quick summary of what I have done:
1- Download Graphics_SDK_setuplinux_4_10_00_01.bin
2- Cross compile it with kernel 3.4.68 (disable 3.2 section for 3.4 in GFX_Linux_KM/services4/3rdparty/linux_drm/Kbuild)
make OMAPES=3.x BUILD=release SUPPORT_XORG=1 all
3- So I used what was copy in my targetfs to put on my SD and boot it. This device already have a X working so I first stop it.
4- cd /opt/gfxlibraries/gfx_rel_es3.x
insmod drm.ko
insmod pvrsrvkm.ko
dmesg shows that the drivers are loaded:
[ 573.680267] [drm] Initialized drm 1.1.0 20060810
[ 590.587066] [drm] Initialized pvrsrvkm 1.10.2359475 20110701 for SGX on minor 0
5- Then try to start demo or simply rc.pvr in /etc/init.d and it crash, here the rc.pvr output but before will give you couple more details about my setup with the gfx_check.sh:
bash ./gfx_check.sh
WSEGL settings
[default]
WindowSystem=libpvrPVR2D_DRIWSEGL.so
#WindowSystem=libpvrPVR2D_FLIPWSEGL.so
ARM CPU information
Processor : ARMv7 Processor rev 3 (v7l)
BogoMIPS : 597.64
Features : swp half thumb fastmult vfp edsp thumbee neon vfpv3 tls
CPU implementer : 0x41
CPU architecture: 7
CPU variant : 0x1
CPU part : 0xc08
CPU revision : 3
Hardware : Gumstix Overo
Revision : 0020
Serial : 0000000000000000
SGX driver information
Version SGX_DDK_Linux_CustomerTI sgxddk 1.10@2359475 (release) /home/knight/SVN/rogue/3rdParty/TI_SGX_Graphics_SDK/trunk/starting_point/INSTALL/GFX_Linux_KM
System Version String: SGX revision = 121
Framebuffer settings
mode "480x272-59"
# D: 9.094 MHz, H: 17.062 kHz, V: 59.243 Hz
geometry 480 272 480 272 32
timings 109962 4 8 2 4 41 10
rgba 8/16,8/8,8/0,0/0
endmode
Frame buffer device information:
Address : 0x9f400000
Type : PACKED PIXELS
Visual : TRUECOLOR
XPanStep : 1
YPanStep : 1
YWrapStep : 0
LineLength : 1920
Accelerator : No
Rotation settings
0
Kernel Module information
Module Size Used by
pvrsrvkm 188686 1
drm 213656 2 pvrsrvkm
Boot settings
console=ttyO2,115200n8 mpurate=500 vram=12M omapfb.mode=dvi:1024x768MR-16@60 omapdss.def_disp=lcd43 root=/dev/mmcblk0p2 rw rootfstype=ext3 rootwait
Linux Kernel version
Linux BrainsightNIRS 3.4.68+ #1 PREEMPT Wed Jan 29 11:13:47 EST 2014 armv7l GNU/Linux
:/etc/init.d# ./rc.pvr start
Loaded PowerVR consumer services.
root@BrainsightNIRS:/etc/init.d# _XSERVTransSocketOpenCOTSServer: Unable to open socket for inet6
_XSERVTransOpen: transport open failed for inet6/BrainsightNIRS:0
_XSERVTransMakeAllCOTSServerListeners: failed to open listener for inet6
X.Org X Server 1.12.0
Release Date: 2012-03-04
X Protocol Version 11, Revision 0
Build Operating System: Linux 2.6.35-30-generic-pae i686
Current Operating System: Linux BrainsightNIRS 3.4.68+ #1 PREEMPT Wed Jan 29 11:13:47 EST 2014 armv7l
Kernel command line: console=ttyO2,115200n8 mpurate=500 vram=12M omapfb.mode=dvi:1024x768MR-16@60 omapdss.def_disp=lcd43 root=/dev/mmcblk0p2 rw rootfstype=ext3 rootwait
Build Date: 03 June 2013 08:03:21PM
Current version of pixman: 0.24.4
Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/usr/local/XSGX/var/log/Xorg.0.log", Time: Tue Sep 13 02:21:35 2011
(++) Using config file: "/usr/local/XSGX/etc/xorg.conf"
(==) ServerLayout "Server Layout"
(**) |-->Screen "Screen" (0)
(**) | |-->Monitor "<default monitor>"
(**) | |-->Device "Video Device"
(==) No monitor specified for screen "Screen".
Using a default monitor configuration.
(**) |-->Input Device "Keyboard"
(**) |-->Input Device "Main Touch Screen"
(==) Not automatically adding devices
(==) Not automatically enabling devices
(WW) The directory "/usr/local/XSGX/share/fonts/X11/TTF/" does not exist.
Entry deleted from font path.
(WW) The directory "/usr/local/XSGX/share/fonts/X11/OTF/" does not exist.
(==) FontPath set to:
/usr/local/XSGX/share/fonts/X11/misc/,
/usr/local/XSGX/share/fonts/X11/Type1/,
/usr/local/XSGX/share/fonts/X11/100dpi/,
/usr/local/XSGX/share/fonts/X11/75dpi/
(==) ModulePath set to "/usr/local/XSGX/lib/xorg/modules"
(II) Loading /usr/local/XSGX/lib/xorg/modules/extensions/libextmod.so
(II) Module extmod: vendor="X.Org Foundation"
compiled for 1.12.0, module version = 1.0.0
(II) Loading /usr/local/XSGX/lib/xorg/modules/extensions/libdbe.so
(II) Module dbe: vendor="X.Org Foundation"
(II) Loading /usr/local/XSGX/lib/xorg/modules/extensions/libglx.so
(II) Module glx: vendor="X.Org Foundation"
(==) AIGLX enabled
(II) Loading /usr/local/XSGX/lib/xorg/modules/extensions/librecord.so
(II) Module record: vendor="X.Org Foundation"
compiled for 1.12.0, module version = 1.13.0
(II) Loading /usr/local/XSGX/lib/xorg/modules/extensions/libdri.so
(II) Module dri: vendor="X.Org Foundation"
(II) Loading /usr/local/XSGX/lib[ 656.987579] ------------[ cut here ]------------
[ 656.993194] WARNING: at arch/arm/mach-omap2/omap_l3_smx.c:161 omap3_l3_app_irq+0xd4/0x11c()
[ 657.001953] In-band Error seen by MPU at address 0
[ 657.007080] Modules linked in: pvrsrvkm(O) drm(O)
[ 657.012084] [<c0012ad4>] (unwind_backtrace+0x0/0x11c) from [<c002e6f0>] (warn_slowpath_common+0x4c/0x64)
[ 657.022064] [<c002e6f0>] (warn_slowpath_common+0x4c/0x64) from [<c002e788>] (warn_slowpath_fmt+0x2c/0x3c)
[ 657.032135] [<c002e788>] (warn_slowpath_fmt+0x2c/0x3c) from [<c0025560>] (omap3_l3_app_irq+0xd4/0x11c)
[ 657.041931] [<c0025560>] (omap3_l3_app_irq+0xd4/0x11c) from [<c0082b18>] (handle_irq_event_percpu+0xb0/0x2b0)
[ 657.052368] [<c0082b18>] (handle_irq_event_percpu+0xb0/0x2b0) from [<c0082d54>] (handle_irq_event+0x3c/0x5c)
[ 657.062713] [<c0082d54>] (handle_irq_event+0x3c/0x5c) from [<c0084fb4>] (handle_level_irq+0xb8/0xd0)
[ 657.072326] [<c0084fb4>] (handle_level_irq+0xb8/0xd0) from [<c0082498>] (generic_handle_irq+0x30/0x44)
[ 657.082122] [<c0082498>] (generic_handle_irq+0x30/0x44) from [<c000e574>] (handle_IRQ+0x60/0x84)
