• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Digital Signal Processors (DSP) » OMAP™ Processors » OMAP-L13x, AM1x and C674x Processors Forum » UBL OMAP-L138 has a PLL bug?
Share
OMAP™ Processors
  • Forums
  • Announcements
Options
  • Subscribe via RSS
Resources
  • OMAP-L1x DSP+ARM9™-based Processors Product Folder
  • OMAP3525/30 DSP+ARM Cortex™-A8-based SOCs Product Folder
  • Top OMAPL Wiki Links
  • OMAPL3x Schematic Review Checklist
  • OMAPL13x Boot resources
  • OMAPL Document Resources
  • OMAPL137 Technical reference manual
  • OMAPL138 Technical reference manual
  • OMAPL Boot loader App Notes
  • UBL OMAP-L138 has a PLL bug?
    This question is answered
    Judson Wilson
    Posted by Judson Wilson
    on Apr 26 2012 21:30 PM
    Intellectual620 points
    If I am reading the code correctly, and using the PLL spreadsheet correctly, for the OMAP-L138 UBL User Boot Loader is setting PLL1 so that SYSCLK3 is 100MHz, which violates the 50MHz (and/or 75MHz) upper limit.
    version 2.40:
    OMAP-L138/Common/src/device.c: 236
    status |= DEVICE_PLL1Init(24, 1, 0, 1, 2);
    I am not sure if this will cause any actual problems but it looks suspicious.
    Also, if this is indeed a problem, it may be necessary to change the PLL in stages because the initial divider settings in PLL1 may conflict with whatever is first setup in PLL0 (since this div3=2 is the default value, which is set even before the aforementioned line is called).
    OMAP-L138 UBL Bug User Boot Loader
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • Mukul Bhatnagar
      Posted by Mukul Bhatnagar
      on Apr 27 2012 05:11 AM
      Verified Answer
      Verified by Judson Wilson
      Mastermind24460 points
      Hi Judson
      You are correct that PLL1_SYSCLK3 if being configured for 100 MHz instead of 50 MHz etc, is violating the max pllout spec for this SYSCLK. However this will not cause any problem in your system if PLL1_SYSCLK3 is not being used in your application.
      PLL1_SYSCLK3 is intended to support a unique use-case (which most customers are not using AFAIK). It is described in the system guide , Device clocking section 7.2
      For PLL0 only, the EXTCLKSRC bit in PLLCTL can be configured to use PLL1_SYSCLK3 as the Bypass mode reference clock
      By default this mode/option is not used.
      PLL0 and PLL1 are completely independent, so PLL1 configuration will not impact the previously configured PLL0 configuration.
      I will forward your email to UBL team to have this corrected in a subsequent release.
      Don't forget to verify answers to your forum questions by using the green "Verify Answer" button.
      Report Abuse
      • Reply
    • Judson Wilson
      on Apr 27 2012 12:12 PM
      Yeah, I figured it wasn't being used, I just was not sure what happens when you have a PLL clock that is out of spec. Maybe it could cause some error in hardware that would be otherwise unrelated if it was working within proper spec? No idea - hence the fear.
      Report Abuse
      • Reply
    • Judson Wilson
      on May 02 2012 14:03 PM
      Mukul Bhatnagar
      In dealing with the Arago PSP code, I found these lines in arch/arm/mach-davinci/da850.c:
          /* Use PLL1_SYSCLK3 for the PLL0 bypass clock */
          da850_set_pll0_bypass_src(true);
      However, I don't actually see it occuring (using some printk calls).
      Report Abuse
      • Reply
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
