Other Parts Discussed in Thread: OMAP-L138, PMP, TEST2, CC2500
Tool/software: Linux
So we're starting to see a bunch of units in the field that have been returning with WAY too many 'mtd->read() returned ECC error' messages. An example is listed below.
When the unit has this many errors, it simply fails to run our application code and is then RMA'ed.
Any help and/or suggestions would be greatly appreciated. Here's the console port output from one returned unit.
OMAP-L138 initialization passed!
Booting TI User Boot Loader
UBL Version: 1.65
UBL Flashtype: NAND
Starting NAND Copy...
Valid magicnum, 0x55424CBB, found in block 0x00000006.
DONE
Jumping to entry point at 0xC1080000.
NAND: 512 MiB
MMC: davinci: 0
Bad block table found at page 262080, version 0x01
Bad block table found at page 262016, version 0x01
In: serial
Out: serial
Err: serial
i2c_read(): called with chip:80 addr:0x7f00 alen:2 len:6
Default using MAC address from environment
Net: DaVinci-EMAC
Hit any key to stop autoboot: 0
U-Boot > printenv
baudrate=115200
bootargs=davinci_emac.eth=28:c7:18:ff:00:f0 mem=128M console=ttyS2,115200n8 root=/dev/mtdblock4 rw rootfstype=jffs2
bootcmd=nand read.e 0xc1180000 0x400000 0x400000; nboot.e 0xc0700000 0 0x200000; bootm
bootdelay=3
bootfile=uImage_2.6.33
ethact=DaVinci-EMAC
ethaddr=28:c7:18:ff:00:f0
gatewayip=169.254.100.1
hw_version=1.1
ipaddr=169.254.100.208
netmask=255.255.255.0
nfshost=169.254.100.1
serverip=169.254.100.1
stderr=serial
stdin=serial
stdout=serial
ver=U-Boot 2012.04.01-00025-g9f45257-dirty (Jul 29 2014 - 12:12:50)
xxx=0
Environment size: 581/131068 bytes
U-Boot > boot
NAND read: device 0 offset 0x400000, size 0x400000
NAND read from offset 400000 failed -74
0 bytes read: ERROR
Loading from nand0, offset 0x200000
Image Name: Linux-2.6.33-rc4
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 2011412 Bytes = 1.9 MiB
Load Address: c0008000
Entry Point: c0008000
## Booting kernel from Legacy Image at c0700000 ...
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kerneli - bgg.
bgg - start_kernel before smp_setup_processor_id..
bgg - start_kernel before lock_kernel..
bgg - start_kernel before tick_init..
bgg - start_kernel before boot_cpu_init..
bgg - start_kernel before page_address_init..
bgg - in asmlinkage before printing linx version....
Linux version 2.6.33-rc4 (bgoetz@volta.altierre.com) (gcc version 4.3.3 (Sourcery G++ Lite 2009q1-203) ) #20 PREEMPT Fri Jan 7 13:54:47 PST 2011
CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177
CPU: VIVT data cache, VIVT instruction cache
Machine: DaVinci DA850/OMAP-L138/AM18xx EVM
Memory policy: ECC disabled, Data cache writeback
bgg beginning of davinci_common_init
bgg after first if stmt..
DaVinci da850/omap-l138/am18xx variant 0x1
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512
Kernel command line: davinci_emac.eth=28:c7:18:ff:00:f0 mem=128M console=ttyS2,115200n8 root=/dev/mtdblock4 rw rootfstype=jffs2
PID hash table entries: 512 (order: -1, 2048 bytes)
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 128MB = 128MB total
Memory: 125680KB available (3576K code, 303K data, 116K init, 0K highmem)
SLUB: Genslabs=11, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Hierarchical RCU implementation.
NR_IRQS:245
Console: colour dummy device 80x30
Calibrating delay loop... 149.50 BogoMIPS (lpj=747520)
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
DaVinci: 144 gpio irqs
NET: Registered protocol family 16
bgg beginning of da850_evm_init.......
