Hi
when i run:
./audioSoc_gpp audioSoc_dsp.out davincieffect_clip.pcm
Dead in SHMDRV_handshake.
Seams there is not set flag:DRV_HANDSHAKE_DATA .
SDK version is: DVSDK4.03 on OMAP-L138
Who can help me to resolve this problem?
Thanks very much!
Hi
when i run:
Thanks very much!
Hi Changsheng Li,
The given information is not sufficient to answer your question/problem.
Could you please elaborate a bit on your question/problem.
I presume that you are facing some audio related issues when you run your audio DSP code through DSPLINK.
Have you disabled the "Audio support" in linux to avoid resource conflict between ARM and DSP ?
Hi Titusrathinaraj Stalin :
Thanks very much! And as i had something to do ,I delay this! Sorry!
When I run command:
By add some log , I find that, when audioSoc_gpp run,
PROC_load () ----OK
PROC_start ()----stop!
Down at :
SHMDRV_handshake
ctrlPtr->handshakeDsp != dspHandshake, because ctrlPtr->handshakeDsp=0xbaba01bf and dspHandshake=0xbaba01ff
The memory config file is:
/** ============================================================================ * @file CFG_OMAPL138GEM_SHMEM.c * * @path $(DSPLINK)/config/all/ * * @desc Defines the configuration information for DSP/BIOS LINK for the * OMAPL138 platform. * * @ver 1.65.01.05_eng * ============================================================================ * Copyright (C) 2002-2009, Texas Instruments Incorporated - * http://www.ti.com/ * * Redistribution and use in source and binary forms, with or without * modification, are permitted provided that the following conditions * are met: * * * Redistributions of source code must retain the above copyright * notice, this list of conditions and the following disclaimer. * * * Redistributions in binary form must reproduce the above copyright * notice, this list of conditions and the following disclaimer in the * documentation and/or other materials provided with the distribution. * * * Neither the name of Texas Instruments Incorporated nor the names of * its contributors may be used to endorse or promote products derived * from this software without specific prior written permission. * * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. * ============================================================================ */ /* ----------------------------------- DSP/BIOS LINK Headers */ #include <dsplink.h> #include <procdefs.h> #if defined (__cplusplus) EXTERN "C" { #endif /* defined (__cplusplus) */ /** ============================================================================ * DSPLINK MEMORY SECTION DIAGRAM * * |--------------[ 0xXXXXXX00 ]---------------------------------| * | | * | RESET VECTOR (0x80) | * | Last two nibbles must be zero | * | | * |-------------------------------------------------------------| * | | * | DSP CODE/DATA | * | DSP executable is loaded to this section | * | | * |=============================================================| * | | * | DSPLINK SHARED MEMORY0 | * | Shared control structure is loaded here | * | | * |-------------------------------------------------------------| * | | * | DSPLINK SHARED MEMORY1 | * | Shared control structure is loaded here | * | | * |-------------------------------------------------------------| * | | * | POOL Buffer Memory | * | Pool's buffers are created in this area | * | | * |-------------------------------------------------------------| * * ============================================================================ */ /** ============================================================================ * @name DRVHANDSHAKEPOLLCOUNT * * @desc POLL Count for Driver handshake. * ============================================================================ */ #define DRVHANDSHAKEPOLLCOUNT ((Uint32) -1u) /** ============================================================================ * @name RESETCTRLADDR * * @desc Indicates the start address of Reset Ctrl memory region. * last two nibbles must be zero i.e. align to 256 boundary. * ============================================================================ */ #define RSTENTRYID 0 #define RESETCTRLADDR 0xC7000000 #define RESETCTRLSIZE 0x80 /** ============================================================================ * @name CODEMEMORYADDR/CODEMEMORYSIZE * * @desc Indicates startaddress/size for dsplink code region. * ============================================================================ * 64M-0x80 */ #define CODEENTRYID 1 #define CODEMEMORYADDR (RESETCTRLADDR + RESETCTRLSIZE) #define CODEMEMORYSIZE 0x03FFFF80u /** ============================================================================ * @name SHAREDENTRYID/SHAREDMEMORYADDR/SHAREDMEMORYSIZE * * @desc Indicates startaddress/size for dsplink shared memory region. * ============================================================================ * 4M */ #define SHAREDENTRYID0 2 #define SHAREDMEMORYADDR0 (CODEMEMORYADDR + CODEMEMORYSIZE) #define SHAREDMEMORYSIZE0 0x00400000 /** ============================================================================ * @name SHAREDENTRYID/SHAREDMEMORYADDR/SHAREDMEMORYSIZE * * @desc Indicates startaddress/size for dsplink shared memory region. * ============================================================================ * 16M */ #define SHAREDENTRYID1 3 #define SHAREDMEMORYADDR1 (SHAREDMEMORYADDR0 + SHAREDMEMORYSIZE0) #define SHAREDMEMORYSIZE1 0x01000000 /** ============================================================================ * @name POOLMEMORYADDR/POOLMEMORYSIZE * * @desc Indicates startaddress/size for dsplink POOL memory region. * ============================================================================ * 16M */ #define POOLENTRYID 4 #define POOLMEMORYADDR (SHAREDMEMORYADDR1 + SHAREDMEMORYSIZE1) #define POOLMEMORYSIZE 0x010000000u /** ============================================================================ * @name LINKCFG_memTable_00 * * @desc Memory table ID 0. * ============================================================================ */ STATIC LINKCFG_MemEntry LINKCFG_memTable_00 [] = { { RSTENTRYID, /* ENTRY : Entry number */ "RESETCTRL", /* NAME : Name of the memory region */ RESETCTRLADDR, /* ADDRPHYS : Physical address */ RESETCTRLADDR, /* ADDRDSPVIRT : DSP virtual address */ (Uint32) -1, /* ADDRGPPVIRT : GPP virtual address (if known) */ RESETCTRLSIZE, /* SIZE : Size of the memory region */ FALSE, /* SHARED : Shared access memory? */ FALSE, /* SYNCD : Synchornized? */ }, { CODEENTRYID, /* ENTRY : Entry number */ "DDR", /* NAME : Name of the memory region */ CODEMEMORYADDR, /* ADDRPHYS : Physical address */ CODEMEMORYADDR, /* ADDRDSPVIRT : DSP virtual address */ (Uint32) -1, /* ADDRGPPVIRT : GPP virtual address (if known) */ CODEMEMORYSIZE, /* SIZE : Size of the memory region */ FALSE, /* SHARED : Shared access memory? */ FALSE, /* SYNCD : Synchornized? */ }, { SHAREDENTRYID0, /* ENTRY : Entry number */ "DSPLINKMEM", /* NAME : Name of the memory region */ SHAREDMEMORYADDR0, /* ADDRPHYS : Physical address */ SHAREDMEMORYADDR0, /* ADDRDSPVIRT : DSP virtual address */ (Uint32) -1, /* ADDRGPPVIRT : GPP virtual address (if known) */ SHAREDMEMORYSIZE0, /* SIZE : Size of the memory region */ TRUE, /* SHARED : Shared access memory? */ FALSE, /* SYNCD : Synchornized? */ }, { SHAREDENTRYID1, /* ENTRY : Entry number */ "DSPLINKMEM1", /* NAME : Name of the memory region */ SHAREDMEMORYADDR1, /* ADDRPHYS : Physical address */ SHAREDMEMORYADDR1, /* ADDRDSPVIRT : DSP virtual address */ (Uint32) -1, /* ADDRGPPVIRT : GPP virtual address (if