• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Digital Signal Processors (DSP) » OMAP™ Processors » OMAP-L13x, AM1x and C674x Processors Forum » Configuring CS7 of the OMAP
Share
OMAP™ Processors
  • Forums
  • Announcements
Options
  • Subscribe via RSS
Resources
  • OMAP-L1x DSP+ARM9™-based Processors Product Folder
  • OMAP3525/30 DSP+ARM Cortex™-A8-based SOCs Product Folder
  • Top OMAPL Wiki Links
  • OMAPL3x Schematic Review Checklist
  • OMAPL13x Boot resources
  • OMAPL Document Resources
  • OMAPL137 Technical reference manual
  • OMAPL138 Technical reference manual
  • OMAPL Boot loader App Notes
  • Configuring CS7 of the OMAP
    This question is not answered
    Vijay
    Posted by Vijay
    on Jan 08 2009 09:53 AM
    Intellectual670 points
    We are facing an issue which we are not sure if it related to our bug or related to Omap chip.
    We are configuring the CS7 to be used as 16bit bus with un multiplexed mode.
    The signal time that we would like to get for the CS is as follow -------|__50ns_____|----100ns------|__50ns_____|---------
    When we are running writing sequence, we are getting it as above. At reading sequence, the 100ns increase to 200ns and we don’t know why.
    Can you help us to fine what the problem is? (OMAP issue or software issue).
    -Warm Regards,
    Vijay
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • BrandonAzbell
      Posted by BrandonAzbell
      on Jan 08 2009 10:50 AM
      Guru55185 points
      If you could provide the register settings for the CS7 configuration, this would be helpful.  Also, please indicate which OMAP device part number you are working with.
      Just a clarifying question, is the 100ns portion of the CS7 waveform meant to indicate CS7 at a logic high?
      I want to make sure I interpret the waveform correctly.  Here is my assumption:
      CS7 high to low transition.
      50ns low
      100ns ?
      50ns low
      CS7 low to high transition
      Brandon
      Report Abuse
      • Reply
    • Vijay
      Posted by Vijay
      on Jan 11 2009 23:46 PM
      Hi Brandon,
      Thanks for the reply. Below is the an excerpt of the c code that configures the CS7.The code setting for CS7 is not the exactly time setting that we achieved with read/write sequence..
      #define        GPMC_CLK            150  //150MHZ
          #define     GPMC_CLK_PERIOD        (1000000/GPMC_CLK) // pico sec
          #define     RD_CYCLE_TIME_VAL       (((160/*ns*/ * 1000)/GPMC_CLK_PERIOD)             & 0x1F)
          #define     WR_CYCLE_TIME_VAL        (((160/*ns*/ * 1000)/GPMC_CLK_PERIOD)             & 0x1F)
          #define     CS_ONTIME_VAL            (((100/*ns*/ * 1000)/GPMC_CLK_PERIOD)             & 0x0F)
          #define     CS_RD_OFFTIME_VAL        ((CS_ONTIME_VAL  + (50/*ns*/ * 1000)/GPMC_CLK_PERIOD) & 0x1F)
          #define     CS_WR_OFFTIME_VAL        CS_RD_OFFTIME_VAL
          #define     CS_OFFTIME_VAL          CS_RD_OFFTIME_VAL
          #define     OE_ONTIME_VAL            ((CS_ONTIME_VAL  + (10/*ns*/ * 1000)/GPMC_CLK_PERIOD) & 0x0F)
          #define     OE_OFFTIME_VAL            ((CS_OFFTIME_VAL - (10/*ns*/ * 1000)/GPMC_CLK_PERIOD) & 0x1F)
          #define        WR_ONTIME_VAL            OE_ONTIME_VAL
          #define        WR_OFFTIME_VAL            OE_OFFTIME_VAL
          #define     RD_ACCESS_TIME_VAL        (((CS_ONTIME_VAL  + (10/*ns*/ * 1000)/GPMC_CLK_PERIOD) -1) & 0x1F)
