Can you help me?I countered the follwing problems when I run a syslink example,I donn't the reason.The full print information is following:
root@seed:~/run# insmod syslink.ko TRACE=1 TRACEFAILURE=1 TRACECLASS=3
SysLink version : 2.21.02.10
SysLink module created on Date:Mar 5 2015 Time:13:19:05
Trace enabled
Trace SetFailureReason enabled
Trace class 3
MemoryOS_map: pa=0x1c00000, va=0xfec00000, sz=0x400000
root@seed:~/run# ./run.sh
+ ./slaveloader startup DSP server_dsp.xe674
MultiProc Module already initialized!
NameServer Module already initialized!
SharedRegion Module already initialized!
GateMP Module already initialized!
Notify Module already initialized!
MessageQ Module already initialized!
HeapBufMP Module already initialized!
HeapMemMP Module already initialized!
ListMP Module already initialized!
ClientNotifyMgr Module already initialized!
FrameQBufMgr Module already initialized!
FrameQ Module already initialized!
ProcMgr_getProcInfo: bootMode: [0]
MemoryOS_map: entry already exists
mapInfo->src [0x1c00000]
mapInfo->dst [0xfec00000]
mapInfo->size [0x400000]
OMAPL1XXPROC_attach: Mapping memory regions
OMAPL1XXPROC_attach: slave is now in reset
OsalDrv_mmap(): setting cache disabled for physical address 11800000
OsalDrv_mmap(): setting cache disabled for physical address 11f00000
Attached to slave procId 0.
Loading procId 0.
DLOAD: ELF: ELF
DLOAD: ELF file header entry point: c3430c00
target_address=0xc3000000
memsz_in_bytes=0x3c1830
objsz_in_bytes=0x3c1830
translated 0xc3000000 (sva) to 0xc3000000 (mpa)
MemoryOS_map: pa=0xc3000000, va=0xc3400000, sz=0x3c1830
_ProcMgr_map for SlaveVirt:
dstAddr [0xc3000000]
sgList.paddr [0xc3000000]
sgList.offset [0x0]
sgList.size [0x3c1830]
target_address=0xc33c1830
memsz_in_bytes=0x10
objsz_in_bytes=0x10
translated 0xc33c1830 (sva) to 0xc33c1830 (mpa)
MemoryOS_map: pa=0xc33c1830, va=0xc32e4830, sz=0x10
dstAddr [0xc33c1000]
sgList.paddr [0xc33c1000]
sgList.offset [0x830]
sgList.size [0x840]
target_address=0xc33c1840
memsz_in_bytes=0x389c0
objsz_in_bytes=0x389c0
translated 0xc33c1840 (sva) to 0xc33c1840 (mpa)
MemoryOS_map: pa=0xc33c1840, va=0xc3300840, sz=0x389c0
sgList.offset [0x840]
sgList.size [0x39200]
target_address=0xc33fa200
memsz_in_bytes=0x30c64
objsz_in_bytes=0x30c64
translated 0xc33fa200 (sva) to 0xc33fa200 (mpa)
MemoryOS_map: pa=0xc33fa200, va=0xc3340200, sz=0x30c64
dstAddr [0xc33fa000]
sgList.paddr [0xc33fa000]
sgList.offset [0x200]
sgList.size [0x30e64]
target_address=0xc342ae68
memsz_in_bytes=0x4bac
objsz_in_bytes=0x4bac
translated 0xc342ae68 (sva) to 0xc342ae68 (mpa)
MemoryOS_map: pa=0xc342ae68, va=0xc32f0e68, sz=0x4bac
dstAddr [0xc342a000]
sgList.paddr [0xc342a000]
sgList.offset [0xe68]
sgList.size [0x5a14]
target_address=0xc342fa18
memsz_in_bytes=0x1120
objsz_in_bytes=0x1120
translated 0xc342fa18 (sva) to 0xc342fa18 (mpa)
MemoryOS_map: pa=0xc342fa18, va=0xc32fca18, sz=0x1120
dstAddr [0xc342f000]
sgList.paddr [0xc342f000]
sgList.offset [0xa18]
