• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Digital Signal Processors (DSP) » OMAP™ Processors » OMAP-L13x, AM1x and C674x Processors Forum » C6745 GEL hangs on PSC1 transitions
Share
OMAP™ Processors
  • Forums
  • Announcements
Options
  • Subscribe via RSS
Resources
  • OMAP-L1x DSP+ARM9™-based Processors Product Folder
  • OMAP3525/30 DSP+ARM Cortex™-A8-based SOCs Product Folder
  • Top OMAPL Wiki Links
  • OMAPL3x Schematic Review Checklist
  • OMAPL13x Boot resources
  • OMAPL Document Resources
  • OMAPL137 Technical reference manual
  • OMAPL138 Technical reference manual
  • OMAPL Boot loader App Notes
  • C6745 GEL hangs on PSC1 transitions
    This question is answered
    Ben Vaughn
    Posted by Ben Vaughn
    on Aug 09 2012 18:33 PM
    Prodigy40 points
    In my GEL file (below ) I attempt to enable all peripherals in PSC0 and PSC1. PSC0 seems to work flawlessly. When it calls any of the PSC1_lPSC_enable() functions it hangs when verifying the state on the line:
    while( (*(unsigned int*)(PSC1_MDSTAT+4 * LPSC_num) & 0x1F) !=0x3);
    I have developed a custom board with a TMS320C6745 DSP and I'm using an XDS100v2 emulator. I can see/edit CPU registers and some memory via the memory manager but anything in SDRAM is zero and unwritable. The SDRAM configuration registers are also unwritable.
    My primary goal is to get the SDRAM working but seeing that I can't get the controller powered on I'm somewhat stuck. This is my first time dealing with this scale of processor.
    Any help/suggestions are welcome. Thanks
    GEL FILE (I have made some modifications):
    * evmomapl137_dsp.gel *
    * Version 1.05 *
    * This GEL file is designed to be used in conjunction with *
    * CCStudio 3.3+ and the omap-l137 based EVM. *
    * Version History: *
    * 1.00 Initial Release *
    * 1.01 Added USB1 clock enable in CFGCGHIP2 *
    * 1.02 Added Setup_Data_Cache(), added hotmenu item Setup_EMIFA_PinMux() *
    * 1.03 Corrected PINMUX0, 11 settings to enable EMB_CLK, AXR2[0] *
    * 1.04 General cleanup *
    * 1.05 Corrected ARM INTC in Memory map *
    * StartUp( ) *
    * Setup Memory Map *
    StartUp( )
    Setup_Memory_Map( );
    * OnTargetConnect( ) *
    * Setup PinMux, Power, PLLs, SDRAM & EMIFs *
    OnTargetConnect( )
    /*GEL_Trace( level );*/
    GEL_TextOut( "\nomap-l137 DSP Startup Sequence\n\n" );
    Setup_Data_Cache(); // Setup L1D to 32 KB cache
    Setup_System_Config( ); // Setup Pin Mux and other system module registers
    Setup_PLL(); // Setup PLL0 (300MHz DSP, 133MHz EMIFs)
    Setup_Psc_All_On( ); // Setup All Power Domains
    //Setup_EMIFA(); // Async EMIF
    Setup_EMIFB(); // Setup SDRAM
    GEL_TextOut( "\nStartup Complete.\n\n" );
    * OnPreFileLoaded( ) *
    * This function is called automatically when the 'Load Program' *
    * Menu item is selected. *
    OnPreFileLoaded( )
    * GEL_Reset() is used to deal with the worst case senario of
    * unknown target state. If for some reason a reset is not desired
    * upon target connection, GEL_Reset() may be removed and replaced
    * with something "less brutal" like a cache initialization
    * function.
    GEL_Reset( );
    // Disable_EDMA( ); // Disable EDMA
    GEL_TextOut( "\n" );
    * OnRestart( ) *
    * This function is called by CCS when you do Debug->Restart. *
    * The goal is to put the CPU into a known good state with respect to *
    * edma. *
    * Failure to do this can cause problems when you restart and *
    * run your application code multiple times. This is different *
    * then OnPreFileLoaded() which will do a GEL_Reset() to get the *
    * ARM9 into a known good state. *
    OnRestart( int nErrorCode )
    * Setup_Psc_All_On( ) *
    * Enable all PSC modules on ALWAYSON and DSP power dominas. *
    hotmenu
    Setup_Psc_All_On( )
    int i;
    GEL_TextOut( "Setup Power Modules (All on)...\n" );
    // PSC0
    PSC0_lPSC_enable(0, 0);
    PSC0_lPSC_enable(0, 1);
    PSC0_lPSC_enable(0, 2);
    PSC0_lPSC_enable(0, 3); // EMIFA
    PSC0_lPSC_enable(0, 4);
    PSC0_lPSC_enable(0, 5);
    PSC0_lPSC_enable(0, 6);
    PSC0_lPSC_enable(0, 8);
    PSC0_lPSC_enable(0, 9);
    PSC0_lPSC_enable(0, 10);
    PSC0_lPSC_enable(0, 11);
    PSC0_lPSC_enable(0, 12);
