Texas Instruments
  • Samples Cart - Add Samples Samples & Purchase Cart
  • Contact Us
  • TI Worldwide: United States
  • my.TI Login
  • Products
  • Applications
  • Design Support
  • Sample & Buy
  • All Searches
TI Home » TI E2E Community » Support Forums » ARMĀ® & DSP Microprocessors » C6000 Single Core DSP » C64x Single Core DSP Forum » Problem with XBus
  • Join
  • Sign In with my.TI Login
TI E2E™ Community
  • Home
  • Support Forums
  • Videos
  • Blogs
  • Groups
  • More ...
  • Go
  • Advanced Search
Share
Details
Rate This
  • 1 Reply
  • 1 Subscriber
  • 94 Views
  • Posted3 months ago
Options
  • Subscribe via RSS
Tags
  • #pragma
  • "anti-aliasing filter" Nyquist
  • "CLK module" TSK_sleep "GLB_Module" Timer Clock CLKIn Frequency
  • .OUT
  • 3
  • 3730
  • 5-6k interface
  • 6211
  • 6415
  • 6416
  • 6416 flash
  • 6418
  • 6424
  • 6424 64x Ethernet EMAC interrupt delay
  • 6424 cche
  • 6424 CSL
  • 6424 EDMA3
  • 6437
  • 6437 dsp_fir_gen
  • 6437 sin math
  • 6455
  • 6455 EMIF RATE
  • 6455 PCI master throughtput
  • 6455 srio
Forum - Title
Problem with XBus
Welcome to the C6000 Single Core DSP Section of the TI E2E Support Community. Ask questions, share knowledge, explore ideas, and help solve problems with fellow engineers. To post a question, click on the forum tab then "New Post".
  • Get this RSS feed
  • Home
  • Announcements
  • Forums
New Post
Problem with XBus
This question is answered
Steve Jankowski
Posted by Steve Jankowski
on Feb 9, 2012 5:20 AM
Prodigy40 points
I'm not sure, that i've found right forum, but i need your help, friends =)
I have a problem with XBus on TMS320C6203B. I can't do anything with it!
What i have:
I can write my program into C6203B and usually it works correctly ;) But, when i try to use XBus - it doesn't happen.
What i need: i need to get high level on all of the XD pins [31-0] and after that, low level on them - and no more. It will be enough. In which mode (synchronous\asynchronous is not important)
But, to be honest, i don't know how to run this freaking bus!
I read all datasheets (including spru579a "XBus" and spru577a "DMA"), but despite this can't solve this simple problem.
It would be great, if anybody could help me.
P.S Actually if you could give me C or asm little code example, it would be better solution, than just good advice... :)
dsp c6000
Report Abuse
  • Reply
You have posted to a forum that requires a moderator to approve posts before they are publicly available.
All Replies
  • Steve Jankowski
    on Feb 10, 2012 12:51 AM
    Verified Answer
    Verified by Steve Jankowski
    Prodigy40 points
    I've solved the problem.
    In my case, there is no need to program anything =)
    Just pull-up and pull-down necessary pins (XCS, XCNTL, XW\R and some others) to get asynchronous host port mode and to run XBus external.
    Details can be found here: spru579a "XBus" (since page 42 and later)
    dsp c6000
    Report Abuse
    • Reply
Share
ALL CONTENT AND MATERIALS ON THIS SITE ARE PROVIDED "AS IS". TI AND ITS RESPECTIVE SUPPLIERS AND PROVIDERS OF CONTENT MAKE NO REPRESENTATIONS ABOUT THE SUITABILITY OF THESE MATERIALS FOR ANY PURPOSE AND DISCLAIM ALL WARRANTIES AND CONDITIONS WITH REGARD TO THESE MATERIALS, INCLUDING BUT NOT LIMITED TO ALL IMPLIED WARRANTIES AND CONDITIONS OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE, TITLE AND NON-INFRINGEMENT OF ANY THIRD PARTY INTELLECTUAL PROPERTY RIGHT. TI AND ITS RESPECTIVE SUPPLIERS AND PROVIDERS OF CONTENT MAKE NO REPRESENTATIONS ABOUT THE SUITABILITY OF THESE MATERIALS FOR ANY PURPOSE AND DISCLAIM ALL WARRANTIES AND CONDITIONS WITH RESPECT TO THESE MATERIALS. NO LICENSE, EITHER EXPRESS OR IMPLIED, BY ESTOPPEL OR OTHERWISE, IS GRANTED BY TI. USE OF THE INFORMATION ON THIS SITE MAY REQUIRE A LICENSE FROM A THIRD PARTY, OR A LICENSE FROM TI.
Content on this site may contain or be subject to specific guidelines or limitations on use. All postings and use of the content on this site are subject to the Terms of Use of the site; third parties using this content agree to abide by any limitations or guidelines and to comply with the Terms of Use of this site. TI, its suppliers and providers of content reserve the right to make corrections, deletions, modifications, enhancements, improvements and other changes to the content and materials, its products, programs and services at any time or to move or discontinue any content, products, programs, or services without notice.
Products | Applications | Design Support | Sample & Buy RSS
TI Worldwide | About TI | Contact Us | Investor Relations | Press Center | Corporate Citizenship | Careers | Tags | my.TI Login | All Searches | Site Map
© Copyright 1995- Texas Instruments Incorporated. All rights reserved. Trademarks | Privacy Policy | Terms of Use
