I'm using a Mistral EVM Board with DM37x cpu. I use the expansion connector of the board to analyse GPMC bus activities with a logic analyser (nOE, nWE, GPMC CLK, D0-D15, ...). This connector is not linked to a device.
We plan to use a DM37x to connect it to FPGA, I would like to configure the GPMC bus on the EVM board to check that I can run it in burst mode. And I would like to analyse the signals with my analyser.
Does anybody has a GPMC configuration which allows to run in synchronous burst mode?
I've started to configure the registers but I not able to get burst work correctly. I use the SDMA to transfer my data but I get independant Chip Select activations.
Best regards.
Laurent