Success configuring NAND pins!
bio: create slab <bio-0> at 0
SCSI subsystem initialized
pca953x 1-0020: failed reading register
i2c-gpio i2c-gpio.1: using pins 20 (SDA) and 21 (SCL)
Switching to clocksource timer0_1
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
EMAC: MII PHY configured, RMII PHY will not be functional
Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
JFFS2 version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
SGI XFS with security attributes, large block/inode numbers, no debug enabled
msgmni has been set to 245
io scheduler noop registered (default)
Serial: 8250/16550 driver, 3 ports, IRQ sharing disabled
serial8250.0: ttyS0 at MMIO 0x1c42000 (irq = 25) is a 16550A
serial8250.0: ttyS1 at MMIO 0x1d0c000 (irq = 53) is a 16550A
serial8250.0: ttyS2 at MMIO 0x1d0d000 (irq = 61) is a 16550A
console [ttyS2] enabled
brd: module loaded
loop: module loaded
ahci ahci: forcing PORTS_IMPL to 0x1
ahci ahci: AHCI 0001.0100 32 slots 1 ports 3 Gbps 0x1 impl SATA mode
ahci ahci: flags: ncq sntf pm led clo only pmp pio slum part ccc
scsi0 : ahci
ata1: SATA max UDMA/133 irq 67
bgg start of nand_davinci_probe Chip Select=1 +++++++++++++++++++++++++++++++++++++++++++++
bgg aemif clock rate=25000000 (25000 KH)+++++++++++++++++++++++
bgg just wrote timing, register c8890014 value 0x80
nand_get_flash_type: bgg beginning of routine
bgg2 NAND device: Manufacturer ID: 0x2c, Chip ID: 0xdc (Micron NAND 512MiB 3,3V 8-bit)
Creating 7 MTD partitions on "davinci_nand.1":
0x000000000000-0x000000020000 : "u-boot env"
0x000000020000-0x000000040000 : "UBL"
0x000000040000-0x0000000c0000 : "u-boot"
0x000000200000-0x000000400000 : "kernel"
0x000000400000-0x000001400000 : "filesystem"
0x000001400000-0x000002400000 : "ap4_fs"
0x000002400000-0x000020000000 : "filesystem_large"
davinci_nand davinci_nand.1: controller rev. 2.5
spi_davinci spi_davinci.1: DaVinci SPI driver in EDMA mode
Using RX channel = 18 , TX channel = 19 and event queue = 1
spi_davinci spi_davinci.1: Controller at 0xfef0e000
tun: Universal TUN/TAP device driver, 1.6
tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
console [netcon0] enabled
bgg test2!!! netconsole: network logging started
i2c /dev entries driver
TCP cubic registered
NET: Registered protocol family 17
Clocks: disable unused i2c1
Clocks: disable unused emac
Clocks: disable unused mcasp
Clocks: disable unused lcdc
Clocks: disable unused mmcsd
Clocks: disable unused spi0
Clocks: disable unused mcbsp0
Clocks: disable unused mcbsp1
Clocks: disable unused vpif
*************** MAC is 28:c7:18:ff:0:f0 (28:c7:18:ff:00:f0)
emac-mii: probed
ata1: SATA link down (SStatus 0 SControl 300)
Empty flash at 0x0000fffc ends at 0x00010000
Empty flash at 0x0002fffc ends at 0x00030000
Empty flash at 0x0004fffc ends at 0x00050000
Empty flash at 0x0006fffc ends at 0x00070000
Empty flash at 0x0008fffc ends at 0x00090000
Empty flash at 0x000afffc ends at 0x000b0000
Empty flash at 0x000cfffc ends at 0x000d0000
Empty flash at 0x000efffc ends at 0x000f0000