[ 657.091369] [<c000e574>] (handle_IRQ+0x60/0x84) from [<c0008544>] (omap3_intc_handle_irq+0x54/0x68)
[ 657.100891] [<c0008544>] (omap3_intc_handle_irq+0x54/0x68) from [<c048fcc4>] (__irq_svc+0x44/0x78)
[ 657.110321] Exception stack(0xdd131c70 to 0xdd131cb8)
[ 657.115631] 1c60: dd3d7000 dd3d70f8 00000040 dd3d7000
[ 657.124237] 1c80: dd3d7000 00000000 00000000 e14b0120 00000000 0000001c 401c6440 bf0a7afc
[ 657.132812] 1ca0: 0002e10e dd131cb8 bf0a8f68 bf0a867c 60000013 ffffffff
[ 657.139984] [<c048fcc4>] (__irq_svc+0x44/0x78) from [<bf0a867c>] (SGXRunScript+0x0/0xa4 [pvrsrvkm])
[ 657.149658] [<bf0a867c>] (SGXRunScript+0x0/0xa4 [pvrsrvkm]) from [<deffc180>] (0xdeffc180)
[ 657.158386] ---[ end trace 1277b4e613d0414f ]---
/xorg/modules/extensions/libdri2.so
(II) Module dri2: vendor="X.Org Foundation"
compiled for 1.12.0, module version = 1.2.0
(II) Loading /usr/local/XSGX/lib/xorg/modules/drivers/pvr_drv.so
(II) Module PVR: vendor="X.Org Foundation"
compiled for 1.12.0, module version = 110.235.9475
(II) Loading /usr/local/XSGX/[ 657.190490] ------------[ cut here ]------------
[ 657.196624] WARNING: at arch/arm/mach-omap2/omap_l3_smx.c:161 omap3_l3_app_irq+0xd4/0x11c()
[ 657.205413] In-band Error seen by MPU at address 0
[ 657.210540] Modules linked in: pvrsrvkm(O) drm(O)
[ 657.215545] [<c0012ad4>] (unwind_backtrace+0x0/0x11c) from [<c002e6f0>] (warn_slowpath_common+0x4c/0x64)
[ 657.225524] [<c002e6f0>] (warn_slowpath_common+0x4c/0x64) from [<c002e788>] (warn_slowpath_fmt+0x2c/0x3c)
[ 657.235595] [<c002e788>] (warn_slowpath_fmt+0x2c/0x3c) from [<c0025560>] (omap3_l3_app_irq+0xd4/0x11c)
[ 657.245391] [<c0025560>] (omap3_l3_app_irq+0xd4/0x11c) from [<c0082b18>] (handle_irq_event_percpu+0xb0/0x2b0)
[ 657.255828] [<c0082b18>] (handle_irq_event_percpu+0xb0/0x2b0) from [<c0082d54>] (handle_irq_event+0x3c/0x5c)
[ 657.266174] [<c0082d54>] (handle_irq_event+0x3c/0x5c) from [<c0084fb4>] (handle_level_irq+0xb8/0xd0)
[ 657.275787] [<c0084fb4>] (handle_level_irq+0xb8/0xd0) from [<c0082498>] (generic_handle_irq+0x30/0x44)
[ 657.285583] [<c0082498>] (generic_handle_irq+0x30/0x44) from [<c000e574>] (handle_IRQ+0x60/0x84)
[ 657.294830] [<c000e574>] (handle_IRQ+0x60/0x84) from [<c0008544>] (omap3_intc_handle_irq+0x54/0x68)
[ 657.304351] [<c0008544>] (omap3_intc_handle_irq+0x54/0x68) from [<c048fcc4>] (__irq_svc+0x44/0x78)
[ 657.313751] Exception stack(0xdd131c70 to 0xdd131cb8)
[ 657.319061] 1c60: 00000000 00000acc 00000000 dd3d7000
[ 657.327667] 1c80: dd3d7000 00000000 00000000 e14b0120 00000000 0000001c 401c6440 bf0a7afc
[ 657.336273] 1ca0: 0002e10e dd131cb8 bf0a86cc bf0a8f68 60000013 ffffffff
[ 657.343414] [<c048fcc4>] (__irq_svc+0x44/0x78) from [<bf0a8f68>] (SGXInitialise+0x2c/0x130 [pvrsrvkm])
[ 657.353454] [<bf0a8f68>] (SGXInitialise+0x2c/0x130 [pvrsrvkm]) from [<bf0ac524>] (SGXPostPowerState+0x50/0xa8 [pvrsrvkm])
[ 657.365142] [<bf0ac524>] (SGXPostPowerState+0x50/0xa8 [pvrsrvkm]) from [<bf0998c4>] (PVRSRVDevicePostPowerStateKM_AnyVaCb+0x6c/0x84 [pvrsrvkm])
[ 657.378906] [<bf0998c4>] (PVRSRVDevicePostPowerStateKM_AnyVaCb+0x6c/0x84 [pvrsrvkm]) from [<bf0a1634>] (List_PVRSRV_POWER_DEV_PVRSRV_ERROR_Any_va+0x30/0x58 [pvrsrvkm])
[ 657.394866] [<bf0a1634>] (List_PVRSRV_POWER_DEV_PVRSRV_ERROR_Any_va+0x30/0x58 [pvrsrvkm]) from [<bf099af0>] (PVRSRVSetDevicePowerStateKM+0x4c/0x64 [pvrsrvkm])
[ 657.409942] [<bf099af0>] (PVRSRVSetDevicePowerStateKM+0x4c/0x64 [pvrsrvkm]) from [<bf0a9cc0>] (SGXScheduleCCBCommandKM+0x64/0xb8 [pvrsrvkm])
[ 657.423431] [<bf0a9cc0>] (SGXScheduleCCBCommandKM+0x64/0xb8 [pvrsrvkm]) from [<bf0a8338>] (SGXGetMiscInfoUkernel+0x78/0xe8 [pvrsrvkm])
[ 657.436340] [<bf0a8338>] (SGXGetMiscInfoUkernel+0x78/0xe8 [pvrsrvkm]) from [<bf0a842c>] (SGXDevInitCompatCheck+0x84/0x2a4 [pvrsrvkm])
[ 657.449157] [<bf0a842c>] (SGXDevInitCompatCheck+0x84/0x2a4 [pvrsrvkm]) from [<bf09e8c0>] (PVRSRVDevInitCompatCheck+0x14/0x20 [pvrsrvkm])
[ 657.462280] [<bf09e8c0>] (PVRSRVDevInitCompatCheck+0x14/0x20 [pvrsrvkm]) from [<bf0a1430>] (List_PVRSRV_DEVICE_NODE_PVRSRV_ERROR_Any+0x20/0x40 [pvrsrvkm])
[ 657.477050] [<bf0a1430>] (List_PVRSRV_DEVICE_NODE_PVRSRV_ERROR_Any+0x20/0x40 [pvrsrvkm]) from [<bf0ae4f0>] (PVRSRVInitSrvDisconnectBW+0x48/0x74 [pvrsrvkm])
[ 657.491912] [<bf0ae4f0>] (PVRSRVInitSrvDisconnectBW+0x48/0x74 [pvrsrvkm]) from [<bf0af4e8>] (BridgedDispatchKM+0xec/0x144 [pvrsrvkm])
[ 657.504760] [<bf0af4e8>] (BridgedDispatchKM+0xec/0x144 [pvrsrvkm]) from [<bf0a7c70>] (PVRSRV_BridgeDispatchKM+0x174/0x234 [pvrsrvkm])
[ 657.517669] [<bf0a7c70>] (PVRSRV_BridgeDispatchKM+0x174/0x234 [pvrsrvkm]) from [<bf04eec0>] (drm_ioctl+0x294/0x3a4 [drm])
[ 657.529296] [<bf04eec0>] (drm_ioctl+0x294/0x3a4 [drm]) from [<c00e8ecc>] (do_vfs_ioctl+0x548/0x5bc)
[ 657.538818] [<c00e8ecc>] (do_vfs_ioctl+0x548/0x5bc) from [<c00e8f8c>] (sys_ioctl+0x4c/0x6c)
[ 657.547637] [<c00e8f8c>] (sys_ioctl+0x4c/0x6c) from [<c000dcc0>] (ret_fast_syscall+0x0/0x3c)
[ 657.556488] ---[ end trace 1277b4e613d04150 ]---
lib/xorg/modules/input/evdev_drv.so
(II) Module evdev: vendor="X.Org Foundation[ 657.567687] ------------[ cut here ]------------
[ 657.573394] WARNING: at arch/arm/mach-omap2/omap_l3_smx.c:161 omap3_l3_app_irq+0xd4/0x11c()
[ 657.582183] In-band Error seen by MPU at address 0
[ 657.587310] Modules linked in: pvrsrvkm(O) drm(O)
[ 657.592315] [<c0012ad4>] (unwind_backtrace+0x0/0x11c) from [<c002e6f0>] (warn_slowpath_common+0x4c/0x64)
[ 657.602294] [<c002e6f0>] (warn_slowpath_common+0x4c/0x64) from [<c002e788>] (warn_slowpath_fmt+0x2c/0x3c)
[ 657.612365] [<c002e788>] (warn_slowpath_fmt+0x2c/0x3c) from [<c0025560>] (omap3_l3_app_irq+0xd4/0x11c)
[ 657.622161] [<c0025560>] (omap3_l3_app_irq+0xd4/0x11c) from [<c0082b18>] (handle_irq_event_percpu+0xb0/0x2b0)
