• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Digital Signal Processors (DSP) » OMAP™ Processors » OMAP-L13x, AM1x and C674x Processors Forum » OMAP-L137/TMS320C6747 FP-Starter Kit DSP/BIOS examples buildable, but not working
Share
OMAP™ Processors
  • Forums
  • Announcements
Options
  • Subscribe via RSS
Resources
  • OMAP-L1x DSP+ARM9™-based Processors Product Folder
  • OMAP3525/30 DSP+ARM Cortex™-A8-based SOCs Product Folder
  • Top OMAPL Wiki Links
  • OMAPL3x Schematic Review Checklist
  • OMAPL13x Boot resources
  • OMAPL Document Resources
  • OMAPL137 Technical reference manual
  • OMAPL138 Technical reference manual
  • OMAPL Boot loader App Notes
  • OMAP-L137/TMS320C6747 FP-Starter Kit DSP/BIOS examples buildable, but not working
    This question is not answered
    Rico Schulze
    Posted by Rico Schulze
    on Jun 25 2010 11:04 AM
    Intellectual480 points
    Hello
    first of all i have to admit that i am completely new to programming a dsp or arm not to mention the hybrid L137.
    I am using CodeComposerStudio v3.3 and the basic examples like "aic3106" or the ones from the ndk worked fine.
    But now i wanted to take a look at the examples of the DSP/BIOS.
    I would like to create 2 tasks by myself, that have to communicate, and searched for an appropriate example.
    To start slowly i opened  a "Basic"-example-program "Hello" for the "evmOMAPL137"
    (directory-path= CCStudio_v3.3/bios_5_33_01/packages/ti/bios/examples/basic/hello/evmOMAPL137 )
    I am able to open and build the example, but after i loaded it to the evm-board and start it, nothing happens.
    I tried some other examples, with the same result. Opening and building works, but after they are started, nothing happens.
    I would appreciate an answer telling me why this is happening, because without any error-Message while building or opening the examples, i do not know where to start searching for my mistake.
    best regards Rico
    OMAP-L137 OMAPL137 OMAP L-137 DSP/BIOS DSP/BIOS programming OMAP L137 DSP/BIOS OMAPL1 OMAPL-137
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • David Friedland
      Posted by David Friedland
      on Jun 25 2010 11:08 AM
      Genius13430 points
      Not sure what you mean by "nothing happens".  The program fails to execute?  You open the User Log, but nothing appears there?
      Report Abuse
      • Reply
    • Rico Schulze
      on Jun 25 2010 13:38 PM
      With "nothing happens" i really want to say that nothing happens, except that the DSP is not in HALT anymore, i suppose all the test-samples i tried out, to prompt something via the standard out-"Window" (or user-log)  of the CCS,  the "Hello world"-example should have showed "hello world" but it did not..
      and i am not sure why .. the only thing that i can see, if i push the "run-button" is that the CPU is not in HALT anymore, but no effect of the program beeing executed is visually shown, even if there was a print in the main-function.
      Report Abuse
      • Reply
    • Rico Schulze
      on Jun 28 2010 09:20 AM
       to clarify the staement more:
      LOG_printf(&trace, "hello world!");
      does not result in showing hello world! ,like it is supposed to, and i am not sure where tosearch for the mistake, because compiling works properly.
      And without the possibility to take a look if, or which task is in progress, i am not able to validate if i understand how multi-tasking works on the OMAP
      Report Abuse
      • Reply
    • Ti Eval
      Posted by Ti Eval
      on Sep 24 2011 10:06 AM
      Intellectual340 points
      Dear Rico,
      it is more than a year ago that you posted this message. Nevertheless, I just ran into the same problem.
      Did you ever find a solution? I have figured out my own explanation: The LOG_printf does only work in combination with
      a real JTAG interface, not with the USB emulator, right?
      HT
      Report Abuse
      • Reply
    • Ti Eval
      Posted by Ti Eval
      on Sep 24 2011 10:28 AM
      Ah, just found the solution: I needed to open a Message Log under DSP/BIOS->Message Log.
      Report Abuse
      • Reply
    • Caio Florentino
      Posted by Caio Florentino
      on May 22 2012 09:19 AM
      Prodigy30 points
      Dear Ti Eval, please help me .... I am working with OMAP-L137/TMS320C6747 Float Point Starter Kit, but I am with some troubles in its use. The code composer V.3.3 does not have the driver for the USB port, so I changed to the code composer v5.0, but it can not run the examples. The following message appears: C674X_0: Trouble Writing Register PC: Error 0x00000006/-1176 Error during: Memory, Register, The IM memory request is not serviced by the HW memory system. This could be caused by the memory address specified does not exist in the specified memory/cache level. I read that you find the solution ... you could explain it to me? Thanks....
      DSP OMAP-L137/TMS320C6747 Float Point Starter Kit
      Report Abuse
      • Reply
    • Caio Florentino
      on Jun 11 2012 22:57 PM
      Prodigy30 points
      dsp omap tms320c4767
      Report Abuse
      • Reply
    • Caio Florentino
      on Jun 11 2012 22:58 PM
      Prodigy30 points
      Dear Rico, please help me .... I am working with OMAP-L137/TMS320C6747 Float Point Starter Kit, but I am with some troubles in its use. The code composer V.3.3 does not have the driver for the USB port, so I changed to the code composer v5.0, but it can not run the examples. The following message appears: C674X_0: Trouble Writing Register PC: Error 0x00000006/-1176 Error during: Memory, Register, The IM memory request is not serviced by the HW memory system. This could be caused by the memory address specified does not exist in the specified memory/cache level. I read that you find the solution ... you could explain it to me? Thanks....
      Report Abuse
      • Reply
    • Vincent Latapie
      Posted by Vincent Latapie
      on Jul 02 2012 16:22 PM
      Prodigy245 points
      Hi Caio,
      the problem may be than both ccs versions are not compatible for the samples/examples.
      The examples provided with OMA L137 Starter Kit are designed for DSP/BIOS 5.X and DspLink whereas CCS V5 considers DSP/BIOS 6.X and SysLink.
      You may convert your DSP/BIOS 5.X project into DSP/BIOS 6.X but SysLink is not supported by OMAP L137...
      Report Abuse
      • Reply
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