sgList.size [0x1b38]
target_address=0xc3430b38
memsz_in_bytes=0x84
objsz_in_bytes=0x84
translated 0xc3430b38 (sva) to 0xc3430b38 (mpa)
MemoryOS_map: pa=0xc3430b38, va=0xc3374b38, sz=0x84
dstAddr [0xc3430000]
sgList.paddr [0xc3430000]
sgList.offset [0xb38]
sgList.size [0xbbc]
target_address=0xc3430bbc
memsz_in_bytes=0x8
objsz_in_bytes=0x8
translated 0xc3430bbc (sva) to 0xc3430bbc (mpa)
MemoryOS_map: pa=0xc3430bbc, va=0xc337abbc, sz=0x8
sgList.offset [0xbbc]
sgList.size [0xbc4]
target_address=0xc3430bc4
memsz_in_bytes=0x28
objsz_in_bytes=0x28
translated 0xc3430bc4 (sva) to 0xc3430bc4 (mpa)
MemoryOS_map: pa=0xc3430bc4, va=0xc3380bc4, sz=0x28
sgList.offset [0xbc4]
sgList.size [0xbec]
target_address=0xc3430c00
memsz_in_bytes=0x200
objsz_in_bytes=0x200
translated 0xc3430c00 (sva) to 0xc3430c00 (mpa)
MemoryOS_map: pa=0xc3430c00, va=0xc3386c00, sz=0x200
sgList.offset [0xc00]
sgList.size [0xe00]
target_address=0xc3430e00
memsz_in_bytes=0x64
objsz_in_bytes=0x64
translated 0xc3430e00 (sva) to 0xc3430e00 (mpa)
MemoryOS_map: pa=0xc3430e00, va=0xc338ce00, sz=0x64
sgList.offset [0xe00]
sgList.size [0xe64]
target_address=0xc3431000
memsz_in_bytes=0x8c
objsz_in_bytes=0x8c
translated 0xc3431000 (sva) to 0xc3431000 (mpa)
MemoryOS_map: pa=0xc3431000, va=0xc3392000, sz=0x8c
dstAddr [0xc3431000]
sgList.paddr [0xc3431000]
sgList.offset [0x0]
sgList.size [0x8c]
Loaded file serv OMAPL1XXPROC_start: Configuring boot register
Reset vector [0xc3430c00]!
er_dsp.xe674 on slave procId 0.
OMAPL1XXPROC_start: Slave successfuly started
[INFO |main@app/main_dsp.c,Started slave procId 0.
84] --> main:
[INFO |message_loop_fun@app/main_dsp.c,24] --> message_loop_fun:
_NotifyDrv: Termination packet
+ ./ad_sample DSP
---> main:
ElfLoader_getSymbolAddress: symName [_Ipc_ResetVector]
ProcMgr_translateAddr: srcAddr [0xc3431000] dstAddr [0xc3392000]
ProcMgr_translateAddr: srcAddr [0xc343101c] dstAddr [0xc339201c]
handle->slaveSRCfg[0].entryBase c2000000
Platform_loadCallback:
No SharedRegion.entry[0].cacheEnable configuration value found, using default FALSE
Mapping SharedRegion 0
addr[ProcMgr_AddrType_MasterPhys] [0xc2000000]
addr[ProcMgr_AddrType_SlaveVirt] [0xc2000000]
size [0x10000]
isCached [0]
MemoryOS_map: pa=0xc2000000, va=0xc33e0000, sz=0x10000
dstAddr [0xc2000000]
sgList.paddr [0xc2000000]
sgList.offset [0x0]
sgList.size [0x10000]
handle->slaveSRCfg[1].entryBase c2010000
No SharedRegion.entry[1].cacheEnable configuration value found, using default FALSE
Mapping SharedRegion 1
addr[ProcMgr_AddrType_MasterPhys] [0xc2010000]
addr[ProcMgr_AddrType_SlaveVirt] [0xc2010000]
size [0xa00000]
isCached [0]
MemoryOS_map: pa=0xc2010000, va=0xc4000000, sz=0xa00000
dstAddr [0xc2010000]
sgList.paddr [0xc2010000]
sgList.offset [0x0]
sgList.size [0xa00000]
Ipc_attach: Ipc_procSyncStart failed!
NotifyDriverShm_registerEvent
Added entry in regChart: [0]
JFFS2 notice: (702) check_node_data: wrong data CRC in data node at 0x18fd73a8: read 0x9a869f04, calculated 0xf8e3969d.