Empty flash at 0x0010fffc ends at 0x00110000
Empty flash at 0x0012ffc8 ends at 0x00130000
Empty flash at 0x0014fffc ends at 0x00150000
Empty flash at 0x0016fffc ends at 0x00170000
Empty flash at 0x0018fffc ends at 0x00190000
Empty flash at 0x001cfffc ends at 0x001d0000
Empty flash at 0x001efffc ends at 0x001f0000
Empty flash at 0x0020fffc ends at 0x00210000
Empty flash at 0x0022ffc8 ends at 0x00230000
Empty flash at 0x0024ff68 ends at 0x00250000
Empty flash at 0x0026fffc ends at 0x00270000
Empty flash at 0x0028fffc ends at 0x00290000
Empty flash at 0x002aff4c ends at 0x002b0000
Empty flash at 0x002efffc ends at 0x002f0000
Empty flash at 0x0030fffc ends at 0x00310000
Empty flash at 0x0032fffc ends at 0x00330000
Empty flash at 0x0034fffc ends at 0x00350000
Empty flash at 0x0036fffc ends at 0x00370000
Empty flash at 0x0038fffc ends at 0x00390000
mtd->read(0x1ed7c bytes from 0xd21284) returned ECC error
jffs2_scan_inode_node(): CRC failed on node at 0x00d2efd0: Read 0xffffffff, calculated 0x04f74197
Empty flash at 0x00d2f014 ends at 0x00d2f800
jffs2_scan_dirent_node(): Node CRC failed on node at 0x00d317e8: Read 0xffffffff, calculated 0x2980220b
Empty flash at 0x00e31a14 ends at 0x00e32000
Empty flash at 0x00e39020 ends at 0x00e39800
VFS: Mounted root (jffs2 filesystem) on device 31:4.
Freeing init memory: 116K
mtd->read(0x3ec bytes from 0xd27c14) returned ECC error
mtd->read(0x818 bytes from 0xd277e8) returned ECC error
mtd->read(0x22c bytes from 0xd275d4) returned ECC error
mtd->read(0x440 bytes from 0x3afbc0) returned ECC error
mtd->read(0x7bc bytes from 0x3af844) returned ECC error
mtd->read(0x790 bytes from 0x3af870) returned ECC error
INIT: version 2.86 booting
Please wait: booting...
Starting udev
mtd->read(0x1b0 bytes from 0xd27e50) returned ECC error
mtd->read(0x124 bytes from 0xd27edc) returned ECC error
JFFS2 notice: (412) check_node_data: wrong data CRC in data node at 0x00e38e80: read 0xb4250ca5, calculated 0xda0c3099.
mtd->read(0x1a8 bytes from 0xd2ee58) returned ECC error
mtd->read(0x50 bytes from 0xd2e7b0) returned ECC error
mtd->read(0x111 bytes from 0xd2e800) returned ECC error
mtd->read(0x1b0 bytes from 0xd2e650) returned ECC error
mtd->read(0x300 bytes from 0xd2e500) returned ECC error
mtd->read(0x554 bytes from 0xd2daac) returned ECC error
mtd->read(0x120 bytes from 0xd2d6e0) returned ECC error
mtd->read(0x41 bytes from 0xd2d800) returned ECC error
mtd->read(0x274 bytes from 0xd2d58c) returned ECC error
mtd->read(0xdc bytes from 0xd2cf24) returned ECC error
mtd->read(0x80 bytes from 0xd2d000) returned ECC error
mtd->read(0x22c bytes from 0xd2cdd4) returned ECC error
mtd->read(0x84 bytes from 0xd2c77c) returned ECC error
mtd->read(0xc3 bytes from 0xd2c800) returned ECC error
mtd->read(0x1dc bytes from 0xd2c624) returned ECC error
mtd->read(0x34 bytes from 0xd2bfcc) returned ECC error
mtd->read(0x800 bytes from 0xd2c000) returned ECC error
mtd->read(0x134 bytes from 0xd2b6cc) returned ECC error
mtd->read(0x27 bytes from 0xd2b800) returned ECC error
