Hi, All.
To grab an image with ov7675/ov7670 sensor, I use media-ctl to configure isp pipeline.
my pipeline configuration: ov7670 -> CCDC -> preview -> preview output,following “a ov7690 configuration”.
my configuration shell script:
#!/bin/sh
media-ctl -v -r
media-ctl -v -f '"ov7670 2-0021":0 [SBGGR8 320x240], "OMAP3 ISP CCDC":1 [SBGGR8 320x240],"OMAP3 ISP preview":1 [UYVY 320x240]'
media-ctl -v -l '"ov7670 2-0021":0 -> "OMAP3 ISP CCDC":0 [1]'
media-ctl -v -l '"OMAP3 ISP CCDC":2 -> "OMAP3 ISP preview":0 [1]'
media-ctl -v -l '"OMAP3 ISP preview":1 -> "OMAP3 ISP preview output":0 [1]'
command “media-ctl -p“‘s outputing seems ok.
Opening media device /dev/media0
Enumerating entities
Found 16 entities
Enumerating pads and links
Media controller API version 0.0.0
Media device information
driver omap3isp
model TI OMAP3 ISP
serial
bus info
hw revision 0xf0
driver version 0.0.0
Device topology
- entity 1: OMAP3 ISP CCP2 (2 pads, 2 links)
type V4L2 subdev subtype Unknown
device node name /dev/v4l-subdev0
pad0: Sink [SGRBG10 4096x4096]
<- "OMAP3 ISP CCP2 input":0 []
pad1: Source [SGRBG10 4096x4096]
-> "OMAP3 ISP CCDC":0 []
- entity 2: OMAP3 ISP CCP2 input (1 pad, 1 link)
type Node subtype V4L
device node name /dev/video0
pad0: Source
-> "OMAP3 ISP CCP2":0 []
- entity 3: OMAP3 ISP CSI2a (2 pads, 2 links)
device node name /dev/v4l-subdev1
-> "OMAP3 ISP CSI2a output":0 []
- entity 4: OMAP3 ISP CSI2a output (1 pad, 1 link)
device node name /dev/video1
pad0: Sink
<- "OMAP3 ISP CSI2a":1 []
- entity 5: OMAP3 ISP CCDC (3 pads, 9 links)
device node name /dev/v4l-subdev2
pad0: Sink [SBGGR8 320x240]
<- "OMAP3 ISP CCP2":1 []
<- "ov7670 2-0021":0 [ENABLED]
pad1: Source [SBGGR8 320x240]
-> "OMAP3 ISP CCDC output":0 []
-> "OMAP3 ISP resizer":0 []
pad2: Source [SBGGR8 320x239]
-> "OMAP3 ISP preview":0 [ENABLED]
-> "OMAP3 ISP AEWB":0 [ENABLED,IMMUTABLE]
-> "OMAP3 ISP AF":0 [ENABLED,IMMUTABLE]
-> "OMAP3 ISP histogram":0 [ENABLED,IMMUTABLE]
- entity 6: OMAP3 ISP CCDC output (1 pad, 1 link)
device node name /dev/video2
pad0: Sink
<- "OMAP3 ISP CCDC":1 []
- entity 7: OMAP3 ISP preview (2 pads, 4 links)
device node name /dev/v4l-subdev3
pad0: Sink [SGRBG10 320x240 (8,4)/306x232]
<- "OMAP3 ISP CCDC":2 [ENABLED]
<- "OMAP3 ISP preview input":0 []
pad1: Source [UYVY 306x232]
-> "OMAP3 ISP preview output":0 [ENABLED]
- entity 8: OMAP3 ISP preview input (1 pad, 1 link)
device node name /dev/video3
pad0: Source
-> "OMAP3 ISP preview":0 []
- entity 9: OMAP3 ISP preview output (1 pad, 1 link)
device node name /dev/video4
pad0: Sink
<- "OMAP3 ISP preview":1 [ENABLED]
- entity 10: OMAP3 ISP resizer (2 pads, 4 links)
device node name /dev/v4l-subdev4
pad0: Sink [YUYV 306x232 (0,0)/306x232]
<- "OMAP3 ISP preview":1 []
<- "OMAP3 ISP resizer input":0 []
pad1: Source [YUYV 320x240]
-> "OMAP3 ISP resizer output":0 []
- entity 11: OMAP3 ISP resizer input (1 pad, 1 link)
device node name /dev/video5
pad0: Source
- entity 12: OMAP3 ISP resizer output (1 pad, 1 link)
device node name /dev/video6
pad0: Sink
<- "OMAP3 ISP resizer":1 []
- entity 13: OMAP3 ISP AEWB (1 pad, 1 link)
device node name /dev/v4l-subdev5
pad0: Sink
<- "OMAP3 ISP CCDC":2 [ENABLED,IMMUTABLE]
- entity 14: OMAP3 ISP AF (1 pad, 1 link)
device node name /dev/v4l-subdev6
pad0: Sink
- entity 15: OMAP3 ISP histogram (1 pad, 1 link)
device node name /dev/v4l-subdev7
pad0: Sink
- entity 16: ov7670 2-0021 (1 pad, 1 link)
device node name /dev/v4l-subdev8
pad0: Source [SBGGR8 320x240]
-> "OMAP3 ISP CCDC":0 [ENABLED]
But when grabing picture, yavta report a error “Unable to start streaming: Broken pipe (32)”,and exit. I checked error -32 EPIPE, it means “The driver implements pad-level format configuration and the pipeline configuration is invalid”, why?
#yavta -f UYVY -f UYVY -s 306x232 -c=1 --stdout /dev/video4
Device /dev/video4 opened.
Device `OMAP3 ISP preview output' on `media' is a video capture device.
Video format set: UYVY (59565955) 306x232 (stride 640) buffer size 148480
Video format: UYVY (59565955) 306x232 (stride 640) buffer size 148480
8 buffers requested.
length: 148480 offset: 0
Buffer 0 mapped at address 0x4006a000.
length: 148480 offset: 151552
Buffer 1 mapped at address 0x40291000.
length: 148480 offset: 303104
Buffer 2 mapped at address 0x402c5000.
length: 148480 offset: 454656
Buffer 3 mapped at address 0x403c6000.
length: 148480 offset: 606208
Buffer 4 mapped at address 0x4046b000.
length: 148480 offset: 757760
Buffer 5 mapped at address 0x404ad000.
length: 148480 offset: 909312
Buffer 6 mapped at address 0x404f4000.
length: 148480 offset: 1060864
Buffer 7 mapped at address 0x405eb000.
Unable to start streaming: Broken pipe (32).
8 buffers released.