[INFO OsalDrv_mmap(): setting cache disabled for physical address c2000000
|message_loop_start@aOsalDrv_mmap(): setting cache disabled for physical address c2010000
pp/message_loop.c,144] message loop start
[INFO |message_loop_start@app/message_loo MessageQ_create: Max number of queues 32
p.c,148] wait for cmd
NameServer_getLocal name [MSG_QUEUE_NAME_SLAVE]
NameServer_getLocal: Entry not found!
ISR handled
ISR handled
MessageQ_open ioctl queueId [0x0]
NameServer_getLocal name [RING_BUFFER]
ISR handled
ISR handled
Failed to get value from remote NameServer
Added entry in regChart: [2]
[DEBUG|RingBuffer@ring_buffer.cpOsalSemaphore_pend: Semaphore pend interrupted
[INFO | Handle [0xc33a4000]
mes
sagp,33] RING_BUFFER is ready
[INFO |enable_fft@controler.cpp,23] enable fft
ad_sample: sample_receiver.cpp:33: vElfLoader_getSymbolAddress: symName [_Ipc_ResetVector]
e_looid SampleReceiver::stop(): Assertion `m_running' failed.
op_on_enable_fft@app/meProcMgr_translateAddr: srcAddr [0xc3431000] dstAddr [0xc3392000]
ssage_loop.c,106] recv enable fft
[FATAL|ipc_ring_buffer_new@ipc/ipc_ring_buffer.c,34] fail to open ring buffer RING_BUFFEProcMgr_translateAddr: srcAddr [0xc3431000] dstAddr [0xc3392000]
R
JFFS2 notice: (702) check_node_data: wrong data CRC in data node at 0x0afe736c: read 0xeec8c820, calculated 0xbf85b427.
JFFS2 notice: (702) check_node_data: wrong data CRC in data node at 0x0362e700: read 0xa7f1d130, calculated 0x9d47d205.
JFFS2 notice: (702) check_node_data: wrong data CRC in data node at 0x0e7cffb8: read 0x926ad7b1, calculated 0x6ede8a77.
*** Platform_stopCallback: Ipc_stop timeout - Ipc_stop not called by slave?
Error [0xffffffff] at Line no: 2366 in file /home/tl/ti/syslink_2_21_02_10/packages/ti/syslink/utils/hlos/knl/Linux/../../../../../../ti/syslink/family/hlos/knl/omapl1xx/Platform.c
_ProcMgr_unmap check:
unmapType [0x5]
srcAddrType [0x2]
mme->info.addr [ProcMgr_AddrType_MasterPhys] [0xc2000000]
mme->info.addr [ProcMgr_AddrType_SlaveVirt] [0xc2000000]
mme->info.addr [ProcMgr_AddrType_MasterKnlVirt] [0xc33e0000]
MemoryOS_unmap:
info->mappedAddress [0xc4000000]
unmapInfo->addr [0xc33e0000]
MemoryOS_unmap:
info->mappedAddress [0xc33e0000]
unmapType [0x5]
srcAddrType [0x2]
mme->info.addr [ProcMgr_AddrType_MasterPhys] [0xc2010000]
mme->info.addr [ProcMgr_AddrType_SlaveVirt] [0xc2010000]
mme->info.addr [ProcMgr_AddrType_MasterKnlVirt] [0xc4000000]
MemoryOS_unmap:
unmapInfo->addr [0xc4000000]
OMAPL1XXPROC_stop: Slave is now in reset
*** Notify_enableEvent: Notify driver not registered
Error [0xfffffff9] at Line no: 1200 in file /home/tl/ti/syslink_2_21_02_10/packages/ti/syslink/utils/hlos/knl/Linux/../../../../../../ti/syslink/ipc/hlos/knl/Notify.c
Aborted
+ ./slaveloader shutdown DSP
OsalDrv_mmap(): setting cache disabled for physical address c3000000
OsalDrv_mmap(): setting cache disabled for physical address c33c1000
OsalDrv_mmap(): setting cache disabled for physical address c33fa000
OsalDrv_mmap(): setting cache disabled for physical address c342a000
OsalDrv_mmap(): setting cache disabled for physical address c342f000
OsalDrv_mmap(): setting cache disabled for physical address c3430000
OsalDrv_mmap(): setting cache disabled for physical address c3431000
Stopped slave procId 0.