known) */ SHAREDMEMORYSIZE1, /* SIZE : Size of the memory region */ TRUE, /* SHARED : Shared access memory? */ FALSE, /* SYNCD : Synchornized? */ }, { POOLENTRYID, /* ENTRY : Entry number */ "POOLMEM", /* NAME : Name of the memory region */ POOLMEMORYADDR, /* ADDRPHYS : Physical address */ POOLMEMORYADDR, /* ADDRDSPVIRT : DSP virtual address */ (Uint32) -1, /* ADDRGPPVIRT : GPP virtual address (if known) */ POOLMEMORYSIZE, /* SIZE : Size of the memory region */ TRUE, /* SHARED : Shared access memory? Logically */ FALSE, /* SYNCD : Synchornized? */ }, { 5, /* ENTRY : Entry number */ "DSPIRAM", /* NAME : Name of the memory region */ 0x11800000, /* ADDRPHYS : Physical address */ 0x11800000, /* ADDRDSPVIRT : DSP virtual address */ (Uint32) -1, /* ADDRGPPVIRT : GPP virtual address (if known) */ 0x40000, /* SIZE : Size of the memory region */ FALSE, /* SHARED : Shared access memory? */ FALSE, /* SYNCD : Synchornized? */ }, { 6, /* ENTRY : Entry number */ "DSPL1DRAM", /* NAME : Name of the memory region */ 0x11F00000, /* ADDRPHYS : Physical address */ 0x11F00000, /* ADDRDSPVIRT : DSP virtual address */ (Uint32) -1, /* ADDRGPPVIRT : GPP virtual address (if known) */ 0x8000, /* SIZE : Size of the memory region */ FALSE, /* SHARED : Shared access memory? */ FALSE, /* SYNCD : Synchornized? */ }, } ; /** ============================================================================ * @name LINKCFG_memTables * * @desc Array of memory tables in the system. * ============================================================================ */ STATIC LINKCFG_MemEntry * LINKCFG_memTables [] = { LINKCFG_memTable_00 /* Memory Table 0 */ } ; /** ============================================================================ * @name LINKCFG_ipsTable_00 * * @desc IPS table ID 0. * ============================================================================ */ STATIC LINKCFG_Ips LINKCFG_ipsTable_00 [] = { { "IPS", /* NAME : Name of the Inter-Processor-Signaling component */ (Uint32) 32, /* NUMIPSEVENTS : Number of IPS events to be supported */ (Uint32) SHAREDENTRYID0, /* MEMENTRY : Memory entry ID (-1 if not needed) */ (Uint32) 28, /* GPPINTID : Interrupt no. to used by the IPS on GPP-side. (-1 if uni-directional to DSP) */ (Uint32) 5, /* DSPINTID : Interrupt no. to used by the IPS on DSP-side. (-1 if uni-directional to GPP) */ (Uint32) 4, /* DSPINTVECTORID : Interrupt vector no. to used by the IPS on DSP-side. (-1 if uni-directional to GPP) */ (Uint32) 50000000, /* ARGUMENT1 : Poll value for which IPS waits while sending event (-1 if infinite) */ 0 /* ARGUMENT2 : Second IPS-specific argument */ }, { "IPS", /* NAME : Name of the Inter-Processor-Signaling component */ (Uint32) 32, /* MAXIPSEVENTS : Number of IPS events to be supported */ (Uint32) SHAREDENTRYID1, /* MEMENTRY : Memory entry ID (-1 if not needed) */ (Uint32) 29, /* GPPINTID : Interrupt no. to used by the IPS on GPP-side. (-1 if uni-directional to DSP) */ (Uint32) 67, /* DSPINTID : Interrupt no. to used by the IPS on DSP-side. (-1 if uni-directional to GPP) */ (Uint32) 5, /* DSPINTVECTORID : Interrupt vector no. to used by the IPS on DSP-side. (-1 if uni-directional to GPP) */ (Uint32) 50000000, /* ARGUMENT1 : Poll value for which IPS waits while sending event (-1 if infinite) */ 0 /* ARGUMENT2 : Second IPS-specific argument */ } } ; /** ============================================================================ * @name LINKCFG_ipsTables * * @desc Array of IPS tables in the system. * ============================================================================ */ STATIC LINKCFG_Ips * LINKCFG_ipsTables [] = { LINKCFG_ipsTable_00 /* IPS Table 0 */ } ; /** ============================================================================ * @name LINKCFG_poolTable_00 * * @desc Pool table ID 0. * ============================================================================ */ STATIC LINKCFG_Pool LINKCFG_poolTable_00 [] = { { "SMAPOOL", /* NAME : Name of the pool */ (Uint32) SHAREDENTRYID1, /* MEMENTRY : Memory entry ID (-1 if not needed) */ (Uint32) POOLMEMORYSIZE, /* POOLSIZE : Size of the pool (-1 if not needed) */ (Uint32) -1, /* IPSID : ID of the IPS used */ (Uint32) -1, /* IPSEVENTNO : IPS Event number associated with POOL */ POOLENTRYID, /* POOLMEMENTRY : Pool memory region section ID */ 0x0, /* ARGUMENT1 : First Pool-specific argument */ 0x0 /* ARGUMENT2 : Second Pool-specific argument */ } } ; /** ============================================================================ * @name LINKCFG_poolTables * * @desc Array of Pool tables in the system. * ============================================================================ */ STATIC LINKCFG_Pool * LINKCFG_poolTables [] = { LINKCFG_poolTable_00 /* Pool Table 0 */ } ; /** ============================================================================ * @name LINKCFG_dataTable_00 * * @desc Data driver table ID 0. * ============================================================================ */ STATIC LINKCFG_DataDrv LINKCFG_dataTable_00 [] = { { "ZCPYDATA", /* NAME : Name of the data driver */ 0, /* BASECHANNELID : Base channel ID for the driver */ 16, /* NUMCHANNELS : Number of channels supported */ 16384, /* MAXBUFSIZE : Maximum size of buffer supported (-1 if no limit) */ (Uint32) SHAREDENTRYID1, /* MEMENTRY : Memory entry ID (-1 if not needed) */ 0, /* POOLID : Pool id for allocating buffers */ 1, /* QUEUELENGTH : Queue length for the data driver */ 1, /* IPSID : ID of the IPS used */ 1, /* IPSEVENTNO : IPS Event number associated with data Driver */ 0x0, /* ARGUMENT1 : First data driver specific argument */ 0x0 /* ARGUMENT2 : Second data driver specific argument */ } } ; /** ============================================================================ * @name LINKCFG_dataTables * * @desc Array of Data driver tables in the system. * ============================================================================ */ STATIC LINKCFG_DataDrv * LINKCFG_dataTables [] = { LINKCFG_dataTable_00 /* Data Table 0 */ } ; /** ============================================================================ * @name LINKCFG_mqtObjects * * @desc Array of Message Queue Transport objects in the system. * ============================================================================ */ STATIC LINKCFG_Mqt LINKCFG_mqtObjects [] = { { "ZCPYMQT", /* NAME : Name of the Message Queue Transport */ (Uint32) SHAREDENTRYID1, /* MEMENTRY : Memory entry ID (-1 if not needed) */ (Uint32) -1, /* MAXMSGSIZE : Maximum message size supported (-1 if no limit) */ 1, /* IPSID : ID of the IPS used */ 0, /* IPSEVENTNO : IPS Event number associated with MQT */ 0x0, /* ARGUMENT1 : First MQT-specific argument */ 0x0 /* ARGUMENT2 : Second MQT-specific argument */ } } ; /** ============================================================================ * @name LINKCFG_ringIoObjects * * @desc Array of RINGIO objects in the system. * ============================================================================ */ STATIC LINKCFG_RingIo LINKCFG_ringIoObjects [] = { { "RINGIOTABLE", /* NAME : Name of the RingIO Table */ SHAREDENTRYID0, /* MEMENTRY : Memory entry ID (-1 if not needed) */ 64, /* NUMENTRIES : Number of RingIO entries supported */ 0, /* IPSID : ID of the IPS used */ 0 /* IPSEVENTNO : IPS Event number associated with RingIO */ } } ; /** ============================================================================ * @name LINKCFG_mplistObjects * * @desc Array of MPLIST objects in the system. * ============================================================================ */ STATIC LINKCFG_MpList LINKCFG_mplistObjects [] = { { "MPLISTTABLE", /* NAME : Name of the MpList Table */ SHAREDENTRYID1, /* MEMENTRY : Memory entry ID (-1 if not needed) */ 64, /* NUMENTRIES : Number of MpList entries supported */ (Uint32) -1, /* IPSID : ID of the IPS used */ (Uint32) -1 /* IPSEVENTNO : IPS Event number associated with MpList */ } } ; /** ============================================================================ * @name LINKCFG_mpcsObjects * * @desc Array of MPCS objects in the system. * ============================================================================ */ STATIC LINKCFG_Mpcs LINKCFG_mpcsObjects [] = { { "MPCS", /* NAME : Name of the MPCS Table */ SHAREDENTRYID1, /* MEMENTRY : Memory entry ID (-1 if not needed) */ 256, /* NUMENTRIES : Number of MPCS entries supported */ (Uint32) -1, /* IPSID : ID of the IPS used */ (Uint32) -1 /* IPSEVENTNO : IPS Event number associated with MPCS */ } } ; /** ============================================================================ * @name LINKCFG_gppObject * * @desc Configuration object for the GPP. * ============================================================================ */ STATIC LINKCFG_Log LINKCFG_logObject = { FALSE, /* GDMSGQPUT : GPP->DSP MSG Transfer - MSGQ_put call */ FALSE, /* GDMSGQSENDINT : GPP->DSP MSG Transfer - GPP sends interrupt */ FALSE, /* GDMSGQISR : GPP->DSP MSG Transfer - DSP receives interrupt */ FALSE, /* GDMSGQQUE : GPP->DSP MSG Transfer - Message queued at DSP */ FALSE, /* DGMSGQPUT : DSP->GPP MSG Transfer - MSGQ_put call */ FALSE, /* DGMSGQSENDINT : DSP->GPP MSG Transfer - DSP sends interrupt */ FALSE, /* DGMSGQISR : DSP->GPP MSG Transfer - GPP receives interrupt */ FALSE, /* DGMSGQQUE : DSP->GPP MSG Transfer - Message queued at GPP */ FALSE, /* GDCHNLISSUESTART : GPP->DSP CHNL Transfer - Entering inside ISSUE call */ FALSE, /* GDCHNLISSUEQUE : GPP->DSP CHNL Transfer - ISSUE: Buffer is queued in internal structure on GPP */ FALSE, /* GDCHNLISSUECOMPL : GPP->DSP CHNL Transfer - ISSUE call completed */ FALSE, /* GDCHNLXFERSTART : GPP->DSP CHNL Transfer - Initiating a buffer transfer by GPP */ FALSE, /* GDCHNLXFERPROCESS : GPP->DSP CHNL Transfer - Actual transfer of buffer is going to take place */ FALSE, /* GDCHNLXFERCOMPL : GPP->DSP CHNL Transfer - Buffer transfer is complete */ FALSE, /* GDCHNLRECLSTART : GPP->DSP CHNL Transfer - Entering RECLAIM call */ FALSE, /* GDCHNLRECLPEND : GPP->DSP CHNL Transfer - RECLAIM: Wait on a semaphore */ FALSE, /* GDCHNLRECLPOST : GPP->DSP CHNL Transfer - RECLAIM: Posting the Semaphore */ FALSE, /* GDCHNLRECLCOMPL : GPP->DSP CHNL Transfer - RECLAIM call completed */ FALSE, /* DGCHNLISSUEQUE : DSP->GPP CHNL Transfer - ISSUE: Buffer is queued in internal structure on DSP */ FALSE, /* DGCHNLXFERSTART : DSP->GPP CHNL Transfer - Initiating a buffer transfer by DSP */ FALSE, /* DGCHNLXFERPROCESS : DSP->GPP CHNL Transfer - Actual transfer of buffer is going to take place */ FALSE, /* DGCHNLXFERCOMPL : DSP->GPP CHNL Transfer - Buffer transfer is complete */ FALSE, /* DGCHNLRECLPEND : DSP->GPP CHNL Transfer - RECLAIM: Wait on a semaphore */ FALSE, /* DGCHNLRECLPOST : DSP->GPP CHNL Transfer - RECLAIM: Posting the Semaphore */ 10, /* MSGIDRANGESTART : MSG ID range: lower limit */ 20 /* MSGIDRANGEEND : MSG ID range: upper limit */ } ; /** ============================================================================ * @name LINKCFG_linkDrvObjects * * @desc Array of Link driver objects in the system. * ============================================================================ */ STATIC LINKCFG_LinkDrv LINKCFG_linkDrvObjects [] = { { "SHMDRV", /* NAME : Name of the link driver */ DRVHANDSHAKEPOLLCOUNT, /* HSHKPOLLCOUNT : Poll value for which