[ 657.632598] [<c0082b18>] (handle_irq_event_percpu+0xb0/0x2b0) from [<c0082d54>] (handle_irq_event+0x3c/0x5c)
[ 657.642944] [<c0082d54>] (handle_irq_event+0x3c/0x5c) from [<c0084fb4>] (handle_level_irq+0xb8/0xd0)
[ 657.652557] [<c0084fb4>] (handle_level_irq+0xb8/0xd0) from [<c0082498>] (generic_handle_irq+0x30/0x44)
[ 657.662353] [<c0082498>] (generic_handle_irq+0x30/0x44) from [<c000e574>] (handle_IRQ+0x60/0x84)
[ 657.671600] [<c000e574>] (handle_IRQ+0x60/0x84) from [<c0008544>] (omap3_intc_handle_irq+0x54/0x68)
[ 657.681121] [<c0008544>] (omap3_intc_handle_irq+0x54/0x68) from [<c048fcc4>] (__irq_svc+0x44/0x78)
[ 657.690521] Exception stack(0xdd131c60 to 0xdd131ca8)
[ 657.695831] 1c60: dd3d7000 00000064 0000007f bf0b82f0 dd3d7000 00000001 00000000 e14b0120
[ 657.704406] 1c80: 00000000 0000001c 401c6440 bf0a7afc 0002e10e dd131ca8 bf0ac134 bf0aa5e0
[ 657.713012] 1ca0: 20000013 ffffffff
[ 657.716857] [<c048fcc4>] (__irq_svc+0x44/0x78) from [<bf0aa5e0>] (SGXWaitClocks+0x0/0x28 [pvrsrvkm])
[ 657.726593] [<bf0aa5e0>] (SGXWaitClocks+0x0/0x28 [pvrsrvkm]) from [<00000000>] ( (null))
[ 657.735168] ---[ end trace 1277b4e613d04151 ]---
compiled for 1.12.0, module version = 2.6.0
(II) pvr: Driver for PowerVR chipsets: PowerVR SGX
(--) using VT number 3
(WW) xf86OpenConsole: setpgid failed: Operation not permitted
(WW) Falling back to old probe method for pvr
[ 657.801483] ------------[ cut here ]------------
[ 657.806396] WARNING: at arch/arm/mach-omap2/omap_l3_smx.c:161 omap3_l3_app_irq+0xd4/0x11c()
[ 657.815185] In-band Error seen by MPU at address 0
[ 657.820281] Modules linked in: pvrsrvkm(O) drm(O)
[ 657.825317] [<c0012ad4>] (unwind_backtrace+0x0/0x11c) from [<c002e6f0>] (warn_slowpath_common+0x4c/0x64)
[ 657.835266] [<c002e6f0>] (warn_slowpath_common+0x4c/0x64) from [<c002e788>] (warn_slowpath_fmt+0x2c/0x3c)
[ 657.845336] [<c002e788>] (warn_slowpath_fmt+0x2c/0x3c) from [<c0025560>] (omap3_l3_app_irq+0xd4/0x11c)
[ 657.855133] [<c0025560>] (omap3_l3_app_irq+0xd4/0x11c) from [<c0082b18>] (handle_irq_event_percpu+0xb0/0x2b0)
[ 657.865570] [<c0082b18>] (handle_irq_event_percpu+0xb0/0x2b0) from [<c0082d54>] (handle_irq_event+0x3c/0x5c)
[ 657.875915] [<c0082d54>] (handle_irq_event+0x3c/0x5c) from [<c0084fb4>] (handle_level_irq+0xb8/0xd0)
[ 657.885498] [<c0084fb4>] (handle_level_irq+0xb8/0xd0) from [<c0082498>] (generic_handle_irq+0x30/0x44)
[ 657.895294] [<c0082498>] (generic_handle_irq+0x30/0x44) from [<c000e574>] (handle_IRQ+0x60/0x84)
[ 657.904541] [<c000e574>] (handle_IRQ+0x60/0x84) from [<c0008544>] (omap3_intc_handle_irq+0x54/0x68)
[ 657.914062] [<c0008544>] (omap3_intc_handle_irq+0x54/0x68) from [<c048fcc4>] (__irq_svc+0x44/0x78)
[ 657.923492] Exception stack(0xdd131c60 to 0xdd131ca8)
[ 657.928802] 1c60: e14f0000 00000c84 9d310000 bf0b82f0 dd3d7000 00000001 00000000 e14b0120
[ 657.937377] 1c80: 00000000 0000001c 401c6440 bf0a7afc 0002e10e dd131ca8 bf0ac154 bf0ac164
[ 657.945983] 1ca0: 20000013 ffffffff
[ 657.949829] [<c048fcc4>] (__irq_svc+0x44/0x78) from [<bf0ac164>] (SGXReset+0x4c/0x18c [pvrsrvkm])
[ 657.959381] [<bf0ac164>] (SGXReset+0x4c/0x18c [pvrsrvkm]) from [<bf0a8f94>] (SGXInitialise+0x58/0x130 [pvrsrvkm])
[ 657.970397] [<bf0a8f94>] (SGXInitialise+0x58/0x130 [pvrsrvkm]) from [<bf0ac524>] (SGXPostPowerState+0x50/0xa8 [pvrsrvkm])
[ 657.982086] [<bf0ac524>] (SGXPostPowerState+0x50/0xa8 [pvrsrvkm]) from [<bf0998c4>] (PVRSRVDevicePostPowerStateKM_AnyVaCb+0x6c/0x84 [pvrsrvkm])
[ 657.995849] [<bf0998c4>] (PVRSRVDevicePostPowerStateKM_AnyVaCb+0x6c/0x84 [pvrsrvkm]) from [<bf0a1634>] (List_PVRSRV_POWER_DEV_PVRSRV_ERROR_Any_va+0x30/0x58 [pvrsrvkm])
[ 658.011718] [<bf0a1634>] (List_PVRSRV_POWER_DEV_PVRSRV_ERROR_Any_va+0x30/0x58 [pvrsrvkm]) from [<bf099af0>] (PVRSRVSetDevicePowerStateKM+0x4c/0x64 [pvrsrvkm])
[ 658.026885] [<bf099af0>] (PVRSRVSetDevicePowerStateKM+0x4c/0x64 [pvrsrvkm]) from [<bf0a9cc0>] (SGXScheduleCCBCommandKM+0x64/0xb8 [pvrsrvkm])
[ 658.040435] [<bf0a9cc0>] (SGXScheduleCCBCommandKM+0x64/0xb8 [pvrsrvkm]) from [<bf0a8338>] (SGXGetMiscInfoUkernel+0x78/0xe8 [pvrsrvkm])
[ 658.053436] [<bf0a8338>] (SGXGetMiscInfoUkernel+0x78/0xe8 [pvrsrvkm]) from [<bf0a842c>] (SGXDevInitCompatCheck+0x84/0x2a4 [pvrsrvkm])
[ 658.066223] [<bf0a842c>] (SGXDevInitCompatCheck+0x84/0x2a4 [pvrsrvkm]) from [<bf09e8c0>] (PVRSRVDevInitCompatCheck+0x14/0x20 [pvrsrvkm])
[ 658.079284] [<bf09e8c0>] (PVRSRVDevInitCompatCheck+0x14/0x20 [pvrsrvkm]) from [<bf0a1430>] (List_PVRSRV_DEVICE_NODE_PVRSRV_ERROR_Any+0x20/0x40 [pvrsrvkm])
[ 658.093994] [<bf0a1430>] (List_PVRSRV_DEVICE_NODE_PVRSRV_ERROR_Any+0x20/0x40 [pvrsrvkm]) from [<bf0ae4f0>] (PVRSRVInitSrvDisconnectBW+0x48/0x74 [pvrsrvkm])
[ 658.108947] [<bf0ae4f0>] (PVRSRVInitSrvDisconnectBW+0x48/0x74 [pvrsrvkm]) from [<bf0af4e8>] (BridgedDispatchKM+0xec/0x144 [pvrsrvkm])
[ 658.121856] [<bf0af4e8>] (BridgedDispatchKM+0xec/0x144 [pvrsrvkm]) from [<bf0a7c70>] (PVRSRV_BridgeDispatchKM+0x174/0x234 [pvrsrvkm])
[ 658.134826] [<bf0a7c70>] (PVRSRV_BridgeDispatchKM+0x174/0x234 [pvrsrvkm]) from [<bf04eec0>] (drm_ioctl+0x294/0x3a4 [drm])
[ 658.146453] [<bf04eec0>] (drm_ioctl+0x294/0x3a4 [drm]) from [<c00e8ecc>] (do_vfs_ioctl+0x548/0x5bc)
[ 658.155975] [<c00e8ecc>] (do_vfs_ioctl+0x548/0x5bc) from [<c00e8f8c>] (sys_ioctl+0x4c/0x6c)
[ 658.164794] [<c00e8f8c>] (sys_ioctl+0x4c/0x6c) from [<c000dcc0>] (ret_fast_syscall+0x0/0x3c)
[ 658.173645] ---[ end trace 1277b4e613d04152 ]---
[ 658.186248] ------------[ cut here ]------------
[ 658.191162] WARNING: at arch/arm/mach-omap2/omap_l3_smx.c:161 omap3_l3_app_irq+0xd4/0x11c()
[ 658.199920] In-band Error seen by MPU at address 0
[ 658.205047] Modules linked in: pvrsrvkm(O) drm(O)
[ 658.210052] [<c0012ad4>] (unwind_backtrace+0x0/0x11c) from [<c002e6f0>] (warn_slowpath_common+0x4c/0x64)
