My customer have created board using OMAP-L138.
However, even though they do not use SATA, they have configured SATA_VDDR pin to supply 1.8V.
If we do not use SATA, it is written in the datasheet that the SATA_VDDR pin should be No Connect.
My customer make SATA pins as configured on the data sheet other than the SATA_VDDR pin .
Is there any problem with this configuration?
Should they change to No Connect?
I would be grateful if you could reply.
Miyashiro