    PSC0_lPSC_enable(0, 13);
    // PSC1
    GEL_TextOut( "PSC1:\n" );
    PSC1_lPSC_enable(0, 1); //USB0 HANGS HERE, OR ON ANY BELOW
    //PSC1_lPSC_enable(0, 2); //USB1 (not present on 6745)
    PSC1_lPSC_enable(0, 3);
    //PSC1_lPSC_enable(0, 4); //HPI (not present on 6745)
    PSC1_lPSC_enable(0, 5);
    PSC1_lPSC_enable(0, 6); // EMIFB
    PSC1_lPSC_enable(0, 7);
    PSC1_lPSC_enable(0, 8);
    //PSC1_lPSC_enable(0, 9); //McASP2 (not present on 6745)
    PSC1_lPSC_enable(0, 10);
    PSC1_lPSC_enable(0, 11);
    PSC1_lPSC_enable(0, 12);
    PSC1_lPSC_enable(0, 13);
    //PSC1_lPSC_enable(0, 16); //LCDC (not present on 6745)
    PSC1_lPSC_enable(0, 17);
    PSC1_lPSC_enable(0, 20);
    PSC1_lPSC_enable(0, 21);
    PSC1_lPSC_enable(0, 24);
    PSC1_lPSC_enable(0, 25);
    PSC1_lPSC_enable(0, 26);
    //PSC1_lPSC_enable(0, 31); //Shared Ram (BR13) (not present on 6745)
    GEL_TextOut( "[Done]\n" );
    /*PSC Module Related Registers*/
    #define PSC0_BASE 0x01C10000
    #define PSC1_BASE 0x01E27000
    #define PSC0_MDCTL (PSC0_BASE+0xA00)
    #define PSC0_MDSTAT (PSC0_BASE+0x800)
    #define PSC0_PTCMD *(unsigned int*) (PSC0_BASE + 0x120)
    #define PSC0_PTSTAT *(unsigned int*) (PSC0_BASE + 0x128)
    #define PSC1_MDCTL (PSC1_BASE+0xA00)
    #define PSC1_MDSTAT (PSC1_BASE+0x800)
    #define PSC1_PTCMD *(unsigned int*) (PSC1_BASE + 0x120)
    #define PSC1_PTSTAT *(unsigned int*) (PSC1_BASE + 0x128)
    /*Enable Function for PSC0*/
    PSC0_lPSC_enable(unsigned int PD, unsigned int LPSC_num) {
    *(unsigned int*) (PSC0_MDCTL+4*LPSC_num) = (*(unsigned int*) (PSC0_MDCTL+4*LPSC_num) & 0xFFFFFFE0) | 0x0003;
    PSC0_PTCMD = 0x1<<PD;
    while( (PSC0_PTSTAT & (0x1<<PD) ) !=0) ; /*Wait for power state transition to finish*/
    while( (*(unsigned int*)(PSC0_MDSTAT+4 * LPSC_num) & 0x1F) !=0x3);
    /*Enable Function for PSC1*/
    PSC1_lPSC_enable(unsigned int PD, unsigned int LPSC_num) {
    //1. GOSTAT[x] bit in PSTAT should be clear
    //2. Set the NEXT bit in MDCTLn to 0x3 (Enable)
    *(unsigned int*) (PSC1_MDCTL+4*LPSC_num) = (*(unsigned int*) (PSC1_MDCTL+4*LPSC_num) & 0xFFFFFFE0) | 0x0003;
    //3.Set the GO[x] bit in PTCMD to 1 to initiate the transition.
    PSC1_PTCMD = 0x1<<PD;
    GEL_TextOut("Wait for power state transition to finish1\n");
    //4. Wait for the GOSTAT[x] bit in PTSTAT to clear to 0.
    while( (PSC1_PTSTAT & (0x1<<PD) ) !=0) ; /*Wait for power state transition to finish*/
    //Check that the module is in the enable state
    GEL_TextOut("Verifying that state is enabled\n");
    while( (*(unsigned int*)(PSC1_MDSTAT+4 * LPSC_num) & 0x1F) !=0x3); This function never completes
    GEL_TextOut("Complete\n");
    menuitem "omap-l137 Memory Map";
    * Setup_Memory_Map( ) *
    * Setup the Memory Map for DSP. *
    hotmenu
    Setup_Memory_Map( )
    GEL_MapOn( );
    GEL_MapReset( );
    /* ARM */
    GEL_MapAddStr( 0xFFFD0000, 0, 0x00010000, "R|W|AS4", 0 ); // ARM Local ROM
    GEL_MapAddStr( 0xFFFEE000, 0, 0x00002000, "R|W|AS4", 0 ); // ARM INTC
    GEL_MapAddStr( 0xFFFF0000, 0, 0x00002000, "R|W|AS4", 0 ); // ARM Local RAM
    GEL_MapAddStr( 0x01BC0000, 0, 0x00001000, "R|W|AS4", 0 ); // ARM ETB Memory
    GEL_MapAddStr( 0x01BC1000, 0, 0x00000800, "R|W|AS4", 0 ); // ARM ETB Regs
    GEL_MapAddStr( 0x01BC1800, 0, 0x00000100, "R|W|AS4", 0 ); // ARM Ice Crusher
    /* DSP */
    GEL_MapAddStr( 0x00700000, 0, 0x00100000, "R|W|AS4", 0 ); // DSP L2 ROM
    GEL_MapAddStr( 0x00800000, 0, 0x00040000, "R|W|AS4", 0 ); // DSP l2 RAM
    GEL_MapAddStr( 0x00E00000, 0, 0x00008000, "R|W|AS4", 0 ); // DSP L1P RAM
    GEL_MapAddStr( 0x00F00000, 0, 0x00008000, "R|W|AS4", 0 ); // DSP L1D RAM
    GEL_MapAddStr( 0x01800000, 0, 0x00010000, "R|W|AS4", 0 ); // DSP Interrupt Controller
    GEL_MapAddStr( 0x01810000, 0, 0x00001000, "R|W|AS4", 0 ); // DSP Powerdown Controller
    GEL_MapAddStr( 0x01811000, 0, 0x00001000, "R|W|AS4", 0 ); // DSP Security ID
    GEL_MapAddStr( 0x01812000, 0, 0x00008000, "R|W|AS4", 0 ); // DSP Revision ID
    GEL_MapAddStr( 0x01820000, 0, 0x00010000, "R|W|AS4", 0 ); // DSP EMC
    GEL_MapAddStr( 0x01830000, 0, 0x00010000, "R|W|AS4", 0 ); // DSP Internal Reserved
    GEL_MapAddStr( 0x01840000, 0, 0x00010000, "R|W|AS4", 0 ); // DSP Memory System