[ 658.220031] [<c002e6f0>] (warn_slowpath_common+0x4c/0x64) from [<c002e788>] (warn_slowpath_fmt+0x2c/0x3c)
[ 658.230102] [<c002e788>] (warn_slowpath_fmt+0x2c/0x3c) from [<c0025560>] (omap3_l3_app_irq+0xd4/0x11c)
[ 658.239898] [<c0025560>] (omap3_l3_app_irq+0xd4/0x11c) from [<c0082b18>] (handle_irq_event_percpu+0xb0/0x2b0)
[ 658.250335] [<c0082b18>] (handle_irq_event_percpu+0xb0/0x2b0) from [<c0082d54>] (handle_irq_event+0x3c/0x5c)
[ 658.260650] [<c0082d54>] (handle_irq_event+0x3c/0x5c) from [<c0084fb4>] (handle_level_irq+0xb8/0xd0)
[ 658.270263] [<c0084fb4>] (handle_level_irq+0xb8/0xd0) from [<c0082498>] (generic_handle_irq+0x30/0x44)
[ 658.280059] [<c0082498>] (generic_handle_irq+0x30/0x44) from [<c000e574>] (handle_IRQ+0x60/0x84)
[ 658.289306] [<c000e574>] (handle_IRQ+0x60/0x84) from [<c0008544>] (omap3_intc_handle_irq+0x54/0x68)
[ 658.298828] [<c0008544>] (omap3_intc_handle_irq+0x54/0x68) from [<c048fcc4>] (__irq_svc+0x44/0x78)
[ 658.308258] Exception stack(0xdd131c60 to 0xdd131ca8)
[ 658.313568] 1c60: dd3d7000 00000064 9d310000 bf0b82f0 dd3d7000 00000001 00000000 e14b0120
[ 658.322174] 1c80: 00000000 0000001c 401c6440 bf0a7afc 0002e10e dd131ca8 bf0ac174 bf0aa5e0
[ 658.330780] 1ca0: 20000013 ffffffff
[ 658.334625] [<c048fcc4>] (__irq_svc+0x44/0x78) from [<bf0aa5e0>] (SGXWaitClocks+0x0/0x28 [pvrsrvkm])
[ 658.344360] [<bf0aa5e0>] (SGXWaitClocks+0x0/0x28 [pvrsrvkm]) from [<00000000>] ( (null))
[ 658.352935] ---[ end trace 1277b4e613d04153 ]---
[ 658.421264] ------------[ cut here ]------------
[ 658.426177] WARNING: at arch/arm/mach-omap2/omap_l3_smx.c:161 omap3_l3_app_irq+0xd4/0x11c()
[ 658.434936] In-band Error seen by MPU at address 0
[ 658.440063] Modules linked in: pvrsrvkm(O) drm(O)
[ 658.445098] [<c0012ad4>] (unwind_backtrace+0x0/0x11c) from [<c002e6f0>] (warn_slowpath_common+0x4c/0x64)
[ 658.455078] [<c002e6f0>] (warn_slowpath_common+0x4c/0x64) from [<c002e788>] (warn_slowpath_fmt+0x2c/0x3c)
[ 658.465148] [<c002e788>] (warn_slowpath_fmt+0x2c/0x3c) from [<c0025560>] (omap3_l3_app_irq+0xd4/0x11c)
[ 658.474945] [<c0025560>] (omap3_l3_app_irq+0xd4/0x11c) from [<c0082b18>] (handle_irq_event_percpu+0xb0/0x2b0)
[ 658.485382] [<c0082b18>] (handle_irq_event_percpu+0xb0/0x2b0) from [<c0082d54>] (handle_irq_event+0x3c/0x5c)
[ 658.495727] [<c0082d54>] (handle_irq_event+0x3c/0x5c) from [<c0084fb4>] (handle_level_irq+0xb8/0xd0)
[ 658.505310] [<c0084fb4>] (handle_level_irq+0xb8/0xd0) from [<c0082498>] (generic_handle_irq+0x30/0x44)
[ 658.515106] [<c0082498>] (generic_handle_irq+0x30/0x44) from [<c000e574>] (handle_IRQ+0x60/0x84)
[ 658.524353] [<c000e574>] (handle_IRQ+0x60/0x84) from [<c0008544>] (omap3_intc_handle_irq+0x54/0x68)
[ 658.533874] [<c0008544>] (omap3_intc_handle_irq+0x54/0x68) from [<c048fcc4>] (__irq_svc+0x44/0x78)
[ 658.543273] Exception stack(0xdd131c60 to 0xdd131ca8)
[ 658.548614] 1c60: e14f0000 00000080 0000007e bf0b82f0 dd3d7000 00000001 00000000 e14b0120
[ 658.557220] 1c80: 00000000 0000001c 401c6440 bf0a7afc 0002e10e dd131ca8 bf0ac180 bf0ac180
[ 658.565826] 1ca0: 60000013 ffffffff
[ 658.569671] [<c048fcc4>] (__irq_svc+0x44/0x78) from [<bf0ac180>] (SGXReset+0x68/0x18c [pvrsrvkm])
[ 658.579223] [<bf0ac180>] (SGXReset+0x68/0x18c [pvrsrvkm]) from [<bf0a8f94>] (SGXInitialise+0x58/0x130 [pvrsrvkm])
[ 658.590240] [<bf0a8f94>] (SGXInitialise+0x58/0x130 [pvrsrvkm]) from [<bf0ac524>] (SGXPostPowerState+0x50/0xa8 [pvrsrvkm])
[ 658.601959] [<bf0ac524>] (SGXPostPowerState+0x50/0xa8 [pvrsrvkm]) from [<bf0998c4>] (PVRSRVDevicePostPowerStateKM_AnyVaCb+0x6c/0x84 [pvrsrvkm])
[ 658.615631] [<bf0998c4>] (PVRSRVDevicePostPowerStateKM_AnyVaCb+0x6c/0x84 [pvrsrvkm]) from [<bf0a1634>] (List_PVRSRV_POWER_DEV_PVRSRV_ERROR_Any_va+0x30/0x58 [pvrsrvkm])
[ 658.631591] [<bf0a1634>] (List_PVRSRV_POWER_DEV_PVRSRV_ERROR_Any_va+0x30/0x58 [pvrsrvkm]) from [<bf099af0>] (PVRSRVSetDevicePowerStateKM+0x4c/0x64 [pvrsrvkm])
[ 658.646759] [<bf099af0>] (PVRSRVSetDevicePowerStateKM+0x4c/0x64 [pvrsrvkm]) from [<bf0a9cc0>] (SGXScheduleCCBCommandKM+0x64/0xb8 [pvrsrvkm])
[ 658.660247] [<bf0a9cc0>] (SGXScheduleCCBCommandKM+0x64/0xb8 [pvrsrvkm]) from [<bf0a8338>] (SGXGetMiscInfoUkernel+0x78/0xe8 [pvrsrvkm])
[ 658.673156] [<bf0a8338>] (SGXGetMiscInfoUkernel+0x78/0xe8 [pvrsrvkm]) from [<bf0a842c>] (SGXDevInitCompatCheck+0x84/0x2a4 [pvrsrvkm])
[ 658.685943] [<bf0a842c>] (SGXDevInitCompatCheck+0x84/0x2a4 [pvrsrvkm]) from [<bf09e8c0>] (PVRSRVDevInitCompatCheck+0x14/0x20 [pvrsrvkm])
[ 658.699005] [<bf09e8c0>] (PVRSRVDevInitCompatCheck+0x14/0x20 [pvrsrvkm]) from [<bf0a1430>] (List_PVRSRV_DEVICE_NODE_PVRSRV_ERROR_Any+0x20/0x40 [pvrsrvkm])
[ 658.713714] [<bf0a1430>] (List_PVRSRV_DEVICE_NODE_PVRSRV_ERROR_Any+0x20/0x40 [pvrsrvkm]) from [<bf0ae4f0>] (PVRSRVInitSrvDisconnectBW+0x48/0x74 [pvrsrvkm])
[ 658.728668] [<bf0ae4f0>] (PVRSRVInitSrvDisconnectBW+0x48/0x74 [pvrsrvkm]) from [<bf0af4e8>] (BridgedDispatchKM+0xec/0x144 [pvrsrvkm])
[ 658.741607] [<bf0af4e8>] (BridgedDispatchKM+0xec/0x144 [pvrsrvkm]) from [<bf0a7c70>] (PVRSRV_BridgeDispatchKM+0x174/0x234 [pvrsrvkm])
[ 658.754516] [<bf0a7c70>] (PVRSRV_BridgeDispatchKM+0x174/0x234 [pvrsrvkm]) from [<bf04eec0>] (drm_ioctl+0x294/0x3a4 [drm])
[ 658.766174] [<bf04eec0>] (drm_ioctl+0x294/0x3a4 [drm]) from [<c00e8ecc>] (do_vfs_ioctl+0x548/0x5bc)
[ 658.775665] [<c00e8ecc>] (do_vfs_ioctl+0x548/0x5bc) from [<c00e8f8c>] (sys_ioctl+0x4c/0x6c)
[ 658.784454] [<c00e8f8c>] (sys_ioctl+0x4c/0x6c) from [<c000dcc0>] (ret_fast_syscall+0x0/0x3c)
[ 658.793334] ---[ end trace 1277b4e613d04154 ]---
[ 658.802032] ------------[ cut here ]------------
[ 658.806915] WARNING: at arch/arm/mach-omap2/omap_l3_smx.c:161 omap3_l3_app_irq+0xd4/0x11c()
[ 658.815704] In-band Error seen by MPU at address 0