mtd->read(0x284 bytes from 0xd2b57c) returned ECC error
mtd->read(0xcc bytes from 0xd2af34) returned ECC error
mtd->read(0x7c bytes from 0xd2b000) returned ECC error
mtd->read(0x230 bytes from 0xd2add0) returned ECC error
mtd->read(0x78 bytes from 0xd2a788) returned ECC error
mtd->read(0xd6 bytes from 0xd2a800) returned ECC error
mtd->read(0x1d4 bytes from 0xd2a62c) returned ECC error
mtd->read(0x28 bytes from 0xd29fd8) returned ECC error
mtd->read(0x800 bytes from 0xd2a000) returned ECC error
mtd->read(0xa0 bytes from 0xd29760) returned ECC error
mtd->read(0xb5 bytes from 0xd29800) returned ECC error
mtd->read(0x1e8 bytes from 0xd29618) returned ECC error
mtd->read(0x378 bytes from 0xd29488) returned ECC error
mtd->read(0x74 bytes from 0xd28f8c) returned ECC error
mtd->read(0xeb bytes from 0xd29000) returned ECC error
mtd->read(0x1d0 bytes from 0xd28e30) returned ECC error
mtd->read(0x34 bytes from 0xd287cc) returned ECC error
mtd->read(0x800 bytes from 0xd28800) returned ECC error
mtd->read(0x54 bytes from 0x3affac) returned ECC error
mtd->read(0xf4 bytes from 0x3aff0c) returned ECC error
mtd->read(0x6ac bytes from 0x3af954) returned ECC error
mtd->read(0x4f8 bytes from 0x3afb08) returned ECC error
mtd->read(0x44 bytes from 0xd283d4) returned ECC error
mtd->read(0x44 bytes from 0xd287cc) returned ECC error
mtd->read(0x11b bytes from 0xd28fd0) returned ECC error
mtd->read(0x44 bytes from 0xd29324) returned ECC error
mtd->read(0x111 bytes from 0xd297a4) returned ECC error
mtd->read(0x44 bytes from 0xd29fd8) returned ECC error
mtd->read(0x10a bytes from 0xd2a7cc) returned ECC error
mtd->read(0x104 bytes from 0xd2af78) returned ECC error
mtd->read(0x44 bytes from 0xd2b57c) returned ECC error
mtd->read(0x117 bytes from 0xd2b710) returned ECC error
mtd->read(0x44 bytes from 0xd2ba74) returned ECC error
mtd->read(0x44 bytes from 0xd2bfcc) returned ECC error
mtd->read(0x103 bytes from 0xd2c7c0) returned ECC error
mtd->read(0x118 bytes from 0xd2cf68) returned ECC error
mtd->read(0x11d bytes from 0xd2d724) returned ECC error
mtd->read(0x44 bytes from 0xd2e500) returned ECC error
mtd->read(0x11d bytes from 0xd2e7f4) returned ECC error
udev: starting version 141
Remounting root file system...
WARNING: Couldn't open directory /lib/modules/2.6.33-rc4: No such file or directory
FATAL: Could not open /lib/modules/2.6.33-rc4/modules.dep.temp for writing: No such file or directory
modprobe: FATAL: Could not load /lib/modules/2.6.33-rc4/modules.dep: No such file or directory
root: mount: mounting rootfs on / failed: No such file or directory
root: mount: mounting usbfs on /proc/bus/usb failed: No such file or directory
mtd->read(0x3f0 bytes from 0xd2dc10) returned ECC error
mtd->read(0x21c bytes from 0xd295e4) returned ECC error
mtd->read(0x468 bytes from 0xd28398) returned ECC error
mtd->read(0x544 bytes from 0xd27abc) returned ECC error
mtd->read(0x44 bytes from 0xd27abc) returned ECC error
Setting up IP spoofing protection: rp_filter.
