• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Digital Signal Processors (DSP) » OMAP™ Processors » OMAP-L13x, AM1x and C674x Processors Forum » How to do SPI Flash programming on the OMAP-L138 using XDS100
Share
OMAP™ Processors
  • Forums
  • Announcements
Options
  • Subscribe via RSS
Resources
  • OMAP-L1x DSP+ARM9™-based Processors Product Folder
  • OMAP3525/30 DSP+ARM Cortex™-A8-based SOCs Product Folder
  • Top OMAPL Wiki Links
  • OMAPL3x Schematic Review Checklist
  • OMAPL13x Boot resources
  • OMAPL Document Resources
  • OMAPL137 Technical reference manual
  • OMAPL138 Technical reference manual
  • OMAPL Boot loader App Notes
  • How to do SPI Flash programming on the OMAP-L138 using XDS100
    This question is answered
    Samuel Raj1
    Posted by Samuel Raj1
    on Jul 29 2012 23:09 PM
    Prodigy130 points
    Hi
    Looking for some advise on the eXperimenter board using OMAP-L138. I am able to use the example codes that came with the CD with the XDS100 but running from the SDRAM. I am also able to do the U-Boot programming using the AIS download via SERIAL but now I am trying to figure out how can I use the CCS 5.2 and the XDS100 to program the SPI Flash with my e.g. LED blink.out binary. I am using only the DSP core at the moment.
    I wasnt too successful with searching for this kind of solution most of what I found as related to AIS. So hoping someone can advise me on how I can do flash programming with XDS100.
    Samuel
    OMAP-L138
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • Rahul Prabhu
      Posted by Rahul Prabhu
      on Jul 30 2012 11:20 AM
      Genius15535 points
      Samuel,
      Have you downloaded the serial flashing and boot utilities.
      http://processors.wiki.ti.com/index.php/Serial_Boot_and_Flash_Loading_Utility_for_OMAP-L138
      The package contains a SPI writer CCS project. Boot your device in Emultation boot mode, connect to the device using your XDS100 and then run the SPI writer CCS project to write your boot image to the SPI Flash. There is another option which I believe will suit your usecase even better. We provide a serial flashing utility called sfh in the serial flash and boot utilities which will program your SPI by reading your AIS boot image over UART. Please look for this utility under the OMAPL138/GNU folder .
      Hope this helps
      Rahul
      Please click the
      Verify Answer button on this post if it answers your question.
      Report Abuse
      • Reply
    • Samuel Raj1
      on Aug 03 2012 03:10 AM
      Prodigy130 points
      Rahul,
      Thanks for the link, I am looking only at using the CCS to write my application to the Flash. I have downloaded and ran the SPIWriter_DSP project file but I always hit a problem when it goes to fPtr = fopen("fileName", "rb"); it seems to freeze once I step over this point. (spiwriter.c).
      So I tried single stepping in assembly code and found that once the fopen loads the "c:\led.bin" right after the last letter goes into the memory....it jumps to location 0x00000000 of the memory. I am not sure why its doing this. Is it because I am using CCS 5.x? instead of 3.x? Which the project was created for? Please advise.
      Samuel
      Report Abuse
      • Reply
    • Rahul Prabhu
      on Aug 03 2012 14:52 PM
      Genius15535 points
      Samuel,
      The version of Code composer studio shouldn`t create an issue with the way DSP executes the SPI writer. Do you see any message in the console window that indicates that the process of loading the boot image over emulator and then programming the flash completed successfully? If you are using the EVM for testing you can try the prebuilt boot images that we have provided here to see if this works for you.
      http://processors.wiki.ti.com/index.php/Boot_Images_for_OMAP-L138
      Rahul
      Please click the
      Report Abuse
      • Reply
    • Samuel Raj1
      on Aug 07 2012 02:26 AM
      Prodigy130 points
      Hi Rahul, Thanks for the support was able to get the SPI flash programed with another method. Now I have another question, I got the output file as led.out using the DSP as the compile environment instead of ARM. I cant seem to be able to get the application running on when I power up the board. The memory location on the linker.cmd is at the SHRAM location @ Shared RAM location where its used in .text when I compiled the program. Could that be the reason or does it need to go thru the AIS to get a BINARY out than loaded?