[ 658.820800] Modules linked in: pvrsrvkm(O) drm(O)
[ 658.825805] [<c0012ad4>] (unwind_backtrace+0x0/0x11c) from [<c002e6f0>] (warn_slowpath_common+0x4c/0x64)
[ 658.835815] [<c002e6f0>] (warn_slowpath_common+0x4c/0x64) from [<c002e788>] (warn_slowpath_fmt+0x2c/0x3c)
[ 658.845855] [<c002e788>] (warn_slowpath_fmt+0x2c/0x3c) from [<c0025560>] (omap3_l3_app_irq+0xd4/0x11c)
[ 658.855651] [<c0025560>] (omap3_l3_app_irq+0xd4/0x11c) from [<c0082b18>] (handle_irq_event_percpu+0xb0/0x2b0)
[ 658.866088] [<c0082b18>] (handle_irq_event_percpu+0xb0/0x2b0) from [<c0082d54>] (handle_irq_event+0x3c/0x5c)
[ 658.876434] [<c0082d54>] (handle_irq_event+0x3c/0x5c) from [<c0084fb4>] (handle_level_irq+0xb8/0xd0)
[ 658.886047] [<c0084fb4>] (handle_level_irq+0xb8/0xd0) from [<c0082498>] (generic_handle_irq+0x30/0x44)
[ 658.895812] [<c0082498>] (generic_handle_irq+0x30/0x44) from [<c000e574>] (handle_IRQ+0x60/0x84)
[ 658.905059] [<c000e574>] (handle_IRQ+0x60/0x84) from [<c0008544>] (omap3_intc_handle_irq+0x54/0x68)
[ 658.914581] [<c0008544>] (omap3_intc_handle_irq+0x54/0x68) from [<c048fcc4>] (__irq_svc+0x44/0x78)
[ 658.923980] Exception stack(0xdd131c50 to 0xdd131c98)
[ 658.929290] 1c40: e14f0000 00000c00 00000008 bf0b82f0
[ 658.937896] 1c60: dd3d7000 00000001 00000000 e14b0120 00000000 0000001c 401c6440 bf0a7afc
[ 658.946502] 1c80: 0002e10e dd131c98 bf0ac0bc bf0ac0c0 60000013 ffffffff
[ 658.953613] [<c048fcc4>] (__irq_svc+0x44/0x78) from [<bf0ac0c0>] (SGXResetInvalDC.isra.4+0x1c/0x60 [pvrsrvkm])
[ 658.964447] [<bf0ac0c0>] (SGXResetInvalDC.isra.4+0x1c/0x60 [pvrsrvkm]) from [<bf0ac190>] (SGXReset+0x78/0x18c [pvrsrvkm])
[ 658.976257] [<bf0ac190>] (SGXReset+0x78/0x18c [pvrsrvkm]) from [<bf0a8f94>] (SGXInitialise+0x58/0x130 [pvrsrvkm])
[ 658.987335] [<bf0a8f94>] (SGXInitialise+0x58/0x130 [pvrsrvkm]) from [<bf0ac524>] (SGXPostPowerState+0x50/0xa8 [pvrsrvkm])
[ 658.999023] [<bf0ac524>] (SGXPostPowerState+0x50/0xa8 [pvrsrvkm]) from [<bf0998c4>] (PVRSRVDevicePostPowerStateKM_AnyVaCb+0x6c/0x84 [pvrsrvkm])
[ 659.012695] [<bf0998c4>] (PVRSRVDevicePostPowerStateKM_AnyVaCb+0x6c/0x84 [pvrsrvkm]) from [<bf0a1634>] (List_PVRSRV_POWER_DEV_PVRSRV_ERROR_Any_va+0x30/0x58 [pvrsrvkm])
[ 659.028656] [<bf0a1634>] (List_PVRSRV_POWER_DEV_PVRSRV_ERROR_Any_va+0x30/0x58 [pvrsrvkm]) from [<bf099af0>] (PVRSRVSetDevicePowerStateKM+0x4c/0x64 [pvrsrvkm])
[ 659.043731] [<bf099af0>] (PVRSRVSetDevicePowerStateKM+0x4c/0x64 [pvrsrvkm]) from [<bf0a9cc0>] (SGXScheduleCCBCommandKM+0x64/0xb8 [pvrsrvkm])
[ 659.057189] [<bf0a9cc0>] (SGXScheduleCCBCommandKM+0x64/0xb8 [pvrsrvkm]) from [<bf0a8338>] (SGXGetMiscInfoUkernel+0x78/0xe8 [pvrsrvkm])
[ 659.070098] [<bf0a8338>] (SGXGetMiscInfoUkernel+0x78/0xe8 [pvrsrvkm]) from [<bf0a842c>] (SGXDevInitCompatCheck+0x84/0x2a4 [pvrsrvkm])
[ 659.082885] [<bf0a842c>] (SGXDevInitCompatCheck+0x84/0x2a4 [pvrsrvkm]) from [<bf09e8c0>] (PVRSRVDevInitCompatCheck+0x14/0x20 [pvrsrvkm])
[ 659.096008] [<bf09e8c0>] (PVRSRVDevInitCompatCheck+0x14/0x20 [pvrsrvkm]) from [<bf0a1430>] (List_PVRSRV_DEVICE_NODE_PVRSRV_ERROR_Any+0x20/0x40 [pvrsrvkm])
[ 659.110839] [<bf0a1430>] (List_PVRSRV_DEVICE_NODE_PVRSRV_ERROR_Any+0x20/0x40 [pvrsrvkm]) from [<bf0ae4f0>] (PVRSRVInitSrvDisconnectBW+0x48/0x74 [pvrsrvkm])
[ 659.125793] [<bf0ae4f0>] (PVRSRVInitSrvDisconnectBW+0x48/0x74 [pvrsrvkm]) from [<bf0af4e8>] (BridgedDispatchKM+0xec/0x144 [pvrsrvkm])
[ 659.138702] [<bf0af4e8>] (BridgedDispatchKM+0xec/0x144 [pvrsrvkm]) from [<bf0a7c70>] (PVRSRV_BridgeDispatchKM+0x174/0x234 [pvrsrvkm])
[ 659.151519] [<bf0a7c70>] (PVRSRV_BridgeDispatchKM+0x174/0x234 [pvrsrvkm]) from [<bf04eec0>] (drm_ioctl+0x294/0x3a4 [drm])
[ 659.163238] [<bf04eec0>] (drm_ioctl+0x294/0x3a4 [drm]) from [<c00e8ecc>] (do_vfs_ioctl+0x548/0x5bc)
[ 659.172729] [<c00e8ecc>] (do_vfs_ioctl+0x548/0x5bc) from [<c00e8f8c>] (sys_ioctl+0x4c/0x6c)
[ 659.181518] [<c00e8f8c>] (sys_ioctl+0x4c/0x6c) from [<c000dcc0>] (ret_fast_syscall+0x0/0x3c)
[ 659.190399] ---[ end trace 1277b4e613d04155 ]---
[ 659.285858] ------------[ cut here ]------------
[ 659.290771] WARNING: at arch/arm/mach-omap2/omap_l3_smx.c:161 omap3_l3_app_irq+0xd4/0x11c()
[ 659.299560] In-band Error seen by MPU at address 0
[ 659.304687] Modules linked in: pvrsrvkm(O) drm(O)
[ 659.309722] [<c0012ad4>] (unwind_backtrace+0x0/0x11c) from [<c002e6f0>] (warn_slowpath_common+0x4c/0x64)
[ 659.319702] [<c002e6f0>] (warn_slowpath_common+0x4c/0x64) from [<c002e788>] (warn_slowpath_fmt+0x2c/0x3c)
[ 659.329772] [<c002e788>] (warn_slowpath_fmt+0x2c/0x3c) from [<c0025560>] (omap3_l3_app_irq+0xd4/0x11c)
[ 659.339569] [<c0025560>] (omap3_l3_app_irq+0xd4/0x11c) from [<c0082b18>] (handle_irq_event_percpu+0xb0/0x2b0)
[ 659.350006] [<c0082b18>] (handle_irq_event_percpu+0xb0/0x2b0) from [<c0082d54>] (handle_irq_event+0x3c/0x5c)
[ 659.360321] [<c0082d54>] (handle_irq_event+0x3c/0x5c) from [<c0084fb4>] (handle_level_irq+0xb8/0xd0)
[ 659.369934] [<c0084fb4>] (handle_level_irq+0xb8/0xd0) from [<c0082498>] (generic_handle_irq+0x30/0x44)
[ 659.379730] [<c0082498>] (generic_handle_irq+0x30/0x44) from [<c000e574>] (handle_IRQ+0x60/0x84)
[ 659.388977] [<c000e574>] (handle_IRQ+0x60/0x84) from [<c0008544>] (omap3_intc_handle_irq+0x54/0x68)
[ 659.398498] [<c0008544>] (omap3_intc_handle_irq+0x54/0x68) from [<c048fcc4>] (__irq_svc+0x44/0x78)
[ 659.407897] Exception stack(0xdd131c50 to 0xdd131c98)
[ 659.413208] 1c40: dd3d7000 00000c00 00000000 bf0b82f0
[ 659.421783] 1c60: dd3d7000 00000001 00000000 e14b0120 00000000 0000001c 401c6440 bf0a7afc
[ 659.430389] 1c80: 0002e10e dd131c98 bf0ac0d4 bf0ac09c 60000013 ffffffff
[ 659.437561] [<c048fcc4>] (__irq_svc+0x44/0x78) from [<bf0ac09c>] (SGXResetSleep.isra.3+0x0/0x8 [pvrsrvkm])