    GEL_MapAddStr( 0x11700000, 0, 0x00100000, "R|W|AS4", 0 ); // DSP L2 ROM (mirror)
    GEL_MapAddStr( 0x11800000, 0, 0x00040000, "R|W|AS4", 0 ); // DSP l2 RAM (mirror)
    GEL_MapAddStr( 0x11E00000, 0, 0x00008000, "R|W|AS4", 0 ); // DSP L1P RAM (mirror)
    GEL_MapAddStr( 0x11F00000, 0, 0x00008000, "R|W|AS4", 0 ); // DSP L1D RAM (mirror)
    /* Shared RAM */
    //GEL_MapAddStr( 0x80000000, 0, 0x00020000, "R|W|AS4", 0 ); // Shared RAM
    /* EMIFA */
    GEL_MapAddStr( 0x68000000, 0, 0x00008000, "R|W|AS4", 0 ); // EMIFA Control
    GEL_MapAddStr( 0x40000000, 0, 0x20000000, "R|W|AS4", 0 ); // EMIFA SDRAM Data
    GEL_MapAddStr( 0x60000000, 0, 0x02000000, "R|W|AS4", 0 ); // AEMIF CS2
    GEL_MapAddStr( 0x62000000, 0, 0x02000000, "R|W|AS4", 0 ); // AEMIF CS3
    GEL_MapAddStr( 0x64000000, 0, 0x02000000, "R|W|AS4", 0 ); // AEMIF CS4
    GEL_MapAddStr( 0x66000000, 0, 0x02000000, "R|W|AS4", 0 ); // AEMIF CS5
    /* DDR */
    GEL_MapAddStr( 0xB0000000, 0, 0x00008000, "R|W|AS4", 0 ); // EMIFB Control
    GEL_MapAddStr( 0xC0000000, 0, 0x20000000, "R|W|AS4", 0 ); // EMIFB SDRAM Data
    /* Peripherals */
    GEL_MapAddStr( 0x01C00000, 0, 0x00008000, "R|W|AS4", 0 ); // TPCC
    GEL_MapAddStr( 0x01C08000, 0, 0x00000400, "R|W|AS4", 0 ); // TPTC0
    GEL_MapAddStr( 0x01C08400, 0, 0x00000400, "R|W|AS4", 0 ); // TPTC1
    GEL_MapAddStr( 0x01C10000, 0, 0x00001000, "R|W|AS4", 0 ); // PSC 0
    GEL_MapAddStr( 0x01C11000, 0, 0x00001000, "R|W|AS4", 0 ); // PLL Controller 0
    GEL_MapAddStr( 0x01C12000, 0, 0x00001000, "R|W|AS4", 0 ); // Key Manager
    GEL_MapAddStr( 0x01C13000, 0, 0x00001000, "R|W|AS4", 0 ); // Security Controller
    GEL_MapAddStr( 0x01C14000, 0, 0x00001000, "R|W|AS4", 0 ); // BootConfig
    GEL_MapAddStr( 0x01C16000, 0, 0x00001000, "R|W|AS4", 0 ); // IOPU 0
    GEL_MapAddStr( 0x01C17000, 0, 0x00001000, "R|W|AS4", 0 ); // IOPU 2
    GEL_MapAddStr( 0x01C20000, 0, 0x00001000, "R|W|AS4", 0 ); // Timer64P 0
    GEL_MapAddStr( 0x01C21000, 0, 0x00001000, "R|W|AS4", 0 ); // Timer64P 1
    GEL_MapAddStr( 0x01C22000, 0, 0x00001000, "R|W|AS4", 0 ); // I2C 0
    GEL_MapAddStr( 0x01C23000, 0, 0x00001000, "R|W|AS4", 0 ); // RTC
    GEL_MapAddStr( 0x01C24000, 0, 0x00001000, "R|W|AS4", 0 ); // IOPU 1
    GEL_MapAddStr( 0x01C30000, 0, 0x00000200, "R|W|AS4", 0 ); // dMax Data RAM 0
    GEL_MapAddStr( 0x01C32000, 0, 0x00000200, "R|W|AS4", 0 ); // dMax Data RAM 1
    GEL_MapAddStr( 0x01C34000, 0, 0x00004000, "R|W|AS4", 0 ); // dMax Control Registers
    GEL_MapAddStr( 0x01C38000, 0, 0x00001000, "R|W|AS4", 0 ); // dMAX MAX0 Config Memory
    GEL_MapAddStr( 0x01C3C000, 0, 0x00001000, "R|W|AS4", 0 ); // dMAX MAX1 Config Memory
    GEL_MapAddStr( 0x01C40000, 0, 0x00001000, "R|W|AS4", 0 ); // MMC/SD 0
    GEL_MapAddStr( 0x01C41000, 0, 0x00001000, "R|W|AS4", 0 ); // SPI 0
    GEL_MapAddStr( 0x01C42000, 0, 0x00001000, "R|W|AS4", 0 ); // UART 0
    GEL_MapAddStr( 0x01C43000, 0, 0x00001000, "R|W|AS4", 0 ); // MPU 0
    GEL_MapAddStr( 0x01D00000, 0, 0x00001000, "R|W|AS4", 0 ); // McASP 0 Control
    GEL_MapAddStr( 0x01D01000, 0, 0x00001000, "R|W|AS4", 0 ); // McASP 0 FIFO Ctrl
    GEL_MapAddStr( 0x01D02000, 0, 0x00001000, "R|W|AS4", 0 ); // McASP 0 Data
    GEL_MapAddStr( 0x01D04000, 0, 0x00001000, "R|W|AS4", 0 ); // McASP 1 Control
    GEL_MapAddStr( 0x01D05000, 0, 0x00001000, "R|W|AS4", 0 ); // McASP 1 FIFO Ctrl
    GEL_MapAddStr( 0x01D06000, 0, 0x00001000, "R|W|AS4", 0 ); // McASP 1 Data
    GEL_MapAddStr( 0x01D08000, 0, 0x00001000, "R|W|AS4", 0 ); // McASP 2 Control
    GEL_MapAddStr( 0x01D09000, 0, 0x00001000, "R|W|AS4", 0 ); // McASP 2 FIFO Ctrl
    GEL_MapAddStr( 0x01D0A000, 0, 0x00001000, "R|W|AS4", 0 ); // McASP 2 Data
    GEL_MapAddStr( 0x01D0C000, 0, 0x00001000, "R|W|AS4", 0 ); // UART 1
    GEL_MapAddStr( 0x01D0D000, 0, 0x00001000, "R|W|AS4", 0 ); // UART 2
    GEL_MapAddStr( 0x01D0E000, 0, 0x00001000, "R|W|AS4", 0 ); // IOPU 4
    GEL_MapAddStr( 0x01E00000, 0, 0x00010000, "R|W|AS4", 0 ); // USB0 (USB HS) Cfg
    GEL_MapAddStr( 0x01E10000, 0, 0x00001000, "R|W|AS4", 0 ); // UHPI Cfg
    GEL_MapAddStr( 0x01E11000, 0, 0x00001000, "R|W|AS4", 0 ); // UHPI (IODFT)
    GEL_MapAddStr( 0x01E12000, 0, 0x00001000, "R|W|AS4", 0 ); // SPI 1
    GEL_MapAddStr( 0x01E13000, 0, 0x00001000, "R|W|AS4", 0 ); // LCD Controller
