Dear all,
I found it is hard for me to implement the VLIB_grayscale_morphology function, because I can't understand some of the input arguments:
void VLIB_grayscale_morphology
uint16_t blk_w, //width of input block, in elements (UQ16.0)
uint16_t line_ofst, //offset between input lines, in elements (UQ16.0)
uint16_t blk_h, //height of input block (UQ16.0)
const uint8_t data_ptr[], //input data pointer (UQ8.0)
uint16_t se_w, //width of structuring element block, in elements (UQ16.0)
uint16_t se_h, //height of structuring element block (UQ16.0)
const uint8_t se_ptr[], //structuring element data pointer (UQ8.0)
const uint8_t refl_se_ptr[], //Reflected structuring element data pointer (UQ8.0)
uint8_t scratch1_ptr[], //scratch 1 pointer. Size of this scratch buffer should be equal to input image size (UQ8.0)
uint8_t scratch2_ptr[], //scratch 2 pointer. This scratch buffer is for temproray data storage and it is used only when se_h =1, and all the elements of //structuring element is one and (blk_h - (se_h-1))se_h = 0. Size of this buffer should be 32*se_h (UQ8.0)
uint8_t output_ptr[], //output data pointer (UQ8.0)
uint8_t operation //Operation selection
1. what does the 'line_ofst' mean, don't understand what is the offset and what is the input lines?
2. how to set scratch2_ptr[], don't understand what '(blk_h - (se_h-1))se_h = 0' mean?
Please provide an example to call this function, I would be very appreciated.