          #define     WR_ACCESS_TIME_VAL        RD_ACCESS_TIME_VAL
          #define     RD_CYCLE_TIME        (RD_CYCLE_TIME_VAL  <<  0)
          #define     WR_CYCLE_TIME        (WR_CYCLE_TIME_VAL  <<  8)
          #define     CS_ONTIME            (CS_ONTIME_VAL      <<  0)
          #define     CS_RD_OFFTIME        (CS_RD_OFFTIME_VAL  <<  8)
          #define     CS_WR_OFFTIME        (CS_WR_OFFTIME_VAL  << 16)
          #define     OE_ONTIME            (OE_ONTIME_VAL      <<  0)
          #define     OE_OFFTIME            (OE_OFFTIME_VAL     <<  8)
          #define        WR_ONTIME            (OE_ONTIME_VAL      << 16)
          #define        WR_OFFTIME            (OE_OFFTIME_VAL     << 24)
          #define     RD_ACCESS_TIME        (RD_ACCESS_TIME_VAL << 16)
          #define     WR_ACCESS_TIME        (RD_ACCESS_TIME_VAL << 24)
          # define FPGA_GPMC_CONFIG1        0x01801000  // 0x00C01000
          # define FPGA_GPMC_CONFIG2        (CS_WR_OFFTIME | CS_RD_OFFTIME | CS_ONTIME)                  // 0x00101000
          # define FPGA_GPMC_CONFIG3        0x00020201
          # define FPGA_GPMC_CONFIG4        (OE_ONTIME | OE_OFFTIME | WR_ONTIME | WR_OFFTIME)            // 0x10031003
          # define FPGA_GPMC_CONFIG5        (RD_CYCLE_TIME | WR_CYCLE_TIME | RD_ACCESS_TIME | (1 << 24)) // 0x010F1111
          # define FPGA_GPMC_CONFIG6        (WR_ACCESS_TIME | (3 << 16) | (1 << 31)) // 0x8F030000
          # define FPGA_GPMC_CONFIG_BASE        (GPMC_CONFIG_CS0 + (7 * GPMC_CONFIG_WIDTH))
          # define FPGA_BASE_ADD            0x38000000  /* CS7 */
          # define FPGA_MEM_SIZE            GPMC_SIZE_16M
      #else
              // --------------------Eli.M 25/11/2008 ---------------------
              //Configuring CS7 for FPGA
              //CS = 50nsec 0-50ns    ----|__________|--------
              //RD cycle time = 55ns
              //WR cycle time = 55ns
              //OE = 40ns   5-45ns    -----|________|---------
              //WR = 40ns   5-45ns    -----|________|---------
              //RD acsess time = 45n
              //WR acsess time = 45n
              #define     RD_CYCLE_TIME_VAL       ((( 55/*ns*/ * 1000)/GPMC_CLK_PERIOD)             & 0x1F)
              #define     WR_CYCLE_TIME_VAL        ((( 55/*ns*/ * 1000)/GPMC_CLK_PERIOD)             & 0x1F)
              #define     CS_ONTIME_VAL            0
              #define     OE_ONTIME_VAL            ((CS_ONTIME_VAL  + (7/*ns*/ * 1000)/GPMC_CLK_PERIOD) & 0x0F)
              #define     OE_OFFTIME_VAL            ((CS_OFFTIME_VAL - (7/*ns*/ * 1000)/GPMC_CLK_PERIOD) & 0x1F)
              #define     RD_ACCESS_TIME_VAL        OE_OFFTIME_VAL
              #define        CYCLE2CYCLE_DELAY_EN    ((0X1)<<7)
              #define        CYCLE2CYCLE_DELAY_VAL    0XF            //    (((100/*NS*/ * 1000)/GPMC_CLK_PERIOD) & 0xF)
              #define     CYCLE2CYCLE_DELAY    (CYCLE2CYCLE_DELAY_VAL  << 8)
              # define FPGA_GPMC_CONFIG6        (WR_ACCESS_TIME | CYCLE2CYCLE_DELAY_EN |CYCLE2CYCLE_DELAY | (3 << 16) | (1 << 31) ) // 0x8F030000
      #endif
          static u32 gpmc_fpga[GPMC_MAX_REG] = {
              FPGA_GPMC_CONFIG1,
              FPGA_GPMC_CONFIG2,
              FPGA_GPMC_CONFIG3,
              FPGA_GPMC_CONFIG4,
              FPGA_GPMC_CONFIG5,
              FPGA_GPMC_CONFIG6, 0
      #if 0
          // ====== DEBUG !!!!!!!!!!!!!!