Configuring network interfaces... eth0: attached PHY driver [Generic PHY] (mii_bus:phy_addr=1:00, id=7c0f1)
mtd->read(0x6c bytes from 0xd27794) returned ECC error
Received vendorclass: <altierre-sync-002
udhcpc (v1.16.0) started
vendorclas = <altierre-sync-002
Sending discover...
mtd->read(0x1e4 bytes from 0xd27e1c) returned ECC error
mtd->read(0x21c bytes from 0xd27de4) returned ECC error
PHY: 1:00 - Link is Up - 100/Full
Sending discover...
Sending select for 172.20.142.63...
udhcpc: No vendor specific info returned.
NTP Server info sent len: 4
Got NTP server sent = 172.20.122.1
Stopping any/all previously running ntpd threads
sh: you need to specify whom to kill
mtd->read(0x5c4 bytes from 0xd27a3c) returned ECC error
mtd->read(0x44 bytes from 0xd27a3c) returned ECC error
Starting up ntpd client to 172.20.122.1
Successfully wrote /tmp/AAP4.cfg!
Lease of 172.20.142.63 obtained, lease time 691200
adding dns 172.20.120.120
adding dns 172.20.120.220
done.
Thu Apr 12 14:22:00 UTC 2018
INIT: Entering runlevel: 5
Starting syslogd/klogd: done
mtd->read(0x3bc bytes from 0xd27c44) returned ECC error
mtd->read(0x32c bytes from 0xd27cd4) returned ECC error
mtd->read(0x44 bytes from 0xd27cd4) returned ECC error
fixuboot2 version 2.2
EEPROM MAC is: 28:c7:18:ff:00:f0 string: 28:c7:18:ff:00:f0
mtd->read(0xb0 bytes from 0xd27750) returned ECC error
EEPROM MAC matches 'ethaddr' environment variable
EEPROM MAC matches 'bootargs' environment variable
EEPROM MAC matches 'ifconfig' MAC address
All MAC addresses match and 'ip=dhcp' has been removed from bootcmd.
Bringing up the JTAG FPGA driver
Setting up OMAP GPIO pins for JTAG interfaceJTAG FPGA: registered with major=65 ...................
Check the size of accessPoint.xsvf
Program the FPGA with accessPoint.xsvf
Download file /mnt/ap4_fs//accessPoint.xsvf to flash ...
In xsvfInitialize
Initialize done... programming FPGA...
1000 2000 3000 4000 5000 6000 mtd->read(0xf4 bytes from 0xd27f0c) returned ECC error
7000 mtd->read(0x788 bytes from 0xd27078) returned ECC error
mtd->read(0x6c bytes from 0xd26794) returned ECC error
mtd->read(0x655 bytes from 0xd26800) returned ECC error
mtd->read(0x4e8 bytes from 0xd25b18) returned ECC error
mtd->read(0x574 bytes from 0xd26000) returned ECC error
mtd->read(0xf7 bytes from 0xd25800) returned ECC error
mtd->read(0x44 bytes from 0xd26794) returned ECC error
mtd->read(0x4c4 bytes from 0xd27b3c) returned ECC error
mtd->read(0x440 bytes from 0xd27bc0) returned ECC error
mtd->read(0x280 bytes from 0xd27d80) returned ECC error
mtd->read(0x180 bytes from 0xd27e80) returned ECC error
mtd->read(0x57c bytes from 0xd28284) returned ECC error
mtd->read(0x6a8 bytes from 0xd2e958) returned ECC error
mtd->read(0x56c bytes from 0xd2e294) returned ECC error
mtd->read(0x778 bytes from 0xd2d888) returned ECC error
mtd->read(0x73c bytes from 0xd2d0c4) returned ECC error
mtd->read(0x6f8 bytes from 0xd2c908) returned ECC error
mtd->read(0x698 bytes from 0xd2c168) returned ECC error
mtd->read(0x794 bytes from 0xd2b86c) returned ECC error
mtd->read(0x740 bytes from 0xd2b0c0) returned ECC error
mtd->read(0x6e4 bytes from 0xd2a91c) returned ECC error
mtd->read(0x694 bytes from 0xd2a16c) returned ECC error
mtd->read(0x4c8 bytes from 0xd29b38) returned ECC error
mtd->read(0x6d0 bytes from 0xd29130) returned ECC error
mtd->read(0x67c bytes from 0xd28984) returned ECC error
mtd->read(0x79c bytes from 0xd28064) returned ECC error
mtd->read(0x7a4 bytes from 0xd2785c) returned ECC error
mtd->read(0x164 bytes from 0xd26e9c) returned ECC error
mtd->read(0x248 bytes from 0xd265b8) returned ECC error
mtd->read(0x6c4 bytes from 0xd2593c) returned ECC error
mtd->read(0x44 bytes from 0xd2e958) returned ECC error
mtd->read(0x344 bytes from 0xd2e4bc) returned ECC error
mtd->read(0x3bc bytes from 0xd2dc44) returned ECC error
mtd->read(0x44 bytes from 0xd2e4bc) returned ECC error
Done with while loop final count = 7536
Completed the download - SUCCESS.