    GEL_MapAddStr( 0x01E14000, 0, 0x00001000, "R|W|AS4", 0 ); // MPU 1
    GEL_MapAddStr( 0x01E15000, 0, 0x00001000, "R|W|AS4", 0 ); // MPU 2
    GEL_MapAddStr( 0x01E20000, 0, 0x00002000, "R|W|AS4", 0 ); // EMAC CPPI port
    GEL_MapAddStr( 0x01E22000, 0, 0x00001000, "R|W|AS4", 0 ); // EMAC CPGMACSS registers
    GEL_MapAddStr( 0x01E23000, 0, 0x00001000, "R|W|AS4", 0 ); // EMAC CPGMAC registers
    GEL_MapAddStr( 0x01E24000, 0, 0x00001000, "R|W|AS4", 0 ); // EMAC MDIO port
    GEL_MapAddStr( 0x01E25000, 0, 0x00001000, "R|W|AS4", 0 ); // USB1 (USB FS)
    GEL_MapAddStr( 0x01E26000, 0, 0x00001000, "R|W|AS4", 0 ); // GPIO
    GEL_MapAddStr( 0x01E27000, 0, 0x00001000, "R|W|AS4", 0 ); // PSC 1
    GEL_MapAddStr( 0x01E28000, 0, 0x00001000, "R|W|AS4", 0 ); // I2C 1
    GEL_MapAddStr( 0x01E29000, 0, 0x00001000, "R|W|AS4", 0 ); // IOPU 3
    GEL_MapAddStr( 0x01E2A000, 0, 0x00001000, "R|W|AS4", 0 ); // PBIST Controller
    GEL_MapAddStr( 0x01E2B000, 0, 0x00001000, "R|W|AS4", 0 ); // PBIST Combiner
    GEL_MapAddStr( 0x01F00000, 0, 0x00001000, "R|W|AS4", 0 ); // EPWM 0
    GEL_MapAddStr( 0x01F01000, 0, 0x00001000, "R|W|AS4", 0 ); // HRPWM 0
    GEL_MapAddStr( 0x01F02000, 0, 0x00001000, "R|W|AS4", 0 ); // EPWM 1
    GEL_MapAddStr( 0x01F03000, 0, 0x00001000, "R|W|AS4", 0 ); // HRPWM 1
    GEL_MapAddStr( 0x01F04000, 0, 0x00001000, "R|W|AS4", 0 ); // EPWM 2
    GEL_MapAddStr( 0x01F05000, 0, 0x00001000, "R|W|AS4", 0 ); // HRPWM 2
    GEL_MapAddStr( 0x01F06000, 0, 0x00001000, "R|W|AS4", 0 ); // ECAP 0
    GEL_MapAddStr( 0x01F07000, 0, 0x00001000, "R|W|AS4", 0 ); // ECAP 1
    GEL_MapAddStr( 0x01F08000, 0, 0x00001000, "R|W|AS4", 0 ); // ECAP 2
    GEL_MapAddStr( 0x01F09000, 0, 0x00001000, "R|W|AS4", 0 ); // EQEP 0
    GEL_MapAddStr( 0x01F0A000, 0, 0x00001000, "R|W|AS4", 0 ); // EQEP 1
    GEL_MapAddStr( 0x01F0B000, 0, 0x00001000, "R|W|AS4", 0 ); // IOPU 5
    * Clear_Memory_Map( ) *
    * Clear the Memory Map *
    hotmenu
    Clear_Memory_Map( )
    GEL_MapOff( );
    GEL_MapReset( );
    menuitem "EVMOMAPL137 Functions";
    _wait( int delay )
    int i;
    for( i = 0 ; i < delay ; i++ ){}
    #define SYS_BASE 0x01C14000
    #define REVID *(unsigned int*)(SYS_BASE + 0x000)
    #define DIEIDR0 *(unsigned int*)(SYS_BASE + 0x008)
    #define DIEIDR1 *(unsigned int*)(SYS_BASE + 0x00C)
    #define DIEIDR2 *(unsigned int*)(SYS_BASE + 0x010)
    #define DIEIDR3 *(unsigned int*)(SYS_BASE + 0x014)
    #define DEVIDR0 *(unsigned int*)(SYS_BASE + 0x018)
    #define DEVIDR1 *(unsigned int*)(SYS_BASE + 0x01C)
    #define BOOTCFG *(unsigned int*)(SYS_BASE + 0x020)
    #define CHIPREVIDR *(unsigned int*)(SYS_BASE + 0x024)
    #define KICK0R *(unsigned int*)(SYS_BASE + 0x038)
    #define KICK1R *(unsigned int*)(SYS_BASE + 0x03c)
    #define HOST0CFG *(unsigned int*)(SYS_BASE + 0x040) //ARM HOST0CFG
    #define HOST1CFG *(unsigned int*)(SYS_BASE + 0x044)
    #define IRAWSTAT *(unsigned int*)(SYS_BASE + 0x0E0)
    #define IENSTAT *(unsigned int*)(SYS_BASE + 0x0E4)
    #define IENSET *(unsigned int*)(SYS_BASE + 0x0E8)
    #define IENCLR *(unsigned int*)(SYS_BASE + 0x0EC)
    #define EOI *(unsigned int*)(SYS_BASE + 0x0F0)
    #define FLTADDRR *(unsigned int*)(SYS_BASE + 0x0F4)
    #define FLTSTAT *(unsigned int*)(SYS_BASE + 0x0F8)
    #define MSTPRI0 *(unsigned int*)(SYS_BASE + 0x110)
    #define MSTPRI1 *(unsigned int*)(SYS_BASE + 0x114)
    #define MSTPRI2 *(unsigned int*)(SYS_BASE + 0x118)
    #define PINMUX0 *(unsigned int*)(SYS_BASE + 0x120) //PINMUX0
    #define PINMUX1 *(unsigned int*)(SYS_BASE + 0x124) //PINMUX1
    #define PINMUX2 *(unsigned int*)(SYS_BASE + 0x128) //PINMUX2
    #define PINMUX3 *(unsigned int*)(SYS_BASE + 0x12C) //PINMUX3
    #define PINMUX4 *(unsigned int*)(SYS_BASE + 0x130) //PINMUX4
    #define PINMUX5 *(unsigned int*)(SYS_BASE + 0x134) //PINMUX5
    #define PINMUX6 *(unsigned int*)(SYS_BASE + 0x138) //PINMUX6
    #define PINMUX7 *(unsigned int*)(SYS_BASE + 0x13C) //PINMUX7
    #define PINMUX8 *(unsigned int*)(SYS_BASE + 0x140) //PINMUX8
    #define PINMUX9 *(unsigned int*)(SYS_BASE + 0x144) //PINMUX9
    #define PINMUX10 *(unsigned int*)(SYS_BASE + 0x148) //PINMUX10
    #define PINMUX11 *(unsigned int*)(SYS_BASE + 0x14C) //PINMUX11
    #define PINMUX12 *(unsigned int*)(SYS_BASE + 0x150) //PINMUX12
