I try MIDAS Ultrasound v2.0 Demo (http://processors.wiki.ti.com/index.php/MIDAS_Ultrasound_v2.0_Demo#PSP_and_DVSDK.C2.A0Setup )
I success all complie except Build MIDAS. (Contents 11. Build MIDAS)
I try setup according to the website.
I have try Contents 11. Build MIDAS step 10 - Build the application as follows. ~..
host $ cd ~/midas
host $ make -j8 midas
So, I get a error message blow.
make[1]: Entering directory `/home/won/midas/ultrasound/servers/mud'make[1]: warning: jobserver unavailable: using -j1. Add `+' to parent make rule.rm -rf mud.x64P servers_mud.tar *.obj package package.* *DataSheet.html mud *.mapmake[1]: Leaving directory `/home/won/midas/ultrasound/servers/mud'make[1]: Entering directory `/home/won/midas/ultrasound/servers/mud'make[1]: warning: jobserver unavailable: using -j1. Add `+' to parent make rule.XDCPATH="/home/won//midas/ultrasound;/home/won//midas/ultrasound;/home/won/dvsdk/dvsdk_3_01_00_06/codec_engine_2_25_01_06/packages;/home/won/dvsdk/dvsdk_3_01_00_06/framework_components_2_25_01_05/packages;/home/won/dvsdk/dvsdk_3_01_00_06/dsplink_linux_1_65_00_01/packages;/home/won/dvsdk/dvsdk_3_01_00_06/xdais_6_25_01_08/packages;/home/won/dvsdk/dvsdk_3_01_00_06/cs1omap3530_1_01_00/packages;/home/won/dvsdk/dvsdk_3_01_00_06/bios_5_41_00_06/packages;/home/won/dvsdk/dvsdk_3_01_00_06/biosutils_1_02_02/packages;/packages;/home/won/dvsdk/dvsdk_3_01_00_06/edma3_lld_01_11_00_03/packages;/home/won/dvsdk/dvsdk_3_01_00_06/local_power_manager_linux_1_24_01/packages;/home/won/dvsdk/dvsdk_3_01_00_06/codec_engine_2_25_01_06/packages/ti;/home/won/dvsdk/dvsdk_3_01_00_06/xdais_6_25_01_08/packages/ti/xdais;/home/won//midas/ultrasound/algos/scu;/home/won//midas/ultrasound/algos/bpu;/home/won//midas/ultrasound/algos/dpu;/home/won//midas/ultrasound/algos" /home/won/dvsdk/dvsdk_3_01_00_06/xdctools_3_16_01_27/xs xdc.tools.configuro -c /home/won/dvsdk/dvsdk_3_01_00_06/cg6x_6_0_16 -o mud \ -t ti.targets.C64P -p ti.platforms.evm3530 -b /home/won//midas/ultrasound/servers/serverconfig.bld \ --tcf mud.cfgmaking package.mak (because of package.bld) ...serverconfig.bld: Running the version from midas/ultrasound/serversgenerating interfaces for package mud (because package/package.xdc.inc is older than package.xdc) ...configuring mud.x64P from package/cfg/mud_x64P.cfg ...platform = ti.platforms.evm3530ti.sdo.fc.dskt2: This module no longer supports the .debug or the .trace config params. Set desired profile for all FC modules as follows: xdc.useModule('ti.sdo.fc.global.Settings').profile = "debug" or set profiles for individual packages like this: xdc.loadPackage('ti.sdo.fc.dskt2').profile = "debug"; . Will default the 'release' profile, if no other setti.sdo.ce.ipc.bios.close(): loading dsplink.dspNOTE: You can find the complete server data sheet in ./package/info/mud.x64P.DataSheet.html------------------------------------------------------------------------------------------- will link with dpu:c64P/dpuCEpkg.lib;c64P/utilCEpkg.lib will link with bpu:c64P/bpu.l64P;c64P/utilCEpkg.lib will link with scu:c64P/scu.l64P will link with ti.sdo.ce.universal:lib/release/universal.a64P