[ 659.447937] [<bf0ac09c>] (SGXResetSleep.isra.3+0x0/0x8 [pvrsrvkm]) from [<bf0ac0d4>] (SGXResetInvalDC.isra.4+0x30/0x60 [pvrsrvkm])
[ 659.460510] [<bf0ac0d4>] (SGXResetInvalDC.isra.4+0x30/0x60 [pvrsrvkm]) from [<bf0ac190>] (SGXReset+0x78/0x18c [pvrsrvkm])
[ 659.472320] [<bf0ac190>] (SGXReset+0x78/0x18c [pvrsrvkm]) from [<bf0a8f94>] (SGXInitialise+0x58/0x130 [pvrsrvkm])
[ 659.483337] [<bf0a8f94>] (SGXInitialise+0x58/0x130 [pvrsrvkm]) from [<bf0ac524>] (SGXPostPowerState+0x50/0xa8 [pvrsrvkm])
[ 659.495025] [<bf0ac524>] (SGXPostPowerState+0x50/0xa8 [pvrsrvkm]) from [<bf0998c4>] (PVRSRVDevicePostPowerStateKM_AnyVaCb+0x6c/0x84 [pvrsrvkm])
[ 659.508697] [<bf0998c4>] (PVRSRVDevicePostPowerStateKM_AnyVaCb+0x6c/0x84 [pvrsrvkm]) from [<bf0a1634>] (List_PVRSRV_POWER_DEV_PVRSRV_ERROR_Any_va+0x30/0x58 [pvrsrvkm])
[ 659.524658] [<bf0a1634>] (List_PVRSRV_POWER_DEV_PVRSRV_ERROR_Any_va+0x30/0x58 [pvrsrvkm]) from [<bf099af0>] (PVRSRVSetDevicePowerStateKM+0x4c/0x64 [pvrsrvkm])
[ 659.539733] [<bf099af0>] (PVRSRVSetDevicePowerStateKM+0x4c/0x64 [pvrsrvkm]) from [<bf0a9cc0>] (SGXScheduleCCBCommandKM+0x64/0xb8 [pvrsrvkm])
[ 659.553283] [<bf0a9cc0>] (SGXScheduleCCBCommandKM+0x64/0xb8 [pvrsrvkm]) from [<bf0a8338>] (SGXGetMiscInfoUkernel+0x78/0xe8 [pvrsrvkm])
[ 659.566284] [<bf0a8338>] (SGXGetMiscInfoUkernel+0x78/0xe8 [pvrsrvkm]) from [<bf0a842c>] (SGXDevInitCompatCheck+0x84/0x2a4 [pvrsrvkm])
[ 659.579101] [<bf0a842c>] (SGXDevInitCompatCheck+0x84/0x2a4 [pvrsrvkm]) from [<bf09e8c0>] (PVRSRVDevInitCompatCheck+0x14/0x20 [pvrsrvkm])
[ 659.592132] [<bf09e8c0>] (PVRSRVDevInitCompatCheck+0x14/0x20 [pvrsrvkm]) from [<bf0a1430>] (List_PVRSRV_DEVICE_NODE_PVRSRV_ERROR_Any+0x20/0x40 [pvrsrvkm])
[ 659.606964] [<bf0a1430>] (List_PVRSRV_DEVICE_NODE_PVRSRV_ERROR_Any+0x20/0x40 [pvrsrvkm]) from [<bf0ae4f0>] (PVRSRVInitSrvDisconnectBW+0x48/0x74 [pvrsrvkm])
[ 659.621826] [<bf0ae4f0>] (PVRSRVInitSrvDisconnectBW+0x48/0x74 [pvrsrvkm]) from [<bf0af4e8>] (BridgedDispatchKM+0xec/0x144 [pvrsrvkm])
[ 659.634735] [<bf0af4e8>] (BridgedDispatchKM+0xec/0x144 [pvrsrvkm]) from [<bf0a7c70>] (PVRSRV_BridgeDispatchKM+0x174/0x234 [pvrsrvkm])
[ 659.647735] [<bf0a7c70>] (PVRSRV_BridgeDispatchKM+0x174/0x234 [pvrsrvkm]) from [<bf04eec0>] (drm_ioctl+0x294/0x3a4 [drm])
[ 659.659362] [<bf04eec0>] (drm_ioctl+0x294/0x3a4 [drm]) from [<c00e8ecc>] (do_vfs_ioctl+0x548/0x5bc)
[ 659.668884] [<c00e8ecc>] (do_vfs_ioctl+0x548/0x5bc) from [<c00e8f8c>] (sys_ioctl+0x4c/0x6c)
[ 659.677673] [<c00e8f8c>] (sys_ioctl+0x4c/0x6c) from [<c000dcc0>] (ret_fast_syscall+0x0/0x3c)
[ 659.686523] ---[ end trace 1277b4e613d04156 ]---
[ 659.700531] Unhandled fault: external abort on non-linefetch (0x1008) at 0xe14f0ca8
[ 659.708618] Internal error: : 1008 [#1] PREEMPT ARM
[ 659.713745] Modules linked in: pvrsrvkm(O) drm(O)
[ 659.718719] CPU: 0 Tainted: G W O (3.4.68+ #1)
[ 659.724609] PC is at PollForValueKM+0x4c/0xbc [pvrsrvkm]
[ 659.730285] LR is at PollForValueKM+0x34/0xbc [pvrsrvkm]
[ 659.735870] pc : [<bf09ea5c>] lr : [<bf09ea44>] psr: 80000013
[ 659.735870] sp : dd131c68 ip : 0002e10e fp : 00000000
[ 659.747924] r10: 00000032 r9 : 000f4240 r8 : 00000001
[ 659.753387] r7 : 157029e4 r6 : 000000ff r5 : e14f0ca8 r4 : 00000000
[ 659.760253] r3 : 00000001 r2 : 000003e7 r1 : 000003e8 r0 : 00000000
[ 659.767089] Flags: Nzcv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 659.774597] Control: 10c5387d Table: 9d11c019 DAC: 00000015
[ 659.780639] Process X (pid: 1041, stack limit = 0xdd1302f0)
[ 659.786499] Stack: (0xdd131c68 to 0xdd132000)
[ 659.791076] 1c60: 00000001 00000000 000000ff dd3d7000 00000001 00000000
[ 659.799652] 1c80: e14b0120 00000000 0000001c 401c6440 bf0a7afc bf0ac0fc 00000032 00000000
[ 659.808258] 1ca0: dd3d7000 bf0ac190 dd3d7000 00000000 00000000 bf0a8f94 dd3d7000 00000000
[ 659.816864] 1cc0: bf0bac88 dd3d7000 00000000 deffc180 dd131da0 bf0ac524 dd131cec c04917c0
[ 659.825469] 1ce0: 80000013 c06e8ee8 bf0a7afc c048f914 dd152140 0698a3aa 0698a3aa c0026b00
[ 659.834075] 1d00: bf0bac10 bf0b0fe4 de580440 00000000 00000000 bf0998c4 dd131d48 bf099858
[ 659.842651] 1d20: 00000000 bf0a1634 de580440 dd131d48 00000000 00000000 00000000 bf0bac0c
[ 659.851257] 1d40: bf099af0 bf099858 00000000 00000000 00000000 00000000 ffffffff deffc180
[ 659.859863] 1d60: 00000006 bf0a9cc0 deffc180 00000006 dd131da0 ffffffff e14b0180 dec1a440
[ 659.868438] 1d80: deffc180 00000000 e08e3000 bf0a8338 00000000 00000000 00000000 00000001
[ 659.877044] 1da0: 00000000 dd152140 00000001 0f003180 e08e2000 e08e3000 0000001c 401c6440
[ 659.885650] 1dc0: dd3d7000 00000000 00000000 dec1a440 e08e3000 0000001c 401c6440 bf0a842c
[ 659.894256] 1de0: bf0a83a8 bf09e8cc 00000000 00000000 e08e2000 bf09e8c0 deffc180 bf0a1430
[ 659.902832] 1e00: bf0bac10 e08e2000 e08e3000 bf0ae4f0 dd131e78 de54a300 00000045 bf0af4e8
[ 659.911437] 1e20: dd131e78 c01c6745 dd23d600 00000411 bf0b84a0 bf0a7c70 de54a300 dd131e78
[ 659.920043] 1e40: dd23d600 dd0ec800 dd23d600 dd131e78 0000001c bf04eec0 00000411 401c6440
[ 659.928619] 1e60: 00000040 0000e200 00000001 c006c778 dd0ec87c be9b8944 00000045 0000001c
[ 659.937225] 1e80: be9b8978 00000008 be9b8970 00000008 00000001 c006c478 dd152140 00000001
[ 659.945831] 1ea0: 0000002b 00000000 00000000 00000007 00000006 00000006 dd1525b8 c006c478
[ 659.954406] 1ec0: dd152140 00000001 00000000 dd152140 00000001 dd152140 00000000 00000000
[ 659.963012] 1ee0: 60000013 dd28ce28 00000000 00000000 60000093 00000000 00000000 be9b8944
[ 659.971618] 1f00: de6bd960 de7452c0 00000007 00000000 dd130000 00000000 0017b14c c00e8ecc
[ 659.980194] 1f20: dd28ce18 60000013 c026e37c dd28ce14 c000de64 dd28ce18 00000000 c048f2b0
[ 659.988800] 1f40: dd152140 00000001 00000000 dd152140 00000001 c048f908 dd152140 00000001
[ 659.997375] 1f60: 00000000 de7452c0 be9b8944 401c6440 00000007 00000000 dd130000 00000000