      Report Abuse
      • Reply
    • Rahul Prabhu
      on Aug 07 2012 09:25 AM
      Genius15535 points
      Samuel,
      OMAPL138 is a ARM boot device, so on this device ARM needs to wake up the DSP so that the DSP can run its executable. Since you have built the led.out for the DSP environment, you need to use a simple ARM secondary boot loader(UBL) that wakes up the DSP and tells the DSP the entry point to the executable. The ARM UBL is provided in the the Boot examples that are provided on the wiki that I pointed to. You need to find out the entry point for the executable you have generated and provide that in the UBL or you can use the same UBL that we have provided by forcing the entry point of executable to 0x80001000 by using this statement in the linker.cmd file of your DSP application.
      -stack          0x00000800 /* Stack Size */
      -heap           0x02500000 /* Heap Size */
      MEMORY
        L2RAM          org=0x11800000 len=0x00040000 /* DSP L2 RAM */
        DRAM        org=0xC0000000 len=0x04000000 /* SDRAM */
        entry_point:     ORIGIN = 0x80010000  LENGTH = 0x00000080
        SHARED_RAM  org=0x80010080 len=0x00007F80 /* DDR for program */
        AEMIF       org=0x60000000 len=0x02000000 /* AEMIF CS2 region */
        AEMIF_CS3   org=0x62000000 len=0x02000000 /* AEMIF CS3 region */
      SECTIONS
        .text:_c_int00 > entry_point
        .text  > SHARED_RAM
        .const > SHARED_RAM
        .bss   > SHARED_RAM
        .far   > SHARED_RAM
        .stack > SHARED_RAM
        .data  > SHARED_RAM
        .cinit > SHARED_RAM
        .sysmem  > DRAM
        .cio  > SHARED_RAM
      Refer to to the description for booting DSP binaries mentioned below:
      http://processors.wiki.ti.com/index.php/Boot_Images_for_OMAP-L138#Booting_DSP_Binaries
      Let me know if you have any follow up questions
      Rahul
      PS: Verify that your executable runs by loading it through CCS. When booting from Flash take care that you do all device PLL, Pin Mux setting (EIther through AIS setting or in code)before you call into required functionality as booting from Flash is different from the GEL file based environment and if you have any issues you can use this GEL file to determine what went wrong during the boot process:
      http://processors.wiki.ti.com/index.php/OMAP-L1x_Debug_Gel_Files
      Please click the
      Report Abuse
      • Reply
    • Samuel Raj1
      on Aug 08 2012 07:03 AM
      Prodigy130 points
      Rahul,
      This very good advice, I managed to get the ARM LED working with the flash programming, now about the UBL, I am not sure where to get one that will work with the above mentioned linker.cmd settings.I tried using the one from the Flash and boot util 2.40 -> ubl_OMAPL138_SPI_MEM.out + led.out and generate the AIS, but it didnt seem to work. If the UBL file is correct is there something I am missing here?
      Samuel
      Report Abuse
      • Reply
    • Rahul Prabhu
      on Aug 08 2012 12:49 PM
      Genius15535 points
      Samuel,
      If you downloaded the code from the Boot Images for OMAPL138 wiki article under the OMAPL138_DSP_LED folder, you have a ARM folder that contains the sample ARM UBL that is used with the DSP LED blink example. Essentially it contains a boot.asm file that puts the ARM in priveledge mode and a main.c file that puts the entry point of the DSP executable in the HOSTCFG  register and wakes up the DSP.. While using the ARM UBL ensure that the sections in the ARM executable and the DSP executable are not overlapping and generate a map file for the DSP executable and ensure that the linker has the cint00 symbol at the address that you provide to the HOSTCFG register.
      Let us know if you have any issues.
      Rahul
      Please click the
      Report Abuse
      • Reply
    • Samuel Raj1
      on Aug 09 2012 07:54 AM
      Prodigy130 points
      Rahul,
      Thanks for all the help its working as per what you mentioned. However I hit a small problem. It seems that on the linker file if were to use the external memory. It doesnt seem to be going into that address (DDR) I am using the 0xC0000000 as the external address location. Is there something I need to do cause the problem is that my program can no longer fit in the SHRAM 0x8001000 location any more.
      Samuel
      Report Abuse
      • Reply
    • Rahul Prabhu
      on Aug 09 2012 13:16 PM
      Verified Answer
      Verified by Samuel Raj1
      Genius15535 points
      Samuel,
      When you say your boot doesn`t seem to be going into that address, do you mean your code doesn`t load in that section of the memory or are you suggesting that the ARM UBL is not forcing the entry point to the executable in DDR memory?
      Is the DDR address double word aligned. Have you set it in the Host1CFG register through your ARM UBL? Are your PLL setting similar to the GEL file setting for enabling DDR access?
      Rahul
      Please click the
      Report Abuse
      • Reply
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