handshake waits (-1 if infinite) */ (Uint32) SHAREDENTRYID1, /* MEMENTRY : Memory entry ID (-1 if not needed) */ 0, /* IPSTABLEID : ID of the IPS table used */ sizeof (LINKCFG_ipsTable_00) / sizeof (LINKCFG_Ips), /* IPSENTRIES : Number of IPS supported */ 0, /* POOLTABLEID : ID of the POOL table */ sizeof (LINKCFG_poolTable_00) / sizeof (LINKCFG_Pool), /* NUMPOOLS : Number of POOLs supported */ 0, /* DATATABLEID : ID of the data driver table */ sizeof (LINKCFG_dataTable_00) / sizeof (LINKCFG_DataDrv), /* NUMDATADRV : Number of data drivers supported */ 0, /* MQTID : ID of the MQT */ 0, /* RINGIOTABLEID : RingIO Table Id used for this DSP */ 0, /* MPLISTTABLEID : MpList Table Id used for this DSP */ 0 /* MPCSTABLEID : MPCS Table ID used for this DSP */ }, } ; /** ============================================================================ * @name LINKCFG_dspObjects * * @desc Array of configuration objects for the DSPs in the system. * ============================================================================ */ STATIC LINKCFG_Dsp LINKCFG_dspObject = { "DA8XXGEM", /* NAME : Name of the DSP */ DspArch_C64x, /* ARCHITECTURE : DSP architecture */ "COFF", /* LOADERNAME : Name of the DSP executable loader */ FALSE, /* AUTOSTART : Autostart the DSP (Not supported) */ "DEFAULT.OUT", /* EXECUTABLE : Executable for autostart */ DSP_BootMode_Boot_Pwr, /* DOPOWERCTRL : Link does the Power Ctrl of DSP. */ RESETCTRLADDR, /* RESUMEADDR : Resume address */ RESETCTRLADDR, /* RESETVECTOR : Reset Vector for the DSP */ RESETCTRLSIZE, /* RESETCODESIZE : Size of code at DSP Reset Vector */ 1, /* MADUSIZE : DSP Minimum Addressable Data Unit */ (Uint32) -1, /* CPUFREQ : DSP Frequency (in KHz), -1 if default setting is to be used */ Endianism_Little, /* ENDIAN : DSP Endianism */ FALSE, /* WORDSWAP : Words must be swapped when writing to memory */ 0, /* MEMTABLEID : ID of the memory table used */ sizeof (LINKCFG_memTable_00)/sizeof (LINKCFG_MemEntry), /* MEMENTRIES : Number of entries in memory table */ 0, /* LINKDRVID : ID of the link driver used */ 0, /* ARG1 : Bus No of PCI card */ 0, /* ARG2 : Slot No of PCI card */ 0, /* ARG3 : DSPLINK Shared memory region for control data structures creation */ 0, /* ARG4 : Unused */ 0 /* ARG5 : Unused */ } ; /** ============================================================================ * @name DA8XXGEM_SHMEM_Config * * @desc DSP/BIOS LINK configuration structure. * ============================================================================ */ LINKCFG_DspConfig DA8XXGEM_SHMEM_Config = { (LINKCFG_Dsp *) &LINKCFG_dspObject, /* DSPOBJECTS : Array of DSP objects */ sizeof (LINKCFG_linkDrvObjects)/sizeof (LINKCFG_LinkDrv), /* NUMLINKDRVS : Number of Link Drviers*/ (LINKCFG_LinkDrv *) LINKCFG_linkDrvObjects, /* LINKDRVOBJECTS : Array of Link Driver objects */ sizeof (LINKCFG_memTables)/sizeof (LINKCFG_MemEntry *), /* NUMMEMTABLES : Number of memory tables */ (LINKCFG_MemEntry **) LINKCFG_memTables, /* MEMTABLES : Array of Memory tables */ sizeof (LINKCFG_ipsTables)/sizeof (LINKCFG_Ips *), /* NUMIPSTABLES : Number of IPS tables */ (LINKCFG_Ips **) LINKCFG_ipsTables, /* IPSTABLES : Array of IPS tables */ sizeof (LINKCFG_poolTables)/sizeof (LINKCFG_Pool *), /* NUMPOOLTABLES : Number of POOL tables */ (LINKCFG_Pool **) LINKCFG_poolTables, /* POOLTABLES : Array of Pool tables */ sizeof (LINKCFG_dataTables)/sizeof (LINKCFG_DataDrv *), /* NUMDATATABLES : Number of data tables */ (LINKCFG_DataDrv **) LINKCFG_dataTables, /* DATATABLES : Array of data tables */ sizeof (LINKCFG_mqtObjects)/sizeof (LINKCFG_Mqt), /* NUMMQTS : Number of MQTs */ (LINKCFG_Mqt *) LINKCFG_mqtObjects, /* MQTOBJECTS : Array of MQT objects */ sizeof (LINKCFG_ringIoObjects)/sizeof (LINKCFG_RingIo), /* NUMRINGIOTABLES: Number of RINGIO tables */ (LINKCFG_RingIo *) LINKCFG_ringIoObjects, /* RINGIOOBJECTS : Array of RINGIO objects */ sizeof (LINKCFG_mplistObjects)/sizeof (LINKCFG_MpList), /* NUMMPLISTTABLES: Number of MPLIST tables */ (LINKCFG_MpList *) LINKCFG_mplistObjects, /* MPLISTOBJECTS : Array of MPLIST objects */ sizeof (LINKCFG_mpcsObjects)/sizeof (LINKCFG_Mpcs), /* NUMMPCSTABLES : Number of MPCS tables */ (LINKCFG_Mpcs *) LINKCFG_mpcsObjects, /* MPCSOBJECTS : Array of MPCS objects */ (LINKCFG_Log *) &LINKCFG_logObject, /* LOGOBJECT : Pointer to LOG object */ } ; #if defined (__cplusplus) } #endif /* defined (__cplusplus) */
/** ============================================================================ * @file dsplink-omapl138gem-base.tci * * @path $(DSPLINK)/dsp/inc/DspBios/5.XX/OMAPL138GEM/ * * @desc This file defines base configuration for DSP/BIOS LINK. * * @ver 1.65.01.05_eng * ============================================================================ * Copyright (C) 2002-2009, Texas Instruments Incorporated - * http://www.ti.com/ * * Redistribution and use in source and binary forms, with or without * modification, are permitted provided that the following conditions * are met: * * * Redistributions of source code must retain the above copyright * notice, this list of conditions and the following disclaimer. * * * Redistributions in binary form must reproduce the above copyright * notice, this list of conditions and the following disclaimer in the * documentation and/or other materials provided with the distribution. * * * Neither the name of Texas Instruments Incorporated nor the names of * its contributors may be used to endorse or promote products derived * from this software without specific prior written permission. * * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. * ============================================================================ */ /* ============================================================================ * Load assert support * ============================================================================ */ utils.importFile("assert.tci"); /* ============================================================================ * Load base TCI file. * ============================================================================ */ utils.loadPlatform("ti.platforms.evmOMAPL138") ; /* ============================================================================ * Enable common BIOS features used by all examples * ============================================================================ */ bios.disableRealTimeAnalysis(prog); bios.enableMemoryHeaps(prog); bios.disableRtdx(prog); bios.enableTskManager(prog); /* ============================================================================ * GBL * ============================================================================ */ prog.module("GBL").ENABLEALLTRC = false ; prog.module("GBL").PROCID = parseInt (arguments [0]) ; prog.module("GBL").C64PLUSCONFIGURE = true ; prog.module("GBL").C64PLUSL2CFG = "32k" ; prog.module("GBL").C64PLUSL1DCFG = "32k" ; prog.module("GBL").C64PLUSMAR192to223 = 0x00000008 ; /* ============================================================================ * MEM * ============================================================================ */ prog.module("MEM").STACKSIZE = 0x1000 ; /* ============================================================================ * MEM : RESET_VECTOR * ============================================================================ */ var RESET_VECTOR = prog.module("MEM").create("RESET_VECTOR"); RESET_VECTOR.base = 0xC7000000 ; RESET_VECTOR.len = 0x00000080; RESET_VECTOR.space = "code/data"; RESET_VECTOR.createHeap = false; RESET_VECTOR.comment = "RESET_VECTOR"; /* ============================================================================ * MEM : DDR * ============================================================================ */ var DDR = prog.module("MEM").instance("DDR"); DDR.base = RESET_VECTOR.base + RESET_VECTOR.len ; DDR.len = 0x03FFFF80; DDR.space = "code/data"; DDR.createHeap = true; DDR.heapSize = 0x2000000; DDR.comment = "DDR"; /* ============================================================================ * MEM : DSPLINKMEM * ============================================================================ */ var DSPLINKMEM = prog.module("MEM").create("DSPLINKMEM"); DSPLINKMEM.base = DDR.base + DDR.len; DSPLINKMEM.len = 0x02400000; DSPLINKMEM.createHeap = false; DSPLINKMEM.comment = "DSPLINKMEM"; /* ============================================================================ * MEM : POOLMEM * ============================================================================ */ var POOLMEM = prog.module("MEM").create("POOLMEM"); POOLMEM.base = DSPLINKMEM.base + DSPLINKMEM.len ; POOLMEM.len = 0x01000000 ; POOLMEM.createHeap = false; POOLMEM.comment = "POOLMEM"; /* ============================================================================ * MEM : IRAM * ============================================================================ */ var IRAM = prog.module("MEM").instance("IRAM"); IRAM.base = 0x11800000 ; IRAM.len = 0x8000 ;
/* --COPYRIGHT--,BSD * Copyright (c) 2010, Texas Instruments Incorporated * * Redistribution and use in source and binary forms, with or without * modification, are permitted provided that the following conditions * are met: * * * Redistributions of source code must retain the above copyright * notice, this list of conditions and the following disclaimer. * * * Redistributions in binary form must reproduce the above copyright * notice, this list of conditions and the following disclaimer in the * documentation and/or other materials provided with the distribution. * * * Neither the name of Texas Instruments Incorporated nor the names of * its contributors may be used to endorse or promote products derived * from this software without specific prior written permission. * * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. * --/COPYRIGHT--*/ /* PSP driver libraries */ /* -l"ti/pspiom/platforms/evmOMAPL138/audio/lib/Release/ti.pspiom.platforms.evmOMAPL138.audio.a674" */ -l"ti/pspiom/platforms/codec/lib/OMAPL138/Release/ti.pspiom.platforms.codec.a674" -l"ti/pspiom/i2c/lib/OMAPL138/Release/ti.pspiom.i2c.a674" -l"ti/pspiom/mcasp/lib/OMAPL138/Release/ti.pspiom.mcasp.a674" -l"ti/pspiom/psc/lib/OMAPL138/Release/ti.pspiom.psc.a674" -l"ti/pspiom/platforms/evmOMAPL138/lib/Release/ti.pspiom.platforms.evmOMAPL138.evmInit.a674" /* EDMA3 LLD libraries */ -l"ti/sdo/edma3/drv/lib/Release/edma3_drv_bios_c674.lib" -l"ti/sdo/edma3/rm/lib/omapl138/Release/edma3_rm_bios.lib" -l"ti/sdo/edma3/drv/sample/lib/omapl138/Release/edma3_drv_bios_sample.lib" /* DSP/BIOS LINK libraries */ -l"dsp/export/BIN/DspBios/OMAPL138/OMAPL138GEM_0/RELEASE/dsplink.lib" -l"dsp/export/BIN/DspBios/OMAPL138/OMAPL138GEM_0/RELEASE/dsplinkdata.lib" -l"dsp/export/BIN/DspBios/OMAPL138/OMAPL138GEM_0/RELEASE/dsplinkmpcs.lib" -l"dsp/export/BIN/DspBios/OMAPL138/OMAPL138GEM_0/RELEASE/dsplinkmplist.lib" -l"dsp/export/BIN/DspBios/OMAPL138/OMAPL138GEM_0/RELEASE/dsplinkpool.lib" -l"dsp/export/BIN/DspBios/OMAPL138/OMAPL138GEM_0/RELEASE/dsplinkringio.lib" -l"dsp/export/BIN/DspBios/OMAPL138/OMAPL138GEM_0/RELEASE/dsplinknotify.lib" -l"dsp/export/BIN/DspBios/OMAPL138/OMAPL138GEM_0/RELEASE/dsplinkmsg.lib" SECTIONS { .data:DSPLINK_shmBaseAddress: fill=0xCB400000 {} > DDR }
On my board, there is 256MB Memory.
I trouble it for some times!
Can you tell me what should I do?
Thanks very much!