Processing Time = 31.340 seconds
Bringing up the EMIFA driver
Beginning of setup_emifa
The value of Register PINMUX5 is 0x11110118
The value of Register PINMUX6 is 0x11111111
The value of Register PINMUX7 is 0x11111111
The value of Register PINMUX8 is 0x11111111
The value of Register PINMUX9 is 0x11111111
The value of Register PINMUX10 is 0x11111111
The value of Register PINMUX11 is 0x11111111
The value of Register PINMUX12 is 0x11111111
AWCC: orig value: 0xf0000000 new value: 0xd0100000
CE3CFG(for NAND): 0x80 CE4CFG(for FPGA): 0x3ffffffc
CE4CFG: 0xc881a018: 0x3ffffffc --> 0x7ffffffd
AFPGA: registered with major=63 ...................
Initial setting AFPGA reset to HIGH
Testing gpio 127 (connected to boot pin S0-0)
Setting GPIO RESET to 1
.. RESET done
Bringing up the SPI driver and start the CC2500 clocks
Beginning of main() **************************************************************************
can't set max write speed hzspi mode: 0
bits per word: 8
max speed: 30000000 Hz (30000 KHz)
Final setting AFPGA reset to LOW
Setting GPIO RESET to 0
.. RESET done
2018-04-18 00:01mtd->read(0x57c bytes from 0xd28284) returned ECC error
:55: Sync Servermtd->read(0x44 bytes from 0xd28284) returned ECC error
system booting.
2018-04-18 00:01:55: Starting Sync Server ...
Setting AFPGA reset to HIGH
.. RESET done
Setting AFPGA reset to LOW
.. RESET done
./sync_server_bin Version: 10.12.9
InitGlobals: product_id: 0x0 init_done: 0 from_aap: 1
Unknown parameter: transmission_ready_time=900
enable_radio: DISABLED radio disabled sync flood
File LogLevel.cfg instructed AP to disable radio
From file: /tmp/AAP4.cfg new NTP server is: 172.20.122.1
Apr 12 14:22:00 arago user.notice kernel: jffs2_scan_inode_node(): CRC failed on node at 0x00d2efd0: Read 0xffffffff, calculated 0x04f74197
Apr 12 14:22:00 arago user.notice kernel: jffs2_scan_dirent_node(): Node CRC failed on node at 0x00d317e8: Read 0xffffffff, calculated 0x2980220b
Apr 12 14:22:00 arago user.notice kernel: JFFS2 notice: (412) check_node_data: wrong data CRC in data node at 0x00e38e80: read 0xb4250ca5, calculated 0xda0c3099.
Watchdog circuit is not part of sync server.
beginning of AAP2Main::Init
2018-04-18 00:02:13: Configuring Sync Server ...
_____ _____ _ _
| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
| | _| .'| . | . | | __| _| . | | | -_| _| _|
|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
|___| |___|
Arago Project http://arago-project.org arago ttyS2
Arago 2009.09 arago ttyS2
arago login:
_____ _____ _ _
|___| |___|
arago login:
