• Join
  • Sign In with my.TI Login
Texas Instruments
  • Products
  • Applications
  • Tools & Software
  • Support & Community
  • Sample & Buy
  • About TI
Sample & Purchase Cart Sample & Purchase Cart
  • Search
  • Advanced
TI E2E™ Community
  • Support Forums
  • Blogs
  • Groups
  • Videos
  • 简体中文
  • More ...
TI Home » TI E2E Community » Support Forums » Digital Signal Processors (DSP) » OMAP™ Processors » OMAP35x Processors Forum » problems with NFS mounting at runtime
Share
OMAP™ Processors
  • Forums
  • Announcements
Options
  • Subscribe via RSS
Resources
  • OMAP-L1x DSP+ARM9™-based Processors Product Folder
  • OMAP3525/30 DSP+ARM Cortex™-A8-based SOCs Product Folder
  • Top OMAPL Wiki Links
  • OMAPL3x Schematic Review Checklist
  • OMAPL13x Boot resources
  • OMAPL Document Resources
  • OMAPL137 Technical reference manual
  • OMAPL138 Technical reference manual
  • OMAPL Boot loader App Notes
  • problems with NFS mounting at runtime
    This question is not answered
    burchmere
    Posted by burchmere
    on Sep 24 2008 10:30 AM
    Intellectual930 points
    I'm trying to mount a directory on my linux host machine from the OMAP35x EVM using NFS and having issues.  I can successfully mount a root filesystem on my host via NFS by setting bootargs_nfs in uboot, so this tells me I must have the /etc/exports correct on host/nfs server.  However, when I try to just do a "mount 192.168.1.123:/home/dir /mnt" I get the following errors...
    rpcbind: server localhost not responding, timeout
    RPC: failed to contact local rpcbind server (errno 5).
    lockd_up: makesock failed, error=-5
    mount: mounting 192.168.1.123:/home/dir on /mnt failed: Input/output error
    Any ideas?  It seems like something simple, but I figured if I could NFS mount my root at boottime, then I should be able to manually NFS mount some other dir as well.
    OMAP35xx Linux NFS
    Report Abuse
    • Reply
    You have posted to a forum that requires a moderator to approve posts before they are publicly available.
    All Replies
    • Juan Gonzales
      Posted by Juan Gonzales
      on Sep 24 2008 11:01 AM
      Mastermind33875 points
      Based on the logs, it appears there are RPC server issues; have you started your ipcbind or portmap services?
      Also, if you search for 'rpcbind errno 5', you are likely to find other related Linux forum posts that may offer solutions to this issue.
      Report Abuse
      • Reply
    • burchmere
      Posted by burchmere
      on Sep 24 2008 11:48 AM
      The problem, apparently, is that when mounting from the client you must either have /sbin/portmap running (which isn't in the stock SDK filesystem) or you must specify the "-o nolock" option on the mount command line.  I used the "-o nolock" and all appears to mount OK.  One other alternative is to put "nolock" in the options portion of an /etc/fstab entry for the nfs mount.
      Thanks.
      Report Abuse
      • Reply
    • Juan Gonzales
      on Sep 24 2008 12:35 PM
      Thank you for sharing this with the community; I am glad to see you have overcomed this issue.
      Report Abuse
      • Reply
    • RobbySun
      Posted by RobbySun
      on Nov 26 2008 19:26 PM
      Intellectual750 points
      Great. I was having eactly the same problem and "mount -o nolock host:/path /mnt" solved it. Thanks for sharing your solution!
      Judging from the error message "rpcbind: server localhost not responding, timed out", rpcbind apparantly was checking localhost as the server. I wonder if adding the Linux host in EVM's /etc/hosts might also solve the problem. This brings up another (probably a very simple) question: how to update the file /etc/hosts on the EVM?
      Report Abuse
      • Reply
    • Bernie Thompson TI
      Posted by Bernie Thompson TI
      on Dec 01 2008 09:25 AM
      Mastermind41680 points
      RobbySun
      You should be able to edit the hosts file directly on the EVM using a terminal based text editor like vi, or if you are using a NFS mount you could edit the file on your host (i.e. \home\user\workdir\filesys\etc\ or wherever you are NFS mounting).
      Report Abuse
      • Reply
    • Vineet
      Posted by Vineet
      on Jan 10 2009 07:16 AM
      Intellectual380 points
      Hi Thompson,
      I am facing the similar issue. I am unable to write anything into NFS directory from my board?How to change the /etc/hosts file which contains the following configuration
      # Do not remove the following line, or various programs
      # that require network functionality will fail.
      127.0.0.1   localhost.localdomain localhost
      Vineet
      Report Abuse
      • Reply
      on Jan 13 2009 15:29 PM
      I am not sure that adding to the hosts file would help, if there was a hosts problem I would expect either intermittent or complete failure of NFS with error messages, since this means you would be disconnected from it, as opposed to just write failures.
      Report Abuse
      • Reply
    • Juan Gonzales
      on Jan 13 2009 16:55 PM
      Try changing your host /etc/exports file as suggested in the following post and see if the permission problems (unable to write) you are experiencing go away
      http://community.ti.com/forums/p/2651/9998.aspx#9998
      Report Abuse
      • Reply
    • José
      Posted by José
      on Apr 01 2010 08:02 AM
      Prodigy180 points
      is it not "mount -o lock" the same as passing to the kernel thru u-boot "root=/dev/nfs nfsroot=$(nfshost):$(rootpath), nolock, ..."?
      In my case, I get nfs running without problems for the first boot. If I then run "init 0" I get the following messages,
      #init 0
      INIT: Switching to runlevel: 0
      INIT: Sending processes the TERM signal
      INIT: SStopping telnet daemon.
      Stopping syslogd/klogd: stopped syslogd (pid 1279)
      stopped klogd (pid 1281)
      done
      NOT deconfiguring network interfaces: / is an NFS mount
      Sending all processes the TERM signal...
      Sending all processes the KILL signal...
      Unmounting remote filesystems...
      Deactivating swap...
      Unmounting local filesystems...
      mount: can't find /mnt/ram in /proc/mounts
      umount: none busy - remounted read-only
      mount: cannot read /proc/mounts: No such file or directory
      nfs: server 10.0.0.114 not responding, still trying
      and it does go down properly. So I reset my EVM and now nfs does not work, in fact, the kernel panics!
      Sending DHCP requests .
      PHY: 1:00 - Link is Up - 100/Full
      ., OK
      IP-Config: Got DHCP answer from 0.0.0.0, my address is 10.0.0.111
      IP-Config: Complete:
           device=eth0, addr=10.0.0.111, mask=255.255.255.0, gw=255.255.255.255,
           host=10.0.0.111, domain=, nis-domain=(none),
           bootserver=0.0.0.0, rootserver=0.0.0.0, rootpath=
      Looking up port of RPC 100003/2 on 0.0.0.0
      rpcbind: server 0.0.0.0 not responding, timed out
      Root-NFS: Unable to get nfsd port number from server, using default
      Looking up port of RPC 100005/1 on 0.0.0.0
      Root-NFS: Unable to get mountd port number from server, using default
      Root-NFS: Server returned error -5 while mounting /tftpboot/$(nfshost):$(rootpath)
      VFS: Unable to mount root fs via NFS, trying floppy.
      VFS: Cannot open root device "nfs" or unknown-block(2,0)
      Please append a correct "root=" boot option; here are the available partitions:
      1f00             512 mtdblock0 (driver?)
      1f01            1792 mtdblock1 (driver?)
      1f02             256 mtdblock2 (driver?)
      1f03            5120 mtdblock3 (driver?)
      1f04          516608 mtdblock4 (driver?)
      b300          498176 mmcblk0 driver: mmcblk
        b301          497983 mmcblk0p1
      Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(2,0)
      I would appreciate any help.
      My /etc/exports is
      /home/jrodrigu/workdir/filesys *(rw,insecure,sync,no_wdelay,no_root_squash,no_subtree_check)
      José
      Report Abuse
      • Reply
      on Apr 01 2010 09:41 AM
      José
      I don't think it should be outputting $(nfshost):$(rootpath) here, it should have resolved to whatever you set nfshost and rootpath to in your U-Boot environment  variables at this point. Try replacing the nfsroot=$(nfshost):$(rootpath) in your bootargs with nfsroot=10.0.0.114:/home/jrodrigu/workdir/filesys to see if that makes any difference (assuming that your NFS server is at 10.0.0.114).
      Report Abuse
      • Reply
    • José
      Posted by José
      on Apr 01 2010 10:51 AM
      Prodigy180 points
      Hi Bernie!
      Replacing nfsroot=$(nfshost):$(rootpath) by nfsroot=10.0.0.114:/home/jrodrigu/workdir/filesys  makes a difference indeed,
      (at least in u-boot 2009.03-dirty (Oct 15 2009 - 11:03:05))
      ....., OK
      IP-Config: Got DHCP answer from 0.0.0.0, my address is 10.0.0.110
           device=eth0, addr=10.0.0.110, mask=255.255.255.0, gw=255.255.255.255,
           host=10.0.0.110, domain=, nis-domain=(none),
           bootserver=0.0.0.0, rootserver=10.0.0.114, rootpath=
      Looking up port of RPC 100003/2 on 10.0.0.114
      rpcbind: server 10.0.0.114 not responding, timed out
      Looking up port of RPC 100005/1 on 10.0.0.114
      Root-NFS: Server returned error -5 while mounting /home/jrodrigu/workdir/filesys
      Nonetheless the kernel keeps panicing. NFS is up & running and I am able to ping the nfshost from other computers.
      Trying ping from u-boot does not work. Why? What could it be wrong?
      José
      Report Abuse
      • Reply
    • José
      Posted by José
      on Apr 01 2010 11:21 AM
      Prodigy180 points
      Interestingly enough I change my host /etc/network/interfaces to
      1)
      auto eth0
      iface eth0 inet dhcp
      instead of
      2)
      allow-hotplug eth0
      iface eth0 inet static
        address 10.0.0.114
        netmask 255.255.255.0
        gateway 10.0.0.138
        network 10.0.0.0
        broadcast 10.0.0.0
        up route add -net 10.0.0.0 netmask 255.255.255.0 gw 10.0.0.138
      and now it is possible to ping nfshost from u-boot. What's wrong with configuration 2)? A Cat-5 cable connects direct the EVM with my Debian Linux Laptop.
      Jos'e
      Report Abuse
      • Reply
      on Apr 01 2010 12:44 PM
      José
      I am not that familiar with setting up custom configurations to /etc/network/interfaces, so I am not sure what is wrong with configuration 2 (though I am sure some Google research would provide some ideas), in general I have used the default DHCP configuration in most Linux PCs I have used with success, the majority of which are Ubuntu.
      Since you mention you have just a cable between the EVM and your Linux host PC directly it is a bit unusual that ping would work with the first configuration, since a direct connection like that implies there is no DHCP server to auto configure the network (unless you have one running on the PC or the EVM). I suppose the DHCP settings for your particular distribution must default to some functional IP address and settings that work if no DHCP server is located.
      Going back a bit, since you get the 'server returned -5' error it sounds like the network layer is ok at the moment, so whatever IP configuration you are using seems at least minimally functional. There are a couple of possibilities as to why this may happen, I am guessing either your NFS server was not restarted with the new /etc/exports file that exports that particular folder, or that your host is running some firewall that is preventing the NFS connection from succeeding. If it is the firewall try a command like /etc/init.d/iptables stop or perhaps for Debian sudo iptables -F may be more appropriate (that works on Ubuntu).
      Report Abuse
      • Reply
    TI E2E™ Community
    • Support Forums
    • Blogs
    • Videos
    • Groups
    • Site Support & Feedback
    • Settings
    TI E2E™ Community Groups
    • TI University Program
    • Make the Switch
    • Microcontroller Projects
    • Motor Drive & Control
    Other Communities
    • Deyisupport
    • Designsomething.org
    • beagleboard.org
    • TI on Element 14
    • TI on TechXchangeSM
    Other Technical & Support Resources
    • WEBENCH® Design Center
    • Product Information Centers
    • Technical Documents
    • TI Design Network
    • TI Technical Articles
    • TI Training
    All content and materials on this site are provided "as is". TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with regard to these materials, including but not limited to all implied warranties and conditions of merchantability, fitness for a particular purpose, title and non-infringement of any third party intellectual property right. TI and its respective suppliers and providers of content make no representations about the suitability of these materials for any purpose and disclaim all warranties and conditions with respect to these materials. No license, either express or implied, by estoppel or otherwise, is granted by TI. Use of the information on this site may require a license from a third party, or a license from TI.
    Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
    Follow Us Texas Instruments on Facebook Texas Instruments on Twitter Texas Instruments on LinkedIn Texas Instruments on Google+
    TI Worldwide | Contact Us | my.TI Login | Site Map | Corporate Citizenship | mobile m.ti.com (Mobile Version)
    TI is a global semiconductor design and manufacturing company. Innovate with 100,000+ analog ICs and
    embedded processors, along with software, tools and the industry’s largest sales/support staff.
    © Copyright 1995-2013 Texas Instruments Incorporated. All rights reserved.
    Trademarks | Privacy Policy | Terms of Use
