• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Digital Signal Processors (DSP) » OMAP™ Processors » OMAP35x Processors Forum » interfacing LPDDR SDRAM to SDRC (OMAP3530)
Share
OMAP™ Processors
  • Forums
  • Announcements
Options
  • Subscribe via RSS
Resources
  • OMAP-L1x DSP+ARM9™-based Processors Product Folder
  • OMAP3525/30 DSP+ARM Cortex™-A8-based SOCs Product Folder
  • Top OMAPL Wiki Links
  • OMAPL3x Schematic Review Checklist
  • OMAPL13x Boot resources
  • OMAPL Document Resources
  • OMAPL137 Technical reference manual
  • OMAPL138 Technical reference manual
  • OMAPL Boot loader App Notes
  • interfacing LPDDR SDRAM to SDRC (OMAP3530)
    This question is not answered
    narasimha reddy72258
    Posted by narasimha reddy72258
    on Jul 25 2012 04:32 AM
    Prodigy200 points
    Dear all,
    am working on OMAP3530, i have selected LPDDR SDRAM of Part number MT46H256M32L4JV-6 IT, below figure shows an block diagram,
    SDRC has 2 CS options and the LPDDR has 2 CS options.
    my question is , OMAP3530 will support this LPDDR SDRAM?
    please help...
    Thanks and Regards
    N Reddy
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • Jethin Sekhar
      Posted by Jethin Sekhar
      on Jul 30 2012 01:30 AM
      Expert1130 points
      Dear narasimha,
      This LPDDR is supported by OMAP
      Please refer section for you configuration in your data sheet mention here
      Figure 10: Dual Rank, Single Channel (4 Die) Package Block Diagram
      Jethin
      Report Abuse
      • Reply
    • narasimha reddy72258
      on Jul 31 2012 01:09 AM
      Prodigy200 points
      Dear Jethin,
      Thank you very much,
      i have to design a customized OMAP3530 board with 8Gbit (1GB) of LPDDR SDRAM and 32 Gbit (4GB) of NAND flash.  as per your advice i will use same LPDDR SDRAM.
      For NAND flash interface, i have selected MT29F16G16ADBCAH4-IT, some
      few  features are . . .
      • Page size x16: 2160 words (2048 + 112 words)
      • Block size: 64 pages (256K + 14K bytes)
      • Device size: 16Gb: 8192 blocks
      • operating Voltage 1.8V
      • 63-ball VFBGA package  etc..
      My question are ...
      1) From OMAP3530 TRM doc, the section 25.4.7.4 NAND (Page Number 3397) shows that " Small page size (512 bytes + 16 bytes) and large page size (2048 bytes + 64 bytes)" but the selected data sheet shows "Page size x16: 2160 words (2048 + 112 words)". the OMAP 3530 will support this kind of NAND flash for Booting ?
      2) From OAMP 3530 TRM doc,  the section 25.4.7.4.1 Initialization and NAND Detection (Page Number 3399) shows the supported NAND flash devices ID's. Is it mandatory that to follow the same device id ? because am not getting exact Device id NAND flash.
      3) The final requirement of NAND flash is 32 Gb, how to interface two NAND flash's of size 16Gb to GPMC?
      Kindly Please help.......
      Thanks and Regards
      N Reddy
      Report Abuse
      • Reply
    • Jethin Sekhar
      on Jul 31 2012 01:31 AM
      Expert1130 points
      Hi Reddy
      Can you please share your datasheet?
      Jethin
      Report Abuse
      • Reply
      on Jul 31 2012 06:35 AM
      Prodigy200 points
      Dear Jethin,
      i am attaching the data sheet for MT29F16G16ADBCAH4-IT,
      Thanks and Regards
      N Reddy
      Report Abuse
      • Reply
      on Jul 31 2012 23:18 PM
      Prodigy200 points
      Dear Jethin,
      Thanks and Regards
      N Reddy
      Report Abuse
      • Reply
    • Jethin Sekhar
      on Aug 01 2012 00:04 AM
      Expert1130 points
      Dear Reddy
      I am not sure about the boot rom support for this nand flash, I have not found any match between the boot rom supported nand list
      Jethin
      Report Abuse
      • Reply
    • Jethin Sekhar
      on Aug 01 2012 00:11 AM
      Expert1130 points
      Reddy,
      But i seems to be detect the first four blocks and give you the details as ID2 and boots.
      Jethin
      Report Abuse
      • Reply
    • babu reddy
      Posted by babu reddy
      on Aug 01 2012 05:20 AM
      Intellectual560 points
      Dear Jethin
      Thanks for your response,
      i have selected another NAND Flash (Part number is MT29F8G08ADBDAH4-IT ), which is 8Gb memory. please let me know wether this will support for booting or not?
      If it supports, then how do i interface 2 or 3 NAND Flash's to GPMC?
      Thanks and Regards
      N Reddy
      Report Abuse
      • Reply
    • Jethin Sekhar
      on Aug 02 2012 00:55 AM
      Expert1130 points
      Dear Reddy,
      this will support by omap
      Jethin
      Report Abuse
      • Reply
    • Jethin Sekhar
      on Aug 02 2012 01:02 AM
      Expert1130 points
      Dear Reddy,
      i have checked and found this nand (MT29F16G16ADBCA) will also supported by omap.
      Jethin
      Report Abuse
      • Reply
      on Aug 02 2012 02:22 AM
      Prodigy200 points
      Dear Jethin
      Thank you very much...
      So i can use MT29F16G16ADBCA for booting as well as data storage device....
      how do i interface 2 NAND Flash's to GPMC to make 4Gbyte?
      actual requirement is 4Gbyte NAND Flash, in that 500Mbyte reserved for Linux OS Storage (Angstrom booting) and remaining can be used as Mass storage device.
      Thanks and Regards
      N Reddy
      Report Abuse
      • Reply
    • Jethin Sekhar
      on Aug 02 2012 02:33 AM
      Expert1130 points
      Dear Reddy,
      You Can use another one chip select for connecting the second nand flash
      Jethin
      Report Abuse
      • Reply
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