          for (i=0; i < GPMC_MAX_REG; i++)
              printf ("gpmc_fpga[%d] = 0x%.8X\n", i, gpmc_fpga[i]);
      #endif
          gpmc_config = gpmc_fpga;
          gpmc_base   = FPGA_GPMC_CONFIG_BASE;
          base        = FPGA_BASE_ADD;
          size        = FPGA_MEM_SIZE;
          //Configure the GPMC CS7
          enable_gpmc_config(gpmc_config, gpmc_base, base, size);
      #if 0
          //Read Test For CS testing
          while (1) { // for(testcounter=0;testcounter<1000;testcounter++){
              unsigned short testval;
              testval = (unsigned short)( __raw_readl(FPGA_BASE_ADD) & 0xFFFF);
              sdelay(300);
              __raw_writel(0x55, FPGA_BASE_ADD);
              __raw_writel(0xAA, FPGA_BASE_ADD);
              __raw_writel(r0x33, FPGA_BASE_ADD);
              sdelay(1000);
          }//for
      #endif
      -Warm Regards,
      Vijay
      Report Abuse
      • Reply
    • Vijay
      Posted by Vijay
      on Jan 12 2009 02:18 AM
      Hi Brandon,
      Some more information:
      Below are the register settings...
      OMAP3EVM #  md 0x6e0001b0
      6e0001b0: 01801000 00070700 00020201 06010601    ................
      6e0001c0: 01060808 86030f80 00000f78 ffffffff    ........x.......
      We would like to know why the read and write sequence are not with the same time setting as we wish too.
      -Warm Regards,
      Vijay
      Report Abuse
      • Reply
    • BrandonAzbell
      on Jan 13 2009 17:06 PM
      Guru55185 points
      Thank you for the printout of the register settings.  So far, I haven't determined where the source of the issue is.  From how I interpret your data, the nCS high period is getting extended by 2X between successive accesses, correct?
      One thing that I would suggest changing is the GPMC_CONFIG1_7[24:23] from 0x3 to 0x1.  The value of 0x3 is reserved.  This is the ATTACHEDDEVICEPAGELENGTH field and the default is 0x0 which indicates 4 words.  I realize you may not be trying to perform page accesses, which should be controlled by the READMULTIPLE and WRITEMULTIPLE fields both set to 0x0, or single access.
      Brandon
      OMAP35xx GPMC
      Report Abuse
      • Reply
    • Eli Makdasi
      Posted by Eli Makdasi
      on Feb 18 2009 06:07 AM
      Prodigy10 points
      7573.u-boot.zipHi,
      I have configured the GPMC registers according your recomendation but i still get doubled read time comparing to write cycle.
      The attache file is our u-boot which configure the GPMC registers.
      if you have more ideas what can cause that you welcome.
      Eli
      Report Abuse
      • Reply
    • santosh vastrad
      Posted by santosh vastrad
      on Nov 22 2011 03:36 AM
      Expert2065 points
      hi vijay:
      I am also doing same thing, that is connecting nand to GPMC_CS7. I need your u-boot modification to access nand,
      I tried by changing u-boot still unable to get device id and manufacture id of the nand flash device.
      16Gbit nand flash (2GB Hynix) (AM3703 processor).
      expecting reply?
      santosh vastrad
      Report Abuse
      • Reply
    • hrishikesh choudhary
      Posted by hrishikesh choudhary
      on Apr 27 2012 07:01 AM
      Intellectual920 points
      Hi Vijay !!!
      Can you let me know...what you are doing in the enable_gpmc_config(gpmc_config, gpmc_base, base, size); function.
      In which register you are Updating this value.
      I have stucked with the same problem... we have interfaced an External NAND of 32Gb through an FPGA. the Processor sends the control signal and Data signal to the FPGA and from there it is Routed to NAND.
      This are My configurations :
      OUT_REGL(GPMC_CONFIG, 0x00000002);
         OUT_REGL(GPMC_CONFIG1_1, 0x00010813);
         OUT_REGL(GPMC_CONFIG2_1, 0x001F1F00);
         OUT_REGL(GPMC_CONFIG3_1, 0x00030383);
         OUT_REGL(GPMC_CONFIG4_1, 0x1A001A00);
         OUT_REGL(GPMC_CONFIG5_1, 0x001D1F1F);
         OUT_REGL(GPMC_CONFIG6_1, 0x1D000505);
         OUT_REGL(GPMC_CONFIG7_1, 0x00000C5f);
      ...Can you let me what you are doing in the function enable_gpmc_config.
      thanks and regard's
      Hrishikesh.
      Report Abuse
      • Reply
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
