I have a custom board that use an OMAP-L138 that uses a NAND to store all the data.
I am facing a problem of a card that don't boot, appearing to have some type of corruption on NAND, the board previously booted ok.
I am trying to find a way to dump the contents of the nand to compare with the data saved.
How I can use slh to load a u-boot image to memory (I am using DDR2 on board) and start it?
I have tried to follow this answer [1] but don't quite understand the changes that I need to make. As it is don't work.
I have crossed with a doc [2] that have an Advisory 2.3.24 that can be the problem that I am facing. How can I confirm that? Is there any tool to help on this matter.
Thanks for the time
[1] - https://e2e.ti.com/support/dsp/omap_applications_processors/f/42/p/151906/552578#552578
[2] - www.ti.com/lit/pdf/sprz305
Aníbal