will link with ti.sdo.ce.bioslog:lib/release/bioslog.a64P will link with ti.sdo.ce:lib/release/ce.a64P will link with ti.sdo.ce.alg:lib/release/Algorithm_BIOS.a64P will link with ti.sdo.ce.ipc.bios:lib/release/ipc_bios.a64P will link with ti.sdo.ce.osal.bios:lib/osal_bios.a64P will link with ti.sdo.ce.osal.bios:lib/osal_bios_pwrm.a64P will link with ti.bios.utils:lib/utils.a64P will link with ti.sdo.fc.acpy3:lib/release/acpy3.a64P will link with ti.sdo.fc.memutils:lib/release/memutils.a64P will link with ti.sdo.fc.dman3:lib/release/dman3Cfg.a64P will link with ti.sdo.fc.dskt2:lib/debug_trace/dskt2.a64P will link with ti.sdo.ce.utils.xdm:lib/release/XdmUtils.a64P will link with ti.sdo.ce.node:lib/release/node.a64P will link with ti.sdo.utils.trace:lib/release/gt.a64Pcl64P package/cfg/mud_x64P.c ...asm64P package/cfg/mud_x64Pcfg.s62 ...cl64P package/cfg/mud_x64Pcfg_c.c .../home/won/dvsdk/dvsdk_3_01_00_06/cg6x_6_0_16 /bin/cl6x -@ mud/compiler.opt -c main.cmake[1]: execvp: /home/won/dvsdk/dvsdk_3_01_00_06/cg6x_6_0_16: Permission deniedmake[1]: *** [main.obj] Error 127make[1]: Leaving directory `/home/won/midas/ultrasound/servers/mud'make: *** [midas] Error 2
dvsdk folder authority is
drwxr-xr-x 26 won won 4096 2012-04-12 11:53 ./drwxr-xr-x 4 won won 4096 2012-04-10 09:52 ../-rwxr-xr-x 1 won won 32316 2012-04-12 13:38 Makefile*-rwxr-xr-x 1 won won 3593 2012-04-13 09:15 Rules.make*drwxr-xr-x 2 won won 4096 2010-04-09 19:35 bin/drwxr-xr-x 5 won won 4096 2010-04-09 19:35 bios_5_41_00_06/drwxr-xr-x 4 won won 4096 2010-04-09 19:35 biosutils_1_02_02/drwxr-xr-x 5 won won 4096 2010-04-09 19:35 ceutils_1_06/drwxr-xr-x 6 won won 4096 2012-04-10 09:56 cg6x_6_0_16/drwxr-xr-x 7 won won 4096 2010-04-09 19:35 cg_xml_v2_12_00/drwxr-xr-x 3 won won 4096 2012-04-10 10:01 clips/drwxr-xr-x 9 won won 4096 2010-04-09 19:35 codec_engine_2_25_01_06/drwxr-xr-x 3 won won 4096 2012-04-10 09:54 cs1omap3530_1_01_00/drwxr-xr-x 4 won won 4096 2010-04-09 19:35 dmai_2_05_00_08/drwxr-xr-x 2 won won 4096 2010-04-09 19:35 docs/drwxr-xr-x 3 won won 4096 2010-04-09 19:35 dsplink_linux_1_65_00_01/drwxr-xr-x 5 won won 4096 2010-04-09 19:36 dvsdk_demos_3_01_00_09/drwxr-xr-x 3 won won 4096 2010-04-09 19:36 dvtb_4_20_04/drwxr-xr-x 6 won won 4096 2010-04-09 19:36 edma3_lld_01_11_00_03/drwxr-xr-x 3 won won 4096 2010-04-09 19:36 examples/drwxr-xr-x 8 won won 4096 2010-04-09 19:36 framework_components_2_25_01_05/drwxr-xr-x 3 won won 4096 2010-04-09 19:36 kernel_binaries/drwxr-xr-x 5 won won 4096 2010-04-09 19:36 linuxlibs_3_01/drwxr-xr-x 7 won won 4096 2010-04-09 19:36 linuxutils_2_25_01_06/drwxr-xr-x 6 won won 4096 2010-04-09 19:36 local_power_manager_linux_1_24_01/-rwxr-xr-x 1 won won 49170 2010-04-09 19:36 omap3530_3_01_release_notes.html*drwxr-xr-x 2 won won 4096 2010-04-09 19:36 targetfs/-rwxr-xr-x 1 won won 1194136 2012-04-10 09:54 uninstall*drwxr-xr-x 9 won won 4096 2010-04-09 19:36 xdais_6_25_01_08/drwxr-xr-x 11 won won 4096 2010-04-09 19:36 xdctools_3_16_01_27/
I input command 'sudo make'.
But I take the same error message.
How can I be able to solve this problem.
Help me.
Thank you.