    #define PINMUX13 *(unsigned int*)(SYS_BASE + 0x154) //PINMUX13
    #define PINMUX14 *(unsigned int*)(SYS_BASE + 0x158) //PINMUX14
    #define PINMUX15 *(unsigned int*)(SYS_BASE + 0x15C) //PINMUX15
    #define PINMUX16 *(unsigned int*)(SYS_BASE + 0x160) //PINMUX16
    #define PINMUX17 *(unsigned int*)(SYS_BASE + 0x164) //PINMUX17
    #define PINMUX18 *(unsigned int*)(SYS_BASE + 0x168) //PINMUX18
    #define PINMUX19 *(unsigned int*)(SYS_BASE + 0x16C) //PINMUX19
    #define SUSPSRC *(unsigned int*)(SYS_BASE + 0x170)
    #define CHIPSIG *(unsigned int*)(SYS_BASE + 0x174)
    #define CHIPSIG_CLR *(unsigned int*)(SYS_BASE + 0x178)
    #define CFGCHIP0 *(unsigned int*)(SYS_BASE + 0x17C)
    #define CFGCHIP1 *(unsigned int*)(SYS_BASE + 0x180)
    #define CFGCHIP2 *(unsigned int*)(SYS_BASE + 0x184)
    #define CFGCHIP3 *(unsigned int*)(SYS_BASE + 0x188)
    #define CFGCHIP4 *(unsigned int*)(SYS_BASE + 0x18C)
    #define PLL0_BASE 0x01C11000 /*SYSTEM PLL BASE ADDRESS*/
    #define PLL0_PID *(unsigned int*) (PLL0_BASE + 0x00) /*PID*/
    #define PLL0_FUSERR *(unsigned int*) (PLL0_BASE + 0xE0) /*x*FuseFarm Error Reg*/
    #define PLL0_RSTYPE *(unsigned int*) (PLL0_BASE + 0xE4) /*Reset Type status Reg*/
    #define PLL0_PLLCTL *(unsigned int*) (PLL0_BASE + 0x100) /*PLL Control Register*/
    #define PLL0_OCSEL *(unsigned int*) (PLL0_BASE + 0x104) /*OBSCLK Select Register*/
    #define PLL0_SECCTL *(unsigned int*) (PLL0_BASE + 0x108) /*PLL Secondary Control Register*/
    #define PLL0_PLLM *(unsigned int*) (PLL0_BASE + 0x110) /*PLL Multiplier*/
    #define PLL0_PREDIV *(unsigned int*) (PLL0_BASE + 0x114) /*Pre divider*/
    #define PLL0_PLLDIV1 *(unsigned int*) (PLL0_BASE + 0x118) /*Diveder-1*/
    #define PLL0_PLLDIV2 *(unsigned int*) (PLL0_BASE + 0x11C) /*Diveder-2*/
    #define PLL0_PLLDIV3 *(unsigned int*) (PLL0_BASE + 0x120) /*Diveder-3*/
    #define PLL0_OSCDIV1 *(unsigned int*) (PLL0_BASE + 0x124) /*Oscilator Divider*/
    #define PLL0_POSTDIV *(unsigned int*) (PLL0_BASE + 0x128) /*Post Divider*/
    #define PLL0_BPDIV *(unsigned int*) (PLL0_BASE + 0x12C) /*Bypass Divider*/
    #define PLL0_WAKEUP *(unsigned int*) (PLL0_BASE + 0x130) /*Wakeup Reg*/
    #define PLL0_PLLCMD *(unsigned int*) (PLL0_BASE + 0x138) /*Command Reg*/
    #define PLL0_PLLSTAT *(unsigned int*) (PLL0_BASE + 0x13C) /*Status Reg*/
    #define PLL0_ALNCTL *(unsigned int*) (PLL0_BASE + 0x140) /*Clock Align Control Reg*/
    #define PLL0_DCHANGE *(unsigned int*) (PLL0_BASE + 0x144) /*PLLDIV Ratio Chnage status*/
    #define PLL0_CKEN *(unsigned int*) (PLL0_BASE + 0x148) /*Clock Enable Reg*/
    #define PLL0_CKSTAT *(unsigned int*) (PLL0_BASE + 0x14C) /*Clock Status Reg*/
    #define PLL0_SYSTAT *(unsigned int*) (PLL0_BASE + 0x150) /*Sysclk status reg*/
    #define PLL0_PLLDIV4 *(unsigned int*) (PLL0_BASE + 0x160) /*Divider 4*/
    #define PLL0_PLLDIV5 *(unsigned int*) (PLL0_BASE + 0x164) /*Divider 5*/
    #define PLL0_PLLDIV6 *(unsigned int*) (PLL0_BASE + 0x168) /*Divider 6*/
    #define PLL0_PLLDIV7 *(unsigned int*) (PLL0_BASE + 0x16C) /*Divider 7*/
    #define PLL0_PLLDIV8 *(unsigned int*) (PLL0_BASE + 0x170) /*Divider 8*/
    #define PLL0_PLLDIV9 *(unsigned int*) (PLL0_BASE + 0x174) /*Divider 9*/
    #define PLL0_PLLDIV10 *(unsigned int*) (PLL0_BASE + 0x178) /*Divider 10*/
    #define PLL0_PLLDIV11 *(unsigned int*) (PLL0_BASE + 0x17C) /*Divider 11*/
    #define PLL0_PLLDIV12 *(unsigned int*) (PLL0_BASE + 0x180) /*Divider 12*/
    #define PLL0_PLLDIV13 *(unsigned int*) (PLL0_BASE + 0x184) /*Divider 13*/
    #define PLL0_PLLDIV14 *(unsigned int*) (PLL0_BASE + 0x188) /*Divider 14*/
    #define PLL0_PLLDIV15 *(unsigned int*) (PLL0_BASE + 0x18C) /*Divider 15*/
    #define PLL0_PLLDIV16 *(unsigned int*) (PLL0_BASE + 0x190) /*Divider 16*/
    #define PLLEN_MUX_SWITCH 4
    #define PLL_LOCK_TIME_CNT 2400
    #define L1DCFG 0x01840040
    #define L1DWB 0x01845040
    Setup_Data_Cache ()
    // Flush L1D
    *((unsigned int *) L1DWB) = 0x01;
    // Reconfigure L1D to default state (full cache)
    *((unsigned int *) L1DCFG) = 0x07;
    hotmenu
    Setup_PLL()
    int i = 0;
    /* Configure ARM, DSP at 300MHz, EMIFs at 133MHz */
    unsigned int DIV45_EN = 1;
    unsigned int CLKMODE = 0;
    unsigned int PLLM = 24;
    unsigned int POSTDIV = 1;
    unsigned int PLLDIV3 = 2;
    unsigned int PLLDIV5 = 5;
    unsigned int PLLDIV7 = 7;
    // Moved step 2c and 2d to step 0
    /*Set PLLEN=0 and PLLRST=0, Reset the PLL*/
    PLL0_PLLCTL &= 0xFFFFFFFE; /*PLL BYPASS MODE*/
    /*wait for 4 cycles to allow PLLEN mux switches properly to bypass clock*/
    for(i=0; i<PLLEN_MUX_SWITCH; i++) {;} /*Make PLLEN_MUX_SWITCH as bootpacket*/
    /*Select the Clock Mode bit 8 as External Clock or On Chip Oscilator*/
    PLL0_PLLCTL &= 0xFFFFFEFF;
    PLL0_PLLCTL |= (CLKMODE<<8); /* Make CLKSRC as BootPacket to pass the value*/
    /*Set PLLENSRC '0',bit 5, PLL Enable(PLLEN) selection is controlled through MMR*/
    PLL0_PLLCTL &= 0xFFFFFFDF;
    /*PLLCTL.EXTCLKSRC bit 9 should be left at 0 for Primus*/
    PLL0_PLLCTL &= 0xFFFFFDFF;
    /* Clear PLLRST bit to 0 -Reset the PLL */
    PLL0_PLLCTL &= 0xFFFFFFF7;
    /*Disable the PLL output*/
    PLL0_PLLCTL |= 0x10;
    /*PLL initialization sequence*/
    /*Power up the PLL- PWRDN bit set to 0 to bring the PLL out of power down bit*/
    PLL0_PLLCTL &= 0xFFFFFFFD;
    /*Enable the PLL from Disable Mode PLLDIS bit to 0 - This is step is not required for Primus*/
    PLL0_PLLCTL &= 0xFFFFFFEF;
    /*PLL stabilisation time- take out this step , not required here when PLL in bypassmode*/
    /* for(i=0; i<PLL_STABILIZATION_TIME; i++) {;} /* Make PLL_STABILIZATION_TIME as bootpacket*/
    /*Program the required multiplier value in PLLM*/
    PLL0_PLLM = PLLM; /* Make PLLMULTIPLEIR as bootpacket*/
    /*If desired to scale all the SYSCLK frequencies of a given PLLC, program the POSTDIV ratio*/
    PLL0_POSTDIV = 0x8000 | POSTDIV; /* Make POSTDIV as bootpacket*/
    /*If Necessary program the PLLDIVx*/
    /*Check for the GOSTAT bit in PLLSTAT to clear to 0 to indicate that no GO operation is currently in progress*/
    while(PLL0_PLLSTAT & 0x1==1){}
    /*Program the RATIO field in PLLDIVx with the desired divide factors. In addition, make sure in this step you leave the PLLDIVx.DxEN bits set so clocks are still enabled (default).*/
    PLL0_PLLDIV3 = 0x8000 | PLLDIV3; /* Make PLLDIV3 as bootpacket, do it for other PLLDIVx to if required*/
    PLL0_PLLDIV5 = 0x8000 | PLLDIV5; /* Make PLLDIV5 as bootpacket, do it for other PLLDIVx to if required*/
    PLL0_PLLDIV7 = 0x8000 | PLLDIV7; /* Make PLLDIV7 as bootpacket, do it for other PLLDIVx to if required*/
    /*Set the GOSET bit in PLLCMD to 1 to initiate a new divider transition.*/
    PLL0_PLLCMD |= 0x1;
    /*Wait for the GOSTAT bit in PLLSTAT to clear to 0 (completion of phase alignment).*/
    while(PLL0_PLLSTAT & 0x1==1) { }
    /*Wait for PLL to reset properly. See PLL spec for PLL reset time - This step is not required here -step11*/
    /* for(i=0; i<PLL_RESET_TIME_CNT; i++) {;} /*128 MXI Cycles*/ /*Make PLL_RESET_TIME_CNT as boot packet*/
    /*Set the PLLRST bit in PLLCTL to 1 to bring the PLL out of reset*/
    PLL0_PLLCTL |= 0x8;
    /*Wait for PLL to lock. See PLL spec for PLL lock time*/
    for(i=0; i<PLL_LOCK_TIME_CNT; i++) {;} /*Make PLL_LOCK_TIME_CNT as boot Packet*/
    /*Set the PLLEN bit in PLLCTL to 1 to remove the PLL from bypass mode*/
    PLL0_PLLCTL |= 0x1;
    KICK0R = 0x83e70b13; // Kick0 register + data (unlock)
    KICK1R = 0x95a4f1e0; // Kick1 register + data (unlock)
    CFGCHIP3 |= 0x4; // Enable 4.5 divider PLL
    CFGCHIP3 |= 0x1; // Select 4.5 divider for EMIFB clock source only (not EMIFA)
    GEL_TextOut( "PLL Setup Complete\n" );
    * setup_pll_0( ) *
    * clock_source <- 0: Onchip Oscillator *
    * 1: External Clock *
    * pll_mult <- 21: 22x Multiplier * 27MHz Clk = 594 MHz *
    setup_pll_0( int clock_source, int pll_mult )
    unsigned int* pll_ctl = ( unsigned int* )( 0x01c11100 );
    unsigned int* pll_pllm = ( unsigned int* )( 0x01c11110 );
    unsigned int* pll_cmd = ( unsigned int* )( 0x01c11138 );
    unsigned int* pll_postdiv = ( unsigned int* )( 0x01c11128 );
    unsigned int* pll_bpdiv = ( unsigned int* )( 0x01c1112c );
    unsigned int* pll_div1 = ( unsigned int* )( 0x01c11118 );
    unsigned int* pll_div2 = ( unsigned int* )( 0x01c1111c );
    unsigned int* pll_div3 = ( unsigned int* )( 0x01c11120 );
    unsigned int* pll_div4 = ( unsigned int* )( 0x01c11160 );
    unsigned int* pll_div5 = ( unsigned int* )( 0x01c11164 );
    unsigned int* pll_div6 = ( unsigned int* )( 0x01c11168 );
    unsigned int* pll_div7 = ( unsigned int* )( 0x01c1116c );
    unsigned int* pll_div8 = ( unsigned int* )( 0x01c11170 );
    unsigned int* pll_div9 = ( unsigned int* )( 0x01c11174 );
    int pll0_freq = 24 * ( pll_mult + 1 );
    GEL_TextOut( "Setup PLL0 " );
    * Step 1 - Set clock mode
    if ( clock_source == 0 )
    *pll_ctl &= ~0x0100; // Onchip Oscillator
    else
    *pll_ctl |= 0x0100; // External Clock
    * Step 2 - Set PLL to bypass
    * - Wait for PLL to stabilize
    *pll_ctl &= ~0x0020;
    *pll_ctl &= ~0x0001;
    _wait( 150 );
    * Step 3 - Reset PLL
    *pll_ctl |= 0x0008;
    * Step 4 - Disable PLL
    * Step 5 - Powerup PLL
    * Step 6 - Enable PLL
    * Step 7 - Wait for PLL to stabilize
    *pll_ctl |= 0x0010; // Disable PLL
    *pll_ctl &= ~0x0002; // Power up PLL
    *pll_ctl &= ~0x0010; // Enable PLL
    _wait( 150 ); // Wait for PLL to stabilize
    * Step 8 - Load PLL multiplier
    *pll_pllm = pll_mult & 0x3f;
    * Step 9 - Set PLL post dividers
    *pll_postdiv= 0x8000 | 1; // Post divider
    *pll_div5 = 0x8001;
    *pll_cmd |= 0x0001; // GO
    _wait( 2000 );
    * Step 10 - Wait for PLL to reset ( 2000 cycles )
    * Step 11 - Release from reset
    _wait( 2000 );
    *pll_ctl &= ~0x0008;
    * Step 12 - Wait for PLL to re-lock ( 2000 cycles )
    * Step 13 - Switch out of BYPASS mode
    _wait( 2000 );
    *pll_ctl |= 0x0001;
    // Enable 4.5X divider
    // CFGCHIP3 |= 0x3; // Select 4.5 divider for EMIFA / EMIFB clock source
    pll0_freq = 24 * ( ( *pll_pllm & 0x3f ) + 1 ) / 2;
    GEL_TextOut( "(DSP = %d MHz + ",,,,, pll0_freq );
    GEL_TextOut( "ARM = %d MHz + ",,,,, pll0_freq );
    GEL_TextOut( "Onchip Oscillator)... " );
    else
    GEL_TextOut( "External Clock)... " );
    * Disable_IRQ_Flush_Cache( ) *
    * Flush Cache & Disable Interrupts *
    * Disable_EDMA( ) *
    * Disabe EDMA events and interrupts, clear any pending events *
    Disable_EDMA( )
    #define EDMA_3CC_IECRH *( unsigned int* )( 0x01c0105c )
    #define EDMA_3CC_EECRH *( unsigned int* )( 0x01c0102c )
    #define EDMA_3CC_ICRH *( unsigned int* )( 0x01c01074 )
    #define EDMA_3CC_ECRH *( unsigned int* )( 0x01c0100c )
    #define EDMA_3CC_IECR *( unsigned int* )( 0x01c01058 )
    #define EDMA_3CC_EECR *( unsigned int* )( 0x01c01028 )
    #define EDMA_3CC_ICR *( unsigned int* )( 0x01c01070 )
    #define EDMA_3CC_ECR *( unsigned int* )( 0x01c01008 )
    GEL_TextOut( "Disable EDMA events\n" );
    EDMA_3CC_IECRH = 0xffffffff; // IERH - Disable high interrupts
    EDMA_3CC_EECRH = 0xffffffff; // EERH - Disable high events
    EDMA_3CC_ICRH = 0xffffffff; // ICRH - Clear high interrupts
    EDMA_3CC_ECRH = 0xffffffff; // ICRH - Clear high events
    EDMA_3CC_IECR = 0xffffffff; // IER - Disable low interrupts
    EDMA_3CC_EECR = 0xffffffff; // EER - Disable low events
    EDMA_3CC_ICR = 0xffffffff; // ICR - Clear low interrupts
    EDMA_3CC_ECR = 0xffffffff; // ICRH - Clear low events
    * Enable_Instruction_Cache( ) *
    * Enable I-Cache *
    hotmenu Enable_Instruction_Cache( )
    GEL_TextOut( "\Enable Instruction Cache.\n\n" );
    CPSR = 0x400000d3; // Set to supervisor mode, disable IRQ/FIQ
    REG_CP15_I_CACHE = 1; // Enable Instruction Cache
    * Setup_System_Config( ) *
    * Configure PINMUX and other system module registers *
    hotmenu
    GEL_TextOut( "Setup PINMUX Registers... " );
    PINMUX0 = 0x11112188; // EMIFB, Check EMU0/RTCK
    PINMUX1 = 0x11111111; // EMIFB
    PINMUX2 = 0x11111111; // EMIFB
    PINMUX3 = 0x11111111; // EMIFB
    PINMUX4 = 0x11111111; // EMIFB
    PINMUX5 = 0x11111111; // EMIFB
    PINMUX6 = 0x11111111; // EMIFB
    PINMUX7 = 0x11111111; // EMIFB, SPI0
    PINMUX8 = 0x21122111; // UART2, McASP1, I2C0, I2C1
    PINMUX9 = 0x11011112; // RMII CLK, McASP0, USB_DRVVBUS, UART2
    PINMUX10 = 0x22222221; // RMII/ McASP0
    PINMUX11 = 0x11142222; // McASP1, UART1, McASP0, MDIO (last 2 digits 0x22 for MDIO instead of GPIO)
    PINMUX12 = 0x11111111; // McASP0 / McASP1
    PINMUX13 = 0x22111111; // SD / McASP1
    PINMUX14 = 0x88222222; // SD / EMIFA
    PINMUX15 = 0x21888888; // SD / EMIFA