Unloaded slave procId 0.
unmapType [0x0]
srcAddrType [0x2]
mme->info.addr [ProcMgr_AddrType_MasterPhys] [0x11800000]
mme->info.addr [ProcMgr_AddrType_SlaveVirt] [0x11800000]
mme->info.addr [ProcMgr_AddrType_MasterKnlVirt] [0x0]
unmapType [0x0]
srcAddrType [0x2]
mme->info.addr [ProcMgr_AddrType_MasterPhys] [0x11f00000]
mme->info.addr [ProcMgr_AddrType_SlaveVirt] [0x11f00000]
unmapType [0x5]
srcAddrType [0x2]
mme->info.addr [ProcMgr_AddrType_MasterPhys] [0xc3000000]
mme->info.addr [ProcMgr_AddrType_SlaveVirt] [0xc3000000]
mme->info.addr [ProcMgr_AddrType_MasterKnlVirt] [0xc3400000]
MemoryOS_unmap:
info->mappedAddress [0xc3392000]
unmapInfo->addr [0xc3400000]
MemoryOS_unmap:
info->mappedAddress [0xc338ce00]
MemoryOS_unmap:
info->mappedAddress [0xc3386c00]
MemoryOS_unmap:
info->mappedAddress [0xc3380bc4]
MemoryOS_unmap:
info->mappedAddress [0xc337abbc]
MemoryOS_unmap:
info->mappedAddress [0xc3374b38]
MemoryOS_unmap:
info->mappedAddress [0xc32fca18]
MemoryOS_unmap:
info->mappedAddress [0xc32f0e68]
MemoryOS_unmap:
info->mappedAddress [0xc3340200]
MemoryOS_unmap:
info->mappedAddress [0xc3300840]
MemoryOS_unmap:
info->mappedAddress [0xc32e4830]
MemoryOS_unmap:
info->mappedAddress [0xc3400000]
unmapType [0x5]
srcAddrType [0x2]
mme->info.addr [ProcMgr_AddrType_MasterPhys] [0xc33c1830]
mme->info.addr [ProcMgr_AddrType_SlaveVirt] [0xc33c1830]
mme->info.addr [ProcMgr_AddrType_MasterKnlVirt] [0xc32e4830]
MemoryOS_unmap:
unmapInfo->addr [0xc32e4830]
MemoryOS_unmap:
MemoryOS_unmap:
MemoryOS_unmap:
MemoryOS_unmap:
MemoryOS_unmap:
MemoryOS_unmap:
MemoryOS_unmap:
MemoryOS_unmap:
MemoryOS_unmap:
MemoryOS_unmap:
unmapType [0x5]
srcAddrType [0x2]
mme->info.addr [ProcMgr_AddrType_MasterPhys] [0xc33c1840]
mme->info.addr [ProcMgr_AddrType_SlaveVirt] [0xc33c1840]
mme->info.addr [ProcMgr_AddrType_MasterKnlVirt] [0xc3300840]
MemoryOS_unmap:
unmapInfo->addr [0xc3300840]
MemoryOS_unmap:
MemoryOS_unmap:
MemoryOS_unmap:
MemoryOS_unmap:
MemoryOS_unmap:
MemoryOS_unmap:
MemoryOS_unmap:
MemoryOS_unmap:
MemoryOS_unmap:
unmapType [0x5]
srcAddrType [0x2]
mme->info.addr [ProcMgr_AddrType_MasterPhys] [0xc33fa200]
mme->info.addr [ProcMgr_AddrType_SlaveVirt] [0xc33fa200]
mme->info.addr [ProcMgr_AddrType_MasterKnlVirt] [0xc3340200]
MemoryOS_unmap:
unmapInfo->addr [0xc3340200]
MemoryOS_unmap:
MemoryOS_unmap:
MemoryOS_unmap:
MemoryOS_unmap:
MemoryOS_unmap:
MemoryOS_unmap:
MemoryOS_unmap:
MemoryOS_unmap:
unmapType [0x5]
srcAddrType [0x2]
mme->info.addr [ProcMgr_AddrType_MasterPhys] [0xc342ae68]
mme->info.addr [ProcMgr_AddrType_SlaveVirt] [0xc342ae68]
