Hi everyone...
I cannot connect to C674XP and ARM9 of OMAP L137 recently and these are the errors,
I have done the SD Config Test, this is the result :
** Using emulation application from directory c:\ccstudio_v3.3\drivers
** Checking for a valid emulator/eZdsp
$$ You are connected to:
$$ EmuProductName=XDS510USB
$$ EmuPortAddr=0x510
$$ EmuPortMode=USB
$$ ProductId=510
$$ ProductVersion=84
** Checking emulator/eZdsp scan connection
** Emulator Test **
$$ EmuPortMode=USB
$$ ProductId=510
** Emulator Scan Test
-- Found JTAG IR length of 6
-- Found 1 JTAG device(s) in the scan chain
$$ EmuPortMode=USB
$$ ProductId=510
This isn't the first time I encountered the errors. Back then, I managed to boot the HPI mode at the board and the board worked well. However after I didn't use the board last week, the errors occurred again and I couldn't use the HPI booting again to make the board worked normal.
Any solution that I can try?
Sorry for bringing this old topic
FYI, I'm using CCS v3.3 and windows7 for the OS