    PINMUX16 = 0x11111112; // SD / EMIFA
    PINMUX17 = 0x00100111; // EMIFA
    PINMUX18 = 0x11111111; // EMIFA
    PINMUX19 = 0x00000001; // EMIFA
    //CFGCHIP2 |= 0x00001000; // Enable USB1 clock
    hotmenu
    PINMUX13 &= 0x00FFFFFF;
    PINMUX13 |= 0x11000000;
    PINMUX14 = 0x11111111;
    PINMUX15 = 0x11111111;
    PINMUX16 = 0x11111111;
    PINMUX17 = 0x11111111;
    PINMUX19 &= 0xFFFFFFF0;
    PINMUX19 |= 0x00000001;
    * Setup_EMIFA( ) *
    * Setup Async-EMIF to the specified timings using either NAND Hw *
    * controller or normal EMIF controller *
    #define AEMIF_AWCCR *( unsigned int* )( 0x68000004 )
    #define AEMIF_A1CR *( unsigned int* )( 0x68000010 )
    #define AEMIF_A2CR *( unsigned int* )( 0x68000014 )
    #define AEMIF_A3CR *( unsigned int* )( 0x68000018 )
    #define AEMIF_A4CR *( unsigned int* )( 0x6800001C )
    #define AEMIF_NANDFCR *( unsigned int* )( 0x68000060 )
    Setup_EMIFA( )
    /* Use extended wait cycles to keep CE low during NAND access */
    AEMIF_AWCCR = 0xff;
    /* Setup CS2 - 8-bit normal async */
    AEMIF_A1CR = 0x00300608;
    AEMIF_NANDFCR &= ~1;
    /* Setup CS3 - 8-bit NAND */
    AEMIF_A2CR = 0x00300388;
    AEMIF_NANDFCR |= 2;
    /* Setup CS4 - 8-bit normal async */
    AEMIF_A3CR = 0x00a00504; // Setup=0, Strobe=A, Hold=0, TA=1, 8-bit
    AEMIF_NANDFCR &= ~4;
    /* Setup CS5 - 8-bit normal async */
    AEMIF_A4CR = 0x00a00504; // Setup=0, Strobe=A, Hold=0, TA=1, 8-bit
    AEMIF_NANDFCR &= ~8;
    * Setup_EMIFB( ) *
    * Configure SDRAM. *
    #define EMIFB_BASE 0xB0000000
    #define EMIFB_SDSTAT *(unsigned int*)(EMIFB_BASE + 0x04) //SDRAM Status Register
    #define EMIFB_SDCFG *(unsigned int*)(EMIFB_BASE + 0x08) //SDRAM Bank Config Register
    #define EMIFB_SDREF *(unsigned int*)(EMIFB_BASE + 0x0C) //SDRAM Refresh Control Register
    #define EMIFB_SDTIM1 *(unsigned int*)(EMIFB_BASE + 0x10) //SDRAM Timing Register
    #define EMIFB_SDTIM2 *(unsigned int*)(EMIFB_BASE + 0x14) //SDRAM Timing Register
    Setup_EMIFB()
    // ISSI IS42S16320B-7TLI SDRAM, 32M x 16 (16-bit data path), 133MHz
    EMIFB_SDCFG = 0 // SDRAM Bank Config Register
    |( 1 << 15) // Unlock timing registers
    |( 1 << 14) // Enable narrow mode (16-bit data bus)
    |( 2 << 9 ) // CAS latency is 2
    |( 2 << 4 ) // 4 bank SDRAM devices
    |( 2 << 0 ); // 1024-word pages requiring 10 column address bits
    EMIFB_SDREF = 0 // SDRAM Refresh Control Register
    |( 0 << 31) // Low power mode disabled
    |( 0 << 30) // MCLK stoping disabled
    |( 0 << 23) // Selects self refresh instead of power down
    |( 1040 <<0); // Refresh rate = 7812.5ns / 7.5ns
    EMIFB_SDTIM1 = 0 // SDRAM Timing Register 1
    |( 25 << 25) // (67.5ns / 7.55ns) - 1 = TRFC @ 133MHz //***check
    |( 1 << 22 ) // (15ns / 7.5ns) - 1 =TRP
    |( 1 << 19 ) // (15ns / 7.5ns) - 1 = TRCD
    |( 1 << 16 ) // (15ns / 7.5ns) - 1 = TWR //t_DPL?
    |( 6 << 11 ) // (45ns / 7.5ns) - 1 = TRAS
    |( 8 << 6 ) // (60ns / 7.5ns) - 1 = TRC
    |( 1 << 3 ); // (15ns / 7.5ns) - 1 = TRRD
    // *(((4 * 14ns) + (2 * 7.5ns)) / (4 * 7.5ns)) -1. = TRRD
    // but it says to use this formula if 8 banks but only 4 are used here.
    // and SDCFG1 register only suports upto 4 banks.
    EMIFB_SDTIM2 = 0 // SDRAM Timing Register 2
    |( 14<< 27) // ***check***not sure how they got this number. the datasheet says value should be
    // "Maximum number of refresh_rate intervals from Activate to Precharge command"
    // but has no equation. TRASMAX is 120k.
    |( 8 << 16) // ( 67.5 / 7.5) - 1
    |( 5 << 0 ); // ( 45 / 7.5 ) - 1
    |( 1 << 16) // Set SDREN to enable SDRAM
    |( 0 << 15) // Unlock timing registers
    /*Program the EMIF3C_SDRAM Controller*/
    // EMIF3C_SDCFG = 0x00008421;
    // EMIF3C_SDTIM1 = 0x10912A10;
    // EMIF3C_SDTIM2 = 0x70090005;
    // EMIF3C_SDREF = 0x410;
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • Ben Vaughn
      on Aug 13 2012 17:52 PM
      Verified Answer
      Verified by Rahul Prabhu
      Prodigy40 points
      I tried again today and it worked. I haven't changed a thing. This is very peculiar. Maybe a good power cycle was all it needed.
      Report Abuse
      • Reply
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