[ 660.005981] 1f80: 0017b14c c00e8f8c 00000007 00000000 be9b8944 401c6440 00000007 00000036
[ 660.014587] 1fa0: c000de64 c000dcc0 be9b8944 401c6440 00000007 401c6440 be9b8944 0000001c
[ 660.023162] 1fc0: be9b8944 401c6440 00000007 00000036 00000014 00108974 00000014 0017b14c
[ 660.031768] 1fe0: 00000001 be9b8920 b6ba6c8c b6dda45c 20000010 00000007 415f4d4b 6156796e
[ 660.040557] [<bf09ea5c>] (PollForValueKM+0x4c/0xbc [pvrsrvkm]) from [<bf0ac0fc>] (SGXResetInvalDC.isra.4+0x58/0x60 [pvrsrvkm])
[ 660.052856] [<bf0ac0fc>] (SGXResetInvalDC.isra.4+0x58/0x60 [pvrsrvkm]) from [<bf0ac190>] (SGXReset+0x78/0x18c [pvrsrvkm])
[ 660.064575] [<bf0ac190>] (SGXReset+0x78/0x18c [pvrsrvkm]) from [<bf0a8f94>] (SGXInitialise+0x58/0x130 [pvrsrvkm])
[ 660.075653] [<bf0a8f94>] (SGXInitialise+0x58/0x130 [pvrsrvkm]) from [<bf0ac524>] (SGXPostPowerState+0x50/0xa8 [pvrsrvkm])
[ 660.087402] [<bf0ac524>] (SGXPostPowerState+0x50/0xa8 [pvrsrvkm]) from [<bf0998c4>] (PVRSRVDevicePostPowerStateKM_AnyVaCb+0x6c/0x84 [pvrsrvkm])
[ 660.101165] [<bf0998c4>] (PVRSRVDevicePostPowerStateKM_AnyVaCb+0x6c/0x84 [pvrsrvkm]) from [<bf0a1634>] (List_PVRSRV_POWER_DEV_PVRSRV_ERROR_Any_va+0x30/0x58 [pvrsrvkm])
[ 660.117034] [<bf0a1634>] (List_PVRSRV_POWER_DEV_PVRSRV_ERROR_Any_va+0x30/0x58 [pvrsrvkm]) from [<bf099af0>] (PVRSRVSetDevicePowerStateKM+0x4c/0x64 [pvrsrvkm])
[ 660.132202] [<bf099af0>] (PVRSRVSetDevicePowerStateKM+0x4c/0x64 [pvrsrvkm]) from [<bf0a9cc0>] (SGXScheduleCCBCommandKM+0x64/0xb8 [pvrsrvkm])
[ 660.145690] [<bf0a9cc0>] (SGXScheduleCCBCommandKM+0x64/0xb8 [pvrsrvkm]) from [<bf0a8338>] (SGXGetMiscInfoUkernel+0x78/0xe8 [pvrsrvkm])
[ 660.158599] [<bf0a8338>] (SGXGetMiscInfoUkernel+0x78/0xe8 [pvrsrvkm]) from [<bf0a842c>] (SGXDevInitCompatCheck+0x84/0x2a4 [pvrsrvkm])
[ 660.171386] [<bf0a842c>] (SGXDevInitCompatCheck+0x84/0x2a4 [pvrsrvkm]) from [<bf09e8c0>] (PVRSRVDevInitCompatCheck+0x14/0x20 [pvrsrvkm])
[ 660.184448] [<bf09e8c0>] (PVRSRVDevInitCompatCheck+0x14/0x20 [pvrsrvkm]) from [<bf0a1430>] (List_PVRSRV_DEVICE_NODE_PVRSRV_ERROR_Any+0x20/0x40 [pvrsrvkm])
[ 660.199157] [<bf0a1430>] (List_PVRSRV_DEVICE_NODE_PVRSRV_ERROR_Any+0x20/0x40 [pvrsrvkm]) from [<bf0ae4f0>] (PVRSRVInitSrvDisconnectBW+0x48/0x74 [pvrsrvkm])
[ 660.214080] [<bf0ae4f0>] (PVRSRVInitSrvDisconnectBW+0x48/0x74 [pvrsrvkm]) from [<bf0af4e8>] (BridgedDispatchKM+0xec/0x144 [pvrsrvkm])
[ 660.226928] [<bf0af4e8>] (BridgedDispatchKM+0xec/0x144 [pvrsrvkm]) from [<bf0a7c70>] (PVRSRV_BridgeDispatchKM+0x174/0x234 [pvrsrvkm])
[ 660.239776] [<bf0a7c70>] (PVRSRV_BridgeDispatchKM+0x174/0x234 [pvrsrvkm]) from [<bf04eec0>] (drm_ioctl+0x294/0x3a4 [drm])
[ 660.251403] [<bf04eec0>] (drm_ioctl+0x294/0x3a4 [drm]) from [<c00e8ecc>] (do_vfs_ioctl+0x548/0x5bc)
[ 660.260925] [<c00e8ecc>] (do_vfs_ioctl+0x548/0x5bc) from [<c00e8f8c>] (sys_ioctl+0x4c/0x6c)
[ 660.269714] [<c00e8f8c>] (sys_ioctl+0x4c/0x6c) from [<c000dcc0>] (ret_fast_syscall+0x0/0x3c)
[ 660.278564] Code: e58d0004 ea000012 e3a03000 e58d3000 (e5953000)
[ 660.285003] ------------[ cut here ]------------
[ 660.289886] WARNING: at arch/arm/mach-omap2/omap_l3_smx.c:161 omap3_l3_app_irq+0xd4/0x11c()
[ 660.298645] In-band Error seen by MPU at address 0
[ 660.303771] Modules linked in: pvrsrvkm(O) drm(O)
[ 660.308746] [<c0012ad4>] (unwind_backtrace+0x0/0x11c) from [<c002e6f0>] (warn_slowpath_common+0x4c/0x64)
[ 660.318725] [<c002e6f0>] (warn_slowpath_common+0x4c/0x64) from [<c002e788>] (warn_slowpath_fmt+0x2c/0x3c)
[ 660.328796] [<c002e788>] (warn_slowpath_fmt+0x2c/0x3c) from [<c0025560>] (omap3_l3_app_irq+0xd4/0x11c)
[ 660.338592] [<c0025560>] (omap3_l3_app_irq+0xd4/0x11c) from [<c0082b18>] (handle_irq_event_percpu+0xb0/0x2b0)
[ 660.349060] [<c0082b18>] (handle_irq_event_percpu+0xb0/0x2b0) from [<c0082d54>] (handle_irq_event+0x3c/0x5c)
[ 660.359374] [<c0082d54>] (handle_irq_event+0x3c/0x5c) from [<c0084fb4>] (handle_level_irq+0xb8/0xd0)
[ 660.368988] [<c0084fb4>] (handle_level_irq+0xb8/0xd0) from [<c0082498>] (generic_handle_irq+0x30/0x44)
[ 660.378784] [<c0082498>] (generic_handle_irq+0x30/0x44) from [<c000e574>] (handle_IRQ+0x60/0x84)
[ 660.388031] [<c000e574>] (handle_IRQ+0x60/0x84) from [<c0008544>] (omap3_intc_handle_irq+0x54/0x68)
[ 660.397552] [<c0008544>] (omap3_intc_handle_irq+0x54/0x68) from [<c048fcc4>] (__irq_svc+0x44/0x78)
[ 660.406951] Exception stack(0xdd131ac0 to 0xdd131b08)
[ 660.412292] 1ac0: 00000001 dd131ae8 dd152140 00000000 c06d70c0 dd130000 00000001 bf09ea5e
[ 660.420867] 1ae0: dd131b52 bf09ea5c 00000000 00000001 00000000 dd131b08 c048f958 c048f960
[ 660.429473] 1b00: 60000113 ffffffff
[ 660.433166] [<c048fcc4>] (__irq_svc+0x44/0x78) from [<c048f960>] (_raw_spin_unlock_irq+0x2c/0x50)
[ 660.442504] [<c048f960>] (_raw_spin_unlock_irq+0x2c/0x50) from [<c00111bc>] (die+0x27c/0x314)
[ 660.451477] [<c00111bc>] (die+0x27c/0x314) from [<c00083d8>] (do_DataAbort+0x84/0x98)
[ 660.459716] [<c00083d8>] (do_DataAbort+0x84/0x98) from [<c048fc5c>] (__dabt_svc+0x3c/0x60)
[ 660.468383] Exception stack(0xdd131c20 to 0xdd131c68)
[ 660.473724] 1c20: 00000000 000003e8 000003e7 00000001 00000000 e14f0ca8 000000ff 157029e4
[ 660.482299] 1c40: 00000001 000f4240 00000032 00000000 0002e10e dd131c68 bf09ea44 bf09ea5c
[ 660.490875] 1c60: 80000013 ffffffff
[ 660.494659] [<c048fc5c>] (__dabt_svc+0x3c/0x60) from [<bf09ea5c>] (PollForValueKM+0x4c/0xbc [pvrsrvkm])
[ 660.504730] [<bf09ea5c>] (PollForValueKM+0x4c/0xbc [pvrsrvkm]) from [<bf0ac0fc>] (SGXResetInvalDC.isra.4+0x58/0x60 [pvrsrvkm])
[ 660.516937] [<bf0ac0fc>] (SGXResetInvalDC.isra.4+0x58/0x60 [pvrsrvkm]) from [<bf0ac190>] (SGXReset+0x78/0x18c [pvrsrvkm])
[ 660.528747] [<bf0ac190>] (SGXReset+0x78/0x18c [pvrsrvkm]) from [<bf0a8f94>] (SGXInitialise+0x58/0x130 [pvrsrvkm])
