5. AQCTLA= 0x030C – CBU=3 (toggle), CAU=0 (don’t care NU),PRD=3 (toggle)
    ePWM1A output shows no activity. (The PINMUX5 set correctly - I checked it)
    TBCNT register (which is the counter itself) is always =’0’.
    When I am writing something to TBCNT – it stays unchanged.
    That means TBCNT is not incrementing.
    I don’t see any “enable bits for TBCNT.  The TBCLK is defined as SYSCLKOUT2/2 = 80MHz.
    TBCNT register is a counter itsef. Is it correct?
    TBCNT must increment with my registyers settings. Is it correct?
    Will I see the TBCNT running when EPWM is working correctly?
    Can you give me the idea why TBCNT is not running?
    Thank you,
    Boris
    Dear E2E:
    OMAP_L138
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • Mukul Bhatnagar
      Posted by Mukul Bhatnagar
      on Apr 16 2012 14:20 PM
      Mastermind24460 points
      Hi
      Can you check if the following post helps
      http://e2e.ti.com/support/dsp/omap_applications_processors/f/42/t/43896.aspx#153579 (this is for OMAPL137/C6747, but the initialization steps should be very similar for OMAPL138)
      The key thing to look for would be the SUSPRC register in SYSCFG , as well as TBCLKSYNC bit in CFGCHIP1 also in SYSCFG module.
      Mukul
      Don't forget to verify answers to your forum questions by using the green "Verify Answer" button.
      Report Abuse
      • Reply
    • Boris Ruvinsky
      on Apr 16 2012 17:13 PM
      Expert1260 points
      Hi Mukul.
      Thank you for your help.
      I set TBCLKSYNC bit in CFGCHIP1 and EPWM1A is running after that.
      I did not change the default in SUSPSRC register in OMAP-L138 SYSCFG module.
      I use GEL file to initialize EPWM1A.
      One thing looks strange: I need to run GEL twice for EPWM1A to start running.
      After the first GEL run - EPWM1A output has an output of ~VDD/2 (~1.6V in my case).
      I checked the registers - they all set OK after the first GEL run.
      Can you give me the idea - why this happened?
      Thank you,
      Boris
      OMAP_L138
      Report Abuse
      • Reply
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