mme->info.addr [ProcMgr_AddrType_MasterKnlVirt] [0xc32f0e68]
MemoryOS_unmap:
unmapInfo->addr [0xc32f0e68]
MemoryOS_unmap:
MemoryOS_unmap:
MemoryOS_unmap:
MemoryOS_unmap:
MemoryOS_unmap:
MemoryOS_unmap:
MemoryOS_unmap:
unmapType [0x5]
srcAddrType [0x2]
mme->info.addr [ProcMgr_AddrType_MasterPhys] [0xc342fa18]
mme->info.addr [ProcMgr_AddrType_SlaveVirt] [0xc342fa18]
mme->info.addr [ProcMgr_AddrType_MasterKnlVirt] [0xc32fca18]
MemoryOS_unmap:
unmapInfo->addr [0xc32fca18]
MemoryOS_unmap:
MemoryOS_unmap:
MemoryOS_unmap:
MemoryOS_unmap:
MemoryOS_unmap:
MemoryOS_unmap:
unmapType [0x5]
srcAddrType [0x2]
mme->info.addr [ProcMgr_AddrType_MasterPhys] [0xc3430b38]
mme->info.addr [ProcMgr_AddrType_SlaveVirt] [0xc3430b38]
mme->info.addr [ProcMgr_AddrType_MasterKnlVirt] [0xc3374b38]
MemoryOS_unmap:
unmapInfo->addr [0xc3374b38]
MemoryOS_unmap:
MemoryOS_unmap:
MemoryOS_unmap:
MemoryOS_unmap:
MemoryOS_unmap:
unmapType [0x5]
srcAddrType [0x2]
mme->info.addr [ProcMgr_AddrType_MasterPhys] [0xc3430bbc]
mme->info.addr [ProcMgr_AddrType_SlaveVirt] [0xc3430bbc]
mme->info.addr [ProcMgr_AddrType_MasterKnlVirt] [0xc337abbc]
MemoryOS_unmap:
unmapInfo->addr [0xc337abbc]
MemoryOS_unmap:
MemoryOS_unmap:
MemoryOS_unmap:
MemoryOS_unmap:
unmapType [0x5]
srcAddrType [0x2]
mme->info.addr [ProcMgr_AddrType_MasterPhys] [0xc3430bc4]
mme->info.addr [ProcMgr_AddrType_SlaveVirt] [0xc3430bc4]
mme->info.addr [ProcMgr_AddrType_MasterKnlVirt] [0xc3380bc4]
MemoryOS_unmap:
unmapInfo->addr [0xc3380bc4]
MemoryOS_unmap:
MemoryOS_unmap:
MemoryOS_unmap:
unmapType [0x5]
srcAddrType [0x2]
mme->info.addr [ProcMgr_AddrType_MasterPhys] [0xc3430c00]
mme->info.addr [ProcMgr_AddrType_SlaveVirt] [0xc3430c00]
mme->info.addr [ProcMgr_AddrType_MasterKnlVirt] [0xc3386c00]
MemoryOS_unmap:
unmapInfo->addr [0xc3386c00]
MemoryOS_unmap:
MemoryOS_unmap:
unmapType [0x5]
srcAddrType [0x2]
mme->info.addr [ProcMgr_AddrType_MasterPhys] [0xc3430e00]
mme->info.addr [ProcMgr_AddrType_SlaveVirt] [0xc3430e00]
mme->info.addr [ProcMgr_AddrType_MasterKnlVirt] [0xc338ce00]
MemoryOS_unmap:
unmapInfo->addr [0xc338ce00]
MemoryOS_unmap:
unmapType [0x5]
srcAddrType [0x2]
mme->info.addr [ProcMgr_AddrType_MasterPhys] [0xc3431000]
mme->info.addr [ProcMgr_AddrType_SlaveVirt] [0xc3431000]
mme->info.addr [ProcMgr_AddrType_MasterKnlVirt] [0xc3392000]
MemoryOS_unmap:
unmapInfo->addr [0xc3392000]
OMAPL1XXPROC_detach: Slave processor is now in reset
MemoryOS_unmap:
info->mappedAddress [0xfec00000]
unmapInfo->addr [0xfec00000]
Detached from slave procId 0.