[ 660.539825] [<bf0a8f94>] (SGXInitialise+0x58/0x130 [pvrsrvkm]) from [<bf0ac524>] (SGXPostPowerState+0x50/0xa8 [pvrsrvkm])
[ 660.551513] [<bf0ac524>] (SGXPostPowerState+0x50/0xa8 [pvrsrvkm]) from [<bf0998c4>] (PVRSRVDevicePostPowerStateKM_AnyVaCb+0x6c/0x84 [pvrsrvkm])
[ 660.565155] [<bf0998c4>] (PVRSRVDevicePostPowerStateKM_AnyVaCb+0x6c/0x84 [pvrsrvkm]) from [<bf0a1634>] (List_PVRSRV_POWER_DEV_PVRSRV_ERROR_Any_va+0x30/0x58 [pvrsrvkm])
[ 660.581024] [<bf0a1634>] (List_PVRSRV_POWER_DEV_PVRSRV_ERROR_Any_va+0x30/0x58 [pvrsrvkm]) from [<bf099af0>] (PVRSRVSetDevicePowerStateKM+0x4c/0x64 [pvrsrvkm])
[ 660.596069] [<bf099af0>] (PVRSRVSetDevicePowerStateKM+0x4c/0x64 [pvrsrvkm]) from [<bf0a9cc0>] (SGXScheduleCCBCommandKM+0x64/0xb8 [pvrsrvkm])
[ 660.609619] [<bf0a9cc0>] (SGXScheduleCCBCommandKM+0x64/0xb8 [pvrsrvkm]) from [<bf0a8338>] (SGXGetMiscInfoUkernel+0x78/0xe8 [pvrsrvkm])
[ 660.622558] [<bf0a8338>] (SGXGetMiscInfoUkernel+0x78/0xe8 [pvrsrvkm]) from [<bf0a842c>] (SGXDevInitCompatCheck+0x84/0x2a4 [pvrsrvkm])
[ 660.635345] [<bf0a842c>] (SGXDevInitCompatCheck+0x84/0x2a4 [pvrsrvkm]) from [<bf09e8c0>] (PVRSRVDevInitCompatCheck+0x14/0x20 [pvrsrvkm])
[ 660.648468] [<bf09e8c0>] (PVRSRVDevInitCompatCheck+0x14/0x20 [pvrsrvkm]) from [<bf0a1430>] (List_PVRSRV_DEVICE_NODE_PVRSRV_ERROR_Any+0x20/0x40 [pvrsrvkm])
[ 660.663299] [<bf0a1430>] (List_PVRSRV_DEVICE_NODE_PVRSRV_ERROR_Any+0x20/0x40 [pvrsrvkm]) from [<bf0ae4f0>] (PVRSRVInitSrvDisconnectBW+0x48/0x74 [pvrsrvkm])
[ 660.678253] [<bf0ae4f0>] (PVRSRVInitSrvDisconnectBW+0x48/0x74 [pvrsrvkm]) from [<bf0af4e8>] (BridgedDispatchKM+0xec/0x144 [pvrsrvkm])
[ 660.691070] [<bf0af4e8>] (BridgedDispatchKM+0xec/0x144 [pvrsrvkm]) from [<bf0a7c70>] (PVRSRV_BridgeDispatchKM+0x174/0x234 [pvrsrvkm])
[ 660.703887] [<bf0a7c70>] (PVRSRV_BridgeDispatchKM+0x174/0x234 [pvrsrvkm]) from [<bf04eec0>] (drm_ioctl+0x294/0x3a4 [drm])
[ 660.715515] [<bf04eec0>] (drm_ioctl+0x294/0x3a4 [drm]) from [<c00e8ecc>] (do_vfs_ioctl+0x548/0x5bc)
[ 660.725036] [<c00e8ecc>] (do_vfs_ioctl+0x548/0x5bc) from [<c00e8f8c>] (sys_ioctl+0x4c/0x6c)
[ 660.733856] [<c00e8f8c>] (sys_ioctl+0x4c/0x6c) from [<c000dcc0>] (ret_fast_syscall+0x0/0x3c)
[ 660.742736] ---[ end trace 1277b4e613d04157 ]---
BrainsightNIRS [ 659.708618] Internal error: : 1008 [#1] PREEMPT ARM
BrainsightNIRS [ 659.780639] Process X (pid: 1041, stack limit = 0xdd1302f0)
BrainsightNIRS [ 659.786499] Stack: (0xdd131c68 to 0xdd132000)
BrainsightNIRS [ 659.791076] 1c60: 00000001 00000000 000000ff dd3d7000 00000001 00000000
BrainsightNIRS [ 659.799652] 1c80: e14b0120 00000000 0000001c 401c6440 bf0a7afc bf0ac0fc 00000032 00000000
BrainsightNIRS [ 659.808258] 1ca0: dd3d7000 bf0ac190 dd3d7000 00000000 00000000 bf0a8f94 dd3d7000 00000000
BrainsightNIRS [ 659.816864] 1cc0: bf0bac88 dd3d7000 00000000 deffc180 dd131da0 bf0ac524 dd131cec c04917c0
BrainsightNIRS [ 659.825469] 1ce0: 80000013 c06e8ee8 bf0a7afc c048f914 dd152140 0698a3aa 0698a3aa c0026b00
BrainsightNIRS [ 659.834075] 1d00: bf0bac10 bf0b0fe4 de580440 00000000 00000000 bf0998c4 dd131d48 bf099858
BrainsightNIRS [ 659.842651] 1d20: 00000000 bf0a1634 de580440 dd131d48 00000000 00000000 00000000 bf0bac0c
BrainsightNIRS [ 659.851257] 1d40: bf099af0 bf099858 00000000 00000000 00000000 00000000 ffffffff deffc180
BrainsightNIRS [ 659.859863] 1d60: 00000006 bf0a9cc0 deffc180 00000006 dd131da0 ffffffff e14b0180 dec1a440
BrainsightNIRS [ 659.868438] 1d80: deffc180 00000000 e08e3000 bf0a8338 00000000 00000000 00000[ 660.900604] ---[ end trace 1277b4e613d04158 ]---
000 00000001
BrainsightNIRS [ 659.877044] 1da0: 00000000 dd152140 00000001 0f003180 e08e2000 e08e3000 0000001c 401c6440
BrainsightNIRS [ 659.885650] 1dc0: dd3d7000 00000000 00000000 dec1a440 e08e3000 0000001c 401c6440 bf0a842c
BrainsightNIRS [ 659.894256] 1de0: bf0a83a8 bf09e8cc 00000000 00000000 e08e2000 bf09e8c0 deffc180 bf0a1430
BrainsightNIRS [ 659.902832] 1e00: bf0bac10 e08e2000 e08e3000 bf0ae4f0 dd131e78 de54a300 00000045 bf0af4e8
BrainsightNIRS [ 659.911437] 1e20: dd131e78 c01c6745 dd23d600 00000411 bf0b84a0 bf0a7c70 de54a300 dd131e78
BrainsightNIRS [ 659.920043] 1e40: dd23d600 dd0ec800 dd23d600 dd131e78 0000001c bf04eec0 00000411 401c6440
BrainsightNIRS [ 659.928619] 1e60: 00000040 0000e200 00000001 c006c778 dd0ec87c be9b8944 00000045 0000001c
BrainsightNIRS [ 659.937225] 1e80: be9b8978 00000008 be9b8970 00000008 00000001 c006c478 dd152140 00000001
BrainsightNIRS [ 659.945831] 1ea0: 0000002b 00000000 00000000 00000007 00000006 00000006 dd1525b8 c006c478
BrainsightNIRS [ 659.954406] 1ec0: dd152140 00000001 00000000 dd152140 00000001 dd152140 00000000 00000000
BrainsightNIRS [ 659.963012] 1ee0: 60000013 dd28ce28 00000000 00000000 60000093 00000000 00000000 be9b8944
BrainsightNIRS [ 659.971618] 1f00: de6bd960 de7452c0 00000007 00000000 dd130000 00000000 0017b14c c00e8ecc
BrainsightNIRS [ 659.980194] 1f20: dd28ce18 60000013 c026e37c dd28ce14 c000de64 dd28ce18 00000000 c048f2b0
BrainsightNIRS [ 659.988800] 1f40: dd152140 00000001 00000000 dd152140 00000001 c048f908 dd152140 00000001
NIRS [ 659.997375] 1f60: 00000000 de7452c0 be9b8944 401c6440 00000007 00000000 dd130000 00000000
BrainsightNIRS [ 660.005981] 1f80: 0017b14c c00e8f8c 00000007 00000000 be9b8944 401c6440 00000007 00000036
BrainsightNIRS [ 660.014587] 1fa0: c000de64 c000dcc0 be9b8944 401c6440 00000007 401c6440 be9b8944 0000001c
BrainsightNIRS [ 660.023162] 1fc0: be9b8944 401c6440 00000007 00000036 00000014 00108974 00000014 0017b14c
BrainsightNIRS [ 660.031768] 1fe0: 00000001 be9b8920 b6ba6c8c b6dda45c 20000010 00000007 415f4d4b 6156796e
BrainsightNIRS [ 660.278564] Code: e58d0004 ea000012 e3a03000 e58d3000 (e5953000)
Any ideas of what's going on here ?
BR,
-Kevyn-Alexandre Pare
